 Old 02-07-2015, 05:41 AM   #1
license2ill's Avatar
Posts: 313   (View Stats)
license2ill is infamous around these partslicense2ill is infamous around these parts
Groans: 30
Groaned at 132 Times in 57 Posts
Default Rear Camber Issues Solved!
Cambertire - Patented Technology
Behold....the lopsided tire:
Stance away, for a flat contact patch.
license2ill is offline   Reply With Quote
 Old 02-07-2015, 05:49 AM   #2
brandon3212's Avatar
Posts: 425   (View Stats)
Interesting concept, it looks like it's actually done for handling.
I can see how stance fags would love this though...
07 Speed 3
Handling: H&R Springs, Koni yellow shocks, JBR .250 Competition RSB, Whiteline poly control arm bushings, Custom 1/2" rod end RSB links, JBR 88D Trilogy, steel RMM bushings, Sparco Pro 2000 race seat (driver), Kirkey race seat (passenger), shift plate, 18X10.5 +15 RPF1, 275/35 18" Nitto NT01
Brakes: Wilwood 6 piston calipers, Cobalt Friction XR1 race pads
Power: Custom 3.5" intake, Synapse Diverter valve, dual 3" Hood Exit, BNR S3, Treadstone 3126 core, 3 port EBCS, 3" custom cold pipe, 2.5" custom underroute hot pipe, Aquamist HSF4
The Following User Says Thank You to brandon3212 For This Useful Post:
Mauro_Penguin (02-07-2015)
Corksport Struts, JBR Rear Sway Bar, JBR Rear Camber Arms Install/Initial Feedback Sinister_Speed3 MazdaSpeed 3/6 - Suspension & Brakes 15 11-25-2015 08:03 AM
How I solved me power steering overheating issues MATT DAMOND MazdaSpeed 6 - Engine, Transmission & Driveline 20 04-09-2015 04:57 PM
Page generated in 0.22886 seconds with 21 queries
