  • 1 Post By Jeff23spl
 Old 06-03-2019, 12:03 PM   #1
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
Default Optimal setup for 255's?
I am a suspension/wheel noob. I can rebuild motors but when it comes to wheels offsets and width of tires, I don't know much. With that being said, I've gone over the "WILL IT FIT" post many times, but I still don't know what the hell I need lol..
Desired set-up: 255's for traction when I put down 500+whp. With some wheels that I like (ill look once I know what size/offset to get). And a flush look. I don't mind going 17's or stay 18's. But I'd like to get a flush look and being able to run 255's with no rubbing.
I have bilstein B12's on stock springs currently, which ill be going to probably Swift springs for a stiffer spring (I've read they're good springs to pair with bilsteins). But open to other suggestions.
So.... What wheel size do I look for, to avoid needing spacers, and fender rolling if possible. I understand avoiding rolling isn't a guarantee.
Thanks guys
2008 Ms3 Black Mica R.I.P. March 2008 - March 2016. MODS: HTP 3" intake, CX Racing FMIC with TR8 core, BNR S3, AP V3, Kozmic EGR delete, Matt Damond OCC, JBR short shift plate with bushings, HIDS, CP-E injector seals, TIG, 1 step colder plugs, Grimspeed EBCS, CS RMM, JBR passenger MM, motor craft tranny fluid, Autotech Internals
Current:
08.5 Ms3 cwp GT: Built block (sp63 4032 pistons, eagle h beams, CA625+ rod bolts/head studs, arp main studs, key'd crank, supertech 55lb valve springs, bsd delete, Block/pistons/rings/bearings WPC treated), HTP 4" intake, bnr S5 turbo (when it comes out), HTP hotside under route pipes, TR8 core, custom made cold pipes, ST intake mani, TIG, CP-E downpipe, CNT CBE, autotech hpfp, AP V3, grimmspeed ebcs, GA v3, TWM short shift assembly, JBR short shift plate, HFS-4 Meth kit, HTP front mount custom meth tank, damond motor mount trilogy, damond 3 port pcv plate, dual damond catch cans (one vented), step colder plugs, corksport injector seals, GFB bov, 51r battery, Bilstein B8 shocks, OZ ultralegga rims, custom oem clutch with Kevlar, Gen 2 trans.
2003 Mazdaspeed protégé (spicy orange); pope E manifold and DP, injen cai, PoS fmic kit, Twisted motion gt2871 turbo, aem fic-6.
HaXiR is offline   Reply With Quote
 Old 06-03-2019, 12:28 PM   #2
shamie's Avatar
Posts: 944   (View Stats)
The honest answer is it all depends on everything.
The Gen Ones have a window you have to get into where the fronts don't rub the suspension and the rears don't rub the fenders. Rolling and spacers will most likely be your friend - or get different wheel offsets front and rear.
 Old 06-03-2019, 12:39 PM   #3
HaXiR's Avatar
Yeah that's my dilemma, what offsets would be needed if someone knows based on experience
Current:
 Old 06-03-2019, 06:15 PM   #4
Federighi's Avatar
Posts: 40   (View Stats)
Federighi is a jewel in the roughFederighi is a jewel in the roughFederighi is a jewel in the rough
You'll need a min rim width of 9.0 to fit 255 correctly. 17 or 18 is up to you (tires for 17's are much cheaper). Offset depends on many things; I've got camber plates in the front and adjustable arms in the rear.
My current street set: BBS Type CH 18x8.0 +38 225/40's Hankook v12 evo / Track set: Volk Racing GT-P 17x9.0 +42 255/40 Toyo r888r
@-2.0 camber all around.
*previously ran: SSR GTV01 18x8.5 +44 245/40 Dunlop Sport MaxxRT & same Volks with 255/40 Hankook Rs-3.
GL!
Federighi is offline   Reply With Quote
 Old 06-04-2019, 08:34 AM   #5
HaXiR's Avatar
GL!
From what ive been gathering, 17x9 +45 is a the wheel size I need for a flush look and big enough for 255's, it will then be about getting some front and or rear fender work to make it fit.
Current:
 Old 06-04-2019, 10:24 AM   #6
Jeff23spl's Avatar
Posts: 2,115   (View Stats)
i don't care about the look, i ran Toyo t1S 245 40 18 on my speed3 on rx8 stock wheels and stock coils. I had to roll the rear fenders to avoid rubbing and there was still some room probably for 255. 245 was already a bit large for the wheels....
This setup added a lot of cornering feel but it was chasing left to right a lot more on uneven pavement.
I was just running close to 400 crank hp with a bit more torque and it was still traction limited for the first 2 gears....I gave up and bought a 6
Fstrnyou likes this.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Jeff23spl is online now   Reply With Quote
Fstrnyou (06-04-2019)
 Old 06-04-2019, 05:27 PM   #7
shamie's Avatar
All 255s are not created equal. These 245s are wider than any 255s I've ever seen but I got them to fit with just 5 (or 8) mm spacers up front. And rolled fenders in the rear. And some camber -> -2.9 front & -1.9 rear.
245/40/17 Hoosier R7
17/9et45 Enkei RPF1
Not hitting optimal boost. lazeryth MazdaSpeed 3/6 - Troubleshoot/Diagnostics 27 12-03-2013 09:23 AM
Optimal Air Straightener Position for CAI haulme MazdaSpeed 3/6 - Turbo Induction 3 03-10-2013 04:42 PM
Less than optimal performance funkytuqe MazdaSpeed 3/6 - ECU Computer Tuning 26 08-08-2012 08:36 AM
Optimal cal/tweak for now ? x09MS3GT MazdaSpeed 3/6 - ECU Computer Tuning 7 03-28-2012 04:14 PM
optimal shifting in MS3 bbonkboy MazdaSpeed 3 - How-To's 31 06-11-2011 11:56 AM
Page generated in 0.28442 seconds with 24 queries
