Like Tree455Likes
 Old 03-14-2012, 02:21 PM   #1041
Kydizzle's Avatar
Posts: 505   (View Stats)
Kydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the world
Not super aggressive but looks good, although i wish wheels were 8.5 wide..
setup is BC Coils, Lightweight Motegi SP-10 HyperBlack 18x8 +40 w/ Kuhmo AST 225/40
tires arnt great but got them for 300 brand new so cant complain
2008 Silver MS3 GT - BNR S2, CP-E HPFP, CP-E Nano, Cobb FMIC, Cobb AP(E-85 Mix [FREEKTUNE]), GrimmSpeed EBCS, CNT Exhaust, Corksport DP, SU Test Pipe W/ Magnaflow HFC, Forge BPV v1, EGR Delete, AWR RMM, SU Shifter Bushing, CP-E Towplate, BC Coilovers, Cobb RSB, Motegi SP-10 HyperBlack(19lbs)
Kydizzle is offline   Reply With Quote
The Following 4 Users Say Thank You to Kydizzle For This Useful Post:
:: Gusto :: (03-15-2012), dastpe (03-14-2012), ReD BoY (03-16-2012), Tweaek (03-23-2012)
 Old 03-14-2012, 03:53 PM   #1042
Originally Posted by dastpe View Post
at +48 you should be okay...not a lot of experience with stock suspension. you may need a 3mm spacer, then you are the same as silva...so whatever prep he did you will need to do (most likely roll. maybe pull/grind rear bumper tab)
I had to do a roll 'n pull on the rear and grind down the tabs.
 Old 03-14-2012, 04:26 PM   #1043
JustanotherMS3's Avatar
Posts: 268   (View Stats)
JustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the world
Groaned at 45 Times in 11 Posts
Originally Posted by goob_os101 View Post
Depends on your tire size
Sorry. Forgot to post that. Stock dunlops I don't even remember what size they are. 225 45 18 I think
Currently own:
2012 Sunburst Orange Civic SI Coupe W/Tech package
Basically stock with an Injen SRI (much thanks to madspd6)
wheels will be here in a week or so: 18x9 +25 Fast Hayaku powder coated White (basically TE37 knockoffs)
Previous car... 2011 Velocity Red MS3 W/Tech
-Engine/Power Mods:
FREEK TUNE IN PROGRESS/UR CBE/UR Race Pipe/Injen SRI/COBB AP/AutoTech HPFP Internals/Stage 2 Driver Mod/Turbo Smart Duel Port/JBR SSP/JBR SSB/Razo Weighted Shift Knob/
-Wheels and suspension:
Lowered on H&R Springs
18x8.5 +30 offset XXR 522 in Gold.
JustanotherMS3 is offline   Reply With Quote
 Old 03-14-2012, 04:56 PM   #1044
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
OEM GenPu tires are 225/40R18...
Even with those narrowish tires, I would think you're going to need to massage things quite a bit to make those wheels work.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 03-15-2012, 07:49 AM   #1045
goob_os101's Avatar
Posts: 697   (View Stats)
goob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the world
Groaned at 10 Times in 7 Posts
I hope to get away with just a roll if I run the SenSen shocks with Ebiach springs. This will give a very subtle drop.
goob_os101 is offline   Reply With Quote
 Old 03-15-2012, 08:09 AM   #1046
fish20bcm's Avatar
Posts: 293   (View Stats)
fish20bcm is the leader of the worldfish20bcm is the leader of the worldfish20bcm is the leader of the worldfish20bcm is the leader of the worldfish20bcm is the leader of the worldfish20bcm is the leader of the worldfish20bcm is the leader of the worldfish20bcm is the leader of the worldfish20bcm is the leader of the worldfish20bcm is the leader of the worldfish20bcm is the leader of the world
Groaned at 3 Times in 1 Post
Looks good, same wheels and same color MS3 as mine
Did you roll the rears at all when you dropped it? I'm currently on stock suspension and on the stock 215/45 tires and i'm getting some rubbing on the outer shoulder of the tire on the drivers side rear from time to time. I'm about to have to get new tires and I was thinking about going either 225/40 or 235/40 but I haven't lowered the car yet, that will come before too long, probably just some Yellows and Eibach ProKit.
