 Old 03-17-2019, 01:13 PM   #1
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
Default nitto nt555 g2 and other choices
anyone run these tires on either MS6 or MS3? doing a google/youtube search nets them particularly on RWD cars such as camaro, charger, mustang, etc but were wondering what they would be like on our cars.
background on my car, stock suspension for now, just picked up some rx8 wheels to run for summer duty.
I was thinking it was between Nitto NT555 G2, Hankook Ventus V12 evo2 or Sumitomo HTR ZIII. looking to spend no more then $750ish for a set and have both good wet and dry traction
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
'79 AMC Spirit AMX, 4.6L stroker I6
 Old 03-17-2019, 06:14 PM   #2
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
I was in the same boat for a set 9f summer tires for rims i just purchased. I did not want to spend more then 160 a tire.I just picked up a set of conti extreme contact sports due to there wet traction reviews the nitto. Hopefully mounting them tommorow. Michelin pilot sport 4 is a better tire but its 200 a pop. Dont have much Experience with the others.
MECP
2012 BM
Rfinkle tune in progress
 Old 03-18-2019, 03:31 PM   #3
eroler1's Avatar
Posts: 133   (View Stats)
eroler1 is just really niceeroler1 is just really niceeroler1 is just really niceeroler1 is just really nice
had experience with federal 595 rs-rr over all better fgrip than nt05 but treadware is terrible, and if you dont have exhaust then road noise is loud
but grip is really good barely spins at 3rd gear
eroler1 is offline   Reply With Quote
 Old 03-19-2019, 11:33 AM   #4
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
I was running Continental Extreme Contact DWS06. I liked the grip and wet traction.
I switched to a set of Hankook Ventus V12 Evo2 and its like night and day. Wet traction is surprisingly good. AWD helps.
But the dry traction is amazing. Way better than the Conti's. Those felt like sponges compared to the Hankooks. I commute over a twisty mountain highway and these tires have much less sidewall flex. They just feel planted mid corner and I cant seem to break them loose. Which is a good thing!
 Old 03-19-2019, 02:57 PM   #5
LenSpeed6's Avatar
awesome! thank you guys for the replies, now I'm just in a dilemma for size, i got some rx8 18" wheels, I'm thinking about 225/45. the wheels have junk tires of that size but it seems like that would fit very well under the car. I am at stock hight right now but planning a suspension overhall next summer if not sooner, lowest I'd go is 1-1.5" lower then stock.
06 Speed6
 Old 03-19-2019, 03:27 PM   #6
eroler1's Avatar
btw the federals and nittos have freeshipping in amazon idk about any other tire company but here in hawaii, its free (sucks here)
 Old 03-19-2019, 05:06 PM   #7
Groans: 211
Those will fit just fine. I'd stick with the 45 sidewall if your roads are rough.
New Nitto NT555's Mooose 2010 MS3 - Wheels & Tires 1 09-08-2015 09:28 PM
Need input on tires (Nitto NT555) Cell Block 54 2010 MS3 - Wheels & Tires 9 02-01-2013 03:26 PM
Page generated in 0.27949 seconds with 23 queries
