Like Tree455Likes
 Old 02-25-2013, 06:06 PM   #1721
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
El Toro is across the street from me. However, I need a clutch, diff mounts, and a none smoky k04. Not to mention the concrete runway you guys run on would kill a set of tires.
I'm not making excuses, I just don't see it happening. But I do appreciate the call out and challenge.
My focus this year is rallyx, and getting the ball rolling on some rally events next year in a AW11 MR2. If I were in the financial situation I was before I purchased this failboat MS6, it would be prepped for the Street Class (400whp) @ eXtremespeed AWD Time Trails... but such is life. Maybe next year on that too.
Past Mazdas & Speeds
The Following User Says NO Thank You to Neverlift For This Un-useful Post:
tigermack (03-19-2013)
 Old 02-25-2013, 06:15 PM   #1722
justint5387's Avatar
Posts: 608   (View Stats)
justint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the world
El Toro isn't too hard on tires and we running around in 2nd gear anyways.
Oh btw, Ford ST test drives champion (should have that on your signature). That course you did is a terrible example of an autox...
justint5387 is offline   Reply With Quote
The Following 3 Users Say Thank You to justint5387 For This Useful Post:
dastpe (02-26-2013), Doberman (02-25-2013), tigermack (02-25-2013)
 Old 02-25-2013, 06:22 PM   #1723
Neverlift's Avatar
Groans: 1,143
I know, it was just funny to see. Haltech asked me to come along and put down a proper lap time so we could say MSF had driven an ST faster and harder than anyone. So I obliged. He was the one recording that video. That's only time I have ever done an autocross, and the hardcore competitors there were not pleased to hear it was my first time. I think the loose (pebbles) surface definitely played into my hand.
If I can get a car, I will be there, but the MS6 is barely road worthy right now. Burns a quart of oil <100miles. The PP has slipped ever since I put in the new engine w/ the new oem disk, and now the diff mounts have completely shit the bed.
 Old 02-25-2013, 08:57 PM   #1724
If you never done a real autocross, you shouldn't bash autocross.
How do you know what it is about? Just cause you read about it on the internet? You live next to one of the best autocross site in the country... Maybe after all your lame excuses are fixed, bring your car out there, get your ass whopped, then you will know what it's about...
The Following User Says Thank You to justint5387 For This Useful Post:
 Old 02-25-2013, 09:45 PM   #1725
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Originally Posted by Neverlift View Post
255's are completely unnecessary on a 6 on that is street driven.
LOL glad I didn't have to say it. Though I've come across competitors who run wider in front to offset weight bias. Tire compound only goes so far...
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
 Old 02-26-2013, 01:35 PM   #1726
Neverlift's Avatar
Groans: 1,143
Car control @ 40-60mph is not something I need practice with. You might, but I find no thrill in tossing a car around a flat parking lot. I like consequences, elevation changes, mid corner bumps, and things that resemble an actual challenge.
The Following 2 Users Say Thank You to Neverlift For This Useful Post:
chuckms6 (02-26-2013), Downmented (02-26-2013)
tigermack (02-26-2013)
 Old 02-26-2013, 01:51 PM   #1727
Lol, you keep stating the same thing and you never been to an autox.... Your car control at 40-60mph may not be as good as you keep implying. All I see is straightlining thru esses on your mountain road videos in a MSM in middle of 3rd and 4th gear at no more than 70mph.
Have you even done a track event? I go to track days too, just because they are higher speed, doesn't make it more challenging. 90% of the tracks mostly consits of just sweepers and esses, going thru them at 90mph-100mph is much easier than going thru transitions at 50-60mph.
Maybe if you went to an autocross, you would know.
The Following 2 Users Say Thank You to justint5387 For This Useful Post:
dastpe (02-26-2013), tigermack (02-26-2013)
 Old 02-26-2013, 02:16 PM   #1728
Neverlift's Avatar
Groans: 1,143
Well, that video is almost 2 years ago and about 6 months into owning the MSM. Long before I owned the NA I kept on 195/50 all seasons and ran only downhill and finally learned proper braking (no ABS). But yeah, cornering @ 60-65 and hitting 80 on the straights. Pretty decent for mostly single lane action despite the camera angle making it look more aggressive.
Like I said before, rally is where I would like to go. Tossing a car through multiple turn sections is definitely more ideal than that of a track or autox.
5 days into owning the MS6. Sorry I don't have the triple digit in the dirt run from later that day... Hamilton accidently deleted it.
Outside my buddies shop just foolin' around with entries...
 Old 02-26-2013, 02:19 PM   #1729
dastpe's Avatar
Posts: 1,644   (View Stats)
im not sure if you saw his sig where it says he has the Semi Pro driver mod...you may want to back off the lateral G specialist. i also remember one of the autocross guys running 275s up front. pics of that would be awesome!
 Old 02-26-2013, 02:22 PM   #1730
Neverlift's Avatar
Groans: 1,143
The sig is a joke. Silva told me to put it in there since its my best mod.
