 Old 04-30-2015, 07:28 AM   #1
Douggievee's Avatar
Posts: 71   (View Stats)
Douggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really nice
Default Noise after installing TSW Nurburgring rims
Last night I installed my brand new TSW Nurburgrings 18 x 7.5 and on the way to work today I noticed around some turns there is a metal like banging noise. Hard to describe. It wasnt there on stock rims. What could be causing this?
2006 Mazdaspeed6 GT: Autotech Fuel pump, GT3071R, Cobb AP FreakTune, 3" Custom Magnaflow Turboback Dual Exhaust, Mazdaspeeed intake/turbo inlet tube, NGK XI 1 step colder plugs, Fidanza Flywheel, EGR/VTCS Delete, Cobb EBC, Cross drilled rotors, Corksport BPV, TSW Nurburgrings, Techna-Fit SS Clutch Line
Douggievee is offline   Reply With Quote
 Old 04-30-2015, 07:30 AM   #2
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
*wheels
Rubbing or banging?
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
monkey.bones.007 (04-30-2015)
 Old 04-30-2015, 07:35 AM   #3
Douggievee's Avatar
more like a rubbing sound id say
 Old 04-30-2015, 07:41 AM   #4
WetzMS3's Avatar
Groans: 430
What offset did you get? What size tires?
Did you check for clearance after putting them on?
Are you lowered at all?
2013 MS3 Black Mica
 Old 04-30-2015, 08:03 AM   #5
Douggievee's Avatar
Im guessing its 45 offset? heres the size I got. TSW Nurburgring
18 X7.5 5-114.30 45 DGMMMS. on 215/45 18 tires. stock suspension.
 Old 04-30-2015, 08:05 AM   #6
WetzMS3's Avatar
Groans: 430
45 is the offset.
I don't know a ton about clearance on the 6, but at that offset and tire size, I don't think you should be rubbing.
2013 MS3 Black Mica
 Old 04-30-2015, 08:08 AM   #7
hatchedspeed3's Avatar
Posts: 1,966   (View Stats)
hatchedspeed3 is the leader of the worldhatchedspeed3 is the leader of the worldhatchedspeed3 is the leader of the worldhatchedspeed3 is the leader of the worldhatchedspeed3 is the leader of the worldhatchedspeed3 is the leader of the worldhatchedspeed3 is the leader of the worldhatchedspeed3 is the leader of the worldhatchedspeed3 is the leader of the worldhatchedspeed3 is the leader of the worldhatchedspeed3 is the leader of the world
Groaned at 24 Times in 11 Posts
could it be the bearing??? I know it would be kind of coincidence, seeing as how the new rims went on, but when they go out, you hear a clunk. @Douggievee; does it increase with speed? if you turn the wheel is it worse one way or the other? Do you hear it when stationary?
08 TR MS3 - totaled and stocked out 1-5-2014
Daily Driver - 2016 WRX w/STI lip kit
2009 CWP MS3 1-23-2014
CXRacing FMIC with TR8 Core /// HKS Turbo Timer /// 6000k HIDs /// Yellow Fog Covers /// Cobb SRI /// Ultimate Racing TBE /// White Avid 21 18x8.5 Wrapped In Kuhmo 225-40-18s /// Short Throw Shifter /// Kozmic Motorsports EGR Delete /// Corksport HPFP internals /// CS Front Sway Bar /// /// JBR RMM, TMM, and PMM (all 80a) /// Slotted Rotors /// CS Foglight Kit /// CS License Plate Bracket /// CS Bypass Hose /// Rolled Fenders /// JBR Weighted Red Shift Knob /// Cobb AP //////
hatchedspeed3 is offline   Reply With Quote
 Old 04-30-2015, 08:10 AM   #8
Douggievee's Avatar
its very intermittant. seems like the noise only happens when taking a turn very quickly and seems to sound like its coming from the rear of the car.
 Old 04-30-2015, 08:12 AM   #9
does it matter which way you turn? how fast are you going? Again, do you hear the "rubbing" when stationary?
 Old 04-30-2015, 08:30 AM   #10
ArmanRus's Avatar
Posts: 1,566   (View Stats)
ArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the world
Groans: 42
Is the hub bore on the wheels the same as on our cars? If not, then you need hubcentric rings, the wheels may not be centered and causing some noise.
