Like Tree455Likes
 Old 01-21-2014, 03:36 PM   #2161
:: Gusto ::'s Avatar
Posts: 1,455   (View Stats)
Thumbs up
your car looks so TOUGH!!
super jealous - what suspension are you running again?
yea yea - i know i cant spell
Downmented (01-21-2014)
 Old 01-21-2014, 04:19 PM   #2162
Scare Dem's Avatar
Posts: 1,505   (View Stats)
Scare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the world
Originally Posted by GOT 2RBO View Post
Finally test fitted my Wedssports and took some pics. Yokohoma tires coming in the next few weeks, hope to have the wheels on by first weekend in March.
Specs please.
2008 Mazdaspeed3 GT
GTX2867r
Scare Dem is offline   Reply With Quote
 Old 01-21-2014, 05:04 PM   #2163
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Currently on BCs. I need to install the sbc ball joints and get an alignment. Im waiting on my 15mm spacers to get here, then the final offset for front and rear will be +30
700HP CLUB
11.479@124mph
#DIX
 Old 01-21-2014, 06:28 PM   #2164
GOT 2RBO's Avatar
Posts: 355   (View Stats)
GOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the world
18x9" +35
GOT 2RBO is offline   Reply With Quote
 Old 01-26-2014, 11:17 AM   #2165
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
@Downmented; I've always wanted my RPF1's to be 18's. You sir, have just changed my mind. Never seen a 6 pull off 17's so good.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
Downmented (01-26-2014)
 Old 01-26-2014, 11:23 AM   #2166
afronese1's Avatar
Posts: 73   (View Stats)
afronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant future
I was thinking the same thing. Yea he definitely pulled it off with the 17s.
MS6/SP63 Stage 1 build/APv3/BNR S4 v2/hpfp internals/JBR full 3" intake/ATP catted dp/Magnaflow cbe/GFB bov/Damond OCC/Damond egr delete/Treadstone TR1035 FMIC kit/CPE rear diff mount/CPE safe seals/Damond rmm/H&R co/18x9 conti dws 235-40/Stoptech bbk/morimoto xb led fogs/Osram Xenarc d2s 6000K bulb/osram led parking light/Led Tails/Purple Drank Tuned
afronese1 is offline   Reply With Quote
The Following User Says Thank You to afronese1 For This Useful Post:
 Old 01-26-2014, 09:12 PM   #2167
Enter the 36 Chambers
NoRegrets's Avatar
Posts: 612   (View Stats)
NoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the world
specs in signature 42 offset
Originally Posted by wassup61 View Post
Blood is good, it feeds your gremlin so your motor doesn't blow. A week without flesh and it will start consuming rods
Tuned by Nishan
GTX3071r : Tial MV-S 38mm ewg : COBB AP : Stratified ebc : CP-E HPFP : CP-E Safe seals : COBB fmic v2 : HKS bov : HTP 4" intake w/battery tray : DNP turbo mani : ATP catless dp : Mazdaspeed cbe : JBR trilogy : TWM sts : MattDamond occ v2 : NGK6510's : Eibach Prokit : Koni Yellow's : Corksport front endlinks : Corksport RSB : JBR EGR Delete : Kozmic Motorsports Primary EGR Delete : TB coolant bypass : Relentless Customs PnP intake mani : Bosch 3 Bar Map Sensor : Bitwise Motorsports Bosch MAP Sensor Connector : South Bend stg3 endurance clutch : 17x8 Enkei TSP5 : Hankook v12 245/45
SP63 Longblock
Head= Mild bowl work as well as mild porting on intake/exhaust.
Bottom end= SP63 Weisco 9.5:1 - 87.5mm : Head Studs 10mm L19 : Manley H-Beam : Rod Bolts ARP Custom Age 625 : Coated Clevite Main & Rod Bearings
NoRegrets is offline   Reply With Quote
The Following User Says Thank You to NoRegrets For This Useful Post:
rymanmazda (01-26-2014)
 Old 01-27-2014, 02:36 PM   #2168
Downmented's Avatar
Groans: 493
Well, i was about to put the car away today and figured id have the wifey snag a few pics with her schnazzy new camera.
Rokusek likes this.
