Like Tree455Likes
 Old 07-17-2014, 06:58 PM   #2401
Astrall's Avatar
Posts: 109   (View Stats)
Astrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to behold
Changed my mind and went with a 225/40/18 and it actually fit pretty nice. Going tomorrow to get my fenders rolled and adjusted.
Astrall is offline   Reply With Quote
 Old 07-17-2014, 07:06 PM   #2402
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
my2k13speed3 is the leader of the worldmy2k13speed3 is the leader of the worldmy2k13speed3 is the leader of the worldmy2k13speed3 is the leader of the worldmy2k13speed3 is the leader of the worldmy2k13speed3 is the leader of the worldmy2k13speed3 is the leader of the worldmy2k13speed3 is the leader of the worldmy2k13speed3 is the leader of the worldmy2k13speed3 is the leader of the worldmy2k13speed3 is the leader of the world
What did you have to do to the fenders to make them fit and not rub?
2013 Mazdaspeed3 Crystal White Pearl
[Damond Motorsports RMM & SSP] [Maisonvi Grooved Dessert Beagle Knob] [COBB AP V3] [CorkSport HPFP Internals, SRI, TIP, TMIC & LEDs] [Sure M3 TP] [cp-e Triton CBE] [GFB BOV] [91 Octane Purple Drank Tuned - 260whp/290wtq - VDyno]
Parts to Install: [JBR 3" TRU-3" Intake & Solid Shifter Bushings] [DDM HID Kit]
my2k13speed3 is offline   Reply With Quote
 Old 07-17-2014, 07:10 PM   #2403
Astrall's Avatar
Tomorrow I'm going to get them taken care of, I imagine that they will be rolling and pulling them a bit
 Old 07-19-2014, 06:23 PM   #2404
Astrall's Avatar
All on have to go back tomorrow and get the rear fender adjusted. Also found out I blew a rear shock so now I have an excuse for coils
NoRegrets likes this.
The Following 3 Users Say Thank You to Astrall For This Useful Post:
Dumbguy (07-20-2014), SC08Speed3 (07-30-2014), Status Update (07-20-2014)
 Old 07-20-2014, 08:00 AM   #2405
justint5387's Avatar
Posts: 608   (View Stats)
justint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the world
Wheels should be measured from inside lip
justint5387 is offline   Reply With Quote
 Old 07-24-2014, 12:57 PM   #2406
hollar1211's Avatar
Posts: 495   (View Stats)
hollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond repute
so a local guy here is selling some mint condition nissan 350z wheels with tires for $300. i need wheels and tires.
they are the 17" 6 spoke design. the front tires are 7.5" and rear are 8". tires are 225-50 up front and 235-50 in rear.
i know the bolt pattern is the same, and i've seen guys run the 350z wheels on speeds before. i'm not a fan of staggered wheels on fwd cars, but like i said, i need some wheels and my budget sucks at the moment.
does anyone run a 235-50 on here? i'm on stock suspension but i do plan to get some lowering springs and the fenders rolled.
for $300, i might try it. but something tells me to walk away.
http://houston.craigslist.org/pts/4580784435.html
hollar1211 is offline   Reply With Quote
 Old 07-24-2014, 02:07 PM   #2407
jrho's Avatar
Posts: 1,341   (View Stats)
jrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the worldjrho is the leader of the world
235/50 is pretty tall. Also aren't the 350z wheels 18" ? I would personally stay away from them though because you'll need the hub bore machined out as the Nissan is smaller hub bore than ours.
2008 Speed3 True Red
jrho is offline   Reply With Quote
 Old 07-25-2014, 08:47 AM   #2408
hollar1211's Avatar
fronts are 7.5", rears are 8". i just told him i'm no longer interested. wasn't even thinking of the bore. thanks man.
 Old 07-25-2014, 09:11 AM   #2409
Out of curiosity why do you need wheels? What's wrong with stock wheels until you can save up and get what you really want and not hunt for a good deal...
 Old 07-25-2014, 10:50 AM   #2410
hollar1211's Avatar
Went in for an alignment a couple weeks ago after I rotated the tires. There was some vibration so I figured it just needed balancing. Turns out I have 2 bent rims. I also need 2 tires. Not an emergency though, I still drive it. Just thought it was a god deal at the time.
2008.5 Speed3 GT
Freek Tuned e33: Cobb AP, Autotech Internals, UR Test Pipe, CPE TMIC, JBR Power Path Stage 2 SRI-TIP/ Short Shifter/ Solid Shifter Bushings/ Heavy Shift Knob/ 88 Duro RMM/ EGR Delete & Block Off Plate/ Throttle Body TIG, NGK IX 6510, 18x8 +35 Drag DR-49
 Old 07-31-2014, 09:12 PM   #2411
:: Gusto ::'s Avatar
Posts: 1,455   (View Stats)
Originally Posted by carlossjr View Post
Cosmis Racing XT005R 18x9 +25
Goodyear Eagle F1 Asymmetric2 245/40/18
let me get this right... you put flares on to gain more space in your wheel wells for your low ET set up.. & then still proceeded to run something NON-Aggressive!???!
