 Old 10-04-2008, 11:43 AM   #1
08cosmic3's Avatar
Posts: 2,920   (View Stats)
08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world
Groaned at 54 Times in 43 Posts
Default 17x7 with 42 offset. anyone?
I'm looking at these wheels from Tire Rack. They are 17x7 and only 14.1 lbs each. That would be 11 lbs lighter than stock. The offset is 42mm, would that be a problem? Anyone here have these? Do you think maybe they are too light?
Kosei K1 TS Silver Painted
08cosmic3 is offline   Reply With Quote
 Old 10-04-2008, 11:47 AM   #2
Lymerock's Avatar
Posts: 1,436   (View Stats)
too light, never
will they stick out too far at +42, more than likely
stock offset is +52.5 so your rims center will be 10mm further out than stock.
I would also suggest looking for something wider than 7, unless you plan to stay with 225's or narrower tires
general prefered offset is either 48 or 50 for most aftermarket rims
some people are rocking +45's but you gotta be sure of your clearances for that, and with a 42, you better be really sure you can fit it before ya go with it
 Old 10-05-2008, 08:50 AM   #3
08cosmic3's Avatar
Ok, Ive got one saying no to 42 offset here and one Yes on another site. Anyone else, please.
 Old 10-05-2008, 11:26 AM   #4
JCMS07's Avatar
Posts: 349   (View Stats)
JCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the world
PM Steven88. I've checked his car out and I'm pretty sure he has the same Kosei K1 TS rims.
JCMS07 is offline   Reply With Quote
 Old 10-06-2008, 12:56 PM   #5
bnoon's Avatar
Posts: 1,770   (View Stats)
on a 7 inch wide rim 42 offset is totally fine. Go for it.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
bnoon is offline   Reply With Quote
 Old 05-15-2018, 11:04 AM   #6
Dkills16's Avatar
Posts: 3   (View Stats)
Dkills16 has a little shameless behaviour in the past
Default wheel questions
what would it take to run a 17x9 +45mm offset rpf1?
Dkills16 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Dkills16 For This Un-useful Post:
Pu Manchu (05-16-2018), Thor Hammer (05-15-2018)
 Old 05-15-2018, 11:26 AM   #7
Djohns's Avatar
Posts: 3,944   (View Stats)
Groans: 112
#1 fuck you for bumping this old thread.
#2 there’s an entire thread to answer this question.
2010 black mica speed3
Soon:built motor
The Following User Says Thank You to Djohns For This Useful Post:
 Old 05-15-2018, 11:34 AM   #8
MoMS3's Avatar
Posts: 235   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
Depends on tire size, I run these with 245/40r17 on stock ride height gen2 with no rub (slightly 4x4 status wheel arch gap), 5mm spacers up front for strut clearance.
That said, you really should put on your big boy try-hard pants and do some research (seriously, I had the same question and was able to figure it out via google within 5min)...oh, and don't resurrect old threads from 10 years ago like a necro.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
 Old 05-15-2018, 02:37 PM   #9
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
1. A jack
2. Tires
3. Socket
4. Breaker bar
5. Torque wrench to hit yourself over the head with.
The Following 2 Users Say Thank You to Thor Hammer For This Useful Post:
Djohns (05-15-2018), MoMS3 (05-15-2018)
 Old 05-15-2018, 02:45 PM   #10
MoMS3's Avatar
Originally Posted by Thor Hammer View Post
1. A jack
2. Tires
3. Socket
4. Breaker bar
No no, use the breaker bar for bashing the head, at least then they haven't thrown off the torque calibration for the next guy.
The Following 2 Users Say Thank You to MoMS3 For This Useful Post:
Djohns (05-15-2018), Thor Hammer (05-16-2018)
 Old 05-16-2018, 05:43 PM   #11
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,982   (View Stats)
Groans: 546
the ten year bump
94 M
06 MS6
will an 38 offset be ok? SLOMS3 MazdaSpeed 3/6 - Wheels & Tires 11 10-10-2008 12:57 PM
Question about this steering wheel.... Babyface MazdaSpeed 3/6 - Appearance 9 09-13-2008 01:48 PM
Wheel/tire fitment question chodaboy1980 MazdaSpeed 3/6 - Wheels & Tires 1 09-01-2008 11:17 PM
Page generated in 0.31742 seconds with 28 queries