2008 MS3 Sport
Sunlight Silver - Corksport HPFP Internals - Corksport Stage 2 SRI & TIP - Corksport OCC - JBR RMM - ROCA PMM - SU Test Pipe - 3" Custom Catback - Hawk HPS - MOOG Rear Endlinks - BC Coilovers - Motegi SP10 HyperBlack 18x8 +40 - 225/45/18 Kumho Ecsta 4X - Morimoto 6000K HID Kit - LED Interior Bulbs - 35% Tint - Nextmod Spoiler Lip - Shaved Side Moldings
fish20bcm is offline   Reply With Quote
 Old 03-15-2012, 11:39 AM   #1047
travis9935's Avatar
Posts: 371   (View Stats)
travis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond repute
Groaned at 41 Times in 24 Posts
oh snapple...a local guy is selling 245/40/18 Nitto 555's w/ 5k on them for $350! Will they fit with a roll and 3mm or 5mm spacers.
Wheels are 5-ZIGEN Fn01r-C 18x8.5 et48 for my 08 Speed3 with stock suspension for now. Soon Racelands or SenSen/eibach spring combo.
That's what I'm thinking, ohhh post pics up!
HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2
travis9935 is offline   Reply With Quote
 Old 03-15-2012, 11:41 AM   #1048
travis9935's Avatar
Pics please
 Old 03-15-2012, 12:09 PM   #1049
Kydizzle's Avatar
i did a little bit of a roll on the back fenders and then stiffened the back shocks a little bit more and i will only rub if i hit a big bump going really fast. or if i have the car full of people
 Old 03-15-2012, 07:40 PM   #1050
:: Gusto ::'s Avatar
Posts: 1,455   (View Stats)
soo... i figured i should ad more pics..
2pc. rpf1's
staggered mazda2
looks like a ph.chop job.. but still...
yea yea - i know i cant spell
 Old 03-16-2012, 01:21 PM   #1051
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Just got my wheels and tires mounted and put on today, nothing to aggressive
18x8.5 +40
FREEKTUNE
The Following User Says Thank You to Boost Addict For This Useful Post:
IshiKage (03-17-2012)
The Following User Says NO Thank You to Boost Addict For This Un-useful Post:
SamInAustinTX (03-16-2012)
 Old 03-16-2012, 01:34 PM   #1052
CeeeJay's Avatar
Posts: 43   (View Stats)
CeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to behold
18x8.5 +40
possibly in the wrong thread?
CeeeJay is offline   Reply With Quote
 Old 03-16-2012, 02:31 PM   #1053
Lol at the groan from @SamInAustinTX, you posted the same exact fucking wheel setup in here
FREEKTUNE
 Old 03-16-2012, 02:33 PM   #1054
SamInAustinTX's Avatar
Posts: 533   (View Stats)
SamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the world
Actually 19"s and thats why I groaned haha, same wheels. Looks like he may have a bit of a stretch as well.
SamInAustinTX is offline   Reply With Quote
 Old 03-16-2012, 05:37 PM   #1055
dastpe's Avatar
Posts: 1,644   (View Stats)
18x8.5 +40
you def need at LEAST a 3mm spacer in front and 5mm in the rear. preferably 5mm in front and 8mm rear. i like the wheels though. -1 on rusty wheels centers. hit that with some brake caliper black paint.
 Old 03-16-2012, 06:36 PM   #1056
Domino81's Avatar
Posts: 5,081   (View Stats)
18x8.5 ET48
Not extremely aggressive, but I wouldn't want to go anymore aggressive. Already wrinkled paint on the inside edge of the fender wells from rolling the fenders. Eventually I'll learn how to avoid do that.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 03-16-2012, 07:04 PM   #1057
Yeah I'm probably going to throw 5mm spacers all around. And I put the center caps in now so all the rust is covered
FREEKTUNE
dastpe (03-16-2012)
 Old 03-18-2012, 08:52 AM   #1058
these recent aggressive set ups... look pretty soft.
wtf... every is posting pics that kind of suck.
wheres the poke.. the stretch... the low offsets??!??!