WTF is the point of that...!!??
Hell if you going to go through the trouble of putting flares on & your running a 25ET wheel... why didn't you just go w/ a 18x11!?!? Something that would at least fill out the space.
congrats, you have achieved this look..
What happened to this thread...?
yea yea - i know i cant spell
The Following 9 Users Say Thank You to :: Gusto :: For This Useful Post:
ArmanRus (11-10-2014), ButtholeRedMS3 (09-27-2015), cshunter (10-31-2015), Downmented (08-01-2014), Jester2552 (12-17-2014), jreiden1 (09-16-2014), Koke382 (11-14-2014), Quigs (08-01-2014), Rokusek (08-01-2014)
 Old 07-31-2014, 09:38 PM   #2412
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
Mine
Domino81 likes this.
2015 Mazda 6
The Following 4 Users Say Thank You to IshiKage For This Useful Post:
Domino81 (08-05-2014), SC08Speed3 (08-01-2014), Swinger13 (07-31-2014), thrisnospork (07-31-2014)
 Old 08-01-2014, 08:13 AM   #2413
7th Initial's Avatar
Posts: 316   (View Stats)
7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world
Groaned at 20 Times in 4 Posts
XXR's only measure the inner lips of the rim, not the it as a whole. Thus 8.75 is well more like a 9.75.
90 Miata Shift extender // Megan EZ Streets // M2 exhaust // Racingbeat intake // Turn Signal Intakes // Autokonexion GT Panels // Autokonexion Aero Fronts // Rota Kyusha 15x9 -15 205/50/15 // Sickspeed lugs // Custom Diffuser // GV Lip
08 Mica MS3 SURE TIP // SURE Intake // Custom Diffuser // Shifter Extender // AUTOTECH HFFP // APV3 // COBB Knob // YellowSpeed Coils // 17x9 RPF1s
08 True Red MS3 SOLD COBB SRI // CS-CA Box // RaceLand Coils // BC Racing BR Coils // Varrasteon ES221 // 5ZIGEN lugs // SURE RMM // TurboSmart Duelport // SU TestPipe // CNT CB // JRB SSP // JRB Knob // CXRacing FMIC // SUPER Tones // 2Nine Rear Diffuser // Nextmod lip // STI V-limited // Prosport BG
7th Initial is offline   Reply With Quote
 Old 08-05-2014, 10:31 AM   #2414
Domino81's Avatar
Posts: 5,081   (View Stats)
After seeing the 531's... I want a set...
Not sure how I feel about them only offering them in a 18x8.5 +35
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
IshiKage (08-07-2014)
 Old 08-05-2014, 10:33 AM   #2415
Seems like everyone and there mothers are running XXR wheels, I don't get it...
Quigs likes this.
The Following User Says Thank You to my2k13speed3 For This Useful Post:
Quigs (08-06-2014)
 Old 08-05-2014, 12:05 PM   #2416
Astrall's Avatar
Cheap and decent looking wheels. Most people get em cause its only around $500-$600 for a set
Downmented (08-05-2014), IshiKage (08-07-2014), Swinger13 (08-06-2014)
 Old 08-05-2014, 12:24 PM   #2417
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
The 513s specifically look almost identical to CCRs, IMO.
700HP CLUB
11.479@124mph
#DIX
 Old 08-06-2014, 12:12 PM   #2418
Swinger13's Avatar
Posts: 3,480   (View Stats)
Swinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the worldSwinger13 is the leader of the world
Groans: 53
Groaned at 45 Times in 25 Posts
IMO you get what you pay for. I wouldnt touch XXR's with a 20 ft pole.
Pictures of them breaking and horror stories scare me.
GunGuru272 likes this.