The Following User Says Thank You to Neverlift For This Useful Post:
silvapain (03-03-2013)
 Old 02-26-2013, 02:31 PM   #1731
Should change it ST Focus champ
Neverlift (02-26-2013), tigermack (02-26-2013)
 Old 02-27-2013, 10:40 PM   #1732
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
h.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the world
Groans: 24
Snapped a few pix today. Need to get a new front lip on there, the old one got owned by a pile of snow
Old stuff: Stock k04 12.301 @ 113.20
New Stuff: PTE 5858 and Built, not bought, by ME
h.h.sk1nny is offline   Reply With Quote
The Following 5 Users Say Thank You to h.h.sk1nny For This Useful Post:
baardoon (03-25-2013), BobtailedSnail (02-28-2013), caesura (02-27-2013), Downmented (03-01-2013), Funkster777 (03-07-2013)
 Old 03-02-2013, 08:16 AM   #1733
luv2gorealfast's Avatar
Posts: 7   (View Stats)
luv2gorealfast will become famous soon enough
first pics were with 235/40/18 rubber
Last pics are with 245/40/18
Wheels are 18X8 +35
luv2gorealfast is offline   Reply With Quote
The Following User Says Thank You to luv2gorealfast For This Useful Post:
Doberman (03-02-2013)
 Old 03-02-2013, 11:22 PM   #1734
chuckms6's Avatar
Posts: 1,618   (View Stats)
Just got some infiniti g35 reps from Oewheelsllc.com
18x9 +45 with a 1/4 spacer
Repainting them silver and polishing the lips, still not done. I'm keeping my 225/45/18's till they wear out then going 245/40.
Tapatalking
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
The Following User Says Thank You to chuckms6 For This Useful Post:
dastpe (03-03-2013)
 Old 03-06-2013, 08:29 AM   #1735
We Are Ninja's Avatar
Posts: 50   (View Stats)
We Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant future
We can derail this lame thread all you want with personal attacks. My point was, 255's are unnecessary on a street driven ms6. I am not speculating, I am just telling you how it is. The dampers, bushings, and brakes are all going to need to be upgraded before you attempt to take advantage of a proper tire on a road course.
Can you do it, sure. Is it ideal, not exactly.
Which bushings are you referring to? I'm not trolling; I'm modding my suspension (and eyeing a set of 245/40/18's) and am genuinely curious...
We Are Ninja is offline   Reply With Quote
 Old 03-06-2013, 05:13 PM   #1736
Neverlift's Avatar
Groans: 1,143
Control arm & trailing arm bushings.
 Old 03-06-2013, 06:20 PM   #1737
ms6-145k's Avatar
Posts: 32   (View Stats)
ms6-145k has much to be proud ofms6-145k has much to be proud ofms6-145k has much to be proud ofms6-145k has much to be proud ofms6-145k has much to be proud ofms6-145k has much to be proud ofms6-145k has much to be proud ofms6-145k has much to be proud ofms6-145k has much to be proud of
ms6-145k is offline   Reply With Quote
The Following 6 Users Say Thank You to ms6-145k For This Useful Post:
4G63 (03-07-2013), Doberman (03-07-2013), h.h.sk1nny (03-06-2013), mazdafreak (03-07-2013), Rokusek (03-07-2013), stuntz89 (03-10-2013)
The Following 3 Users Say NO Thank You to ms6-145k For This Un-useful Post:
Manny (03-07-2013), Neverlift (03-06-2013), tigermack (03-19-2013)
 Old 03-07-2013, 01:49 AM   #1738
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Originally Posted by ms6-145k View Post
What wheels are those?? They better be real, not rotas or some cheap shit.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 03-07-2013, 03:37 AM   #1739
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
Well, they are real Evo X GSR wheels, if that counts.
The Following User Says NO Thank You to 3Gee Tee For This Un-useful Post:
Neverlift (03-08-2013)
 Old 03-07-2013, 03:44 AM   #1740
4G63's Avatar
Posts: 1,479   (View Stats)
4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world
Groans: 123
Groaned at 157 Times in 79 Posts
Yea dawg Rota's suck
Idiot
2003 Evo VIII
BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever.
Old: 2009 White MS3. Fully bolted and tuned. Sold
4G63 is offline   Reply With Quote
The Following 3 Users Say Thank You to 4G63 For This Useful Post:
3Gee Tee (03-07-2013), bstover17 (03-07-2013), chuckms6 (03-07-2013)
The Following 2 Users Say NO Thank You to 4G63 For This Un-useful Post:
mazdafreak (03-07-2013), Neverlift (03-08-2013)
 Old 03-07-2013, 03:49 AM   #1741
Slash's Avatar
Posts: 110   (View Stats)
Slash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the world
Those Fucking stripes I don't know how you thought that was a good idea, but I'm glad you did because they look amazing haha!
