-   -   Rota torque offset? (http://www.mazdaspeedforums.org/forum/f319/rota-torque-offset-103112/)
S-hendrix 01-24-2012 04:54 PM
Rota torque offset?
A buddy of mine has a set of rota torque 18x8's. He has 3 so I will need to buy a 4th. I'm not in town right now but I would like to order it and have it ready to go when I get back. So anyways I was hoping someone could tell me the offset. I just have 1 picture.to go off of. I test fitted them on the front and had no rubbing with a drop on eibach sportlines and koni yellows. The back will need a very slight fender roll. Any help would be appreciated.
Attachment 50450
Sent from my DROID X2 using Tapatalk
Design 01-25-2012 12:58 PM
Most are +48. I assume you confirmed the bore and bolt pattern?
S-hendrix 01-25-2012 01:18 PM
Yep I test fitted them. I'm assuming they are +48 because the fronts fit without rubbing on my drop.
cabrone 01-25-2012 01:29 PM
I could have sworn it says it on the wheel (inside) on my old torques...
Tapatalked
S-hendrix 01-25-2012 01:33 PM
Its supposed to be stamped in there but we can't find it if it is.
3mazdaspeed 01-25-2012 01:35 PM
+48s around and you really shouldn't have to roll fenders. Good luck though.
S-hendrix 01-25-2012 01:49 PM
Cool. Thanks man. Maybe they are 35 because they are close to rubbing in the front and on the back they rub the fender.
cabrone 01-25-2012 05:42 PM
On the back it may be here http://t0.gstatic.com/images?q=tbn:A...0Kh-dL_rPtDAfs
Or perhaps here http://t3.gstatic.com/images?q=tbn:ANd9GcSUVec8r-Z5g20XbURkc6cqSz54KdKteR8eBu0A_ihG3bIHfEwq
Tapatalked
S-hendrix 01-26-2012 05:35 AM
Originally Posted by cabrone (Post 1227466)
Thanks alot man. With your pics my buddies were able to find it. It is a +35. That explains the fender roll. I appreciate everyone's help. Now its time to order a wheel. :) Ill post pics when I get them put on.
tbcota25 02-02-2015 01:40 PM
How much do the rota torques weight?
Page generated in 0.17540 seconds with 11 queries