700HP CLUB
11.479@124mph
#DIX
The Following 13 Users Say Thank You to Downmented For This Useful Post:
6Y MAZDA (02-02-2014), ckMS3 (01-27-2014), Domino81 (01-27-2014), Mazdazilla6 (01-28-2014), NoRegrets (01-27-2014), nrankin01 (03-04-2014), Quigs (01-30-2014), redboat (02-03-2014), Rokusek (02-10-2014), rymanmazda (01-27-2014), sidekick (02-02-2014), speed3 britz (01-29-2014), Status Update (01-27-2014)
 Old 01-27-2014, 11:01 PM   #2169
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
h.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the world
Groans: 24
This aint pullin it off? 17x8 pf01 at the moment, but will be rockin 17x9 rpf1s shortly. I will get some more recent photos up soon. Currently rockin the winter setup
Mazdazilla6 likes this.
Old stuff: Stock k04 12.301 @ 113.20
New Stuff: PTE 5858 and Built, not bought, by ME
h.h.sk1nny is offline   Reply With Quote
The Following 3 Users Say Thank You to h.h.sk1nny For This Useful Post:
Mazdazilla6 (01-28-2014), Rokusek (02-10-2014), Status Update (01-28-2014)
 Old 01-28-2014, 02:15 AM   #2170
jucca's Avatar
Posts: 159   (View Stats)
jucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond repute
Hard to get Rotas here in Croatia, but found something very similar for my MS6. Have searched whole this thread, didn't found someone with 18x9 with ET40.
Now I have 19x8.5 with 225/35 tyres and with Eibachs but it rubs here and then, even with just driver. Doubt I will go for coilovers, will change those Eibachs with H&R in few weeks.
Wonder if my planned next setup with 18x9 with ET40 will easy fit?
Those are wheels I'm interested in. Anoyone have heard f them? They're Japan Racing JR3
Cobb AP V3
Stratified tune
Autotech HPFP internals
M2 DP
JBR PowerPath stg II
Sure RMM
Sure Rear Diff Mount
TurboXS 50/50
Grimspeed EBCS
NGK Iridium step colder
Ebay OCC
EGR delete
3BAR MAP w/ Harness
3" CBE w/ high flow mufflers
Eibach -35mm
18x9 JapanRacing JR3 w/ 235/40/18 Kumho KU39
jucca is offline   Reply With Quote
 Old 01-28-2014, 07:01 AM   #2171
Looks damn nice. I've always liked your car but I've got such a soft spot for RPF1s. They're easily my favorite wheels. Definitely post pics once you get them mounted.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-28-2014, 04:49 PM   #2172
7th Initial's Avatar
Posts: 316   (View Stats)
7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world
Groaned at 20 Times in 4 Posts
90 Miata Shift extender // Megan EZ Streets // M2 exhaust // Racingbeat intake // Turn Signal Intakes // Autokonexion GT Panels // Autokonexion Aero Fronts // Rota Kyusha 15x9 -15 205/50/15 // Sickspeed lugs // Custom Diffuser // GV Lip
08 Mica MS3 SURE TIP // SURE Intake // Custom Diffuser // Shifter Extender // AUTOTECH HFFP // APV3 // COBB Knob // YellowSpeed Coils // 17x9 RPF1s
08 True Red MS3 SOLD COBB SRI // CS-CA Box // RaceLand Coils // BC Racing BR Coils // Varrasteon ES221 // 5ZIGEN lugs // SURE RMM // TurboSmart Duelport // SU TestPipe // CNT CB // JRB SSP // JRB Knob // CXRacing FMIC // SUPER Tones // 2Nine Rear Diffuser // Nextmod lip // STI V-limited // Prosport BG
7th Initial is offline   Reply With Quote
The Following User Says Thank You to 7th Initial For This Useful Post:
 Old 01-30-2014, 02:04 PM   #2173
thrisnospork's Avatar
Posts: 254   (View Stats)
thrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond repute
Originally Posted by NoRegrets View Post
specs in signature 43 offset
I was planning on settling for some 17x8 MB Weapons come tax season until you posted your pics, now I'm thinking grids again, thanks
What kind of roll was required (if at all)? The set that I'm looking at is apparently +42, not sure why its changed 1mm...
thrisnospork is offline   Reply With Quote
 Old 01-30-2014, 02:10 PM   #2174
Downmented's Avatar
Groans: 493
Im just going to throw this out there, but if people are posting in this thread, and you are responding to pictures posted, a question about needing to roll fenders is useless. Anyone with "aggressive offsets" is going to require fender rolling/ pulling. Its a given. Just do it.
Quigs likes this.
