Like Tree455Likes
 Old 08-19-2012, 07:52 AM   #1401
Stangcobra's Avatar
Posts: 584   (View Stats)
Groans: 51
new piktarz of my car coming soon along with a feature on a site
I am a huge faggot
 Old 08-19-2012, 11:25 AM   #1402
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Over exaggeration to make a point is silly. Most quality wheels are less than 500 a piece.
ZOMGAWD, I am being featured for nothing performance related at all. Let me brag to a site who does not give a flying fuck...
I hope they feature your awesome driving @ 55mph into curbs as well. You and your legitimate wheels are badasses.
Past Mazdas & Speeds
The Following User Says Thank You to Neverlift For This Useful Post:
Darth_Nuruodo (08-19-2012)
 Old 08-19-2012, 09:26 PM   #1403
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Originally Posted by another 6cms6 View Post
Rota does not use MAT Technology... only Konig does..
MAT applies to < 10% of Enkei's lineup (mostly racing wheels) and is not a traditional casting process. Almost all wheels (particularly OEM) are gravity or low pressure casted - not flow spun. Rota and Enkei use a very similar casting method on most of their wheels.
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
The Following User Says Thank You to Design For This Useful Post:
Stangcobra (08-19-2012)
 Old 08-19-2012, 09:43 PM   #1404
Stangcobra's Avatar
Groans: 51
Your car isn't fitted and yet you're posting in a fitment thread. I guess you are illiterate
Ps: My rotas are the same as your enkeis/sonic tuning/whatever gay discount tire shit you are running on your car
I am a huge faggot
 Old 08-19-2012, 09:46 PM   #1405
Neverlift's Avatar
Groans: 1,143
This is the aggressive offset thread my child. Who is illiterate now?
The Following User Says NO Thank You to Neverlift For This Un-useful Post:
Buddhamonk (08-20-2012)
 Old 08-19-2012, 11:16 PM   #1406
SamInAustinTX's Avatar
Posts: 533   (View Stats)
SamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the worldSamInAustinTX is the leader of the world
SamInAustinTX is offline   Reply With Quote
The Following 2 Users Say Thank You to SamInAustinTX For This Useful Post:
Downmented (08-22-2012), Stangcobra (08-19-2012)
 Old 08-19-2012, 11:21 PM   #1407
Stangcobra's Avatar
Groans: 51
I'll save you the embarrassment of admitting you dont know what fitted means and explain it
fitment is making your aggressively offset wheels fit flush with your car's body
I am a huge faggot
 Old 08-19-2012, 11:32 PM   #1408
Design's Avatar
Originally Posted by radbrad View Post
and arnt rotas really heavy?
Any cast wheel will be heavy. Our own 24lb wheel is most likely made by Enkei (they are the top OEM wheel supplier to Mazda)...
09 CWP MS3 GT
 Old 08-20-2012, 12:27 AM   #1409
Neverlift's Avatar
Groans: 1,143
My shits flush.
Hell, my daily beater is flush. I belong more then you know.. you mentioned nothing of ride height in that explanation. Or the smaller sizing of tires... which was the main driving force for what started this whole played out hellaflush nonsense. Bet you don't even know when or why.
But please, tell us more about your poser shit... w/ your ricelands & rotas. Matched w/ the rest of your ebay parts list. Look at you, wishing, hoping, for some sort of recognition.
You are on the wrong forum.
 Old 08-20-2012, 03:43 AM   #1410
Design's Avatar
Originally Posted by secondchance View Post
You are simply trying to pick apart the original argument. Fact, Rota has a higher failure rate then almost any other brand of wheels, regardless of the driving circumstances. Fact, they are made offshore to a lower standard then wheels in the states, japan, and even china. Fact, you get what you pay for.
Now to reply to the ignorant claims. If you go to google, and again type in Rota Wheel Failure, and click on the images, they all take u to forum posts. Read a few, some were track, and some were normal dd spirited driving. Now do the same on the other brands. None were track, and all were potholes and circumstances that the wheels were meant to withstand. Rotas FAIL. Other wheels break when damaged or when they are in an accident. These are 2 VERY DIFFERENT events. I get that you have a hard time separating the 2 in your brain, but you need to get it eventually don't you? Maybe not.
