 Old 06-19-2008, 09:30 AM   #1
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Default Ok, i need tires..
So my tires are looking pretty tore up after 16K... and to be honest, im sick of these 215s on an 8 inch wheel.
I really really want to squeeze 245s under this thing.. so.. what is your recommendations for tires to look at? Ill be doing the coilovers at the same time btw.
 Old 06-19-2008, 09:48 AM   #2
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
i have 235/40's definatly more traction BUT you can say goodbye to the light nice feeling of the steering.. plus taking hard fast turns it seems it doesn't feel as stable. If i could go back i prob would have gone 225/45-or40..
 Old 06-19-2008, 09:50 AM   #3
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
^ but dont you have 235/40 on the stock 7" wheels?
 Old 06-19-2008, 09:50 AM   #4
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Hmm, well taking high speed turns on 215's isnt a very good feeling either.
 Old 06-19-2008, 09:52 AM   #5
gsrtype1's Avatar
Groans: 102
yes i do, it may make a diff with diff wheel
 Old 06-19-2008, 09:53 AM   #6
gsrtype1's Avatar
Groans: 102
feels safer-better with 215 than 235... on the stock wheel
 Old 06-19-2008, 09:54 AM   #7
gsrtype1's Avatar
Groans: 102
foward traction is definatly improved though with the wider tire
 Old 06-19-2008, 09:58 AM   #8
aaronc7's Avatar
Groans: 370
I have 235/40 on a 7.5. Feels like maybe i should have went with a slightly more narrow tire (225). According to some tire specs I just looked up, 235/40 or 245/40 should be OK iwth 8" wide wheels.
With that said, I'll probably be getting different wheels soon (8"), I will try to squeeze 245s in.
 Old 06-19-2008, 10:28 AM   #9
redrocketz's Avatar
Posts: 1,122   (View Stats)
redrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond repute
when you figure out which ones you want let me know I may be able to help you out with prices.
redrocketz is offline   Reply With Quote
 Old 06-19-2008, 11:05 AM   #10
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Zach, thats the problem. I dont know which ones would fit. Ive heard of some guys who have made it work, but its not discussed in length. ill be forced to go local to see if this can be done. i dunno, maybe i would be better off with 225 but than again, that wouldnt be going extreme either and i want extreme tires
kpsoerensen (05-27-2010)
 Old 06-19-2008, 11:22 AM   #11
blaggah's Avatar
Posts: 132   (View Stats)
blaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud ofblaggah has much to be proud of
The Dunlop Z1 Star Spec seem to be all the rage right now. On a 8" wide wheel I think you can run these at 225 and have it not be too tight. If I decide to go with these tires, that's the size I will run on my 16x8.
Here's a link that compares the Dunlops at 235 to Hankooks at 225
SCCAForums.com - Dunlop Direzza Sport Z1
Looks like a much bigger difference than 10mm.
blaggah is offline   Reply With Quote
 Old 06-19-2008, 11:24 AM   #12
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Thanks blag. I did go with a 8 inch wheel to run a bigger tire than a 225 though. That gives me a brand to start with at least. Ill keep you updated on my findings.
 Old 06-19-2008, 11:36 AM   #13
Anklh's Avatar
Posts: 166   (View Stats)
Anklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond repute
I went with SO3's 225/45 on my 18x8 48 off rim
Soon as I wear those down I will be deciding between 245/40's with Bridgestone Potenza REO50A Pole Position, Yokohama (if I can find Neova's in that size), Goodyear or the new "dark horse"...Sumitomo HTR Z lll, which TireRack raves about.
Anklh is offline   Reply With Quote
 Old 06-19-2008, 11:39 AM   #14
mdogg's Avatar
Posts: 841   (View Stats)
mdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the world
Groans: 86
Groaned at 36 Times in 25 Posts
Sumitomo HTR Z III - Max Performance Summer tires 245/40/18
I got them only $500 shipped from TireRack
300 treadwear rating
Amazing grip so far in dry weather - I haven't "tested" on anything wet yet...
They are so cheap that even if they aren't the perfect tire for you, you wouldn't feel so bad about ditching them.
What's your price range? Knowing the little about you I do know.... that's probably a dumb question though. If you want something grippier - I would say the BFG KD.... (not the KDW) but those are quite a bit pricier - something in the $250/wheel range IIRC
L76-powered
mdogg is offline   Reply With Quote
 Old 06-19-2008, 11:39 AM   #15
ztuner's Avatar
Posts: 554   (View Stats)
ztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the world
Default >>>
Not sure if you are willing to try this but i am thinking of going 245/45/17's vs 18s. This should should give me more width (lateral grip )as well as a taller sidewall which should help straightline traction. Downside might be reduction in steering response.
Harry
ztuner is offline   Reply With Quote
 Old 06-19-2008, 11:44 AM   #16
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
I really didnt want to go 17's but i also dont like the fact i need to go 40's on an 18. Either way, it sucks but i got to make due with what i got now. I hate small wheels for daily driving.
 Old 06-19-2008, 12:11 PM   #17
blaggah's Avatar
Well at leas you have more options on 17" and 18" wheels. Options for a 16" in a wider tire are very limited, not much larger than 225/50(55)-16, only a few 245/50-16 and I have not been able to find anything at 235/xx-16
 Old 06-19-2008, 03:34 PM   #18
Laloosh's Avatar
Posts: 5,166   (View Stats)
Groans: 57
go with 235/40/18 falken 615s or kumho mxs
azenis if ure autox
mxs if u drive hard on the street
 Old 06-19-2008, 04:04 PM   #19
blaggah's Avatar
What's the everyone's opinion of General UHP's? I don't autoX, mostly a daily driver car for me with the occasional spirited canyon run.
