Like Tree455Likes
 Old 02-13-2011, 07:24 PM   #481
jwilkins88's Avatar
Posts: 3,675   (View Stats)
jwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the world
Groans: 126
Groaned at 59 Times in 47 Posts
Originally Posted by tigermack View Post
Fronts can only be pulled anyways.
They will rub, only when you corner hard and have passengers going over bumps on freeway. Even rubbed with 225/45. 225/50 & 235/45 are both taller.
Hrmmm... Were you only rubbing in the back?
I've got 18x8.5 245/45s +38 offset in the front, and I don't rub at all
jwilkins88 is offline   Reply With Quote
 Old 02-14-2011, 05:17 PM   #482
tigermack's Avatar
Posts: 650   (View Stats)
Groans: 78
In the back only.
No rubbing in front, full lock would touch, though.
The Following User Says Thank You to tigermack For This Useful Post:
jwilkins88 (02-14-2011)
 Old 02-16-2011, 11:07 PM   #483
Cameron Letcher's Avatar
Posts: 311   (View Stats)
Cameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the world
What's up ya'all. I'm trying to do some homework before buying some new shoes for my 06 speed 6. Does anyone know if 19x9 +35 offset wheels will fit on my ride? Any help or input would be awesome. Tires 245/35.
Cameron Letcher is offline   Reply With Quote
 Old 02-17-2011, 12:51 PM   #484
Albertogti117's Avatar
Posts: 136   (View Stats)
Albertogti117 has a brilliant futureAlbertogti117 has a brilliant futureAlbertogti117 has a brilliant futureAlbertogti117 has a brilliant futureAlbertogti117 has a brilliant futureAlbertogti117 has a brilliant futureAlbertogti117 has a brilliant futureAlbertogti117 has a brilliant futureAlbertogti117 has a brilliant futureAlbertogti117 has a brilliant futureAlbertogti117 has a brilliant future
Few recent pictures of my car. Maxed out on BC's. Fronts need to go lower
Albertogti117 is offline   Reply With Quote
The Following User Says Thank You to Albertogti117 For This Useful Post:
Roszko (02-18-2011)
 Old 02-17-2011, 01:22 PM   #485
romeox929's Avatar
Posts: 207   (View Stats)
romeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud of
looks like a twin of my car minus tint. 225 tires?
-cookie cutter mods-
romeox929 is offline   Reply With Quote
 Old 02-17-2011, 01:41 PM   #486
225/40 front 215/45 in the rear. I didn't do this on purpose, I just happened to have some tires in my garage that give me just enough clearance
 Old 02-17-2011, 01:59 PM   #487
bcmountainspeed's Avatar
Posts: 361   (View Stats)
bcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the world
[QUOTE=KeysMS3;713411]SSR Longchamp XR-4Z kai
18x9.5 +13
215/35/18 federal 595's
[/QU
Hey guys whats it like running that much camber does it handle different.Maybe noob question but I gotta know.
bcmountainspeed is offline   Reply With Quote
 Old 02-17-2011, 02:00 PM   #488
romeox929's Avatar
Yea a lil too skinny. Plans to roll and wider tires?
 Old 02-17-2011, 03:28 PM   #489
jwilkins88's Avatar
Groans: 126
It handles worse, and your tires will wear hella unevenly and quicker
 Old 02-17-2011, 03:38 PM   #490
Chriscote's Avatar
Posts: 913   (View Stats)
Chriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the world
Groans: 137
Groaned at 17 Times in 7 Posts
Chriscote is offline   Reply With Quote
The Following User Says NO Thank You to Chriscote For This Un-useful Post:
jracer (03-16-2011)
 Old 02-17-2011, 04:42 PM   #491
Tweaek's Avatar
Posts: 319   (View Stats)
Tweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the world
Attachment 23872
Attachment 23873
Attachment 23874
Good lookin!
Tweaek is offline   Reply With Quote
 Old 02-22-2011, 10:37 PM   #492
Roszko's Avatar
Location: Home Base: Houston, TX. Currently: San Marcos, TX
Posts: 249   (View Stats)
Roszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the world
Once again, Michael (SumTHAIguy) KILLIN' it.