To be fair, this is more a result of the vocal minority than factual, documented failures. In most discussions where an actual owner (not a "friend") has reported a "defect," most suspect/agree it's due to negligence, high speed impact, or an application failure (ie. insufficient clearance from the caliper or mismatched suspension components). For the 99% out there, Rota will take just as much abuse as any other cast wheel.
To people that know wheels, Rota is just another high volume manufacturer with the same rigorous production standards as every other OEM supplier. If they REALLY had the amount of defects people claimed, their venture with Toyota would have expired over a decade ago. The REAL reason people hate on Rota is 1) they are accessible to just about everyone 2) their paint & finish is paper-thin 3) their designs mimic many of the limited production brands. Reading through some of the fail threads can be a real eye-opener.
I probably will never buy Rotas, but I won't frown upon those that do.
09 CWP MS3 GT
The Following 3 Users Say Thank You to Design For This Useful Post:
chuckms6 (08-20-2012), Nliiitend1 (08-21-2012), Stangcobra (08-20-2012)
 Old 08-20-2012, 05:36 AM   #1411
chuckms6's Avatar
Posts: 1,618   (View Stats)
Thank you for understanding my point and correcting that misinformation!
Tapatalking
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 08-20-2012, 06:18 AM   #1412
Jo3f1sh's Avatar
Posts: 131   (View Stats)
Jo3f1sh is the leader of the worldJo3f1sh is the leader of the worldJo3f1sh is the leader of the worldJo3f1sh is the leader of the worldJo3f1sh is the leader of the worldJo3f1sh is the leader of the worldJo3f1sh is the leader of the worldJo3f1sh is the leader of the worldJo3f1sh is the leader of the worldJo3f1sh is the leader of the worldJo3f1sh is the leader of the world
I had a set of Rotas once. One cracked. Got fixed. Cracked again. Got fixed. Cracked again. Got thrown in dumpster.
That was just my experience. I probably wouldn't run them again, but I know plenty of people who do (Subaru folks) and they seem to be fine. Compared to the other sets of wheels I've owned, the Rotas seemed to be the worst quality, however, they were also the cheapest. To me, that just confirms the age old adage: you get what you pay for.
2008½ CWP Mazdaspeed 3 - COBB Stage 2+++
Jo3f1sh is offline   Reply With Quote
 Old 08-20-2012, 08:36 AM   #1413
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
stancefags, you know who you are.
07 MS3
The original Genpoo Hater
 Old 08-20-2012, 08:41 AM   #1414
Boost Addict's Avatar
Posts: 1,327   (View Stats)
This thread make me lol
I love how defensive all the stance people get, I could give two shits.
FREEKTUNE
The Following User Says Thank You to Boost Addict For This Useful Post:
 Old 08-20-2012, 12:31 PM   #1415
tigermack's Avatar
Posts: 650   (View Stats)
Groans: 78
lol people still run less than 235's on a MS3? Fucking fail, you don't deserve the car. Go drive a fucking hybrid.
 Old 08-20-2012, 12:37 PM   #1416
Stangcobra's Avatar
Groans: 51
lol at function people wasting their time in here
I am a huge faggot
The Following 2 Users Say NO Thank You to Stangcobra For This Un-useful Post:
Neverlift (08-21-2012), tigermack (08-20-2012)
 Old 08-20-2012, 01:23 PM   #1417
LOL at stance people wasting MSF's time.
Deldran and Darth_Nuruodo like this.
