Like Tree455Likes
 Old 11-07-2016, 06:58 AM   #2521
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Originally Posted by kryskunka View Post
Planning on buying Varrstoen MK6 18×9 ET 30 on my gen pu. Currently stock height but this week installing coilovers and dropping 2 inches all around. Don't know if this wheel will fit since I know it's an aggressive set up. Wondering if this wheel will fit or what adjustment I would need to make to make it fit
Yeah it'll fit. Post pics when you're done
Blue Pu.
The Following 2 Users Say Thank You to anavrinIV For This Useful Post:
JMEngineer (12-23-2016), KiwiFlavor (11-07-2016)
 Old 11-07-2016, 11:44 AM   #2522
kryskunka's Avatar
Posts: 83   (View Stats)
kryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to all
Groaned at 7 Times in 6 Posts
Hmm... not sure if being sarcastic or not. Went through a good 30 pages of threads. Got mixed answers. +30 offset is really aggressive buddy. And I don't want to run camber or pull the fenders but rolling the fenders is an option
17x9 Enkei Rpf1 wrapped in Hankook ventus rs3 255/40/17 tires~Cobb Accessport V3~Corksport RMM~UR Turbo back Exhaust~ CP-E 3.25 intake~Autotech hpfp internals~Tuned by Purple Drank Tuning on 22lbs boost
kryskunka is offline   Reply With Quote
 Old 11-07-2016, 12:58 PM   #2523
anavrinIV's Avatar
Groans: 63
It'll fit. post pics when it's done
KiwiFlavor likes this.
Blue Pu.
JMEngineer (12-23-2016), KiwiFlavor (11-09-2016)
 Old 11-09-2016, 12:40 AM   #2524
alden's Avatar
Posts: 400   (View Stats)
alden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant future
I'm running 18x9.5 et 35, rolled, dropped on CS springs, approx 1.5" front, and 1.2" rear, IMO it sits dead even front to back, so id say closer to 1.5 all around. That being said, I've never rubbed, or had an issues what so ever. I've actually got some room to drop for sure, and I'm on 235 tires, probably going 245 next. Long store short, you should be fine. Going to look really nice, for sure post pics.
alden is offline   Reply With Quote
The Following User Says Thank You to alden For This Useful Post:
kryskunka (11-15-2016)
 Old 11-15-2016, 06:35 AM   #2525
kryskunka's Avatar
Thanks for the info. I changed my mind though. Finally decided on wheels. Getting cosmis mr7 18x9 ET 25. Buying them this week after deciding on what I want. It's aggressive for sure. I just want it so be aggressive but not be hella flush or camber. I'll see how it goes. Hopefully it'll fit. I'll post pics for sure
 Old 11-15-2016, 07:02 AM   #2526
anavrinIV's Avatar
Groans: 63
After 30 pages of this thread your takeaway is that 18x9 +25 will be fine without camber, stretched tires, and pulled fenders?
It'll fit. post pics when you're done
KiwiFlavor and _SPEED3GT_ like this.
Blue Pu.
The Following 3 Users Say Thank You to anavrinIV For This Useful Post:
JMEngineer (12-23-2016), KiwiFlavor (12-09-2016), Neverlift (12-21-2016)
 Old 12-08-2016, 12:49 PM   #2527
kryskunka's Avatar
Just bought nitto 255/40/18 tires. Need to know what kind of wheels I need to make it fit and what offset. Found some 18×9 mb battles +38. Will it clear the calipers? I'm on stock suspension and may keep it that way. I'm expecting to roll the fenders most likely. Sorry for the past couple of troll posts.
The Following User Says NO Thank You to kryskunka For This Un-useful Post:
 Old 12-08-2016, 01:12 PM   #2528
anavrinIV's Avatar
Groans: 63
Those tires are way too tall. A full inch diameter larger than stock which is a lot. I suggest you return them.
Blue Pu.
 Old 12-08-2016, 04:29 PM   #2529
kryskunka's Avatar
Shit...alright.. what tires do you suggest then? I want beefy tires like 255 but I thought it would fit on stock suspension
 Old 12-09-2016, 05:18 AM   #2530
anavrinIV's Avatar
Groans: 63
245/40/18 is close to gen1 stock size. If you want 255 you're looking at 255/35 which is just very slightly shorter (negligible) or you could run the gen1 size 245/40 and should be okay.
If you step down to 17s a 255/40 is just about right
Blue Pu.
