Like Tree455Likes
 Old 03-26-2013, 10:01 PM   #1841
:: Gusto ::'s Avatar
Posts: 1,455   (View Stats)
Originally Posted by MS3LUKE View Post
Yes
Thats the exact fitment I want
It still performs just fine
try the... Mazda fitment forum
yea yea - i know i cant spell
 Old 03-28-2013, 03:24 PM   #1842
7th Initial's Avatar
Posts: 316   (View Stats)
7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world
Groaned at 20 Times in 4 Posts
I'm going to be running some 18x8.5 +35 offset, but I'm not totally sure on what kind if tire to run. I was thinking a 225/40/18 buying want the little bit of finger gap in the rear to be filled up so maybe 225/45/18's? The rear are rolled some, after running 18x7.5 with 225/40/18s.
90 Miata Shift extender // Megan EZ Streets // M2 exhaust // Racingbeat intake // Turn Signal Intakes // Autokonexion GT Panels // Autokonexion Aero Fronts // Rota Kyusha 15x9 -15 205/50/15 // Sickspeed lugs // Custom Diffuser // GV Lip
08 Mica MS3 SURE TIP // SURE Intake // Custom Diffuser // Shifter Extender // AUTOTECH HFFP // APV3 // COBB Knob // YellowSpeed Coils // 17x9 RPF1s
08 True Red MS3 SOLD COBB SRI // CS-CA Box // RaceLand Coils // BC Racing BR Coils // Varrasteon ES221 // 5ZIGEN lugs // SURE RMM // TurboSmart Duelport // SU TestPipe // CNT CB // JRB SSP // JRB Knob // CXRacing FMIC // SUPER Tones // 2Nine Rear Diffuser // Nextmod lip // STI V-limited // Prosport BG
7th Initial is offline   Reply With Quote
 Old 03-28-2013, 03:31 PM   #1843
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Tyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the world
18x8 +35 215/45's. Needed a roll in the back, stock height
edit: I'll post the original, that one is pretty dark
SOLD 2008 MS3 17x8 Evo 9's, 235 v12
1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat
2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD
Tyhackman15 is offline   Reply With Quote
The Following User Says Thank You to Tyhackman15 For This Useful Post:
Rokusek (04-08-2013)
 Old 03-28-2013, 03:46 PM   #1844
dastpe's Avatar
Posts: 1,644   (View Stats)
my rear is that exact width and offset with 235s. dont run 225/45s for crying out loud. i feel like i just should post this on repeat.
1.) roll fenders flat
2.) slightly pull fenders
3.) trim rear bumper tab
chewed up wheel edge much? and get some bigger rubber than 215. and go low. then maybe, just maybe you would qualify for aggressive.
The Following User Says Thank You to dastpe For This Useful Post:
Downmented (03-28-2013)
 Old 03-28-2013, 03:55 PM   #1845
Bought them for cheap and will refinish in summer, but thanks for noticing. And no thanks, not going lower as I already nearly scrape going up my driveway. Not going to sacrifice practicality
 Old 03-28-2013, 04:08 PM   #1846
So 235/40's, I sit pretty low. How about the front?
 Old 03-28-2013, 07:11 PM   #1847
dastpe's Avatar
okay. so we agree you are not aggressive.
let me correct myself from my earlier post. front is 8.5 with a +35 and 235s and rear is +33 with 235s. that doesnt negate the fact that youll need everything mentioned before to fit them. the fronts will be fine, no modification needed.
 Old 03-30-2013, 11:15 AM   #1848
Doberman's Avatar
Posts: 269   (View Stats)
Doberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the world
Yes
By just fine do you mean has no traction and is prone to sliding? Because in that case you are correct. -9 degrees is retarded.
Doberman is offline   Reply With Quote
The Following User Says Thank You to Doberman For This Useful Post:
Downmented (03-30-2013)
 Old 04-01-2013, 08:54 PM   #1849
madspd6's Avatar
Posts: 1,009   (View Stats)
madspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the world
Groans: 31
So i played with my coils and camber and...
then i lifted it right the fuck back up because potholes.
Velocity Red Mica 06 Speed6 (ricer) #834
Some shitty; s300sx fmw turbo, home made fmic setup, home made 4" Intake, 3.5 blowthrough maf, home made downpipe, poorly self tuned. More motor mounts then necessary.