The Following 6 Users Say Thank You to silvapain For This Useful Post:
Darth_Nuruodo (08-20-2012), Deldran (01-22-2013), naoandlater (08-20-2012), Neverlift (08-21-2012), Nliiitend1 (08-21-2012), tigermack (08-20-2012)
 Old 08-20-2012, 08:18 PM   #1418
ericdebruyn1's Avatar
Posts: 344   (View Stats)
This is like when your ass is so loose and sweaty and your sitting in night school, next to the hottest girl in the class, then you have the feeling hat you have to fart and you do all you can to hold it in but their is nothing you can do because it's so sweaty and slippery and it flys out and it's really loud the girl that your trying to get with has the dirtiest look on her face. What do you do? So I asked her to get food with me, she said "your car is so cute!" it doesn't matter what do if your car is "stancedout" and still drivable for everyday and your still able to hall ass on the back roads it's alright but if your "hellaflush" you can suck my dick. It doesn't mater what your into just don't run tons of negative camber and dont stretch 215/40's on a 9.5" wide rim. So that's my opinion
The Following User Says Thank You to ericdebruyn1 For This Useful Post:
Chimmike (08-28-2012)
The Following User Says NO Thank You to ericdebruyn1 For This Un-useful Post:
 Old 08-20-2012, 08:54 PM   #1419
Stangcobra's Avatar
Groans: 51
Yep 215/40s on a 9.5 is gay as fuck, thats why I went 215/35s on a 9
also uh...did you just say you shit yourself in front of some girl? what the fuck are you talking about
I am a huge faggot
 Old 08-20-2012, 09:01 PM   #1420
jrdm91's Avatar
Posts: 10   (View Stats)
jrdm91 will become famous soon enoughjrdm91 will become famous soon enough
Originally Posted by silversurfer3 View Post
This is exactly where I want to get to! Looking good!
jrdm91 is offline   Reply With Quote
The Following User Says Thank You to jrdm91 For This Useful Post:
 Old 08-20-2012, 09:02 PM   #1421
apawk's Avatar
Posts: 606   (View Stats)
Groaned at 8 Times in 4 Posts
Yep. Looks good!! What offset?
PERM Tuned by Alan and DJ
 Old 08-20-2012, 09:03 PM   #1422
Stangcobra's Avatar
Groans: 51
sexy, once my 215s are done I plan to go with some meaty 255s
I am a huge faggot
 Old 08-21-2012, 05:02 PM   #1423
Did I just read about someone shitting their pants in night school?
 Old 08-21-2012, 08:01 PM   #1424
Neverlift's Avatar
Groans: 1,143
Did I just see some faggot put Di-noc on his hatch and hood. Kill yourself.
 Old 08-21-2012, 10:04 PM   #1425
tigermack's Avatar
Groans: 78
IIRC, those are CF hood and hatch...
 Old 08-22-2012, 05:52 AM   #1426
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
@Stangcobra Do you realize why you got flamed in the first place? It wasnt just because you are riding on Rotas, its because you claimed you didnt want to be unsafe on the road. Now, when your entire setup is build with some of the parts on the market which are most prone to failure, then you present a threat to other motorists on the road.That is the initial reason you were initially flamed, Yes part of that is because you ride Rotas. They are a known failure among the entire market. Take it as you will. You cannot argue that fact.
On a side note, you are still a faggot. And yes i am riding on a set of Sonic Tuning wheels, They are cheap and get the job done, how many Sonic failures have you heard of?
Want to know what the last set of rims i owned was? A set of Work VSXX with tiffany blue faces, 17x9.5 front and 17x10.5 rear. Ask anyone, those are not cheap.
700HP CLUB
11.479@124mph
#DIX
 Old 08-22-2012, 07:28 AM   #1427
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
Stil ugly though...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 08-22-2012, 07:38 AM   #1428
Downmented's Avatar
Groans: 493
Stil ugly though...
Beautiful wheels, wrong car.
700HP CLUB
11.479@124mph
#DIX
 Old 08-22-2012, 07:39 AM   #1429
SketchyMark's Avatar
Posts: 96   (View Stats)
SketchyMark is the leader of the worldSketchyMark is the leader of the worldSketchyMark is the leader of the worldSketchyMark is the leader of the worldSketchyMark is the leader of the worldSketchyMark is the leader of the worldSketchyMark is the leader of the worldSketchyMark is the leader of the worldSketchyMark is the leader of the worldSketchyMark is the leader of the worldSketchyMark is the leader of the world
SketchyMark is offline   Reply With Quote
The Following 3 Users Say Thank You to SketchyMark For This Useful Post:
Downmented (08-22-2012), Pope (08-22-2012), ZoomByU (08-24-2012)
 Old 08-22-2012, 07:59 AM   #1430
Pope's Avatar
Posts: 683   (View Stats)
Pope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the world
Groans: 51
Groaned at 40 Times in 28 Posts
Originally Posted by SketchyMark View Post
let me say love it! black n white pic ftw, also what wheels are those
1.5 millions posts here. Every question you ever had about this car, has been answered...