06 Speed 6 rock chipped n' shit
Performance:
Stratified Tune in progress
Old Set-up: CS Ram air intake with 3" HTP inlet + "sig"
Vdyno 323 awhp 349 awtq uncorrected
Current Set up: JBR 3.5" WP, Perm PCV w/dual catch cans, trunk battery
Vdyno 343 awhp 374 awtq uncorrected
Corksport CBE ~ Ebay DP ~ Autotech Internals ~ COBB AP ~ BC Racing Coilovers ~ SURE shortcut ~ SURE countershift ~ SURE anchors ~ heavy sphere shift knob by maisonvi (MSF member) ~ CP-E seals ~ BSD ~ baffle pan ~ Dual Corksport OCC ~ CP-E Rear Diff Mount ~ SURE Juggernaught ~ Dashhawk ~ AWR 88 duro trilogy ~ EGR delete ~ 3 bar ~ JBR TIG's ~ Grimmspeed 3 port ~ GT2871R w/ported hotside ~ JBR 3.5 inch intake ~ Perm Tuning PCV Plate ~ Forge V1 BPV ~ ITV22's @ .026" ~ CP-E Helihose
Swinger13 is offline   Reply With Quote
The Following 2 Users Say Thank You to Swinger13 For This Useful Post:
my2k13speed3 (08-06-2014), Quigs (08-06-2014)
 Old 08-07-2014, 07:55 PM   #2419
IshiKage's Avatar
Groans: 278
Ive seen pics of various brands of wheels breaking. Even OEM wheels have broken so... Wheels crack or break everyday, B.
2015 Mazda 6
 Old 08-18-2014, 10:26 AM   #2420
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Ok so I found a stupid good deal on some rpf1's with tires. But the issue is they're 18x9.5 +15. Has anyone fit anything with similar dimensions on a 6?
Edit: Fuck it, not gonna waste my time trying to fit something that huge.
Quigs likes this.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
Quigs (08-18-2014)
 Old 08-18-2014, 12:03 PM   #2421
Status Update's Avatar
Posts: 461   (View Stats)
Status Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the world
This is what 18x9.5 +22 looks like LOL.
Sent from my Nexus 5 using Tapatalk 2
Hoyoman likes this.
BMW 335xi 6MT
AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R
2007 BM Mazdaspeed 6 GT #10477
SOLD 8/29/14
Status Update is offline   Reply With Quote
The Following 3 Users Say Thank You to Status Update For This Useful Post:
2.3speed06 (08-19-2014), Mazdazilla6 (08-18-2014), Swinger13 (09-01-2014)
 Old 08-18-2014, 02:15 PM   #2422
Oh dear lord that's absurd. Maybe if I ever go with fender flares...
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 09-01-2014, 12:33 PM   #2423
Mr Wilson's Avatar
Posts: 120   (View Stats)
Mr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the world
^^^Same size wheels on a 3 for those that care (265/35 RE-11 tires).
2008.5 CWP SPEED3
MODS TO DATE: KW V3 Cobb AP V3, RSB, STS TWM Shifter Extender Sure Shortcut, Countershift CP-e Tow Plate, FMIC, HPFP, DP, Exhaust Manifold, HeliHose, PMM/TMM, Nexus CBE, Injector Seals TiAL bpv JBR WP, Solid Shifter Bushings, TB/IM Gasket, RMM Celestspeed3 Coolant Bypass DBA 4300 T3 Hawk HP+ Denso itv22 Saikou Michi OCC DGM Lip HTP Slim Battery Tray SilverDemon EGR Block Off Rays Volk TE37 SL 18x9.5 +22, Formula Lugs Bridgestone RE-11 265/35-18 SilverDemon EGR Delete Kit Stratified ECBS, 3-Bar Map Sensor Intake Manifold PnP
Mr Wilson is offline   Reply With Quote
The Following User Says Thank You to Mr Wilson For This Useful Post:
Status Update (09-01-2014)
 Old 09-01-2014, 02:16 PM   #2424
Flares required LOL
BMW 335xi 6MT
SOLD 8/29/14
 Old 09-01-2014, 02:29 PM   #2425
Mr Wilson's Avatar
Very much so. Needless to say the fd's are back on.
2008.5 CWP SPEED3
 Old 09-14-2014, 09:11 PM   #2426
Cheese5.0's Avatar
Posts: 170   (View Stats)
Cheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the world
255/40-18 Potenza S-04 on Evo GSR wheels. Lowered on Auto exe springs. Discuss.
Before roll and pull
After roll and pull
How it looks tucked (large human in my trunk)
2006 WWP Mazdaspeed 6 #00694 Built 09/05
Stock K04
50/50 E85 mix
304/349 Central Florida Turbo Mustang Dyno
4/18/15
Tuned by NISHAN
Cheese5.0 is offline   Reply With Quote
 Old 09-15-2014, 04:21 PM   #2427
255 is massive for a 6
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
Cheese5.0 (09-15-2014)
 Old 09-15-2014, 11:35 PM   #2428
I_AINT_RICE's Avatar
Posts: 196   (View Stats)
I_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond repute
Just looked through a good amount of these posts. Just picked up some 350z GT v2 staggered rims for cheap. Anyone know if you could run a 235 on these rims with a "light" rear fender roll? I'm pretty sure the offset is like 30 and 33, with 8.0 and 8.5 wide. Also the rims came with 2 new 225/45/r18 tires, probably too tall I'm guessing but input would be appreciated.
