 Old 04-04-2008, 06:14 AM   #1
kneedragger241's Avatar
Posts: 67   (View Stats)
kneedragger241 has a spectacular aura aboutkneedragger241 has a spectacular aura about
Question Running without TPMS Sensors?
What happens if I run without TPMS sensors installed?
Will I have an annoying light flashing at me the whole time I'm driving?
I think I read somewhere that someone on one of these forums experienced difficulties when his dealership tried to do a TSB reflash on his ECU. Something like the computer couldn't complete the process because the sensors weren't there?
It's not like I need a sensor to tell me to check my tire pressure :-p
2007 True Red Mazdaspeed3
I'm on the MySpace
kneedragger241 is offline   Reply With Quote
The Following User Says Thank You to kneedragger241 For This Useful Post:
Lee123 (01-02-2009)
 Old 04-04-2008, 10:25 AM   #2
det_ms3's Avatar
Posts: 479   (View Stats)
det_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the world
yes to the light without tpms
2008 Sunlight Silver MS3 the toy
2012 Chrysler 200 Limited 3.6l the daily driver
det_ms3 is offline   Reply With Quote
 Old 04-04-2008, 10:30 AM   #3
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
The light flashes for a couple of minutes, then stays lit.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 04-04-2008, 10:57 AM   #4
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
Piece of tape covers the light.
Crossbow is offline   Reply With Quote
 Old 04-04-2008, 12:19 PM   #5
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
AutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond repute
The light will eventually turn off after a few start-up cycles... But,
If you park near your stock wheels like I do, the light will never turn off...
I have my stock wheels stacked in the corner of my garage and it seems to pick up the sensors everytime I pull in; another instance is parking or pulling next to another MS3 with stock wheels will reset the light to where it will flash and stay on for a period of time.
2008 Stage 3 Roush Mustang
302E 5.0L Stroker 647rwhp-620 rwtq
AutoXRacer is offline   Reply With Quote
 Old 04-04-2008, 12:51 PM   #6
SLS MS3's Avatar
Over 30 start-up cycles for me so far, and my light still comes on. I don't park anywhere near my stock wheels.
 Old 04-05-2008, 01:01 AM   #7
ptperformance's Avatar
Posts: 4,123   (View Stats)
ptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the world
Put the sensors in your spare tire. All fixed now.
ptperformance is offline   Reply With Quote
 Old 04-06-2008, 11:57 AM   #8
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
thats actually a pretty smart idea
 Old 04-07-2008, 09:13 AM   #9
flashfrenzy's Avatar
Posts: 123   (View Stats)
flashfrenzy has a spectacular aura aboutflashfrenzy has a spectacular aura aboutflashfrenzy has a spectacular aura about
Ya, then you have no excuse for having a flat, pulling out the spare...and seeing that it's flat too.
flashfrenzy is offline   Reply With Quote
 Old 04-07-2008, 09:51 AM   #10
sleeper3's Avatar
Posts: 675   (View Stats)
sleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant future
how can you put your sensors in your spare tire? there's only room for one valve stem?
are these tpms different from others?
Ribs. I had ribs for lunch. That's why I'm doing this.
sleeper3 - 2.234, 8.742 @ 84.18, 13.365 @ 106.75 (I/IN/IC/MM)
sleeper3 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f319/running-without-tpms-sensors-2313/
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 04-06-2008 12:51 PM
How-To remove O2 sensors without messing them up mazdaspeedjay MazdaSpeed 3 - How-To's 38 07-14-2009 08:02 AM
will car start without the o2 sensors wires? CMESCOOT MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 04-09-2008 06:55 PM
Spycam: 2010 Chevrolet Camaro running the Nurburgring Haltech Automotive News 0 04-08-2008 12:50 PM
Spy Shots: Nissan GT-R Spec V confirmed, caught running the 'Ring Haltech Automotive News 0 04-08-2008 10:40 AM
Nike Men's Shox Remix + II Running Shoe - $93.49 + Free Shipping Haltech Hot Deals Section 0 03-27-2008 01:50 PM
Page generated in 0.30084 seconds with 28 queries