FUCK. ME.
And after that bombshell... Here's some of my MS3 from a photoshoot this weekend.
djkemistry and Carlg21 like this.
Last edited by Roszko; 02-22-2011 at 10:37 PM. Reason: MSF Database - Automerged Doublepost
Roszko is offline   Reply With Quote
The Following 7 Users Say Thank You to Roszko For This Useful Post:
Evan@COBB (12-09-2011), frivolous_rob (03-24-2011), iTygarin (05-28-2013), MarkyMark (03-15-2011), PapaSmurf (03-17-2011), Qwik6 (02-24-2011), RichieRichness (03-10-2011)
 Old 02-22-2011, 10:45 PM   #493
zumin's Avatar
Posts: 623   (View Stats)
zumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the world
Groaned at 6 Times in 6 Posts
Sex:
that S13 looks SOOOO familiar!
zumin is offline   Reply With Quote
 Old 02-22-2011, 11:30 PM   #494
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Originally Posted by Snyeed View Post
Man that shit is hella flush, the drop is perfect. The car looks mean!
Never mind, just got onboard the fail boat. Bumping this awesome thread.
 Old 02-23-2011, 07:49 AM   #495
jwilkins88's Avatar
Groans: 126
Originally Posted by zumin View Post
I actually like this car... It's pretty clean.
 Old 02-23-2011, 01:36 PM   #496
zumin's Avatar
ok i knew i had seen it, one of the local guys knows the person that owns this, i think their name is yuri? the wheels are one-offs apparently he made them while working at one of the wheel companies
 Old 02-24-2011, 05:17 PM   #497
Qwik6's Avatar
Posts: 695   (View Stats)
Qwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the world
Roszko is killin it
2006 MAZDASPEED6
FREEKTUNED @ 20PSI // COBB AP V3 // CPE TMIC // COBB SF // PG TIH // DENSO ITV22s // AUTOTECH INTERNALS // SURE TP // MAGNAFLOW CATBACK // JBR OCC // JBR IM SPACER // JBR PASSENGER & TRANNY MOUNT // SURE RMM // H&R SPRINGS // XXR 530 18X8.75 +35 // CAR LED TAILS // CPE REAR DIF MOUNT // TURBINE TECH FRONT DIF MOUNT // CPE TOW HOOK // 35% TINT // 3M DINOC WRAPPED ROOF // AUTOEXE CARBON FIBER BADGELESS GRILL
Qwik6 is offline   Reply With Quote
The Following User Says Thank You to Qwik6 For This Useful Post:
Roszko (02-25-2011)
 Old 02-26-2011, 01:14 AM   #498
Roszko's Avatar
SumTHAIguy's new feature on Stance:Nation. I don't even know what to say, no words. Gorgeous.
Full Feature here!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
:: Gusto :: likes this.
The Following 3 Users Say Thank You to Roszko For This Useful Post:
:: Gusto :: (03-29-2011), Kvo_8 (03-13-2014), RichieRichness (03-10-2011)
 Old 02-27-2011, 05:16 PM   #499
Qwik6's Avatar
Originally Posted by Roszko View Post
Best car in here IMO.
2006 MAZDASPEED6
The Following 3 Users Say Thank You to Qwik6 For This Useful Post:
801MS3 (02-28-2011), nycMS3 (03-03-2011), Roszko (03-24-2011)
 Old 02-27-2011, 06:20 PM   #500
Roszko's Avatar
Much appreciated, good sir
The Following User Says Thank You to Roszko For This Useful Post:
Qwik6 (02-27-2011)
 Old 02-27-2011, 06:40 PM   #501
ZoomByU's Avatar
Posts: 1,236   (View Stats)
not professional shots, but you get the idea....
The Following 9 Users Say Thank You to ZoomByU For This Useful Post:
802MS3 (04-12-2011), BaseballD2 (04-14-2011), flapjack (02-05-2018), madvillain (02-27-2011), NoTraction (03-28-2011), Qwik6 (02-27-2011), RichieRichness (03-10-2011), romeox929 (02-28-2011), Roszko (02-28-2011)
 Old 02-28-2011, 07:46 PM   #502
romeox929's Avatar
yin and yang..