Also the car is lowered on KW v2's with adjustable camber arms
I_AINT_RICE is offline   Reply With Quote
 Old 09-16-2014, 06:17 AM   #2429
jrho's Avatar
Before anything, you're going to need the hub bore enlarged on those wheels to run them.
The Following User Says Thank You to jrho For This Useful Post:
Mr Wilson (09-16-2014)
 Old 09-16-2014, 08:47 AM   #2430
Already have that in mind, but do you know whats the widest I can go with out rubbing?
 Old 09-16-2014, 11:25 AM   #2431
jrho's Avatar
If you run 235/40/18 tires with the 8.5J in the rear you're going to have to do a flat roll. I have 235/45/17 on 17x9 et35 in the rear on natural camber and I rub on big dips with a flat roll
SpeedyGuy (09-16-2014)
 Old 09-16-2014, 11:32 AM   #2432
Sorry to sound like a newb but what do you mean roll them flat?
 Old 09-16-2014, 11:39 AM   #2433
jrho's Avatar
Basically a pretty aggressive roll so that your fender lip is bent completely flush to the fender
 Old 09-16-2014, 12:18 PM   #2434
Any pics of the insides of the fender wells? And thanks for the help man I really appreciate it
 Old 09-16-2014, 02:46 PM   #2435
Robi's Avatar
Posts: 11   (View Stats)
Robi is a name known to allRobi is a name known to allRobi is a name known to allRobi is a name known to allRobi is a name known to allRobi is a name known to all
I tossed on some 5/16" spacers I had laying around. So now I have 18x8.5 +40mm offset, effectively.
Before:
After:
Ultimately what I was looking for was something more aggressive and truth be told I was thinking of selling these wheels. I think it gives the perfect compliment to them and the car and I once again feel like I did when I first installed the ST100's on the car. They're still heavy, but now they give the car a better attitude and I'm really diggin' it.
Any rubbing issues with that width and offset? Roll?
Robi is offline   Reply With Quote
 Old 09-16-2014, 04:23 PM   #2436
In case anyone was interested, you DONT need to bore the hub for 350z wheels
 Old 09-16-2014, 08:18 PM   #2437
MY DICK IS SMALL-beautfpowers@gmail.com's Avatar
Posts: 327   (View Stats)
MY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these parts
Groaned at 212 Times in 84 Posts
id just like to take this moment to say... if you don't run 295s on a 10 inch rim, you really shouldn't being in the aggressive offset thread...
MY DICK IS SMALL-beautfpowers@gmail.com is offline   Reply With Quote
 Old 09-17-2014, 05:50 AM   #2438
Domino81's Avatar
Had to play around with the roll, as well as the camber. I eventually replaced the 8mm with a 5mm spacer. And set the camber back to a more neutral setting.
Robi likes this.
 Old 10-14-2014, 01:18 PM   #2439
CaseyBueno's Avatar
Posts: 295   (View Stats)
CaseyBueno is the leader of the worldCaseyBueno is the leader of the worldCaseyBueno is the leader of the worldCaseyBueno is the leader of the worldCaseyBueno is the leader of the worldCaseyBueno is the leader of the worldCaseyBueno is the leader of the worldCaseyBueno is the leader of the worldCaseyBueno is the leader of the worldCaseyBueno is the leader of the worldCaseyBueno is the leader of the world
Hey guys!
Wanted to join the thread! I posted in the general discussion, but I want in!!
Here's my MS6 with MB Battles 18x8 +30 offset running Hankook 215/45/18
I'll probably get 5mm spacers to close the gab a LITTLE more + pull my rear fenders.
:: Gusto :: likes this.
Car - 06' Mazdaspeed 6 GT Black Mica/Panda Interior
Work - Content Creation (www.goodedreams.com)
Dream - Liver
"Life's a garden; dig it."
-Joe Dirt
CaseyBueno is offline   Reply With Quote
The Following 2 Users Say Thank You to CaseyBueno For This Useful Post:
2.3speed06 (10-15-2014), Status Update (10-14-2014)
 Old 10-14-2014, 08:20 PM   #2440
Pseudonym's Avatar
Posts: 1,429   (View Stats)
Pseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the world
did you really put regular 6 tails on your car?
Cobb AP JBR SSP/SSB's
AWR PMM/RMM Autotech Internals
Sonic Tuning Coilovers ETS TMIC
HTP 3 Incher Forge V2 BPV
eBay Test Pipe
SCUBA TUNED
Pseudonym is offline   Reply With Quote
Page generated in 0.58518 seconds with 40 queries