Gay and coated white enkei rpf1s with stupid 245/45 tires. Pointless drilled and slotted rotors. Clunky coilovers. Ricer lips and lights.
madspd6 is offline   Reply With Quote
The Following 5 Users Say Thank You to madspd6 For This Useful Post:
:: Gusto :: (04-09-2013), Bob-o (04-01-2013), ckMS3 (04-12-2013), Downmented (04-02-2013), Rokusek (04-08-2013)
 Old 04-02-2013, 04:54 AM   #1850
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
@madspd6; Specs on wheels?
700HP CLUB
11.479@124mph
#DIX
 Old 04-02-2013, 05:52 AM   #1851
madspd6's Avatar
Groans: 31
18x9 +35
When I bought them I thought it was a little much but I like em.
The Following User Says Thank You to madspd6 For This Useful Post:
 Old 04-02-2013, 05:57 AM   #1852
Downmented's Avatar
Groans: 493
Originally Posted by madspd6 View Post
18x9 +35
What size tires?
700HP CLUB
11.479@124mph
#DIX
 Old 04-02-2013, 07:08 AM   #1853
madspd6's Avatar
Groans: 31
They are 235/40 neuton nt5000's. They have made it through 1.5 summers already and they look like they have another 2 left in then. They are an eco+ tire and pretty hard. Not the best handeling or grippy tire but for DD purpouses and only costing me 400$ for a set! I really can't complain.
 Old 04-03-2013, 11:13 AM   #1854
NICKELL666's Avatar
Posts: 566   (View Stats)
NICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the world
18x8.75 +35. I have some fender work to do
09 MS3: Cobb AP; Autotech HPFP; HTP 3" Intake; CP-E TMIC; GFB Respons; NGK Iridium IX; M2 Catless DP; TurboXS cbe; JBR 88a; JBR SSP; Ralco RZ STS; Aeroforce Interceptor; Defi Red Racer; Racelands v2(until I have issues); SPC camber arms; 18x8.75 +35; 215/40/18; Freek Tune; 50/50 Corn
NICKELL666 is offline   Reply With Quote
The Following User Says Thank You to NICKELL666 For This Useful Post:
Doberman (04-03-2013)
 Old 04-04-2013, 05:11 PM   #1855
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
17x9 +45
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
The Following 6 Users Say Thank You to ckMS3 For This Useful Post:
:: Gusto :: (04-18-2013), Boost Addict (04-04-2013), Rokusek (04-04-2013), rwelsh (04-09-2013), taf0422 (04-04-2013), Vader (04-08-2013)
 Old 04-04-2013, 05:13 PM   #1856
Rokusek's Avatar
Posts: 5,551   (View Stats)
Originally Posted by ckMS3 View Post
17x9 +45
Fucking tits!!! I love this look!!!
ckMS3 (04-04-2013)
 Old 04-04-2013, 05:16 PM   #1857
ckMS3's Avatar
Thanks a bunch. Yours is looking good too sir.
The Following User Says Thank You to ckMS3 For This Useful Post:
Rokusek (04-05-2013)
 Old 04-04-2013, 05:16 PM   #1858
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
17x9 +45
255's??
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 04-04-2013, 05:16 PM   #1859
ckMS3's Avatar
255's??
245/45 nitto 555r
taf0422 likes this.
The Following 2 Users Say Thank You to ckMS3 For This Useful Post:
Rokusek (04-05-2013), taf0422 (04-04-2013)
 Old 04-04-2013, 05:19 PM   #1860
taf0422's Avatar
Groans: 192
245/45 nitto 555r
Nice!! Looks beastly. I was going to go 245/40 next.
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
ckMS3 (04-04-2013)
 Old 04-04-2013, 05:21 PM   #1861
Boost Addict's Avatar
Posts: 1,327   (View Stats)
245/45 nitto 555r
Looks tough as shit, nice work.
ckMS3 likes this.
FREEKTUNE
The Following User Says Thank You to Boost Addict For This Useful Post:
ckMS3 (04-04-2013)
 Old 04-04-2013, 05:23 PM   #1862
ckMS3's Avatar
Do it! I should have gotten that size because now I rub like a mofo in the rears with a roll and small pull.
taf0422 likes this.