 Old 12-09-2016, 07:14 AM   #2531
kryskunka's Avatar
Yeah I returned the tires already. About to go pick up 17x9 +45 enkei rpf1 wrapper in ventus 255/40/17 for a killer deal. I think I'll need a rears fender rolled. This is a common set up on mazdapseed3 if I'm correct. I'll post pics when I get them today. Thanks for the advice
 Old 12-09-2016, 06:35 PM   #2532
kryskunka's Avatar
Default Well Finally Got Them
I'mBrand new 17×9 ET +45 wrapped in Hankook ventus rs3 255/40/17. Got them for a sweet deal
 Old 12-09-2016, 07:34 PM   #2533
whitedevil's Avatar
Posts: 35   (View Stats)
whitedevil has a spectacular aura aboutwhitedevil has a spectacular aura aboutwhitedevil has a spectacular aura about
I'm running 18x8.75 +20 on stock suspension and only rubs in the rear on biiig bumps or dips and I currently have a bad rear passenger strut...and where the rub marks are on the tire its like a 1/4" from not rubbing at all so a mild fender roll and itll be cookin
manu likes this.
'12 tech package
corksport TBE
turbosmart supersonic
xxr 530 gold 18x8.75 +20
235/40 BFG g-force a/s
whitedevil is offline   Reply With Quote
 Old 12-10-2016, 12:01 PM   #2534
kryskunka's Avatar
Attachment 229807
Attachment 229808
Those are sticking out pretty good. You must of had to put some big spacers on there for sure
 Old 12-10-2016, 07:16 PM   #2535
whitedevil's Avatar
nope no spacers those aren't good pics for refrence but the rears stick out a good 1/2-3/4 inch and fronts are alittle less...this shows the dish alittle better
'12 tech package
corksport TBE
 Old 12-10-2016, 07:19 PM   #2536
whitedevil's Avatar
you should be good with the set you bought the only possible issue would be the 40 profile tires
'12 tech package
corksport TBE
 Old 12-11-2016, 10:14 AM   #2537
kryskunka's Avatar
How so?
 Old 12-11-2016, 02:05 PM   #2538
whitedevil's Avatar
idk from the pic they seem to be alittle tall for a 2" drop just my opinion you should be fine
'12 tech package
corksport TBE
 Old 12-12-2016, 06:06 PM   #2539
sick_ed's Avatar
Posts: 2   (View Stats)
sick_ed has a little shameless behaviour in the past
Default Cosmis Wheels
So I'm looking to pick up some cosmis wheels in 18x9.5 +10 for my 08 MS3. Im riding stock height, but am looking for coils to drop a bit (not slam). Very new to the Mazda community, so any input would be great! Should i be expecting issues as far as having to camber or roll fenders? and having meaty tires? Thanks for bearing with me as i get the hang of this forum.
sick_ed is offline   Reply With Quote
 Old 12-13-2016, 05:50 AM   #2540
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Those stick out because of the low offset. +20 is a very low offset for this car.
Also, you'll be fine with those set up. 255/40/17 is close to our stock wheel diameter. If you are lowered, you're going to need a fender roll.
@whitedevil; you're going to need more than a MILD fender roll for that offset. prob need -3 degree of cambers lol.
2012 NASA Spaceship Gray MS3
The Following User Says NO Thank You to KiwiFlavor For This Un-useful Post:
 Old 12-13-2016, 08:08 AM   #2541
anavrinIV's Avatar
Groans: 63
Don't.
yes.
Your time is short
Blue Pu.
JMEngineer (12-23-2016), KiwiFlavor (12-13-2016)
 Old 12-13-2016, 03:51 PM   #2542
whitedevil's Avatar
@whitedevil; you're going to need more than a MILD fender roll for that offset. prob need -3 degree of cambers lol.[/QUOTE]
yes more then likely just trying to be optimistic
'12 tech package
corksport TBE
 Old 12-14-2016, 06:36 AM   #2543
RalliartRsX's Avatar
Posts: 366   (View Stats)
RalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the world
Yeah, you are going to need a miracle.........and a sawzall.
RalliartRsX is offline   Reply With Quote
The Following User Says Thank You to RalliartRsX For This Useful Post:
KiwiFlavor (12-14-2016)
 Old 12-14-2016, 01:07 PM   #2544
manu's Avatar
Posts: 80   (View Stats)
manu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of light
Groaned at 7 Times in 5 Posts
Raceland.com
This is pretty affordable coilovers setup
Sent from my SM-G900P using Tapatalk
manu is offline   Reply With Quote
The Following User Says NO Thank You to manu For This Un-useful Post:
 Old 12-14-2016, 01:10 PM   #2545
manu's Avatar
This is what i got ,but i got K sports coilovers and everything else is adjustable
 Old 12-15-2016, 05:15 PM   #2546
sick_ed's Avatar
Originally Posted by manu View Post
Raceland.com
I was looking into Ksport Coils but as of now I might go with BC not sure yet. Your set up looks great though.