ArmanRus is offline   Reply With Quote
 Old 04-30-2015, 08:32 AM   #11
Originally Posted by ArmanRus View Post
Is the hub bore on the wheels the same as on our cars? If not, then you need hubcentric rings to center the wheels.
@dale_gribble; you had these wheels on your 6 no? were they hubcentric?
 Old 04-30-2015, 08:34 AM   #12
pirate steve's Avatar
Posts: 248   (View Stats)
pirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the world
^^Beat me to it.
Yea check that. The lugs don't always center the wheel perfectly so your wheels could be shifting slightly as they rotate.
EDIT: I checked the interwebs and these wheels have a 72mm hub bore which is about 4.9mm oversized.
2011 grey MS3: HTP TIP, COBB SRI, HPFP internals, CS TMIC, Dammond EGR delete, Dammond OCC, M2 full DP all of the cats deleted, freektune OTS+, denso ITV22, Maisonvi turbo bolt, CP-e S2 RMM
pirate steve is offline   Reply With Quote
 Old 04-30-2015, 08:38 AM   #13
Douggievee's Avatar
I have rings which ive never used before but they are little plastic rings that i sat in the middle of the wheel before putting them on. hopefully i did that right, not really sure how else they could have been put on though. and when stationary I havenet heard any noise. i would say the noise comes when making a turn going about 40 mph or so.
 Old 04-30-2015, 08:39 AM   #14
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Mattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the world
If you haven't already, remove the wheel where you think the sound is coming from. See if you are getting any points of rub on the wheel. Worth a check.
Mattyhawk1 is offline   Reply With Quote
 Old 04-30-2015, 08:39 AM   #15
dale_gribble's Avatar
Posts: 4,720   (View Stats)
No these are punched out to the standard 73.1mm. They need adapters and/or the lugs need to be set on correctly.
MINI H1 6.0 - CAR LED TAILS
hatchedspeed3 (04-30-2015)
 Old 04-30-2015, 08:40 AM   #16
definately leaning towards the hubcentric issue then, and not so much the bearing. the bearing you would hear all the time, increasing with speed. Hopefully dale will chime in, but looks like @pirate steve; has your answer. Do you have the boxes the rims came in still? Or an invoice. Should say it somewhere on there
EDIT: He chimed in. There ya go.
 Old 04-30-2015, 08:42 AM   #17
ArmanRus's Avatar
Groans: 42
You use them just like that. The question is if they are the right size. The Mazda hub is a 67mm.
 Old 04-30-2015, 08:44 AM   #18
If those "little plastic rings" aren't correctly sized for the gap between the wheel and your hub you could have sandwiched the plastic between the hub and wheel.
Take the wheels off and check that the ring fits snuggly around the hub.
 Old 04-30-2015, 08:49 AM   #19
Douggievee's Avatar
The rings dont fit around the hub of the car, they sit inside the rim and i thought maybe they just sit on top of the hub but the rings dont fit inside the hub circle or around the hub circle, they just match the diameter of the hub circle.
 Old 04-30-2015, 08:51 AM   #20
ArmanRus's Avatar
Groans: 42
Reinstall stock wheels and overnight some hubcentric rings lol. Double check the size you need, I read 73.1mm or 72mm.
 Old 04-30-2015, 08:52 AM   #21
WetzMS3's Avatar
Groans: 430
I'm not really sure what you are trying to say there.
The hubcentric rings should slide over the hub, and fit inside the wheel bore.
2013 MS3 Black Mica
 Old 04-30-2015, 08:52 AM   #22
There's your problem. Go to a discount tire and get propperly sized rings.
The Following User Says Thank You to pirate steve For This Useful Post:
WetzMS3 (04-30-2015)
 Old 04-30-2015, 09:07 AM   #23
Douggievee's Avatar
ok i thought they were supposed to fit differently, thanks guys.
TSW nurburgring vrspeed10 2010 MS3 - Wheels & Tires 190 05-14-2014 05:36 AM
HU noise after installing stiffer mounts apena85 Mazdaspeed3/6 General Discussion 0 12-06-2012 06:33 AM
Lotus and Harman partner on noise-cancelling, noise-creating tech Haltech Automotive News 0 04-16-2009 05:00 PM
Page generated in 0.40582 seconds with 27 queries
