Like Tree455Likes
 Old 05-29-2014, 11:05 AM   #2361
EvoFire's Avatar
Posts: 389   (View Stats)
EvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the world
Originally Posted by GOT 2RBO View Post
Qwik I swear you got the sexiest Speed 6 I have seen.
Wheels are 18x9" +25 all around and are the SA60M.
As for caps, I ordered the silver ones that they make for the SA60M, but they sent the CF black ones to me on accident, yet they ended up fitting anyways. These are not advertised to work on the SA60M, so I got lucky . I wanted these from the jump.
Mind telling me how much the caps cost? They are kind of ridiculous up here in the North.
2009 CWP MS3 | JBR short shift plate, JBR shifter bushings, CP-e stage 2 RMM, JBR RSB, JBR Wide-Path, CS downpipe, UR catted test pipe, Cobb cat-back, Forge BPV V1, Swift Spec R springs, Bilstein B8, Whiteline KCA428 ALK, Whiteline Bumpsteer Correction, Corksport injector seals, Weds Sports SA55M 18x8 +48, Bridgestone S-04 245/40/18, BLOX Limited 490g shiftknob
Dyno'ed at 277whp/290lb-ft on 91 piss
EvoFire is offline   Reply With Quote
 Old 05-29-2014, 11:33 AM   #2362
GOT 2RBO's Avatar
Posts: 355   (View Stats)
GOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the world
I ordered mine at the same time I ordered the wheels. It was over $100 I believe.
GOT 2RBO is offline   Reply With Quote
 Old 05-29-2014, 11:40 AM   #2363
carlossjr's Avatar
Posts: 16   (View Stats)
carlossjr is a jewel in the roughcarlossjr is a jewel in the roughcarlossjr is a jewel in the rough
A quick phone shot. Cars a lil dirty
carlossjr is offline   Reply With Quote
The Following User Says Thank You to carlossjr For This Useful Post:
Status Update (05-29-2014)
 Old 05-29-2014, 11:50 AM   #2364
Swinger13's Avatar
Posts: 3,480   (View Stats)
Swinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the world
Groans: 53
Groaned at 45 Times in 25 Posts
flares tsk tsk tsk.....
06 Speed 6 rock chipped n' shit
Performance:
Stratified Tune in progress
Old Set-up: CS Ram air intake with 3" HTP inlet + "sig"
Vdyno 323 awhp 349 awtq uncorrected
Current Set up: JBR 3.5" WP, Perm PCV w/dual catch cans, trunk battery
Vdyno 343 awhp 374 awtq uncorrected
Corksport CBE ~ Ebay DP ~ Autotech Internals ~ COBB AP ~ BC Racing Coilovers ~ SURE shortcut ~ SURE countershift ~ SURE anchors ~ heavy sphere shift knob by maisonvi (MSF member) ~ CP-E seals ~ BSD ~ baffle pan ~ Dual Corksport OCC ~ CP-E Rear Diff Mount ~ SURE Juggernaught ~ Dashhawk ~ AWR 88 duro trilogy ~ EGR delete ~ 3 bar ~ JBR TIG's ~ Grimmspeed 3 port ~ GT2871R w/ported hotside ~ JBR 3.5 inch intake ~ Perm Tuning PCV Plate ~ Forge V1 BPV ~ ITV22's @ .026" ~ CP-E Helihose
Swinger13 is offline   Reply With Quote
 Old 05-29-2014, 01:45 PM   #2365
rymanmazda's Avatar
Posts: 1,531   (View Stats)
rymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the world
Groans: 122
Groaned at 4 Times in 2 Posts
Bushwackers?
2006 BCM Mazdaspeed 6 GT w/navi SOLD
Freektune: 400whp/387awtq
Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18
-Autocross Setup-
17x8 +38, BF Goodrich R1 225/45/17
Other Rides:
2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013)
1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it.
1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father)
1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD)
rymanmazda is offline   Reply With Quote
The Following 3 Users Say Thank You to rymanmazda For This Useful Post:
:: Gusto :: (07-02-2015), ButtholeRedMS3 (09-27-2015), impossible (06-05-2016)
 Old 05-29-2014, 02:03 PM   #2366
Status Update's Avatar
Posts: 461   (View Stats)
Status Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the world
Dem flares look good.
