Notices
 Old 07-23-2008, 06:53 PM   #1
Jasnall's Avatar
Posts: 53   (View Stats)
Jasnall is a jewel in the roughJasnall is a jewel in the roughJasnall is a jewel in the roughJasnall is a jewel in the rough
Question stock wheels: Size,Bolt Pattern,Offset,Bore
I've done searching but I'm just trying to find a straight up answer.
in this format what are the numbers on the stock MS3 wheels.
Stock wheels
18x7.... 5x114.3....... 52.5mm ..........67.1 ???
"The specs on the MS6 OEM wheels are 18"x7", +55mm offset, 5x114.3mm, 67.1mm hub bore. "
Thanks a lot for any info.
Jasnall is offline   Reply With Quote
The Following 6 Users Say Thank You to Jasnall For This Useful Post:
alien_sporez (06-16-2010), labikesrcool (10-08-2009), MGM_GT3 (01-27-2011), mo08ms3 (01-20-2009), SRTCE142 (12-25-2008), toprock (02-21-2009)
 Old 07-23-2008, 07:01 PM   #2
Derek88's Avatar
Posts: 774   (View Stats)
Derek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the world
Stock wheels are 18x7 5x114.3 52.5mm and idk the center bore
-Derek
No longer in the Mazdaspeed Family
Derek88 is offline   Reply With Quote
 Old 07-23-2008, 07:11 PM   #3
Jasnall's Avatar
Thank you sir!
 Old 07-24-2008, 01:20 AM   #4
MS3-oholic's Avatar
Posts: 124   (View Stats)
MS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond repute
center bore is 67.1 mm on stock wheels
MS3-oholic is offline   Reply With Quote
 Old 11-29-2008, 04:12 PM   #5
gdg
gdg's Avatar
Posts: 121   (View Stats)
gdg has much to be proud ofgdg has much to be proud ofgdg has much to be proud ofgdg has much to be proud ofgdg has much to be proud ofgdg has much to be proud ofgdg has much to be proud ofgdg has much to be proud of
Groaned at 16 Times in 3 Posts
Default Sticky This - Stock Rim/size/offset
I've been looking for this information for a few hours.. I would recommend a sticky. I would post stock weight with it too though, I've seen conflicting information on the weight aspect.
-GG
gdg is offline   Reply With Quote
 Old 11-30-2008, 10:35 PM   #6
sumthaiguy's Avatar
Posts: 75   (View Stats)
sumthaiguy has a brilliant futuresumthaiguy has a brilliant futuresumthaiguy has a brilliant futuresumthaiguy has a brilliant futuresumthaiguy has a brilliant futuresumthaiguy has a brilliant futuresumthaiguy has a brilliant futuresumthaiguy has a brilliant futuresumthaiguy has a brilliant futuresumthaiguy has a brilliant futuresumthaiguy has a brilliant future
yea sticky this ho! ive spent a good amount of my time trying to look for this info
sumthaiguy is offline   Reply With Quote
 Old 12-01-2008, 05:25 AM   #7
Lymerock's Avatar
Posts: 1,436   (View Stats)
QFT
-GG
weight I believe is 25-26lbs, they are meaty bitches
with the stock rubber on them they come in a bit over 50lbs
07 CB Speed3
COBB AP S2+, MS CAI (shorty w/ straightener), RPMC inlet, ETS 3.25", Devils Own S2 Alchy Injection, PG Manifold V2, TXS DP (with Cobb highflow cat soon), TXS mid, MS CBE, HKS Plugs (1 step colder), Fidanza Flywheel, KMD CDFP internals, COBB Sways, Koni Dual Adjustable Shocks, AWR 88 trans mount, Hawk HP+ pads (F+R), Motul RBF 600 brake fluid, 18x8 +50 weds sa70's 245/40 falken rt-615's, V1 hardwired, Autometer ES Gauges (boost/vac, water, oil pres), Dashhawk, stock turbo with modified boost control system
The Following User Says Thank You to Lymerock For This Useful Post:
gdg (12-01-2008)
 Old 12-07-2008, 06:15 PM   #8
qualm's Avatar
Posts: 12   (View Stats)
qualm is an unknown quantity at this point
sticky
qualm is offline   Reply With Quote
 Old 02-21-2009, 09:59 AM   #9
MS6_Auburn_Fan's Avatar
Posts: 478   (View Stats)
MS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the world
Does anyone have this same information for the MS6 wheels?
MS6_Auburn_Fan is offline   Reply With Quote
 Old 02-24-2009, 06:15 AM   #10
Target:STi's Avatar
Posts: 289   (View Stats)
Target:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the world
IIRC stock MS6 is 18x7 5x114.3 +60 offset about 25-26lbs per wheel
IIRC stock RX8 is 18x7.5 5x114.3 +55 offset about 24-25lbs per wheel
Target:STi is offline   Reply With Quote
 Old 02-24-2009, 06:24 AM   #11
mdogg's Avatar
Posts: 841   (View Stats)
mdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the world
Groans: 86
Groaned at 36 Times in 25 Posts
Not sure on the weights, but....
stock MS6 is +55mm offset (I forget if they are 7 or 7.5 width, though)
stock RX8 is 18x8; 5x114.3 bolt pattern; +50mm offset
L76-powered
mdogg is offline   Reply With Quote
 Old 02-24-2009, 08:12 PM   #12
Target:STi's Avatar
hmm.. i mustve been told wrong about that then. either that or my memory has gonee to shit
Formerly: TG 06 MS6- CAI, TMIC, TBE
Currently: RR 08 Evo X- SRI, UICP, TP, CBE, Tune
 Old 02-25-2009, 04:19 AM   #13
Qluber's Avatar
Posts: 267   (View Stats)
Qluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud of
stock wheels, hubcentric or lugcentric?
08.5 BLACK MICA GT,
CP-e CAI,
Black Forge bov
DEBADGED
Magnaflow Catback
Corksport Test Pipe
TRZ Rear Mount
1 Step Colder NGK's
Qluber is offline   Reply With Quote
 Old 02-25-2009, 07:09 AM   #14
ILL3ST
xcoldricex's Avatar
Posts: 2,758   (View Stats)
Groans: 105
and if anyone wants to get aftermarket lug nuts for the speed3 you need the 12x1.5mm variety.
xcoldricex is online now   Reply With Quote
The Following User Says Thank You to xcoldricex For This Useful Post:
Zeya (03-05-2009)
 Old 03-12-2009, 04:19 PM   #15
 Old 09-29-2009, 08:19 AM   #16
Vansquish's Avatar
Posts: 1,187   (View Stats)
Groans: 420
Groaned at 24 Times in 8 Posts
Thanks for the info...I gather that RX8 wheels fit the MS6, but are there rubbing issues or any suspension mods that need to be carried out to accomodate the wider wheels?
 Old 04-30-2010, 11:53 AM   #17
Alpha's Avatar
Posts: 3,430   (View Stats)
Groaned at 66 Times in 49 Posts
Does anyone know the weight of stock 18" MS6 wheels without tires?
Alpha is online now   Reply With Quote
Stock wheels fitment..... winniep MazdaSpeed 3/6 - Wheels & Tires 5 07-18-2010 01:20 AM
What size are the stock injectors on the MS3? Haltech MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 15 05-16-2008 12:57 AM
Page generated in 0.40675 seconds with 33 queries