The Following User Says NO Thank You to sick_ed For This Un-useful Post:
 Old 12-15-2016, 05:36 PM   #2547
manu's Avatar
From what i ve heard from related discussions with BC s they dont always drop as low as some will desire
 Old 12-16-2016, 01:30 PM   #2548
EvoFire's Avatar
Posts: 389   (View Stats)
EvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the world
If you haven't put them on and wonder how they look. I got the same setup but with NT-01
2009 CWP MS3 | JBR short shift plate, JBR shifter bushings, CP-e stage 2 RMM, JBR RSB, JBR Wide-Path, CS downpipe, UR catted test pipe, Cobb cat-back, Forge BPV V1, Swift Spec R springs, Bilstein B8, Whiteline KCA428 ALK, Whiteline Bumpsteer Correction, Corksport injector seals, Weds Sports SA55M 18x8 +48, Bridgestone S-04 245/40/18, BLOX Limited 490g shiftknob
Dyno'ed at 277whp/290lb-ft on 91 piss
EvoFire is offline   Reply With Quote
 Old 12-22-2016, 02:42 AM   #2549
manu's Avatar
Attachment 229807
Attachment 229808
With thewe new Wider set up you Must upgrade the suspension all around , the oem are made for the 7" stock wheels/tires and there's no tolerance
Djohns (12-22-2016)
 Old 12-22-2016, 05:56 AM   #2550
Djohns's Avatar
Posts: 3,944   (View Stats)
Groans: 112
Wrong. Just stop. That would be absurd to have to upgrade the suspension just because you have a little wider setup. And furthermore, raceland coilovers are far from an upgrade. That is the shittiest suspension on the market for our cars. Stock suspension blows that crap away.
Neverlift and KiwiFlavor like this.
2010 black mica speed3
Soon:built motor
The Following 2 Users Say Thank You to Djohns For This Useful Post:
KiwiFlavor (12-22-2016), Neverlift (12-22-2016)
 Old 12-22-2016, 06:06 AM   #2551
KiwiFlavor's Avatar
I'm on swift springs and stock struts and can fit 9" RPF1s with 5mm spacers in the front.
+1 on no on Riceland.
blackstar (07-23-2017)
 Old 12-22-2016, 07:54 AM   #2552
manu's Avatar
My stock rear right was leaking oil , and had broken bushing, thankfully was under warranty, had then around 30k ,again the following year spring broken bushings, dealer repaired, i really think the oem were very poor quality, or was mine a Bad batch.
Again the front shocks were squeaky on all of the deeper bumbs, had a pretty nasty experience
 Old 12-22-2016, 06:05 PM   #2553
alden's Avatar
I ran oem struts/shocks, CS springs, and 9.5" wide miro 398's, 18", no issues what so ever.
 Old 12-22-2016, 08:44 PM   #2554
Jonb82's Avatar
Posts: 416   (View Stats)
Jonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the world
Groaned at 24 Times in 9 Posts
Yeah? How many miles on the car? I'm looking into a nice drop next and am debating on doing struts too or just springs. I've read the stockers are garbage. Just want another point of view
Sent while probably pooping
CS TIP/SRI CS RMM CS Sexy Steering Wheel CS Springs & Struts CS Shirt Throw Shifter CS Shifter Bushings CS TBE CS Boost Tubes CP-e TMIC HKS BOV in resirc DM Vented OCC DM TMM DM PMM DM SSP Autotech Internals Custom E33 Freaktune
Jonb82 is offline   Reply With Quote
 Old 12-22-2016, 08:54 PM   #2555
Djohns's Avatar
Groans: 112
Well if so you so happen to go VIP you'll see I have springs for sale used them with stock struts and the setup was just fine.
Soon:built motor
The Following User Says Thank You to Djohns For This Useful Post:
KiwiFlavor (12-23-2016)
 Old 12-23-2016, 04:46 AM   #2556
KiwiFlavor's Avatar
About 48k miles.
Stock struts is prob around 30k miles on them and 20k miles on Swift springs (Prob even less. I don't feel like doing the math this early lol). I had Ksport coilovers and they blew within a year. To be fair tho, I bought them used so yeah.
 Old 12-23-2016, 04:48 AM   #2557
anavrinIV's Avatar
Groans: 63
No mention of offset or tire specs....wheel width is only one part of the equation
Blue Pu.
 Old 12-24-2016, 12:44 AM   #2558
alden's Avatar
Damn, totally forgot to mention that. et 35, 235 re760 sports!
 Old 03-05-2017, 03:50 PM   #2559
Astrall's Avatar
Posts: 109   (View Stats)
Astrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to behold
I'm sure this is gonna catch a lot of flame but its in the right section lmao.
Gen 1 speed 3 18x9.5 +22 w/ 215/35/18
Bc Extreme Low
Rear Camber Arms
Quality time with a fender roller
manu likes this.
Last edited by Astrall; 03-05-2017 at 03:51 PM. Reason: MSF Database - Automerged Doublepost
Astrall is offline   Reply With Quote
 Old 03-05-2017, 05:01 PM   #2560
Djohns's Avatar
Groans: 112
Bc Extreme Low
Rear Camber Arms
You are correct this is the proper section. I would love to flame you, and normally I would haha but I respect the blue lives matter sticker. Therefore, you sir, have a free pass. Enjoy it, because I don't give many of those away.
Soon:built motor
Page generated in 0.61370 seconds with 32 queries