Sent from my Nexus 5 using Tapatalk 2
BMW 335xi 6MT
AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R
2007 BM Mazdaspeed 6 GT #10477
SOLD 8/29/14
Status Update is offline   Reply With Quote
 Old 05-29-2014, 02:28 PM   #2367
7th Initial's Avatar
Posts: 316   (View Stats)
7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world
Groaned at 20 Times in 4 Posts
:: Gusto :: and bmwboost1986 like this.
90 Miata Shift extender // Megan EZ Streets // M2 exhaust // Racingbeat intake // Turn Signal Intakes // Autokonexion GT Panels // Autokonexion Aero Fronts // Rota Kyusha 15x9 -15 205/50/15 // Sickspeed lugs // Custom Diffuser // GV Lip
08 Mica MS3 SURE TIP // SURE Intake // Custom Diffuser // Shifter Extender // AUTOTECH HFFP // APV3 // COBB Knob // YellowSpeed Coils // 17x9 RPF1s
08 True Red MS3 SOLD COBB SRI // CS-CA Box // RaceLand Coils // BC Racing BR Coils // Varrasteon ES221 // 5ZIGEN lugs // SURE RMM // TurboSmart Duelport // SU TestPipe // CNT CB // JRB SSP // JRB Knob // CXRacing FMIC // SUPER Tones // 2Nine Rear Diffuser // Nextmod lip // STI V-limited // Prosport BG
7th Initial is offline   Reply With Quote
The Following 7 Users Say Thank You to 7th Initial For This Useful Post:
1987 (06-27-2014), :: Gusto :: (07-31-2014), Drumea88 (06-10-2014), Qwik6 (05-29-2014), rymanmazda (05-29-2014), Status Update (05-29-2014), xx5PEEDxx (05-30-2014)
 Old 05-29-2014, 07:17 PM   #2368
Qwik6's Avatar
Posts: 695   (View Stats)
Qwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the world
Thanks man, yours is very nice as well!
Originally Posted by afronese1 View Post
@qwik6 what size tires are you using?
I'm running 225/40 nitto neo gens. I honestly do not see how anything any wider would fit without rubbing an already rolled fender on this size wheel and offset.
2006 MAZDASPEED6
FREEKTUNED @ 20PSI // COBB AP V3 // CPE TMIC // COBB SF // PG TIH // DENSO ITV22s // AUTOTECH INTERNALS // SURE TP // MAGNAFLOW CATBACK // JBR OCC // JBR IM SPACER // JBR PASSENGER & TRANNY MOUNT // SURE RMM // H&R SPRINGS // XXR 530 18X8.75 +35 // CAR LED TAILS // CPE REAR DIF MOUNT // TURBINE TECH FRONT DIF MOUNT // CPE TOW HOOK // 35% TINT // 3M DINOC WRAPPED ROOF // AUTOEXE CARBON FIBER BADGELESS GRILL
Qwik6 is offline   Reply With Quote
The Following User Says Thank You to Qwik6 For This Useful Post:
afronese1 (05-30-2014)
 Old 06-02-2014, 05:32 PM   #2369
Ti_grey_rx8's Avatar
Posts: 5   (View Stats)
Ti_grey_rx8 is just really niceTi_grey_rx8 is just really niceTi_grey_rx8 is just really niceTi_grey_rx8 is just really nice
Another RPF-01 setup.
Fronts are 17x9.5 +38. Had to run a 3mm spacer to clear the strut. Rears are 17x9 +45. Tires are 255/40/17. Fronts: Falken Azenis. Rears: Federal RSR's
ISC street/sport coilovers with max camber upfront. SPC camber arms almost maxed out. Rear fenders are rolled flat and the bumper tabs are ground down slightly. I still need an alignment but I barely scrape the fenders front and rear. I will be raising the car before I rub the inner fender away
Top Tier Imports - 2014 Spring Awakening by au.ken, on Flickr
2008.5 Mazdaspeed 3
Auto tech HPFP int, RMM, HKS CBE, Turbo XS dp, mp, COBB AP, TIP, SRI, FMIC. ISC coilovers
Ti_grey_rx8 is offline   Reply With Quote
The Following 7 Users Say Thank You to Ti_grey_rx8 For This Useful Post:
:: Gusto :: (07-31-2014), ArmanRus (06-06-2014), Drumea88 (06-10-2014), impossible (06-05-2016), jrho (06-02-2014), NoRegrets (06-03-2014), speed3 britz (06-03-2014)
 Old 06-02-2014, 05:34 PM   #2370
jrho's Avatar
Posts: 1,341   (View Stats)
jrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the world
You're almost exactly like me but lower. I'm running same front but a 17x9 et35 in the rear with 235s
:: Gusto :: likes this.
