 Old 04-09-2015, 01:57 PM   #1
Jeff23spl's Avatar
Posts: 2,128   (View Stats)
Default TPMS compatibility ?
I have a 2007 Us speed 3 and my wife a canadian 2010 cx7. Both are equip with tire pressure monitoring system. I wonder if both use the same wheel sensors and if it is all compatible with the ones availaible for sale?
Is it all the same or i need to check for specific part # or models to work with the OEM reading module.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 04-09-2015, 03:35 PM   #2
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
I think all the Mazdas use the same ones.
I have 4 different sets: one set that came with my MS3, another set that came on the RX8 wheels I bought years ago, and 2 sets that I've purchased separately (one from a private seller on ebay, another from Amazon).
They all work.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Chuthor (04-09-2015)
 Old 04-09-2015, 05:25 PM   #3
Chuthor's Avatar
Posts: 435   (View Stats)
Chuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the world
I believe there have been a few revisions. But as far as I've tried all newer revisions are backwards compatible. Old sensors however may not be forward compatible. I'll dig up the current revision part number and post it.
Here is a link to some more information about the sensor changes: http://www.tpmsdirect.com/Mazda_TPMS...tion_a/725.htm
I'm still not 100% on if old sensor types will work with the newer systems, but I've used the current sensors with older mazdas. But like @Nliiitend1; said they pretty much use their sensors across all their cars.
Oh yeah the current part # is bbm2-37-140b
Sent from my XT1254 using Tapatalk
2012 CWP w/ Tech; Damond Motorsports RMM; AT Internals; CS Stage II Intake; Cobb DP; Phate Tuned; KW V1 Coilovers; Damond SSP; DM OCC
Chuthor is offline   Reply With Quote
The Following User Says Thank You to Chuthor For This Useful Post:
Nliiitend1 (04-09-2015)
cobb accessport v2 compatibility? skippy23488 MazdaSpeed 3/6 - ECU Computer Tuning 9 03-17-2014 09:18 AM
Cylinder Head Compatibility 93GTS MazdaSpeed 3 - Engine, Transmission & Driveline 0 12-30-2013 11:38 AM
FMIC compatibility derek13p 2010 MS3 - Turbo Induction 6 07-19-2012 06:32 AM
Guardian Angel BPC compatibility. himurax13 Stratified Automotive Controls 25 07-09-2012 06:10 AM
MS3 Radio Compatibility BERTO_702 MazdaSpeed 3/6 - Car Audio & Electronics 3 04-07-2012 11:13 AM
Page generated in 0.24216 seconds with 22 queries