700HP CLUB
11.479@124mph
#DIX
The Following 2 Users Say Thank You to Downmented For This Useful Post:
6Y MAZDA (02-02-2014), Quigs (01-30-2014)
 Old 01-30-2014, 07:47 PM   #2175
NoRegrets's Avatar
My fenders are rolled but not pulled. I still rub ever so slightly every once in a while. So i would suggest a slight pull as well.
At the moment, I'm not running spacers. The rear clears fine, but the front has bearly enough room to stick my pinky finger in. So when my tires need replacing and i upgrade to a 255, I'm going to use 3mm spacers up front.
Realized I put the wrong offset, thanks for pointing that out. It's 42.
Tuned by Nishan
SP63 Longblock
thrisnospork (01-31-2014)
 Old 02-02-2014, 04:55 PM   #2176
Downmented's Avatar
Groans: 493
Funkster777 and Rokusek like this.
700HP CLUB
11.479@124mph
#DIX
The Following 14 Users Say Thank You to Downmented For This Useful Post:
6Y MAZDA (02-02-2014), Boost Addict (02-02-2014), ckMS3 (02-02-2014), Funkster777 (02-02-2014), h.h.sk1nny (02-02-2014), IshiKage (06-04-2014), jreiden1 (02-02-2014), Mazdazilla6 (02-02-2014), Rokusek (02-10-2014), rymanmazda (02-02-2014), Scare Dem (02-02-2014), sidekick (02-02-2014), Snyeed (02-02-2014), Status Update (02-02-2014)
 Old 02-02-2014, 05:01 PM   #2177
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Is this the STI lip? Or something else?
2006 Mazdaspeed6
 Old 02-02-2014, 05:04 PM   #2178
Downmented's Avatar
Groans: 493
lol, STI lip
700HP CLUB
11.479@124mph
#DIX
 Old 02-02-2014, 08:36 PM   #2179
Status Update's Avatar
Posts: 461   (View Stats)
Status Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the world
@Downmented; Car looks great man!
Downmented likes this.
BMW 335xi 6MT
AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R
2007 BM Mazdaspeed 6 GT #10477
SOLD 8/29/14
Status Update is offline   Reply With Quote
The Following User Says Thank You to Status Update For This Useful Post:
Downmented (02-03-2014)
 Old 02-02-2014, 10:55 PM   #2180
afronese1's Avatar
HOT DAMN!! your ms6 looks so perfect! Where can i buy that lip??? 06-07 sti lip??
 Old 02-03-2014, 02:21 AM   #2181
Bullet's Avatar
Posts: 78   (View Stats)
Bullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond repute
As low as i can go
Bullet is offline   Reply With Quote
The Following User Says Thank You to Bullet For This Useful Post:
Status Update (02-03-2014)
The Following User Says NO Thank You to Bullet For This Un-useful Post:
7th Initial (02-03-2014)
 Old 02-03-2014, 08:53 AM   #2182
@Downmented; BTW I saw your car in person with the st120's and those looked tits too! What spacers were you running with those? If it's possible I'd love to see some more pics of the st120's with the spacers.
BMW 335xi 6MT
SOLD 8/29/14
 Old 02-03-2014, 10:06 AM   #2183
Downmented's Avatar
Groans: 493
So the ST120s were 18x8 +35, without spacers. Here are a few pics.
Rokusek likes this.
700HP CLUB
11.479@124mph
#DIX
The Following 4 Users Say Thank You to Downmented For This Useful Post:
Rokusek (02-10-2014), speed3 britz (02-03-2014), Status Update (02-03-2014), xx5PEEDxx (02-11-2014)
 Old 02-03-2014, 10:06 AM   #2184
Carlg21's Avatar
Posts: 4   (View Stats)
Carlg21 is an unknown quantity at this point
I'm looking for the same specs but i'm wondering if the set up rubs a lot or with the pull it's ok?! thx
Originally Posted by Roszko View Post
They're Rota Grids, 18x9.5 +38
On BC (BR-Type) Coilovers, dropped all the way. Spacer delete on rear springs to drop it lower
No camber adjustments other than an alignment
3mm spacers on front to clear the struts when turning
Tires are Bridgestone Potenza RE760 Sport 225/40/18
Rear fenders pulled, rolled and dremmeled. Front fenders simply pulled with my hands
Thanks for the compliments man, appreciate it!
Carlg21 is offline   Reply With Quote
 Old 02-03-2014, 10:26 AM   #2185
speed3 britz's Avatar
Posts: 1,155   (View Stats)
speed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the world
I love this last shot!