2008 Speed3 True Red
jrho is offline   Reply With Quote
 Old 06-02-2014, 05:36 PM   #2371
Swinger13's Avatar
Groans: 53
fuckin pink wheels
Performance:
The Following User Says Thank You to Swinger13 For This Useful Post:
jrho (06-02-2014)
 Old 06-03-2014, 09:10 PM   #2372
itzfajardo801's Avatar
Posts: 9   (View Stats)
itzfajardo801 is an unknown quantity at this point
Noob question in sure but what are your wheel specs? Those flares look great
itzfajardo801 is offline   Reply With Quote
 Old 06-03-2014, 10:38 PM   #2373
afronese1's Avatar
Posts: 73   (View Stats)
afronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant futureafronese1 has a brilliant future
With flares like that you gotta go wider wheels ;-)
carlossjr likes this.
MS6/SP63 Stage 1 build/APv3/BNR S4 v2/hpfp internals/JBR full 3" intake/ATP catted dp/Magnaflow cbe/GFB bov/Damond OCC/Damond egr delete/Treadstone TR1035 FMIC kit/CPE rear diff mount/CPE safe seals/Damond rmm/H&R co/18x9 conti dws 235-40/Stoptech bbk/morimoto xb led fogs/Osram Xenarc d2s 6000K bulb/osram led parking light/Led Tails/Purple Drank Tuned
afronese1 is offline   Reply With Quote
The Following 2 Users Say Thank You to afronese1 For This Useful Post:
:: Gusto :: (07-31-2014), impossible (06-05-2016)
 Old 06-03-2014, 11:17 PM   #2374
carlossjr's Avatar
They're cosmis xt-005rs 18x9 +25 with 245/40's, and thanks man, hope to get some better pics later this week
Ahaha talk about aggressive!
Last edited by carlossjr; 06-03-2014 at 11:17 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-04-2014, 08:39 AM   #2375
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
Originally Posted by speedaholic View Post
That MS6 is seeexy.
Yet another with 530s:
What width, 8.75? Do you think 9.5 would be a bit much? What kit is that on your rear bumper? What are guys using for the sides and front to match?
Finally got some quality pics of my new setup.
Nice attention to detail with all the little additions
2015 Mazda 6
The Following User Says Thank You to IshiKage For This Useful Post:
 Old 06-04-2014, 10:37 AM   #2376
speedaholic's Avatar
Posts: 154   (View Stats)
speedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the world
Depends what offset and drop height, juan or pu. I'm on the limit of OEM rear specs and don't have camber arms. With 9.5, you're going to need enough offset to clear the struts, pushing it out even more.
I think he XXRs in 9"+ are 25 offset. Mad concave look but not without ridiculous poke or stretch. I wouldn't do it...
*edit* Rear lip is Home Depot Lip or EZ lip. I have the same up front, nothing on the sides.
Testdriver127 likes this.
2015 Black Mustang GT
RIP 2015-06-27
2013 Liquid Silver MS3
speedaholic is offline   Reply With Quote
 Old 06-04-2014, 01:19 PM   #2377
IshiKage's Avatar
Groans: 278
im looking at the XXR 531s in 18 x 9.5 +35 on a Pu. Any thoughts?
2015 Mazda 6
 Old 06-04-2014, 06:21 PM   #2378
@IshiKage; I think you're going to want to check inside clearance as it might be tight without spacers:
Wheel / Tire Size Comparer - RIMSnTIRES.com
RIP 2015-06-27
The Following User Says Thank You to speedaholic For This Useful Post:
IshiKage (06-04-2014)
 Old 06-04-2014, 06:56 PM   #2379
jrho's Avatar
Actually you might be okay. Might need a small spacer in the front but I know a guy with a pu on 18x9.5 et38 with no spacers
The Following 2 Users Say Thank You to jrho For This Useful Post:
IshiKage (06-04-2014), speedaholic (06-04-2014)
 Old 06-04-2014, 09:08 PM   #2380
IshiKage's Avatar
Groans: 278
calculator said
"100% clear (leaves even more room than OEM)"
I was considering running staggered. (225)8.5" +35 Front and (225)9.5" +35 rear or would you stick with (225)9.5" front and rear? I was thinking by going with 8.5" up front I wouldnt have to run as much neg camber as I would with 9.5 thus having a better contact patch which id prefer.