 Old 02-28-2011, 07:50 PM   #503
emag remrofni's Avatar
Posts: 1,594   (View Stats)
emag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the world
Groans: 209
Groaned at 92 Times in 38 Posts
Is there a purpose to dropping your car so low it's un-drivable?
// 09 CWP // Cobb SRI // SURE Race RMM // eBay double penetration DP // SU BPV // ITV22's // JBR SSP // KMD Internals // VTAK GAUGE // Cobb FMIC V.1 //
4 Gallon E85 by Stratified
My Photography - DarkSidePhotoshoot.com
Originally Posted by Monotonous ONE View Post
it was a mexican
whoever said they are lazy is a stupid dumb fucking idiot
and they can do ANYTHING...they prolly got the wheels off with a branch and some hedge clippers
Originally Posted by FreeFlyFreak View Post
The dick bone is not connected to the asshole... Mind over matter, learn to control them both.
emag remrofni is offline   Reply With Quote
 Old 03-01-2011, 01:55 AM   #504
ZoomByU's Avatar
maybe for the same reason people want to mod a FWD car over 400whp....just to prove they can and try something new.
...and i have no problem navigating the streets of Hawaii which are probably some of the shittiest in the states.
The Following 2 Users Say Thank You to ZoomByU For This Useful Post:
flapjack (02-05-2018), nycMS3 (03-03-2011)
 Old 03-01-2011, 10:08 AM   #505
Qwik6's Avatar
Yes. Becuase it looks sexy.
2006 MAZDASPEED6
The Following 10 Users Say Thank You to Qwik6 For This Useful Post:
802MS3 (04-12-2011), :: Gusto :: (03-29-2011), HXC LOL (03-07-2011), jracer (03-16-2011), KeysMS3 (03-16-2011), MarkyMark (03-15-2011), mazdafreak (12-02-2011), nycMS3 (03-03-2011), SPEED3 EDDIE (03-06-2011), ZoomByU (03-01-2011)
 Old 03-09-2011, 07:46 PM   #506
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Originally Posted by ZoomByU View Post
...the streets of Hawaii which are probably some of the shittiest in the states.
You've obviously never been to Pennsylvania
Plavin1991 likes this.
The Following 2 Users Say Thank You to Mizzle For This Useful Post:
jeb8699 (05-04-2011), uncorked11 (12-09-2011)
 Old 03-10-2011, 02:58 PM   #507
fishin53's Avatar
Posts: 1,721   (View Stats)
Groans: 44
no jersey has you beat
2010 Black Mica Speed3 SOLD
fishin53 is offline   Reply With Quote
 Old 03-10-2011, 03:53 PM   #508
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Groans: 112
I've driven in pretty much every state in the north east and I'd have to say Massachusetts, rhode island and new jersey have the worst roads.
860whp/677wtq
2.7 V6 Ecoboost
 Old 03-15-2011, 05:40 PM   #509
Malicioso's Avatar
Posts: 3   (View Stats)
Malicioso is an unknown quantity at this point
Hey guys nOOb from Aus here!
I've been lurking around this thread for a while and have paid special attention to the MS3s with the 18x9.5 Rota Grids. I'm looking at running this same setup but wanted to know more about how they drive and if they rub at all???
The roads here are pretty crap, big dips and random pot holes, so basically not as flat as Texas. Can anyone give me a heads up??? i.e. lock to lock and also if they're able to take passengers in the rear of the car???
I'd like to be the first one here in Aus running this setup, MPS/MS3 owners here are real conservative and there is only a hand full of ppl who go with the aggressive fitment.
Any info will be greatly appreciated...
Cheers!
Malicioso is offline   Reply With Quote
 Old 03-16-2011, 01:04 PM   #510
Regulator's Avatar
Posts: 192   (View Stats)
Regulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the world
Groaned at 9 Times in 4 Posts
am i doing it right?
Bolted, permed.