:: Gusto :: likes this.
07 Mazdaspeed 3 Grand Touring Black Mica (The Summer Daily / Toy)
Fanboy Brand Mods: A'PEXi Turbo Timer, Autotech Internals, BNR S3 V1, Bosch 3 Bar MAP, CNT 3" CBE, COBB AP V3, STS, FMIC Piping, Corksport Adjustable Shocks/Struts, CP-E Dash Pod, Safe-Seals, Enkei Evo IX (17x8+38), Exide 51RX Battery, FoMoCo XT-M5-QS, Grimmspeed EBCS, Ground Control Bumpstops, Hankook RS-3 (235/45/17), H&R Springs, Hawk HPS Pads, HTP 51R Battery Tray, JBR 88d RMM, 80d PMM, Shifter Bushings, TIG's, Secondary EGR Delete, 3.5" Aluminum WP, Mudflaps, Kozmic Primary EGR Delete, maisonvi Knob Collection, Damond OCC, NGK LTR7IX-11, Progress RSB, Prosport Boost, Oil Temp, Oil Press, Redline Tuning Hood Struts, SPC Camber Arms, Speed Daddy (Ebay) Catless DP, SP63 MAP Harness, Stratified Guardian Angel, Treadstone TR8, TRZ TMM, TurboXS H-RFL VTA BOV, XS Power V1 Manifold
Maisonvi's Inherited Motor Build: ARP L19 Head Studs, Crank Bolt, Cam Bolts, Manley H-Beam Rods, SP63 Wiseco Armor Plated Pistons,
New Rice, AKA To be Installed: Autoexe Front Bumper Cover, GT Spec Strut Brace, Wedge Engineering Seat Base, Sparco Speed Bucket Seat,
08 Mazda 6i Hatchback (The Daily MPG Commuter)
93 Mazda B2600i 4wd (The Winter Beater / terMINATOR Parts Hauler)
speed3 britz is offline   Reply With Quote
The Following 5 Users Say Thank You to speed3 britz For This Useful Post:
Downmented (02-03-2014), Rokusek (02-10-2014), rymanmazda (02-03-2014), Scare Dem (02-03-2014), Status Update (02-03-2014)
 Old 02-03-2014, 10:38 AM   #2186
@Downmented; Makes me so excited to get my st120's mounted! I currently have the +48 offsets so after seeing yours I'll probably order some 10mm spacers.
BMW 335xi 6MT
SOLD 8/29/14
 Old 02-03-2014, 11:08 AM   #2187
Carlg21's Avatar
Originally Posted by ZoomByU View Post
not professional shots, but you get the idea....
Hey I just want to know if you have the same specs as Roszko? You rolled at the back and pulled all fenders? got spacers on front? Does it rub a lot?? I'm looking for the same specs with 225/40/18 tires... Did you play with your camber? Thx Hope you're gonna receive my message
Crystal white 2008.5 mazdaspeed 3
 Old 02-07-2014, 10:48 PM   #2188
DVM17's Avatar
Posts: 1,283   (View Stats)
DVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the world
Groaned at 25 Times in 6 Posts
alright, as we all know, tax season is here, and I'm really looking into an auto-x setup and needed some advice.
Now, Idk if I'll be the first ms6 to test this out, but I'm planning on
17x9.5 +38 rpf1's with 275/40/17 nitto nt01's and getting some coilovers
The point isn't that I won't have enough grip, but I'm kind of a sucker for overstated sidewalls. I'm trying to figure out a couple things. Would I be better off trying to fit them on the 17x9 +45 rpf1's? and after looking over the measurements, it looks as if I don't want to be lowered too much to avoid rubbing as much as possible. And idk if the 40 sidewall is too beefy.
I'm super excited to see how it turns out, but most likely I'll end up getting some spacers and extended studs. Sorry if this annoys the stance guys but I really need some good advice on setups for actual functional autocrossers. And not the kind of advice that says "just stick with some 245's" I wantz moar grip
I haven't seen a ms6 with anything more than 265's, maybe for good reason....
2006 Mazdaspeed 6 (Titanium Gray) : Built, gtx2867r Purple Drank tuned
12.07 @ 116 on 205 snow tires
hunting for 11's on 245's
DVM17 is offline   Reply With Quote
 Old 02-07-2014, 10:50 PM   #2189
jrho's Avatar
Posts: 1,341   (View Stats)
jrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the world
You're going to get a ton of poke with that set up. Also tires are larger than the stock diameter. Why not just get 17x9s with 255/40/17.
