 Old 08-29-2008, 01:57 PM   #1
gofast's Avatar
Posts: 90   (View Stats)
gofast is on a distinguished roadgofast is on a distinguished road
Groaned at 59 Times in 29 Posts
Default speedo correction
Has anyone with different that oem size tires have anything yet to correct the speedo? I was just thinking that when winter rolls back around and the winter tires go back on i would like to make sure the speedo is accurate; mainly for odometer accuracy. Considering that i drive close to 100 miles per day atleast 5 days a week a couple mph off can really start to add up.
gofast is offline   Reply With Quote
The Following 6 Users Say NO Thank You to gofast For This Un-useful Post:
 Old 08-29-2008, 03:32 PM   #2
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
on my car I put on 225/45/18 instead of the stock 215/45/18 and it is "plus zero" with the oem tire size meaning you dont need to recalibrate your speedo....so just get a tire in either of those sizes and your good to go.
bykeryder4life is offline   Reply With Quote
 Old 08-29-2008, 04:33 PM   #3
gofast's Avatar
how do you figure its plus zero? 45% of 225mm is more than 45% of 215mm. actually its almost a 1/2 inch total diameter per tire. the speedo will be off. the good news with that scenario though is that the speedo will be reading slow.
The Following 4 Users Say NO Thank You to gofast For This Un-useful Post:
 Old 08-30-2008, 01:26 PM   #4
06kr's Avatar
Posts: 89   (View Stats)
06kr is infamous around these parts06kr is infamous around these parts06kr is infamous around these parts06kr is infamous around these parts
A wider tire will not afect your speedo, only a taller or shorter tire.
Running a 225 to 245/45/18 will not change your speedo readings.
But a 215 to whatever/ 40 or lower/ 18 will.
The number you need to worry about for speedo readings is the middle number.
2008.5 MS3 GT, Black Mica.-CAI
1994 ZR1 Corvette, Torch Red-exhaust, CAI, tune.
2006 Ford F150 4x4 King Ranch, white- exhaust, CAI, tune.
06kr is offline   Reply With Quote
 Old 08-30-2008, 10:11 PM   #5
Groans: 38
sorry, that was a typo. I meant a 225/40/18. Yes I am an idiot for not proofreading....
 Old 08-30-2008, 10:38 PM   #6
gofast's Avatar
lol riiight but do you know why the middle number will affect the speedo? its a percentage of the width of the tire. so yes a 245/45/18 will give your a speedo a different reading than a 215/45/18.
so back to the original question....has anyone, and i am now assuming not, done anything to correct there speedo with different size tires?
The Following User Says Thank You to gofast For This Useful Post:
Laloosh (05-26-2009)
The Following 5 Users Say NO Thank You to gofast For This Un-useful Post:
 Old 08-31-2008, 06:46 PM   #7
Groans: 38
I take it as a no. so how off is mine with the 225/40/18 ? I hope it's close.
 Old 08-31-2008, 07:12 PM   #8
06kr's Avatar
Its not off enough to worry about.
215/45/18 = a 3.80" sidewall.
225/40/18 = a 3.54" sidewall.
245/40/18 = a 3.85" sidewall.
Also all tires are differant a 225/40/18 goodyear will most likely be a little bigger or smaller then the same size nitto. Also speedo's have a + and - they are not perfect.
 Old 08-31-2008, 08:53 PM   #9
gofast's Avatar
thats my winter set up and at 65mph i was 2mph off(reading fast) according to my gps. with the stockers i am dead on
 Old 08-31-2008, 09:02 PM   #10
gofast's Avatar
the 245 40 18 is close but thats not the tire size that i am choosing to run. you have to take that sidewall measurement and multiply it x2. so the difference is actually twice what you have posted. while i appreciate you trying to tell me that that its not going to make that much of a difference i just really want the original question answered. i assure you that i know all about tire sizing. i dont need an edumacation on this subject.
 Old 08-31-2008, 09:55 PM   #11
06kr's Avatar
I'm sorry, not trying to educate you my answer was for bykeryder4life. I should of quoted him.
But maybe you can educate me. I came up with my numbers by
225/25.4(millimeters per inch)=8.85x.40= 3.54"
Not understanding were the x2 comes into play.
As far as changing the speedo reading, you would think that the cobb programer would be able to do that. But I have never looked into one. I just know that all the programer's I have had for other cars had that function.
 Old 09-01-2008, 07:13 AM   #12
MikeHTally's Avatar
Posts: 77   (View Stats)
MikeHTally is a jewel in the roughMikeHTally is a jewel in the roughMikeHTally is a jewel in the roughMikeHTally is a jewel in the rough
Groaned at 16 Times in 4 Posts
215/45x18=25.62" diameter
225/45x18=25.97" diameter
The 225 is 1.4% larger (taller). Speedometer reading will be that much lower. Actually, doing this very thing made my speedo dead on at 60. It was reading a pinch high (1/2 mph).