 Old 03-18-2012, 09:08 AM   #1059
GOT 2RBO's Avatar
Posts: 355   (View Stats)
GOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the world
18x8" +30 225/40/18
GOT 2RBO is offline   Reply With Quote
The Following User Says Thank You to GOT 2RBO For This Useful Post:
Rokusek (03-19-2012)
 Old 03-18-2012, 10:01 AM   #1060
Nliiitend1's Avatar
Groans: 67
I rather enjoy the recent trend of posting setups that have some semblance of functionality to them...
A setup shouldn't have to be retardedly misfitted to the car to be considered "aggressive".
Just my $0.02...
2008 MS3 GT
2016 MX-5 Club
The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post:
Design (03-19-2012), silvapain (03-18-2012), tigermack (03-19-2012)
 Old 03-18-2012, 10:06 AM   #1061
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Just my $0.02...
my tires have been pretty aggressively destroying my fenders over the past couple days due to my new wheels and tires....evo's with 245/40s. The guy I bought them from stretched 225s onto 18x10.5s...I'll get some pics of it today for everyone who's into that kind of thing.
Blue Pu.
 Old 03-19-2012, 07:20 AM   #1062
Rokusek's Avatar
Posts: 5,551   (View Stats)
well i got some pics taken, lowered the front and the rear a little more, still not rubbing, time to go just a little lower and see how we feel.
Downmented likes this.
 Old 03-19-2012, 07:41 AM   #1063
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
@Rokusek We need to paint that front grill piece. Looks like ass, but on the other hand, the pictures turned out fantastic and i am rather jelly
700HP CLUB
11.479@124mph
#DIX
 Old 03-19-2012, 08:01 AM   #1064
Rokusek's Avatar
Yea, Im waiting on the original pics from my boy who took them and the paint to fix the stache as well... i think the dirtyness of the wheels have grown on me too looks like beat up road cones... time for moar lows
 Old 03-19-2012, 08:11 AM   #1065
WhoIsJeremy's Avatar
Posts: 2,196   (View Stats)
WhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the worldWhoIsJeremy is the leader of the world
Are you the dude that works at iag by any chance? lol
OR does anyone know where to get fenders pulled in the MD/DC area?!
They're rolled but every fucking bump (because springs I suppose) they like to make the sidewalls look more and more like spaghetti.
2007 MS3 GT -- > World's first flying Mazdaspeed3.
2006 MS6 GT -- > World's first n2o Mazdaspeed6.
1990 LS1 RX7-- > Probably broke somewhere
#DIX, for all the single ladies
WhoIsJeremy is offline   Reply With Quote
 Old 03-19-2012, 08:44 AM   #1066
Downmented's Avatar
Groans: 493
Pull your own fenders fool.
700HP CLUB
11.479@124mph
#DIX
The Following User Says Thank You to Downmented For This Useful Post:
 Old 03-19-2012, 08:50 AM   #1067
0__o
No thanks lol You gonna roll your fenders with a baseball bat lol
 Old 03-19-2012, 09:01 AM   #1068
fishin53's Avatar
Posts: 1,721   (View Stats)
Groans: 44
^i was thinking of rolling mine with a bat lol
2010 Black Mica Speed3 SOLD
fishin53 is offline   Reply With Quote
The Following User Says NO Thank You to fishin53 For This Un-useful Post:
dastpe (03-19-2012)
 Old 03-19-2012, 09:09 AM   #1069
Downmented's Avatar
Groans: 493
0__o
My fenders are already rolled you tool. And no it wasnt done with a bat
700HP CLUB
11.479@124mph
#DIX
 Old 03-19-2012, 11:16 AM   #1070
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Finally did some measurements on the KW's. Tires are Pirelli P-Zero A/S 215/45/18 on OEM rims. On a 1" drop with front camber maxed towards positive, here's what you're looking at:
- Strut perch to inner front tire: 15mm
- Rear outer tire @ -1.5* to top fender: 6mm (tire measured on incline flush with fender)
Best guess, subtract 1mm of inner clearance (front) for every .1" you drop the car.