 Old 04-04-2013, 05:45 PM   #1863
Boostman07's Avatar
Posts: 229   (View Stats)
Boostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond repute
17x9 +45
Love the stance, I was nervous about going with 245/45's, but looks great.
tappy tap
09 MS3 GT
Fully Bolted
50/50 e85 Richtune
Boostman07 is offline   Reply With Quote
 Old 04-05-2013, 08:04 AM   #1864
Alright anyone whos running a pretty low setup, do you still have the front fender well plastics on? I got my new mounted with tires yesterday and it just rubs crazy on those plastics.
 Old 04-05-2013, 08:10 AM   #1865
Downmented's Avatar
Groans: 493
Nope, get rid of those shits.
Rokusek likes this.
700HP CLUB
11.479@124mph
#DIX
The Following 2 Users Say Thank You to Downmented For This Useful Post:
7th Initial (04-05-2013), Rokusek (04-08-2013)
 Old 04-05-2013, 11:11 AM   #1866
NICKELL666's Avatar
I still have mine.. Rub every time I hit a bump though. I was wondering the same thing.
 Old 04-07-2013, 08:12 AM   #1867
Anyone have pics of their notched/shaved rear after fitment issues?
 Old 04-07-2013, 10:19 AM   #1868
dastpe's Avatar
there is a thread on doing it. i think the guy was fitting evo wheels.
 Old 04-08-2013, 05:40 AM   #1869
Okay for all though's who wonder where they need to shave I have finally found a picture of someones shave job.
" My MGM MS3 with EVO X wheels ".
- It's about half way down the page.
 Old 04-08-2013, 10:20 AM   #1870
MPS_Mike's Avatar
Posts: 1   (View Stats)
MPS_Mike is an unknown quantity at this point
Hey Madvillain I am looking to do a very similar set up to my MS3 is there anyway you can tell me the size of the stuff you're running it would help guide me a million times better. There is so much information out here and ive narrowed it down. i want a fitment just like that!
Thank you for your time.
MPS_Mike is offline   Reply With Quote
 Old 04-08-2013, 12:52 PM   #1871
Rokusek's Avatar
I really want to see someone fit something like these on a speed for daily but with street tires...
 Old 04-08-2013, 01:21 PM   #1872
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
Diamond Racing makes wheels like that, but I don't think they make anything large than 16"...
Home
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Tomas (04-08-2013)
 Old 04-08-2013, 01:28 PM   #1873
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
^ That is correct. They don't.
16"s apparently clear the stock front calipers on the circumference. Not sure they would horizontally if they were made like above pic however.
Nliiitend1 (04-08-2013)
 Old 04-08-2013, 01:35 PM   #1874
Rokusek's Avatar
@doubleflusher; fit 16's with no problems last year, and i think he was even able to fit a 15 as well... I have always loved the way that looks on car, esecially seeing them on miatas.
I wanna see someone do that for a daily and pull it off... or maybe even just for track use i think would be sick. I just dont have the balls to spend the money on that kind of set up.
 Old 04-08-2013, 01:51 PM   #1875
Posts: 20,650   (View Stats)
Groans: 1,443
16's fit without issue.
15's fit with spacers and a little caliper shaving.
Rokusek likes this.
The Following 3 Users Say Thank You to doubleflusher For This Useful Post:
Nliiitend1 (04-08-2013), Rokusek (04-09-2013), Tomas (04-08-2013)
 Old 04-09-2013, 12:39 PM   #1876
NICKELL666's Avatar
I removed the back part of my fender liner and flattened the seam in the wheel well. No more rub!
The Following 2 Users Say Thank You to NICKELL666 For This Useful Post:
mazdafreak (04-23-2013), Rokusek (04-09-2013)
 Old 04-09-2013, 01:25 PM   #1877
Rokusek's Avatar
what is that on the fender below the blinker?
 Old 04-09-2013, 01:31 PM   #1878
NICKELL666's Avatar
mazdaspeed "badge" thing.. I dunno. They were on the car when i bought it..hell I never even noticed that other ones didn't have it until just now
 Old 04-09-2013, 07:19 PM   #1879
18x9 +35
looks really clean..nice
 Old 04-09-2013, 08:55 PM   #1880
what tires you running Nickell? Those XXR's are 18x8.75 correct?
Page generated in 0.59280 seconds with 37 queries
