 Old 01-24-2012, 04:54 PM   #1
S-hendrix's Avatar
Posts: 1,410   (View Stats)
S-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the world
Default Rota torque offset?
A buddy of mine has a set of rota torque 18x8's. He has 3 so I will need to buy a 4th. I'm not in town right now but I would like to order it and have it ready to go when I get back. So anyways I was hoping someone could tell me the offset. I just have 1 picture.to go off of. I test fitted them on the front and had no rubbing with a drop on eibach sportlines and koni yellows. The back will need a very slight fender roll. Any help would be appreciated.
Sent from my DROID X2 using Tapatalk
BNR S3 . FREEKTUNED . COBB FMIC . COBB CBE . SURE full 3" . CPe Safe Seals . KMD Internals . Grimmspeed EBCS . Guardian Angel . TWM Short Shifter Replacement . MSD DashHawk V2 . Turbo XS DP+RP . Turbosmart Hybrid BOV (full recirc) . JBR SSP+Bushings+Knob/ Rear Sway Bar/ Rear Camber Arms . Sure PMM/TMM . JBR EGR Delete . AWR Adjustable Front/Rear Endlinks . TRZ Dogbone RMM . Denso ITV-22 . Eibach Sport Line . Koni Yellows
S-hendrix is offline   Reply With Quote
 Old 01-25-2012, 12:58 PM   #2
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Most are +48. I assume you confirmed the bore and bolt pattern?
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
The Following User Says Thank You to Design For This Useful Post:
S-hendrix (01-26-2012)
 Old 01-25-2012, 01:18 PM   #3
S-hendrix's Avatar
Yep I test fitted them. I'm assuming they are +48 because the fronts fit without rubbing on my drop.
 Old 01-25-2012, 01:29 PM   #4
cabrone's Avatar
Posts: 529   (View Stats)
cabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the world
I could have sworn it says it on the wheel (inside) on my old torques...
Tapatalked
08.5 CWP MS3 GT
AP Stage 2 S-OTS+ | Cobb Catted DP | Magnaflow CBE | JBR SRI | Cobb TIP | JBR 70 Duro RMM |NGK Iridiums | Autotech Internals | Lamin-X Yellow Fog Overlays
cabrone is offline   Reply With Quote
The Following User Says Thank You to cabrone For This Useful Post:
 Old 01-25-2012, 01:33 PM   #5
S-hendrix's Avatar
Its supposed to be stamped in there but we can't find it if it is.
 Old 01-25-2012, 01:35 PM   #6
3mazdaspeed's Avatar
Posts: 485   (View Stats)
3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world
+48s around and you really shouldn't have to roll fenders. Good luck though.
3mazdaspeed is offline   Reply With Quote
The Following User Says Thank You to 3mazdaspeed For This Useful Post:
 Old 01-25-2012, 01:49 PM   #7
S-hendrix's Avatar
Cool. Thanks man. Maybe they are 35 because they are close to rubbing in the front and on the back they rub the fender.
 Old 01-25-2012, 05:42 PM   #8
cabrone's Avatar
On the back it may be here http://t0.gstatic.com/images?q=tbn:A...0Kh-dL_rPtDAfs
Or perhaps here http://t3.gstatic.com/images?q=tbn:ANd9GcSUVec8r-Z5g20XbURkc6cqSz54KdKteR8eBu0A_ihG3bIHfEwq
Tapatalked
08.5 CWP MS3 GT
 Old 01-26-2012, 05:35 AM   #9
S-hendrix's Avatar
Originally Posted by cabrone View Post
Thanks alot man. With your pics my buddies were able to find it. It is a +35. That explains the fender roll. I appreciate everyone's help. Now its time to order a wheel. Ill post pics when I get them put on.
The Following User Says Thank You to S-hendrix For This Useful Post:
cabrone (01-26-2012)
 Old 02-02-2015, 01:40 PM   #10
tbcota25's Avatar
Posts: 1,542   (View Stats)
tbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the world
How much do the rota torques weight?
2012 Black Mica
Mods
CS catless DP, CS RP
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
CS Short Shit Kit and Shifter Bushings
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
JBR Reticulation Tube
Cobb AP v2
H&R springs
JBR Rear Sway Bar
Self Built 3 Port EBCS
maisonvi Shift Knob
Tuned on 93 and corn
tbcota25 is offline   Reply With Quote
Rota Torque Gunmetalic PaPaSpeed Wheels & Tires - BLACK 17 01-24-2015 05:44 PM
Rota Torque on MGM walv89 MazdaSpeed 3/6 - Wheels & Tires 17 03-12-2010 07:23 PM
Rota Torque walv89 Wheels & Tires - METRO GREY 4 03-07-2010 08:12 PM
Less offset - how bad is the torque steer? Trader MazdaSpeed 3/6 - Wheels & Tires 6 06-23-2009 07:18 PM
which size offset for rota slips Darksun280 MazdaSpeed 3/6 - Wheels & Tires 31 10-08-2008 08:47 AM
Page generated in 0.29710 seconds with 25 queries