For my future wheels size, they are the lightest "performance" wheels I've found. 21lbs a tire + 15.5lbs a wheel should be a nice drop from the stock setup.
 Old 06-20-2008, 04:23 PM   #20
MadOzodi's Avatar
Posts: 686   (View Stats)
MadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the world
I still have the stock 215/45/18s on my 18x8 +48 rims. As soon as those are worn down, I also plan on 245/40/18s since that size gives the same tire height as the stockers at 25.7"
Only suspension mod I plan on doing is the Cobb rear sway. Only lowering I'll do is if Stretch comes through with new springs/koni yellow setup through CPE.
07 COSMIC BLUE MS3 GT
00 OBSIDIAN BLACK TRIUMPH LEGEND TT 900 - gone, but not forgotten
09 PACIFIC BLUE TRIUMPH SPRINT ST 1050 - SOLD
11 BLACK SUZUKI GSX-R750 - totaled
11 BLACK SUZUKI GSX-R750 - totaled...again
*OFFICIALLY RETIRED FROM TWO WHEELS*
MadOzodi is offline   Reply With Quote
 Old 06-20-2008, 06:15 PM   #21
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
That Koni setup would really be badass if that goes through!
Well, option 1, 2 and 3 is for 245/40/18... only option 4, less than 245 will go into affect if i cant get this to work, but im going to try my hardest.
 Old 06-20-2008, 06:38 PM   #22
ztuner's Avatar
i use the generals on my infiniti - i have to say great tire fore the money - excellent ride , very good grip but sidewalls are soft so turnin is a bit squishy
Harry
 Old 06-20-2008, 06:47 PM   #23
Demi's Avatar
Posts: 1,107   (View Stats)
Demi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the world
Groans: 61
Groaned at 16 Times in 11 Posts
Well i went with Nitto NT-555s. Got em cheap too.
2-Day Parts - Search Results Here are some good prices.
Amazing tire. Slayed the 2nd gear wheel spin monster (mostly its still a 225), and the cornering improvement is phenomenal. I went with 225/40/18 because im still running stockers, but the have all the sizes you could want. I think I have found my tire of choice. They look sick as balls on the car too.
Beginners guide to turbos<- New to this? Give it a look!
-And for the rest of you, if it comes from Autozone and doesnt replace something that broke off your car or make your cabin smell like Coco Butter, its fucking rice.
Demi is offline   Reply With Quote
 Old 06-20-2008, 07:21 PM   #24
redrocketz's Avatar
I had 555's on my last car and loved them but any sign of rain and I was hanging on for dear life it seemed.
 Old 06-20-2008, 07:29 PM   #25
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
I had those on my Cobra and felt the same way.
 Old 06-20-2008, 11:18 PM   #26
Demi's Avatar
Groans: 61
Lol i live in AZ so i have no idea.
 Old 06-21-2008, 10:30 PM   #27
Young Roids
Lurkers
Young Roids's Avatar
Posts: n/a
I haven't ran them but I have heard the hankook Ventus R-S2 is about as good as the falken azenis 615 so they may be worth a try.
Hey demi, how does it feel cornering with those 225s on your 7 inch rims? Because I am debating weather or not to run 235s on 7.5 inch rims wich would be about the same amount over.
 Old 06-22-2008, 12:26 AM   #28
Radar_This's Avatar
Posts: 1,134   (View Stats)
Radar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the worldRadar_This is the leader of the world
i am running toyo 225/45's...love them...
Radar_This is offline   Reply With Quote
 Old 06-22-2008, 07:10 AM   #29
CMESCOOT's Avatar
Posts: 429   (View Stats)
CMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the world
check out the nitto envo's.
http://active.com/donate/1soldier
Making the world a safer place one Taliban at a time.
Arias 8.8:1 Pistons - Pauter rods - Balance Shaft Delete - ARP Head Studs - Street Unit Rear Motor Mount - TurboXS Hybrid BOV - TurboXS Downpipe - - TurboXS FMIC - CP-E CAI - Custom Built/ported and polished Turbo and Wastegate - CP-E Engine Management - Upgraded high pressure fuel pump - PG Turbo Exhaust manifold - PG Dash mount gauge pod - Cooling Mist Progressive Methanol Injection - Apexi TT - VEI gauges (oil pressure, boost ) - Dashhawk -LaminX Fog lights - H&R Sport Springs - Cobb Rear Sway Bar - Tenzo DC-s wrapped in Nitto InVo's - TWM short throw shifter and bushings
CMESCOOT is offline   Reply With Quote
Anyone try these NanKang tires? BlackMS3 MazdaSpeed 3/6 - Wheels & Tires 16 07-29-2008 09:30 PM
Ordered new tires! MS3-oholic MazdaSpeed 3/6 - Wheels & Tires 25 06-07-2008 10:18 PM
got new tires det_ms3 MazdaSpeed 3/6 - Wheels & Tires 0 05-08-2008 10:50 AM
Q Tires testing Celsius retractable-stud snow tires Haltech Automotive News 0 04-01-2008 10:40 AM
Page generated in 0.45214 seconds with 32 queries