The "x2" has to be used, 'cause the total sidewall height is necessary, plus the diameter of the wheel. Unless the speedo is electronic, no programmer will change it. Are our speedometers mechanical? If so, the only way to change it is to change the gear driving it (not worth the expense, IMO).
2008 1/2 CWP GT
Free shifter mod
15/15/5/15 tint/Vent Shades
Rear bumper guards/Redline Tuning hood springs
Cobb RSB & SRI
RX-8 wheels/Yokohama YK520 225/45
2006 Chrysler 300C
Bentley Grill
Splash guards
Vent Shades
2003 Dodge Ram 1500 QC Hemi
TrueFlow intake/Magnaflow Exhaust
Etc., etc.
MikeHTally is offline   Reply With Quote
 Old 09-01-2008, 07:15 AM   #13
Boost Whore
Unoriginalusername's Avatar
Posts: 1,757   (View Stats)
Unoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the world
Groans: 223
http://www.mazdaspeedforums.org/foru...t-updates.html
Originally Posted by Josh @ COBB View Post
COBB AccessPORT
Upcoming Features
  • Realtime to be added
Requested Features (we will try to work in at release or as an update later)
  • Removing boost reduction for steering angle.
  • LC & FFS
  • Tire size recalibrations (iffy on this one)
  • Shift Light
"God created turbo lag to give v8's a chance"
Unoriginalusername is offline   Reply With Quote
 Old 09-01-2008, 07:25 AM   #14
MikeHTally's Avatar
Maybe all speedometers are electronic anymore?
 Old 09-01-2008, 08:55 AM   #15
gofast's Avatar
the x2 has to be used because you have to look at a tires diameter not just the sidewall. there is sidewall at all point on a tire including on top and on bottom. if i used your equation here, a 225/40/18 would be 3.54(sidewall) + 18(rim diameter) which would equal a total tire diameter of 21.54" which is not correct. you have to take that 18" + 3.54 x 2 = 25.08 that is the correct diameter of that tire. give or take a couple 1/100ths
its not JUST the sidewall height that causes the speedo to read different when a different size tire than what the speedo was calibrated for is used. its the over all diameter and circumference of any size tire that effects how many revs that particular size takes to go around per mile. and if that is not what the speedo is calibrated for, then the speedo will be off whether is .5 mph or 20mph.
The Following 3 Users Say NO Thank You to gofast For This Un-useful Post:
 Old 09-01-2008, 08:56 AM   #16
gofast's Avatar
i believe most, if not all, late model vehicles are electronic now.
 Old 09-01-2008, 05:04 PM   #17
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
LOL at this thread.
Hey guys dont forget to take tire wear into account in all your calculations...... remember to rotate your tires and recalibrate your speed every 3000 miles.... LOL
Someone please answer the OP's question.
So far I see an iffy maybe on a future Cobb AP revision.
Suspension:
 Old 09-01-2008, 08:30 PM   #18
MadOzodi's Avatar
Posts: 686   (View Stats)
MadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the world
I wonder if my Abbot ERA I just ripped outta my Mustang would work on the MS3?
07 COSMIC BLUE MS3 GT
00 OBSIDIAN BLACK TRIUMPH LEGEND TT 900 - gone, but not forgotten
09 PACIFIC BLUE TRIUMPH SPRINT ST 1050 - SOLD
11 BLACK SUZUKI GSX-R750 - totaled
11 BLACK SUZUKI GSX-R750 - totaled...again
*OFFICIALLY RETIRED FROM TWO WHEELS*
MadOzodi is offline   Reply With Quote
 Old 09-09-2008, 07:18 PM   #19
MadOzodi's Avatar
That Speedrite looks like it's just a more evolved version of the Abbott ERA I have. Damn it was a pain getting the thing out I hope I can find a better spot for it in my MS3.
 Old 04-10-2009, 11:52 AM   #20
ROWDRNR's Avatar
Posts: 1   (View Stats)
ROWDRNR is an unknown quantity at this point
Everyone can check out this website:
Tire size calculator
I find it useful. At the bottom it shows the comparison for the SPEEDO difference between the two different tires that are selected. Always double check rather than using the website, but I have found it helpful for a quick look with my winter tire setup and other questions I had related to tire size. I am going to go to a 225/45ZR18 in a Sport Contact 3 for my Speed 3.
ROWDRNR is offline   Reply With Quote
 Old 04-10-2009, 08:14 PM   #21
The Kamikaze King!