AT Internals/Cobb AP/NGK LTR7IX/CS SRI/CS TIP/CS TP/CX Racing FMIC/Cobb XLE 50-50/JBR Rmm and Weight/Hankook Ventus v12/18x8.5 Rota Grids
13.39 at 103.35 in the 1320. Allegedly ~290WHP/~370WTQ
Tuned by The FREEK
Slash is offline   Reply With Quote
 Old 03-07-2013, 08:22 AM   #1742
mazdafreak's Avatar
Groans: 124
Rly? They dont look like them.....The spokes like they stick out and concave too much.....idk.
Idiot
Still cheap rotas faggot.....Did I say they suck? No.
Idiot.
713whp/569wtq!
 Old 03-07-2013, 08:30 AM   #1743
naoandlater's Avatar
Posts: 655   (View Stats)
naoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the world
Got Rota G Force 18x9 +30 offset
@mazdafreak; @3Gee Tee;
07 True Red Mazdaspeed 3 GT - Totaled 2/7/2015
15 Soul Red Mazda3s GT HB
naoandlater is offline   Reply With Quote
The Following User Says Thank You to naoandlater For This Useful Post:
 Old 03-07-2013, 08:35 AM   #1744
3Gee Tee's Avatar
Thanks, they look pretty similar since X wheels have similar specs (18x8.5 +38).
 Old 03-07-2013, 09:16 AM   #1745
4G63's Avatar
Groans: 123
Idiot.
Your running Evo wheels on your Mazda. You lose
2003 Evo VIII
Doberman (03-07-2013), Pseudonym (03-07-2013)
 Old 03-07-2013, 09:18 AM   #1746
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
*You're*
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 03-07-2013, 09:23 AM   #1747
4G63's Avatar
Groans: 123
Neutral  -1 score
*You're*
*Likes dick*
2003 Evo VIII
 Old 03-07-2013, 10:26 AM   #1748
3Gee Tee's Avatar
Says the Evo driver on the Mazda forums, lol.
 Old 03-07-2013, 11:10 AM   #1749
dastpe's Avatar
guys run FD wheels all the time on evo drag cars
 Old 03-07-2013, 11:10 AM   #1750
4G63's Avatar
Groans: 123
I had a Speed 3 a year ago. I stay around to keep the slow in check
The Following User Says NO Thank You to 4G63 For This Un-useful Post:
 Old 03-07-2013, 11:26 AM   #1751
mazdafreak's Avatar
Groans: 124
Actually im not. That was old setup. You lose.
713whp/569wtq!
 Old 03-07-2013, 11:41 AM   #1752
4G63's Avatar
Groans: 123
You shut your God damn mouth lol. I know this it goes to the point of saying something is cheap or "faggot" like when I'm actuality it's further from the truth. I was being sarcastic.
2003 Evo VIII
 Old 03-07-2013, 11:55 AM   #1753
dastpe's Avatar
Haha. The way I look at it is I decreased the weight and increased the width of my wheels from stock, so that's a huge plus. The fact that its from another car bothers me not at all. That being said, don't you run stock wheels on your Evo?
 Old 03-07-2013, 12:12 PM   #1754
3Gee Tee's Avatar
Meh, my X wheels have Mazda center caps on them, lol.
The Following User Says Thank You to 3Gee Tee For This Useful Post:
4G63 (03-07-2013)
 Old 03-07-2013, 12:54 PM   #1755
Nliiitend1's Avatar
Groans: 67
*Likes dick*
2008 MS3 GT
2016 MX-5 Club
4G63 (03-07-2013)
 Old 03-07-2013, 03:41 PM   #1756
ms6-145k's Avatar
haha thanx, i dnt know i just wanted to do something i guess, but its plasti dip, i can peal it off anytime...
 Old 03-07-2013, 03:54 PM   #1757
Pseudonym's Avatar
Posts: 1,429   (View Stats)
Pseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the world
u need to continue that stripe up the pillar and maybe black that roof out. ive got a black cherry and was thinking of doing a flat black stripe like that but we'll see.
Pseudonym is offline   Reply With Quote
 Old 03-07-2013, 04:20 PM   #1758
ms6-145k's Avatar
Yeah i was thinking about blacking that pillar too, the roof is already black
The Following User Says NO Thank You to ms6-145k For This Un-useful Post:
 Old 03-09-2013, 04:20 PM   #1759
keeganb's Avatar
Posts: 13   (View Stats)
keeganb will become famous soon enoughkeeganb will become famous soon enough
Default wheel and tire fit 2010 speed3
stock suspension. was lookin a the konig lace rims. 18x8 +45. what size of tire will i have to run without having rub issues or having to roll my fenders? thanks
keeganb is offline   Reply With Quote
 Old 03-09-2013, 09:01 PM   #1760
Boost Addict's Avatar
Posts: 1,327   (View Stats)
New setup rear shot 17x9.5 et29, camber arms are on the way.
FREEKTUNE
The Following 3 Users Say Thank You to Boost Addict For This Useful Post:
Bob-o (03-10-2013), dastpe (03-10-2013), ZoomByU (03-13-2013)
Page generated in 0.60391 seconds with 38 queries
