 Old 04-24-2008, 04:32 PM   #1
Yahdy Ras's Avatar
Posts: 221   (View Stats)
Yahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to behold
Groaned at 14 Times in 7 Posts
Default Wheel Gurus Please Help
I was about to purchase my enkei gtc-01s today when the tire rack rep told me that the setup requested wouldn't fit. Please take a look at both options and let me know:
His recommended option:
18x7.5 48mm offset
225/40/18
My set up:
18x8.0 48mm offset
235/40/18
My car is dropped roughly 2" on coilovers so they can go up. Anyone have either of these sizes on a dropped car and care to give insight i would really appreciate it. The difference between the 2 setups is $30 so price isn't an issue. Thanks guys
Yahdy Ras is offline   Reply With Quote
 Old 04-24-2008, 05:13 PM   #2
Derek88's Avatar
Posts: 773   (View Stats)
Derek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the world
His setup is safer. Lowered 2", you will probably rub with your setup. Maybe mix the 2 setups.. 18x8 and 225s or 18x7.5 with 235s. If I had to pick, I would go with his setup.
-Derek
No longer in the Mazdaspeed Family
Derek88 is offline   Reply With Quote
 Old 04-24-2008, 05:17 PM   #3
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
no balls!!!! 18x8, 235/40 all the way. if you gotta roll the fenders...so be it i guess
 Old 04-24-2008, 05:27 PM   #4
Yahdy Ras's Avatar
not plannin on rolling the fenders...in the end i want the fattest TIRE from the back, not the fattest RIM. Anyone have pics of 225 on an 8" wheel? Does the lip stick out farther than the tire? Vice versa...235 on a 7.5" wheel...will the tires bubble out? Im goin for a flush look. Thanks
 Old 04-24-2008, 05:33 PM   #5
aaronc7's Avatar
Groans: 370
235 on 7.5
 Old 04-24-2008, 05:37 PM   #6
Yahdy Ras's Avatar
looks good and safe but ur four by fouring it in comparison to my car so im not sure itll work. Shit, i wish i could just try it out first! Anyone else...possibly with roadmagents, H&R or one of those lower set ups?
Do your 235s rub?
 Old 04-24-2008, 06:36 PM   #7
aaronc7's Avatar
Groans: 370
cobb springs no rubbing problems
 Old 04-24-2008, 07:07 PM   #8
Grim's Avatar
Posts: 2,395   (View Stats)
Grim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the world
are those 18's?
Grim is offline   Reply With Quote
 Old 04-25-2008, 08:10 AM   #9
Sumosub's Avatar
Posts: 164   (View Stats)
Sumosub has a reputation beyond reputeSumosub has a reputation beyond reputeSumosub has a reputation beyond reputeSumosub has a reputation beyond reputeSumosub has a reputation beyond reputeSumosub has a reputation beyond reputeSumosub has a reputation beyond reputeSumosub has a reputation beyond reputeSumosub has a reputation beyond reputeSumosub has a reputation beyond reputeSumosub has a reputation beyond repute
I dont know how much difference there is between the MZ3 and MS3...I have an MZ3 lowered on S-tech 48 offset on 225/40/18 and my rears rub
2008.5 Black Mica
Z's is bigger than mine
Sumosub is offline   Reply With Quote
 Old 04-25-2008, 08:12 AM   #10
Yahdy Ras's Avatar
Thanks for the input, guessing 235 on a 8" wheel is gonna rub then huh
 Old 04-25-2008, 05:35 PM   #11
aaronc7's Avatar
Groans: 370
Yeah mine are 18s, they just look smaller (like 17s) because of hte way the spokes are...don't go all the way out to the edge
 Old 04-25-2008, 09:34 PM   #12
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
235's will rub if you are dropped 2 inches.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
Tire and Wheel Calculator SpdFreak MazdaSpeed 3/6 - Wheels & Tires 11 01-06-2012 08:21 AM
Tire and Wheel Calculator SpdFreak MazdaSpeed 3/6 - Wheels & Tires 1 02-02-2011 11:47 AM
Help with wheel choice! MS3-oholic MazdaSpeed 3/6 - Wheels & Tires 11 04-22-2008 07:05 PM
BIG WHEEL UPDATE!!!! ptperformance Mazdaspeed3/6 General Discussion 59 04-20-2008 12:16 PM
big wheel jlarson1983 Mazdaspeed3/6 General Discussion 57 04-01-2008 06:29 PM
Page generated in 0.30639 seconds with 26 queries