2015 Mazda 6
 Old 06-04-2014, 09:46 PM   #2381
Yeah, it doesn't really work that way. Staggered for a FWD is form > function / ricy. Also, aggressive camber can yield better grip while cornering in a track setup, it's pointless and a waste of rubber for a daily driver.
You might want to search and read more before biting the bullet on a new setup:
2010 MS3 - Suspension & Brakes
RIP 2015-06-27
 Old 06-04-2014, 10:05 PM   #2382
IshiKage's Avatar
Groans: 278
I know the benefits of aggressive camber on the track. I know Im throwing out a lot of function to gain form but Im not tracking this car. Its a DD. I know that Im going to be chomping through rubber since Im going with an aggressive set up but my question is, could I get a better contact patch up front from an 8.5" wheel and less neg camber than I would having a 9.5" or it would be negligible since both wheels will have +35 offset and that 1 inch difference wouldnt make much of a difference either way?
2015 Mazda 6
 Old 06-04-2014, 10:09 PM   #2383
jrho's Avatar
The only stagger you should do on a fwd is wider in the front. With camber it depends on your toe and how extreme your camber is. I run -2.2 camber with 0 toe all around I don't see any camber wear.
 Old 06-05-2014, 07:03 AM   #2384
Imo, if you only run an intake and possibly a tune (as per your sig), a quality sticky set of 235s on those 8.5s are more than sufficient. As is, I personally would go for 8.5s all around or, 9.5s if I was feeling ambitious or planning on modding for more power.
Another problem with the staggered setup is you can't rotate them for longer tread life. If that option is only for looks, than there's no point in discussing it's function, or lack of...
RIP 2015-06-27
The Following 2 Users Say Thank You to speedaholic For This Useful Post:
IshiKage (06-05-2014), Quigs (06-05-2014)
 Old 06-19-2014, 08:20 AM   #2385
Domino81's Avatar
Posts: 5,081   (View Stats)
I tossed on some 5/16" spacers I had laying around. So now I have 18x8.5 +40mm offset, effectively.
Before:
After:
Ultimately what I was looking for was something more aggressive and truth be told I was thinking of selling these wheels. I think it gives the perfect compliment to them and the car and I once again feel like I did when I first installed the ST100's on the car. They're still heavy, but now they give the car a better attitude and I'm really diggin' it.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
The Following 3 Users Say Thank You to Domino81 For This Useful Post:
speed3 britz (06-26-2014), Swinger13 (06-19-2014), taf0422 (06-19-2014)
 Old 06-24-2014, 10:12 PM   #2386
alpineguy's Avatar
Posts: 40   (View Stats)
alpineguy is just really nicealpineguy is just really nicealpineguy is just really nicealpineguy is just really nice
I am running xxr 531 18x9.5 +35 with 225/40r18's
Carlg21 likes this.
alpineguy is offline   Reply With Quote
The Following 2 Users Say Thank You to alpineguy For This Useful Post:
jrho (06-26-2014), Status Update (06-24-2014)
 Old 06-26-2014, 09:05 AM   #2387
speed3 britz's Avatar
Posts: 1,155   (View Stats)
speed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the world
Enkei Evo 9's 17x8+38, Hankook Ventus RS-3 235/45/18
07 Mazdaspeed 3 Grand Touring Black Mica (The Summer Daily / Toy)
Fanboy Brand Mods: A'PEXi Turbo Timer, Autotech Internals, BNR S3 V1, Bosch 3 Bar MAP, CNT 3" CBE, COBB AP V3, STS, FMIC Piping, Corksport Adjustable Shocks/Struts, CP-E Dash Pod, Safe-Seals, Enkei Evo IX (17x8+38), Exide 51RX Battery, FoMoCo XT-M5-QS, Grimmspeed EBCS, Ground Control Bumpstops, Hankook RS-3 (235/45/17), H&R Springs, Hawk HPS Pads, HTP 51R Battery Tray, JBR 88d RMM, 80d PMM, Shifter Bushings, TIG's, Secondary EGR Delete, 3.5" Aluminum WP, Mudflaps, Kozmic Primary EGR Delete, maisonvi Knob Collection, Damond OCC, NGK LTR7IX-11, Progress RSB, Prosport Boost, Oil Temp, Oil Press, Redline Tuning Hood Struts, SPC Camber Arms, Speed Daddy (Ebay) Catless DP, SP63 MAP Harness, Stratified Guardian Angel, Treadstone TR8, TRZ TMM, TurboXS H-RFL VTA BOV, XS Power V1 Manifold
