Washer-seat Lug Nuts Anyone know of any companies that make quality lug nuts with conical washers at the base that aren't $250+ for a set? Like this: http://www.fizzautosports.com/images...IMG_0450RE.jpg |
Sorry Mizzle, need some clarification (for aftermarket fitment...correct?), but I think that Evasivemotorsports.com has many of the popular lug brands. One other to check out is dropengineering. That color is called neo chrome (if you were having a hard time finding it). EDIT: Mcgard makes rotating seat lugs for $100. http://www.wheeldude.com/catalog/pro...oducts_id=5888 |
Either/or. I'm just tired of fucking up the paint on the rim seat only to find aluminum oxide the next year. I just wanna know who makes'em other than Project Kics-brand... b/c they're rape-me-in-the-ear expensive. |
neo chrome. Check Evasivemotorsports, or even Amazon.com Search "open ended lugs". Muteki Dropengineering Gorilla Blox etc. EDIT: Do those have a rotating seat? @Mizzle, you want a rotating seat, don't you. http://www.wheeldude.com/catalog/pro...oducts_id=5888 |
lol yes... hence the "washer-seat" title lol. I actually would rather have capped lugs to prevent corrosion. Those are pretty sexy. McGard has great stuff. This is for next year so there's no rush, but I am curious as to who else makes them. So McGard is a non-rapey version. Any others? (I heard bad stuff about gorilla and muteki with corrosion so not too interested in those either way) |
I have had the same set of mcguard since 2002. They will be going on my speed 6 in the spring with my summer tires. This will be the 3rd car I have used them on. The best $60 or $70 I ever spent. They are the splined ones with the one special key for each wheel type. |
With the rotating seat? |
Yea, the only thing you need to do now and again is dab a little oil on the washer so it does not freeze up. The locking lug nut is the only one that does not have the washer. |
I took a closer look at that part number. Those don't have a rotating seat. They have a zinc plating for better torque readings. Looks like I'll be saving up for Kics in a couple years lol |
havent looked into it much, but they say two piece on that link: "-Unique two piece design which helps protect wheel finishes and provide even torque for the lugs" |
http://mcgard.com/files/images/Autom...seat_illus.gif Quote:
remember that if you do end up with something like that (although the nuts will come with torque specs) reduce the torque used on zinc plated nuts by 15%. |
splain? |
zinc coating on bolts is similar to oiling a bolt. less torque on the bolt will equate to more clamping force, because there is less resistance. similar to oiling a bolt, you get more uniform torquing. here is a source: BOLTS AND TORQUE SPECS |
I've always heard it gave a more accurate reading. Now it appears there's dry and wet specifications for torque. This is all gay. |
read title as "washer eating lug nuts" time to lay off the nog and rum |
1 Attachment(s) Attachment 47993 These are the ones that I have had for years that are from mcguard. |
I actually just got a set of mcgards with the red cap. they are the splinedrive set, no locks. they do have the rotating washer. Now what I really want to find is a 1/2" or 3/8" spline socket so I can get the full torque from my makita 18v impact wrench. it works, I just need to minimize the vibration between the spline adapter and the 21mm socket. |
| All times are GMT -7. The time now is 08:32 AM. |
