  • 1 Post By mituc
 Old 10-20-2016, 11:38 AM   #1
Frank2310's Avatar
Posts: 24   (View Stats)
Frank2310 is an unknown quantity at this point
Default Smallest suggested snow tire width
I am currently looking for a set of snow tires, I came across a set with rims that are 195/55/r16, would these be to small for our cars?
Frank2310 is offline   Reply With Quote
 Old 10-21-2016, 03:28 AM   #2
frothy's Avatar
Posts: 1,067   (View Stats)
Well, the diameter of the tire is 1.2" shorter than stock. So you'd have a larger wheel well gap, you'd be dumping your car ~.6" closer to the ground, your speedometer would read higher than it should and you'd be racking up miles on your odometer at a faster rate than normal.
If you're looking for recommended sizes:
205/60R16 or 215/55R16
Play with this if need be:
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
EDIT: Another thing to keep in mind is running a tire size with a different diameter than stock may affect the ABS/Traction Control systems seeing as they work in conjunction with the wheel speed sensors which wouldn't be receiving accurate readings.
 Old 10-21-2016, 06:54 AM   #3
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
I think they mostly work on speed differentials between wheels so running a different size would be okay in that regard.
The rest I agree with though, you don't want a tire that much smaller than stock.
Blue Pu.
 Old 10-21-2016, 07:14 AM   #4
frothy's Avatar
That's correct. I've been in vehicles with broken, free–spinning, tone rings. In such a scenario traction control and ABS tend to kick in once you get to ~5mph and the system detects the discrepancy between the wheel speed sensors. I don't suspect it would wreak havoc on the system, just suggesting the potential might exist for traction control to engage prematurely with the smaller wheels and higher wheel speed sensor readings.
 Old 10-22-2016, 10:47 AM   #5
Frank2310's Avatar
Thanks for the help, I figured that small of a tire wouldn't be the greatest idea on these cars.
 Old 10-22-2016, 12:20 PM   #6
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
205/50/r17.
16" rims are a bit too small, they are 2mm away from the front brake callipers and there isn't going to been ough cooling for the brakes not even during winter.
Also, 195mm tire is simply not enough for a 3500lb car assuming that you're not driving only on snow in 2nd gear.
dallin jones likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-10-2019, 07:43 AM   #7
SkippyScallop's Avatar
Posts: 65   (View Stats)
SkippyScallop is an unknown quantity at this point
Originally Posted by mituc View Post
205/50/r17.
Sorry to resurrect an old thread, but what are you basing your insufficient brake-cooling statement on?
SkippyScallop is offline   Reply With Quote
 Old 01-10-2019, 01:59 PM   #8
Jeff23spl's Avatar
Posts: 2,232   (View Stats)
If you have a speed3, 16inch open mag wasn't a problem for me, i never get brakes overheated, but i had HP+ pads and may not drive has hard as peoples do in Russia :-)
i think i used 215 55 16 to have them to last more than few months...
It doesn't fit at all on a speed6 unless you swap front brakes from a normal6
Minimum is 17inch despite ms3 and ms6 have the same rotor size, the caliper takes more space...i learned it few months ago.
i use these 16inch wheels, the offset was a bit agressive and the rear was rubbing a bit on stock coils. i rolled the fender a bit to fit 245 on RX8 wheels for summer and it solved this too at the same time.
https://www.picclickimg.com/d/l400/p...-OEM-Wheel.jpg
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Last edited by Jeff23spl; 01-10-2019 at 02:12 PM. Reason: MSF Database - Automerged Doublepost
Tread Width Vs Section Width license2ill MazdaSpeed 3/6 - Wheels & Tires 10 02-10-2015 07:07 PM
Debating between snow tire sizes sxshep MazdaSpeed 3/6 - Wheels & Tires 9 11-26-2012 04:20 PM
Matching tire size to wheel width 0nsp MazdaSpeed 3/6 - Wheels & Tires 9 05-06-2011 09:27 AM
snow tire removal karl-hungus MazdaSpeed 3 - How-To's 19 03-25-2010 11:05 AM
Page generated in 0.29678 seconds with 25 queries