Regulator is offline   Reply With Quote
The Following 23 Users Say Thank You to Regulator For This Useful Post:
801MS3 (03-30-2011), 802MS3 (04-12-2011), andrewpiro (10-09-2011), BaseballD2 (04-14-2011), Chriscote (05-08-2011), cocoanton (03-29-2011), Delphie (03-23-2011), drummermike58 (04-24-2011), Hectik1 (12-03-2011), Jedyboyrokr (05-24-2011), jracer (03-16-2011), jwilkins88 (03-16-2011), madvillain (03-24-2011), mazdafreak (12-02-2011), mituc (03-17-2011), Mizzle (03-21-2011), myt_tuf1 (03-17-2011), Nliiitend1 (03-16-2011), PapaSmurf (03-17-2011), romeox929 (03-16-2011), saitek (03-16-2011), super_pablo_ (03-16-2011), ZoomByU (03-18-2011)
 Old 03-16-2011, 03:53 PM   #511
Malicioso's Avatar
Sorry a lil off topic...
ZoomBYU, I received your PM but since I'm a noob I can't reply due to my post count lol
Do you mins sending me your emila address via pm so I can reply back??? I've got a few questions and stuff I wanna ask about your setup.
Cheers!
 Old 03-16-2011, 04:57 PM   #512
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
regulator... I think thats what this thread is all about now... so ur definitely doin it rite!
super_pablo_ is offline   Reply With Quote
 Old 03-16-2011, 09:23 PM   #513
Malicioso's Avatar
Meh needs moar low :p
 Old 03-17-2011, 01:16 AM   #514
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
No but you're almost there, you need to re-paint your bicycle with some paint that has a front wheel
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 03-17-2011, 01:40 AM   #515
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Spoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the world
Originally Posted by KeysMS3 View Post
sumthaiguy's new setup
This the idiot that ripped off his front bumper trying to pull out of his driveway?
Spoofmastafly is offline   Reply With Quote
 Old 03-17-2011, 02:32 AM   #516
HXC LOL's Avatar
Posts: 107   (View Stats)
HXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant futureHXC LOL has a brilliant future
Groaned at 6 Times in 1 Post
You wanna know what's sad?
You really are doing it right.
Edit: LOL the fixie on the bike rack is a nice touch
I drive an underpowered Volkswagen.
HXC LOL is offline   Reply With Quote
The Following User Says Thank You to HXC LOL For This Useful Post:
 Old 03-17-2011, 02:41 AM   #517
HXC LOL's Avatar
Originally Posted by Spoofmastafly View Post
This the BADASS that ripped off his front bumper trying to pull out of his driveway?
lolfixed
I wouldn't doubt that though.
KeysMS3 (03-17-2011)
 Old 03-17-2011, 10:18 PM   #518
KeysMS3's Avatar
Posts: 341   (View Stats)
KeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the world
Groaned at 8 Times in 3 Posts
not an idiot, if i remember right his bumper is pretty much quick release style lol but yes same boss rollin hard.
KeysMS3 is offline   Reply With Quote
 Old 03-18-2011, 03:20 AM   #519
ZoomByU's Avatar
same could be said for a good majority of people here...
"These are the IDIOTS who tried putting 400hp on their FWD Mazdaspeed with a stock bottom."
Everyone has their own opinions and reasonings for what they do. Someones always going to hate whether that person is going for function or form.
 Old 03-18-2011, 03:33 AM   #520
NoTraction's Avatar
Posts: 117   (View Stats)
NoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond repute
Groaned at 8 Times in 4 Posts
Originally Posted by dastpe View Post
those are some sick wheels. for some reason i would love to see them on a red car.
My winter wheels are this color
No big pictures yet
GARAGE: 10' GTI(FS), 14' BRZ, 95' corolla, Z750s, klr250
07 Mazdaspeed3 #2 SOLD
HT tuner, RMM, CS SRI, Exhaust
Things I miss: Both my Speed3's of the past, Fz1, 2zz Mr2-s
Turbo s2k wanted...but in the mean time
NoTraction is offline   Reply With Quote
The Following User Says Thank You to NoTraction For This Useful Post:
SixxSpeed6 (05-05-2011)
Page generated in 0.59788 seconds with 45 queries
