 Old 02-20-2015, 11:25 AM   #1
JTD
JTD's Avatar
Posts: 49   (View Stats)
JTD is a jewel in the roughJTD is a jewel in the roughJTD is a jewel in the roughJTD is a jewel in the rough
Default Small Hubcentric Wheel Spacers
Hey everyone,
This may be a dumb question and can't seem to find the answer.
I have a set of 18x8.5 +55 wheels and looking at running either 245 35 18 or 245 40 18. I know this is going to be very close to rubbing on the inside and will likely have to run a small spacer, 3-5mm at least.
My question is, how to keep the rim hubcentric with a small spacer? I know most larger spacers have a hub ring built into the, but all small spacers I have ever seen are flat?
Who has used 3-5mm spacers?
JTD is offline   Reply With Quote
 Old 02-20-2015, 11:40 AM   #2
Vader's Avatar
Posts: 1,651   (View Stats)
Groans: 45
I have the Jbr 5mm spacers. There is enough hub left to grab the stock wheel just fine.
If you have wheels with hub rings, it gets tricky. I have to double side tape the hub ring to the hub/spacer, then put the wheel on.
I agree with you though. I have always wanted a 5mm with the hub bump thing.
Originally Posted by mikelevi View Post
...When you have 600 lbs of faggot in your car, you are much slower than someone with 10 lbs of dick.
Vader is offline   Reply With Quote
 Old 02-20-2015, 11:54 AM   #3
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
What is the center bore size of your wheels?
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 02-20-2015, 11:56 AM   #4
JTD
JTD's Avatar
75mm so I will need hubcentric rings as well.
 Old 02-20-2015, 12:03 PM   #5
Nliiitend1's Avatar
Groans: 67
These guys can make you custom spacers that are both hub and wheel centric:
We manufacture the best Wheel Spacers money can buy | Motorsport Tech
Not cheap, but they're quality products for sure.
2008 MS3 GT
2016 MX-5 Club
The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post:
Mattyhawk1 (02-20-2015), Mauro_Penguin (02-20-2015), Vader (02-22-2015), WetzMS3 (02-20-2015)
 Old 02-20-2015, 07:14 PM   #6
license2ill's Avatar
Posts: 313   (View Stats)
license2ill is infamous around these partslicense2ill is infamous around these parts
Groans: 30
Groaned at 132 Times in 57 Posts
I think that wheel will put even a 9.5" 235mm tire over 1" inboard, or over about 35mm. The wheel itself will inset 22mm closer, plus 13mm of tire or so.
How much room is there stock? Somebody's got to know, but I don't think I've seen a number specified anywhere for the oem tires.
license2ill is offline   Reply With Quote
The Following User Says NO Thank You to license2ill For This Un-useful Post:
btstarcher (02-25-2015)
 Old 02-21-2015, 03:43 AM   #7
JTD
JTD's Avatar
Great question and would love to know as I am currently guessing on the minimum spacer I will need. There seems to be a huge variance in offsets used and working.
 Old 02-21-2015, 07:00 AM   #8
chd_wtkns's Avatar
Posts: 54   (View Stats)
chd_wtkns has much to be proud ofchd_wtkns has much to be proud ofchd_wtkns has much to be proud ofchd_wtkns has much to be proud ofchd_wtkns has much to be proud ofchd_wtkns has much to be proud ofchd_wtkns has much to be proud ofchd_wtkns has much to be proud ofchd_wtkns has much to be proud ofchd_wtkns has much to be proud of
This, just got a set for my fronts with rpf1's, top notch and totally worth the price.
chd_wtkns is offline   Reply With Quote
 Old 02-21-2015, 08:13 AM   #9
Groans: 30
Yeah, most of the offsets I've seen are lower(less positive), so it seems like more of an issue at the fender. But, many of those I've noted here have still used spacers within a wide range of 5mm-15mm too. It will ultimately matter the specific height of the tire and actual measured section width of the model of tire on that wheel width.
An example is the Michelin Pilot Super Sport, as shown on tirerack in a 245/40/18 as 25.7" tall(equal to the oem Bridgestone in the 215/45/18 size), but 9.8" wide, an actual 249mm, as measured on an 8.5" wheel, vs the stock Bridgestone tire's 8.5"(216mm) measured on the 7" wheel. Others actual size may vary a few mm too.
 Old 02-21-2015, 09:30 AM   #10
Nliiitend1's Avatar
Groans: 67
18x8.5" et55 wheels will probably require AT LEAST a 5 mm spacer, and may even need an 8-10 mm spacer (especially if you're using coilovers with a thicker than OEM strut body, as some use).
I know of people running et45 wheels of the same size with no spacers, but there isn't much room on the inside with those setups...
2008 MS3 GT
2016 MX-5 Club
zenit (02-21-2015)
 Old 02-22-2015, 11:19 AM   #11
JTD
JTD's Avatar
Any others running high offset wheels?
I am hoping to run the smallest spacer I can so trying to make as educated guesstimate as possible for ordering spacers and hoping get it right!
Thanks for the info.
Anyone put small spacers on the back of their Gen 2? BLK_MS3 2010 MS3 - Wheels & Tires 16 07-02-2011 11:55 PM
wheel spacers builthatch MazdaSpeed 3/6 - Wheels & Tires 2 09-13-2008 06:39 PM
Page generated in 0.31659 seconds with 24 queries
