Like Tree4Likes
 Old 12-13-2013, 03:58 PM   #41
ms3fanboy's Avatar
Posts: 9   (View Stats)
ms3fanboy will become famous soon enoughms3fanboy will become famous soon enough
Are any of you guys with FD wheels on coilovers? I bought some from a local drifter with 195 55 16s and the tire hits the spring seat. Will a spacer fix this? I tried searching but no luck
Sent from my SGH-M919 using Tapatalk
ms3fanboy is offline   Reply With Quote
 Old 12-17-2013, 09:58 PM   #42
snakedoc's Avatar
Posts: 33   (View Stats)
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
Groaned at 7 Times in 2 Posts
unknown im on lowered springs and i dont rub, 255/50/16 if i recall right...
08 Speed3
Mods- Fully Built/ Wiseco pistons(stock bore)/Manley H-beams/Gtx3076 EWG/ All supporting bolt ons/ Tuned e juice
Track times
Stock turbo best 12.5@112mph with hoosier QTP
Bnr S3 best 12.4@117mph with Mickey et streets
snakedoc is offline   Reply With Quote
 Old 03-26-2014, 12:06 PM   #43
Adam is so pro's Avatar
Posts: 410   (View Stats)
Adam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the world
Groaned at 27 Times in 15 Posts
Adam is so pro is offline   Reply With Quote
 Old 04-02-2014, 09:05 AM   #44
dtrackstar's Avatar
Posts: 72   (View Stats)
dtrackstar is a splendid one to beholddtrackstar is a splendid one to beholddtrackstar is a splendid one to beholddtrackstar is a splendid one to beholddtrackstar is a splendid one to beholddtrackstar is a splendid one to beholddtrackstar is a splendid one to behold
Any ms6s running qtps?
Sent from my Nexus 4 using Tapatalk
dtrackstar is offline   Reply With Quote
 Old 04-02-2014, 02:37 PM   #45
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Groans: 112
I don't think so, but the few with 700+ will need them or a radial. Going to start spinning and hurting their 60Ft
Sent from your girlfriends tapabedroom
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-03-2014, 10:18 PM   #46
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
They could probably benefit from a little wheel spin.
Just tapa it in.
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
udntknw is offline   Reply With Quote
The Following User Says Thank You to udntknw For This Useful Post:
Voltron (04-28-2014)
 Old 04-04-2014, 06:58 AM   #47
PapaSmurf's Avatar
Groans: 112
Just tapa it in.
a little? I have seen 600hp evo's/sti's here that spin badddd. Big difference with a radial or slick set up on awd.
Ive seen certain cars here run 1.7-1.8 60 ft on street tires spinning and then when they switch to a radial/slick set up they were running 1.4-1.5's
2-3 tenth gain in a 60ft is HUGE.
860whp/677wtq
2.7 V6 Ecoboost
The Following 3 Users Say Thank You to PapaSmurf For This Useful Post:
mxlplx71 (04-04-2014), MZRSPEED (04-05-2014), Voltron (04-28-2014)
 Old 04-04-2014, 07:37 AM   #48
udntknw's Avatar
I didn't realize they were spinning that bad and street tires at lower numbers. Haven't seen much for compared 60' times with street vs drag tires.
Just tapa it in.
**Old Motor**
**New Motor**
 Old 04-23-2014, 07:38 AM   #49
What kind of skinnies you guys running?
 Old 04-23-2014, 09:11 AM   #50
PapaSmurf's Avatar
Groans: 112
15x4 1.75 backspacing
860whp/677wtq
2.7 V6 Ecoboost
The Following User Says Thank You to PapaSmurf For This Useful Post:
MZRSPEED (04-25-2014)
 Old 04-23-2014, 12:19 PM   #51
oh wolla
 Old 04-28-2014, 05:32 AM   #52
What tire pressure you guys running?
 Old 04-28-2014, 07:12 AM   #53
PapaSmurf's Avatar
Groans: 112
whatever hooks the best for your car and weather situation.
Ive tried anywhere from 8psi-16psi.
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-28-2014, 07:17 AM   #54
Voltron's Avatar
Posts: 4,556   (View Stats)
Groans: 77
I think a little bit of spin for the awd guys are good. If they dead hook, shit is going to break fast.
As for tire psi, it really all depends on the track. Ive tried from 6 to 12, and usually if I can get a nasty long burnout in, 11 seems to be magic number for me.
The Following 3 Users Say Thank You to Voltron For This Useful Post:
Adam is so pro (04-28-2014), dtrackstar (05-28-2014), PapaSmurf (04-28-2014)
 Old 05-28-2014, 10:31 AM   #55
 Old 01-07-2015, 08:34 PM   #56
snakedoc's Avatar
Default question
OK, so I had the 26x9.5 qtps before on fd wheels , has anyone had something else on them that are better, wider or just different.
08 Speed3
Track times
 Old 03-04-2015, 09:26 AM   #57
kungfumonkey1131's Avatar
Posts: 50   (View Stats)
kungfumonkey1131 has a spectacular aura aboutkungfumonkey1131 has a spectacular aura about
Does anyone on here have experience with these tires on the track?
Hankook Ventus TD Z221 Hard
I can get them new for pretty cheap right now but not sure if I should go with these or Toyo R888. Its a difference of about $25 per tire. I will be running 235/45/17 for now.
kungfumonkey1131 is offline   Reply With Quote
 Old 08-26-2015, 09:20 AM   #58
tanspeed3's Avatar
Posts: 23   (View Stats)
tanspeed3 is just really nicetanspeed3 is just really nicetanspeed3 is just really nicetanspeed3 is just really nice
28×11.5×16 MT ET slicks. I found a sweet deal on them. Anyone use?
Sent from my SGH-I337M using Tapatalk
CWP Pu. #gingerbuilt longblock, gtx3076r, self tuned on 94, 420whp, 408wtq. 2015 highest HP in Ontario.
CWP Juan. Speed#2. The racecar. Rebuild commencing.
tanspeed3 is offline   Reply With Quote
 Old 08-26-2015, 10:03 AM   #59
NCspecV81's Avatar
Posts: 2,867   (View Stats)
NCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the world
Groaned at 32 Times in 17 Posts
@tanspeed3; good luck getting those to fit.
2013 CWP and Stock
NCspecV81 is offline   Reply With Quote
 Old 08-26-2015, 11:07 AM   #60
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
No luck needed. They will not even come close to fitting.
The Following User Says Thank You to Realgib3 For This Useful Post:
NCspecV81 (08-26-2015)
 Old 08-26-2015, 11:12 AM   #61
tanspeed3's Avatar
Ok I kinda figured that haha. Thanks boys! @ncspecv81 @realgib3
 Old 05-05-2019, 09:58 AM   #62
Bmurray94's Avatar
Posts: 22   (View Stats)
Bmurray94 will become famous soon enough
Bump
Anyone know if my 26x9.5-16 Hoosier qtps from my evo will fit okay on the front of the gen1? On a 16x7 +40 Rota slip. The evo requires a 25mm spacer to clear the huge brakes.
07 GT MS3 - TBD
06 SSL Evo 9 - 10.1 @ 149.9mph
@Bmurray_evo9
Bmurray94 is offline   Reply With Quote
Slicks / Drag Radials 9900rpm 2010 MS3 - Wheels & Tires 8 11-27-2009 03:42 PM
15" slicks on your MS3? Would you like... ptperformance Mazdaspeed3/6 General Discussion 19 01-25-2009 08:13 PM
Page generated in 0.39268 seconds with 31 queries
