 Old 10-31-2016, 08:51 AM   #1
Bryce99's Avatar
Posts: 112   (View Stats)
Bryce99 is a jewel in the roughBryce99 is a jewel in the roughBryce99 is a jewel in the rough
Default Traction control issue! 08 Mazdaspeed 3
I was driving home after work and slowly accelerated. At 3k rpm my traction control kicks in for no reason, cuts power and the car shakes. I pulled over and checked for codes on my AP, nothing. I went back on the road with traction control turned off but the light stays on, and no issue? whats going on? Im thinking maybe some type of sensor?
Bryce99 is offline   Reply With Quote
 Old 10-31-2016, 09:03 AM   #2
Police - Grammarhead
Vansquish's Avatar
Groans: 1,911
If you push the traction control button to turn the system off, the TCS light should stay on.
If you want us to diagnose your problems, then you're going to need to provide more than a three sentence squib that barely gives any indicia of a problem. You have an AP, why don't you datalog?
WetzMS3 (10-31-2016)
 Old 10-31-2016, 06:26 PM   #3
sheston's Avatar
Posts: 1,847   (View Stats)
Disconnect the connector in the steering column, the light will stay on, but you will never have traction control problems again :-)
 Old 11-01-2016, 10:05 AM   #4
Bryce99's Avatar
Sorry guys I'm new to the forums and I just bought the car.
Sent from my Pixel XL using Tapatalk
ABS and traction control andrew22888 Mazdaspeed3/6 General Discussion 55 03-07-2015 03:00 PM
Traction Control MS6 hinkema1 Mazdaspeed3/6 General Discussion 14 10-16-2012 07:29 PM
Strange launch control interaction with traction control fortressofcomfort Gen2 MS3 General Discussion 47 03-29-2012 08:41 AM
can't stop, ABS/Traction Control lights, no cruise control...vacuum leak? btstarcher MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 06-17-2011 11:06 PM
Page generated in 0.25301 seconds with 22 queries
