-   -   Offset help with 17x8s (http://www.mazdaspeedforums.org/forum/f319/offset-help-17x8s-54875/)
Nazarite 04-23-2010 08:55 PM
Hey guys, I'm finally getting around to rims. I'm going 17x8 for weight savings. I want to run a 245 width. Not sure what height tire I would need (50?) Could I do this without rolling the fenders? Or should I just go 17x7.5 and run a 235? Also, what would the offset be for both of these setups? And finally, anyone doing this with rpf1s?
Nazarite 04-23-2010 09:27 PM
bump
Kick in the Box 04-25-2010 08:15 AM
For Autox I run a Rota 17x8-48 offset 245/40/17 Hoosier A6 with no Issues.... Little roll with heat and rubber mallet.
dbrier 04-26-2010 06:46 AM
245/45/17 is the perfect size, very close to the OEM diameter.
Most people with that size will have to roll the rear fenders and some 245 tires are wider than others. You'll be fine with an offset between +53 and +48 with a fender roll.
If you absolutely don't want to roll the fenders, keep the offset as high as you can and run a 235/45/17.
TongMan 04-26-2010 08:10 AM
Would 18x9.0 fit on a mazdaspeed3? I don't want to roll my fenders. What offset can I run without issues?
Nazarite 04-26-2010 08:39 AM
Check out the my crazy offset thread. There's like one guy who's trying that. I don't remember who though...
P5_2_MS3 04-26-2010 11:42 AM
245/45-17 is actually within spec to fit on 17x7.5. The result is a bit bubbly, but it's within manufacturer's rim width range (7.5-9 for 45 profile). I run this tire size on Racing Hart CP-035's with a 48 offset.
TongMan 05-01-2010 06:44 PM
Sorry that I'm threadjacking, but I didn't want to start a new thread for this. Will a +35 offset on a 18x8.0 rim fit my mazdaspeed3? I tried using the calculater but don't understand it.
madvillain 05-02-2010 01:12 AM
Yes, a 35 offset will fit great with a small amount of fender rolling in the rear, depending on what tires you want to run and what suspension setup you have.
Here's the best example of 18x8 +35. scroll down and theres tons of pictures
stripes or no stripes - Mazda Forums
a lil weekend preview - Mazda Forums
FenixTX717 05-02-2010 01:42 AM
Also not to high jack the thread but might as well keep this going instead of starting a new one since I kind of understand off-set but don't.
I'm looking at 17x8.5 with 245/45 tires at a 35mm offset on the stock suspension. I will plan on rolling my fenders in the future but would I be fine with running them with teh stock suspension for now or would I definately need to get the fenders rolled before hand?
Also, the lower the offset means the center of the rim will stick out toward the fender vs. a higher offset which sinks in and that is what gives a deeper lip correct?
CeeeJay 05-02-2010 01:46 AM
i have enkei rpf1, 17x9, +45mm offset, and 235/45-17 tires. the rears need to be rolled though
Mifunego 05-02-2010 02:08 AM
Pics?
CeeeJay 05-02-2010 02:25 AM
http://carphotos.cardomain.com/ride_...0102_large.jpg
More pics here: http://www.cardomain.com/ride/3066081
tigermack 05-05-2010 02:58 AM
Anything 8" wide pretty much need to get rolled.
VTEC_EATER 05-05-2010 03:03 PM
I am running 18x8 +40 with the stock rubber (stock ride height) and it does not need to be rolled for this. You might be able to get away with a 225 tire as well, but a 235 will need to be rolled.
Any 9" wheel will need a roll in the rear. It doesn't matter what your offset is.
You will need a good amount of rolling in the rear. That setup will actually stick out of the rear fender just a touch. Possibly the front as well, but you probably wont be rubbing in the front.
Don't think of it as the center of the wheel. That will always be in the same place - right against the hub. Its the outer rim of the wheel that moves. The lower the number, the further out the rim of the wheel sits. The higher number, the further in the rim of the wheel sits. Wheels with lower offsets will have a larger lip (depending on the design of the wheel) than wheels with higher offsets.
FenixTX717 05-05-2010 04:03 PM
Thanks that helps a lot! I still wish I could find that website that had the pictures and explained it as well. Was a great site for noobs like myself that don't know much about offset.
speedyhans 05-07-2010 03:26 PM
Originally Posted by CeeeJay (Post 506092)
is this ur ms3
CeeeJay 05-07-2010 03:45 PM
Originally Posted by speedyhans (Post 512134)
is this ur ms3
yep
speedyhans 05-07-2010 05:46 PM
look real good i love how it look in white lol i just got my autoexe front bumper and im loving it 2
Page generated in 0.18828 seconds with 11 queries