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
 Old 03-19-2012, 12:27 PM   #1071
Nliiitend1's Avatar
Groans: 67
Your inner clearance shouldn't get any smaller as you lower the car...
The relationship angle between the wheel/tire and the strut is actually increased slightly as the suspension compresses (or is "dropped" via the coilover perch), hence why we talk about "camber loss" in a Macpherson strut setup, and why such relatively large negative static camber values are necessary to get good cornering grip with such a setup.
This means that your wheel/tire-to-strut clearance actually should increase ever-so-slightly as you lower the car (even though your overall static camber is becoming more negative)...
2008 MS3 GT
2016 MX-5 Club
 Old 03-19-2012, 01:02 PM   #1072
Design's Avatar
True, but until you clear the apex of the tire's section width, clearance will continue to reduce. Example from a similar size/offset, but a more aggressive drop:
09 CWP MS3 GT
The Following User Says Thank You to Design For This Useful Post:
Nliiitend1 (03-19-2012)
 Old 03-19-2012, 02:30 PM   #1073
tigermack's Avatar
Posts: 650   (View Stats)
Groans: 78
Nice bush there.
 Old 03-19-2012, 02:44 PM   #1074
goob_os101's Avatar
what is your wheel, tire and suspension specs?
I just ordered some hubcentric rings and some lugs...I am about if I will rub or not.
You can pull your own fenders...if you dare bwhahahaha:
 Old 03-19-2012, 04:13 PM   #1075
Nliiitend1's Avatar
Groans: 67
Lol.
I was (short-sightedly) coming at this from the perspective of the strut tube clearance only and wasn't even thinking about the perch clearance issue.... Doh!
2008 MS3 GT
2016 MX-5 Club
Design (03-19-2012)
 Old 03-19-2012, 04:14 PM   #1076
Roszko's Avatar
Location: Home Base: Houston, TX. Currently: San Marcos, TX
Posts: 249   (View Stats)
Roszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the worldRoszko is the leader of the world
Specs on this badboy?
09 CPW MS3
SSP Street Tune | PTP Internals | CNT Catless DP | CNT CBE | CX Racing FMIC | Cobb SRI | Cobb TIP | Turbosmart BOV (full recirc) | TWM STS | Hotchkis F&R Sways | JBR Shifter Plate | DBA 4000 Slotted Front Rotors | HKS Turbo Timer | SU RMM | Cobb AP | SU Solid Shifter Bushings | 6k HIDs | Hawk HPS Pads | Braided SS Brake Lines | Lamin-X Yellow Fog Overlays
Roszko is offline   Reply With Quote
The Following 2 Users Say Thank You to Roszko For This Useful Post:
Boost Addict (03-19-2012), dastpe (03-19-2012)
 Old 03-19-2012, 07:34 PM   #1077
I live around the area, my friend works there in the body shop and they roll fenders.
FREEKTUNE
 Old 03-20-2012, 04:25 AM   #1078
dastpe's Avatar
here are some more pics: season opener - a set on Flickr
not sure about specs.
The Following 2 Users Say Thank You to dastpe For This Useful Post:
araw (03-23-2012), Roszko (03-20-2012)
 Old 03-20-2012, 07:08 AM   #1079
i'm on eibach sport springs and the wheels are 18x8 but idk the offset. They came with the car but winters were on and the dude that bought em has no clue. Rubber is 225/45. Fenders are rolled. i have an appointment to get them pulled on April 12
 Old 03-20-2012, 08:24 AM   #1080
dastpe's Avatar
offset is almost always stamped on the rear of the wheel somewhere (spoke, hub). 225/45 rubs on a lowered car because of the taller sidewall than stock. not sure how much pulling will help with a taller tire. and you can pull your own fenders with some heat and a fender roller if you would want to. not sure if that answers your ? since there were none of these (?) in the post.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Page generated in 0.62842 seconds with 42 queries