Maisonvi's Inherited Motor Build: ARP L19 Head Studs, Crank Bolt, Cam Bolts, Manley H-Beam Rods, SP63 Wiseco Armor Plated Pistons,
New Rice, AKA To be Installed: Autoexe Front Bumper Cover, GT Spec Strut Brace, Wedge Engineering Seat Base, Sparco Speed Bucket Seat,
08 Mazda 6i Hatchback (The Daily MPG Commuter)
93 Mazda B2600i 4wd (The Winter Beater / terMINATOR Parts Hauler)
speed3 britz is offline   Reply With Quote
The Following User Says Thank You to speed3 britz For This Useful Post:
Swinger13 (07-06-2014)
 Old 07-06-2014, 12:26 PM   #2388
Astrall's Avatar
Posts: 109   (View Stats)
Astrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to behold
Ok so I just ordered my xxr 527s In 18x8.75 +35 for my gen1. I'm kinda nervous about fitment and such. I'm currently lowered on eibach sportlines ~2in . I plan on rolling the fenders but just how bad is it gonna be fitting it and will I have any major issues. Thanks for the help I really appreciate it
Astrall is offline   Reply With Quote
 Old 07-06-2014, 12:33 PM   #2389
Astrall's Avatar
Also I will be running oem tire size
 Old 07-06-2014, 12:40 PM   #2390
Swinger13's Avatar
Groans: 53
what color/ powder are your wheels?
Performance:
 Old 07-06-2014, 09:48 PM   #2391
Quigs's Avatar
Posts: 1,152   (View Stats)
Quigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the world
Well, you already know you need a roll. Possibly a pull, too, since you're lowered about two inches. In the end it's been done many times since so many people feel the need to get those same wheels. You shouldn't have any surprises and should be able to make them fit like everyone else has.
And for the love of god, please get some properly fitting tires. Stock sized tires are going to make it look (and more importantly perform) like crap.
2009 Mazdaspeed3
Bolted, Mounted, Hypnotic Tuned
2000 Mazda Miata MX-5
NASA TTE build ongoing
Quigs is offline   Reply With Quote
 Old 07-07-2014, 06:30 AM   #2392
Dormant Raspberry base with High Gloss clear
Swinger13 (07-07-2014)
 Old 07-15-2014, 09:45 PM   #2393
Astrall's Avatar
Just got my 527s in today and I ordered the 18x8.75 +35. I am convinced they some how sent me the wrong size even though the box is correct
 Old 07-15-2014, 11:20 PM   #2394
rymanmazda's Avatar
Groans: 122
@Astrall; if you wanted 18x8.75.... That isn't 8.75 wide.
-Autocross Setup-
Other Rides:
 Old 07-16-2014, 02:40 AM   #2395
Astrall's Avatar
I just emailed the company, time to see what happens
 Old 07-16-2014, 08:19 AM   #2396
Im pretty sure there is a thread out there that discuss this. They say 8.75 but I believe they are measuring from the the inner lips rather then the outer lips of the rim. thus actually making it a 9"+ wheel.
The Following User Says Thank You to 7th Initial For This Useful Post:
anodizedeeznutz (07-16-2014)
 Old 07-16-2014, 11:07 AM   #2397
alpineguy's Avatar
Measure inside lip to inside lip
 Old 07-16-2014, 02:33 PM   #2398
carlossjr's Avatar
Cosmis Racing XT005R 18x9 +25
Goodyear Eagle F1 Asymmetric2 245/40/18
The Following 2 Users Say Thank You to carlossjr For This Useful Post:
Status Update (07-18-2014), Tyhackman15 (07-16-2014)
 Old 07-16-2014, 03:03 PM   #2399
anodizedeeznutz's Avatar
Posts: 2,796   (View Stats)
anodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the world
@Astrall; that looks about right fitment wise.
It's gonna be some work and stretch to not rub.
2013 CWP Mazdaspeed3 - SOLD
2014 Mitsubishi Evo X - time for some fun.
anodizedeeznutz is offline   Reply With Quote
 Old 07-16-2014, 06:28 PM   #2400
Astrall's Avatar
After some research and a call to XXR, it turns out that they measure by the inside and it ends up being a much bigger rim then planned. I will make it work some how... Wish me luck
The Following User Says Thank You to Astrall For This Useful Post:
PearlySpeed (05-28-2018)
Page generated in 0.62604 seconds with 40 queries
