 Old 07-07-2016, 02:17 PM   #41
EvoFire's Avatar
Posts: 389   (View Stats)
EvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the world
Originally Posted by Mmahan3510 View Post
best bang for your buck on traction in my opinion is firestone firehawk indy 500, the new style. they are rebranded re0003 from eu market. got some awesome reviews, decided to try them and i am not disappointed at all. i do not have the power you do nor do i track the car. may be worth at least taking a look at. price is also very good! tire rack is the cheapest i found.
not sure if srs, or troll........ NT-01 is a r comp, and you are talking about a street tire. Nevermind that this thread is specifically about the NT-01 and not about which tire is good.....
2009 CWP MS3 | JBR short shift plate, JBR shifter bushings, CP-e stage 2 RMM, JBR RSB, JBR Wide-Path, CS downpipe, UR catted test pipe, Cobb cat-back, Forge BPV V1, Swift Spec R springs, Bilstein B8, Whiteline KCA428 ALK, Whiteline Bumpsteer Correction, Corksport injector seals, Weds Sports SA55M 18x8 +48, Bridgestone S-04 245/40/18, BLOX Limited 490g shiftknob
Dyno'ed at 277whp/290lb-ft on 91 piss
EvoFire is offline   Reply With Quote
 Old 07-07-2016, 02:25 PM   #42
Mmahan3510's Avatar
Posts: 93   (View Stats)
Mmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of light
Groaned at 19 Times in 6 Posts
I am not the only one in this thread that has mentioned a different tire than the nt-01, so I felt my input would be good for others. DW tires are also street tires, they have been mentioned quite a few times here. And a quite a few other street tires as well...I guess some people just say things to make themselves feel better sometimes...
Sent from my VIVO XL using Tapatalk
2012 Mica Black Speed3, 3" CS intake/TIP, CS MZR bypass valve, CS hpfp internals, CS 3 port EBCS full interupt, NGK 1 step colder plugs, Ebay catless DP, 2nd cat delete, resonator delete, Custom Magnaflow axle back, CS OCC, EGR delete, throttle body coolant bypass, CS 70 duro RMM, firehawk indy 500 225/40/18, DM SSP, rear adj control arms, 3.5" shift extender, MofiyStreet 450oz ball shift knob, Purple Drank Tuned 93 map/Purple Drank Tuned E30 map, 295/337 dyno jet heatsoaked at 150 BAT, 314/362 vdyno at 100 BAT
Mmahan3510 is offline   Reply With Quote
Reviews wanted for nt555r's and nt-01's Boosted Beluga MazdaSpeed 3/6 - Wheels & Tires 75 04-29-2012 10:09 AM
Nitto NT-05 followed by more goodies... AJ713 MazdaSpeed 3/6 - Wheels & Tires 33 06-23-2011 10:25 PM
nitto invo? k0m MazdaSpeed 3/6 - Wheels & Tires 8 10-06-2009 11:24 PM
Nitto NT-05 Nliiitend1 MazdaSpeed 3/6 - Wheels & Tires 38 09-10-2009 06:58 AM
Page generated in 0.23552 seconds with 22 queries