I suggest you start reading the forum in depth. This community is nothing like you have ever joined before.
its sexiest..
its perverted
its racist
its all performance
And somehow, it all manages to work.
Pope is offline   Reply With Quote
 Old 08-22-2012, 08:12 AM   #1431
Jo3f1sh's Avatar
Look like Rota Grids.
The Following User Says Thank You to Jo3f1sh For This Useful Post:
Stangcobra (08-22-2012)
 Old 08-22-2012, 08:35 AM   #1432
thanks man! yeah there grids
The Following User Says Thank You to SketchyMark For This Useful Post:
 Old 08-22-2012, 09:24 AM   #1433
Stangcobra's Avatar
Groans: 51
OMG ROTAS YOURE A FAGGOT AND YOUR CAR IS UNSAFE
it looks clean man, I like it a lot
I am a huge faggot
 Old 08-22-2012, 09:32 AM   #1434
Haha Thanks dude
2012FailWheelDrive (11-17-2012)
 Old 08-22-2012, 11:41 AM   #1435
Jo3f1sh's Avatar
Way too much camber in the rear for my taste. And those tires are absolutely tiny on those wheels.
Not my cup of tea.
 Old 08-22-2012, 01:04 PM   #1436
tigermack's Avatar
Groans: 78
Since there are so much heat going on... I feel like typing some bullshit. lol
Rotas are fine, just that people dislike the fact they are knock-offs. A lot of time attack teams use them and have no problems, they go through more abuse than any of us with their wheels/cars. Why hate? I mean, Rotas aren't exactly cheap now, they are like $850 a set? They used to be $500-600! The reason why there are so many articles about Rota cracking is because they are most hated company and they are successful knocking off those $2-3K set wheels. People want to bring them down! To be honest, how many people would want to buy a set of wheels and not have much else done to their car? You can buy Rotas and have plenty of other mods done compare to buying a set of Volks...
If you guys wanna knock on somebody, knock on the people who paint/powdercoat their fucking stock wheels. NOW, that's a waste of money for no fucking upgrade what-so-ever!
I still think rubberbands are gay and the amount of camber added to compensate for a set of wheels that you can't fit is just DUMB. I just don't like the fact people uses a car to look cool...
Nliiitend1, Design and NoRegrets like this.
The Following 6 Users Say Thank You to tigermack For This Useful Post:
Design (08-24-2012), ericdebruyn1 (08-24-2012), Nliiitend1 (08-22-2012), SketchyMark (08-22-2012), Stangcobra (08-22-2012), ZoomByU (08-24-2012)
 Old 08-22-2012, 08:11 PM   #1437
dastpe's Avatar
Posts: 1,644   (View Stats)
[/IMG]
no one has heard of sonic wheels failing because the few have even heard of sonic...and my biggest complaint with them is that the wheels are heavy. i am biased, but using stock wheels from other cars works awesome.
The Following 2 Users Say Thank You to dastpe For This Useful Post:
Downmented (08-22-2012), Nliiitend1 (08-22-2012)
 Old 08-22-2012, 08:27 PM   #1438
:: Gusto ::'s Avatar
Posts: 1,455   (View Stats)
okay.. . so rota's are mid priced knock offs. .. what are xxr wheels? ...cheap whores?!
heh
yea yea - i know i cant spell
 Old 08-24-2012, 06:17 PM   #1439
I agree don't hate.... I had Rotas on my civic, they looked good wernt too heavy didn't have any problems tell I spun out and drilled a curb going 60 but the rims was the least of my problem, I have nothing against them
 Old 08-28-2012, 10:55 AM   #1440
Boostman07's Avatar
Posts: 229   (View Stats)
Boostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond repute
17x8 unknown brand or offset.. guessing by how they sit I'm thinking +38. They came off of my buddies gsx. It blew up.. surprise.
tappy tap
09 MS3 GT
Fully Bolted
50/50 e85 Richtune
Boostman07 is offline   Reply With Quote
The Following User Says NO Thank You to Boostman07 For This Un-useful Post:
SLOWHATCH (08-28-2012)
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Page generated in 0.58988 seconds with 40 queries