Groans: 754
Originally Posted by FORZDA 1 View Post
If you really want to correct any sensor driven sopeedo, go here
Speedrite Speedo Callibrator - Corrects Speedo Errors and Calibrates Tachometers
Im surprised we cant do this with the Cobb AP, all this shit is set in the ECU, no need to buy a new box.
Suspension:
 Old 04-10-2009, 09:16 PM   #22
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
my gps says my speedo is off by two with stock bridgestones
"Go find your own enterprise, and get the fuck off my bridge!"
2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard"
1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action"
skeeter149 is offline   Reply With Quote
 Old 04-16-2009, 01:46 PM   #23
zoomed777's Avatar
Posts: 33   (View Stats)
zoomed777 has a spectacular aura aboutzoomed777 has a spectacular aura aboutzoomed777 has a spectacular aura about
according to this tire size calculator the new 225/45 is 1.4% slow, at 60mph your actually going 60.8mph.
zoomed777 is offline   Reply With Quote
 Old 04-16-2009, 02:21 PM   #24
Eazy's Avatar
Posts: 1,539   (View Stats)
Eazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the world
Groaned at 32 Times in 14 Posts
What he's saying is the speedo reads high from the factory.... this is done for liability reasons (better to read high than low) so assuming the 2mph under (speedo reads 60, you're doing 58) that was mentioned above and adding 1mph with slightly bigger tires would actually make your speedo more accurate (now reads 60 at 59mph)
Eazy is offline   Reply With Quote
 Old 05-26-2009, 12:36 AM   #25
corbs's Avatar
Posts: 4,066   (View Stats)
corbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the world
Groans: 336
Groaned at 121 Times in 71 Posts
hey hey fuck u
haters phailyb|haltech|wakeboarddude|bykeryder4life
corbs is offline   Reply With Quote
 Old 05-26-2009, 06:25 AM   #26
Laloosh's Avatar
Posts: 5,166   (View Stats)
Groans: 57
why was this guy banned when he basically schooled half the idiots in this thread?
 Old 05-26-2009, 10:28 AM   #27
The Kamikaze King!
Groans: 754
Yes I would like to know why he got banned too. I looked through his past posts and didnt see anything ban worthy.
Suspension:
 Old 05-26-2009, 10:42 AM   #28
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
might be another banned user using a new handle...could this be ryz?
-- Mario Andretti --
 Old 05-26-2009, 10:49 AM   #29
The Kamikaze King!
Groans: 754
Originally Posted by mordant80 View Post
Lookin at this thread and how some of the groans make absolutely no sense to me, I'd say a mod has been through here and cleaned something up.
EDIT:
You know what, now I look at the complete thread again you are right, i remember some of the posts that have been removed, but from what I saw he was in the right, and the other users were not. Like Laloosh said he basically schooled them. As you can see from the groans it was some of the "in crowd" he schooled, maybe that is why.
Suspension:
 Old 05-26-2009, 11:02 AM   #30
The Kamikaze King!
Groans: 754
Strange..
I edited my post, I was just going by the last few posts, after I read the whole thing again I realised it has been cleaned up big time.
But from what I remember, gofast was in the right and the other users were getting schooled and flaming him.
Anyway, it is what it is.
I would like to know who banned him and why though.
Could be it had nothing to do with this thread, as he posted for almost 6 months after his last post in here.
I dont see anything in those 6 months ban worthy, but again you dont know what has been deleted/cleaned up.
Suspension:
mordant80 (05-26-2009)
 Old 05-26-2009, 12:46 PM   #31
Driver
Fobio's Avatar
Groans: 44
erm...the groans are all from today....the boys are just letting it off on a banned user since he can't groan them back. I don't think you can count the groans today as to why gofast got banned...
FWIW, I don't remember anything coming from gofast that was ban worthy...but calling Haltech out or personally insulting a mod could've been enough...
 Old 05-26-2009, 06:51 PM   #32
Driver
Fobio's Avatar
Groans: 44
I miss all the crazy shitz...chk the MWI thread...lol...
 Old 05-26-2009, 07:42 PM   #33
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
its cause he is a super-fag-mod on 247 lol
'08 CWP MS3 w/ T3 3071r
Correction: Pontiac G8 GT will NOT have an optional 6-speed stick Haltech Automotive News 0 06-24-2008 07:10 AM
Correction: Diesel Maxima coming with automatic and maybe a stick Haltech Automotive News 0 06-18-2008 12:00 PM
Correction: Honda F1 not testing Danica, but would like to Haltech Automotive News 0 06-12-2008 05:50 PM
New Speedo Coupon Codes - $20 off $80 Haltech Hot Deals Section 0 04-07-2008 11:21 PM
Page generated in 0.50601 seconds with 34 queries
