I ordered mine at the same time I ordered the wheels. It was over $100 I believe. |
Bushwackers? |
Sent from my Nexus 5 using Tapatalk 2 |
Another RPF-01 setup. Fronts are 17x9.5 +38. Had to run a 3mm spacer to clear the strut. Rears are 17x9 +45. Tires are 255/40/17. Fronts: Falken Azenis. Rears: Federal RSR's ISC street/sport coilovers with max camber upfront. SPC camber arms almost maxed out. Rear fenders are rolled flat and the bumper tabs are ground down slightly. I still need an alignment but I barely scrape the fenders front and rear. I will be raising the car before I rub the inner fender away https://farm6.staticflickr.com/5532/...43f7d703_c.jpg Top Tier Imports - 2014 Spring Awakening by au.ken, on Flickr |
http://img.tapatalk.com/d/14/06/03/e4yte5es.jpg Sent from my Nexus 5 using Tapatalk |
I think he XXRs in 9"+ are 25 offset. Mad concave look but not without ridiculous poke or stretch. I wouldn't do it... *edit* Rear lip is Home Depot Lip or EZ lip. I have the same up front, nothing on the sides. |
@IshiKage; I think you're going to want to check inside clearance as it might be tight without spacers: Wheel / Tire Size Comparer - RIMSnTIRES.com |
Yeah, it doesn't really work that way. Staggered for a FWD is form > function / ricy. Also, aggressive camber can yield better grip while cornering in a track setup, it's pointless and a waste of rubber for a daily driver. You might want to search and read more before biting the bullet on a new setup: 2010 MS3 - Suspension & Brakes |
Another problem with the staggered setup is you can't rotate them for longer tread life. If that option is only for looks, than there's no point in discussing it's function, or lack of... |
I tossed on some 5/16" spacers I had laying around. So now I have 18x8.5 +40mm offset, effectively. Before: http://img.photobucket.com/albums/v4...ps885218d4.jpg http://img.photobucket.com/albums/v4...psd6383d62.jpg After: http://img.photobucket.com/albums/v4...ps9ccce0d7.jpg http://img.photobucket.com/albums/v4...psd7e4e224.jpg Ultimately what I was looking for was something more aggressive and truth be told I was thinking of selling these wheels. I think it gives the perfect compliment to them and the car and I once again feel like I did when I first installed the ST100's on the car. They're still heavy, but now they give the car a better attitude and I'm really diggin' it. |
http://i157.photobucket.com/albums/t...d/_DSC2232.jpg http://i157.photobucket.com/albums/t...d/_DSC2080.jpg I am running xxr 531 18x9.5 +35 with 225/40r18's |
Enkei Evo 9's 17x8+38, Hankook Ventus RS-3 235/45/18 http://i214.photobucket.com/albums/c...ps90gcxp5g.jpg http://i214.photobucket.com/albums/c...ps832wfx9f.jpg http://i214.photobucket.com/albums/c...psq88vl65n.jpg |
Ok so I just ordered my xxr 527s In 18x8.75 +35 for my gen1. I'm kinda nervous about fitment and such. I'm currently lowered on eibach sportlines ~2in . I plan on rolling the fenders but just how bad is it gonna be fitting it and will I have any major issues. Thanks for the help I really appreciate it |
Also I will be running oem tire size |
And for the love of god, please get some properly fitting tires. Stock sized tires are going to make it look (and more importantly perform) like crap. |
Just got my 527s in today and I ordered the 18x8.75 +35. I am convinced they some how sent me the wrong size even though the box is correct http://img.tapatalk.com/d/14/07/16/ny4abuny.jpg http://img.tapatalk.com/d/14/07/16/gehyhepu.jpghttp://img.tapatalk.com/d/14/07/16/yzu2utu4.jpghttp://img.tapatalk.com/d/14/07/16/jynebahe.jpghttp://img.tapatalk.com/d/14/07/16/bazare7u.jpg |
@Astrall; if you wanted 18x8.75.... That isn't 8.75 wide. |
Im pretty sure there is a thread out there that discuss this. They say 8.75 but I believe they are measuring from the the inner lips rather then the outer lips of the rim. thus actually making it a 9"+ wheel. |
Measure inside lip to inside lip |
Cosmis Racing XT005R 18x9 +25 Goodyear Eagle F1 Asymmetric2 245/40/18 http://img.tapatalk.com/d/14/07/17/qurababe.jpghttp://img.tapatalk.com/d/14/07/17/yhusa2uj.jpghttp://img.tapatalk.com/d/14/07/17/qape5evy.jpghttp://img.tapatalk.com/d/14/07/17/bygeqe7a.jpghttp://img.tapatalk.com/d/14/07/17/syge5ama.jpg |
After some research and a call to XXR, it turns out that they measure by the inside and it ends up being a much bigger rim then planned. I will make it work some how... Wish me luck |
| All times are GMT -7. The time now is 08:37 AM. |