Sent from my Nexus 5 using Tapatalk
2008 Speed3 True Red
jrho is offline   Reply With Quote
 Old 02-07-2014, 10:52 PM   #2190
DVM17's Avatar
I should've mentioned, these are going to be a pure track setup. So it doesn't matter to me how much they poke.
Basically on the days at the track, I'll bolt them up, and take them off when I get home.
Especially with a 100AAA treadwear rating on the tires. lol
 Old 02-11-2014, 03:20 PM   #2191
jucca's Avatar
Got my new rims finnaly, 18x9 ET40, and went into problems I think. Don't know how did you got fitted 9" widht rims with similar offset, but it looks pretty hard to me without major bodywork.
Any workaround here?
Cobb AP V3
Stratified tune
M2 DP
Sure RMM
TurboXS 50/50
Grimspeed EBCS
Ebay OCC
EGR delete
3BAR MAP w/ Harness
Eibach -35mm
The Following 3 Users Say Thank You to jucca For This Useful Post:
:: Gusto :: (02-14-2014), Status Update (02-11-2014), thrisnospork (02-11-2014)
 Old 02-11-2014, 03:32 PM   #2192
Very helpful pics, thanks!
Edit: oops I see you drive a speed 6, oh well still informative
 Old 02-11-2014, 07:16 PM   #2193
Boost Addict's Avatar
Posts: 1,327   (View Stats)
New wheels I picked up and just got done refinishing....blitz type 03
FREEKTUNE
The Following 2 Users Say Thank You to Boost Addict For This Useful Post:
Koke382 (02-11-2014), Status Update (03-30-2014)
 Old 02-11-2014, 07:17 PM   #2194
jrho's Avatar
Attachment 147543
Specsss?
 Old 02-11-2014, 07:19 PM   #2195
They're 18x10 +45 and 18x9 +41, but ill be running spacers
FREEKTUNE
The Following User Says Thank You to Boost Addict For This Useful Post:
 Old 02-12-2014, 11:31 AM   #2196
GOT 2RBO's Avatar
Looks sick Boost. Been following you on IG, can't wait to see the finished product.
As for how we fit 18x9 on our cars. Some camber, little bit of tire stretch, rolled/pulled fenders, plus when tires are mounted, the car is lowered to the ground and the wheels compress, they compress into the fender at an angle, not straight up and down. So when you test fit wheels without putting it back on the ground, it will always look like the wheels won't fit.
Getting tires for my Wedssports next week guys, hope to have some pics soon after.
The Following 2 Users Say Thank You to GOT 2RBO For This Useful Post:
Carlg21 (02-13-2014), jucca (02-12-2014)
 Old 02-12-2014, 11:42 AM   #2197
jucca's Avatar
Thanks. How do you adjust front camber?
Cobb AP V3
Stratified tune
M2 DP
Sure RMM
TurboXS 50/50
Grimspeed EBCS
Ebay OCC
EGR delete
3BAR MAP w/ Harness
Eibach -35mm
 Old 02-12-2014, 12:09 PM   #2198
rymanmazda's Avatar
Posts: 1,531   (View Stats)
rymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the world
Groans: 122
Groaned at 4 Times in 2 Posts
You need adjustable front ball joints! I run spc adjustable ball joints and I'm running -1 ish degrees of front camber (can't remember the exact number off the top of my head).
2006 BCM Mazdaspeed 6 GT w/navi SOLD
Freektune: 400whp/387awtq
Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18
-Autocross Setup-
17x8 +38, BF Goodrich R1 225/45/17
Other Rides:
2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013)
1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it.
1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father)
1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD)
rymanmazda is offline   Reply With Quote
The Following User Says Thank You to rymanmazda For This Useful Post:
jucca (02-12-2014)
 Old 02-12-2014, 12:21 PM   #2199
jucca's Avatar
Saw somewhere you can twist some excentric bolt to adjust camber, cant remeber where I have read that. True, or just spc ball joints can do the job?
Cobb AP V3
Stratified tune
M2 DP
Sure RMM
TurboXS 50/50
Grimspeed EBCS
Ebay OCC
EGR delete
3BAR MAP w/ Harness
Eibach -35mm
 Old 02-12-2014, 01:10 PM   #2200
Scare Dem's Avatar
:thumbup:
2008 Mazdaspeed3 GT
GTX2867r
Page generated in 0.62560 seconds with 40 queries
