| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() | | #1 | ![]() |
![]() Join Date: Jul 2014
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
Groaned at 3 Times in 1 Post
![]() Join Date: Aug 2012 Location: Plano, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score It sounds like you are pushing the rotor into the brake/mount. What is the part number for the rotors you installed? Did the rotor spin with the brake bolted in place? Was the rotor sitting flush or was it being pushed out?
__________________ 2013 Speed3- Autotech HPFP-FORGE BPV- JBR 3.5 Intake - JBR FMIC -CorkSport Catback - GTX3076 *"Other stuff" 1995 Chevy 6.5 k2500- 18PSI - still slow |
(Thread Starter) | Not Ranked : 0 score Autopart International 1407-77130. Yeah everything spun with the brakes installed, it seemed pretty hard to turn them though. Do you mean flush against the hub? |
![]() | | #4 | ![]() |
![]() Join Date: Jan 2013 Location: Vancouver, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
| Not Ranked : 0 score try putting some washers down on the lug studs and running a few lug nuts down (don't kill them with an impact just tight with a 3/8" or be careful with a 1/2"). If the rotor won't turn you should be able to find out where it's hitting. Some checking for witness marks may help as well.
__________________ 2011 Mazdaspeed3 non-tech package Drivetrain CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune Chassis JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace Rice LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers |
| The Following User Says Thank You to nekret For This Useful Post: | Natey (08-20-2014) |
![]() | | #5 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well I looked up the part number and it definitely says that it fits the Mazda 6... do speeds have different rotors than stock? I noticed weird notches inside the new rotors that my old ones didn't have. The same thing happens on both sides so the odds of something being mounted bad the same way on both sides? |
| The Following 3 Users Say NO Thank You to paddypilot For This Un-useful Post: |
![]() | | #6 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
Groans: 67
*EDIT* Yup:
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club Last edited by Nliiitend1; 08-20-2014 at 11:27 AM. Reason: Edited for clarity - took partially incorrect info from another site... | ||
| The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post: | Easter Bunny (08-20-2014), Natey (08-20-2014), UnknownSuperhero (08-20-2014), Vansquish (08-20-2014) |
![]() | | #7 | ![]() |
(Thread Starter) | Not Ranked : 0 score That's odd because I put them on top of each other and they were the same diameter. Jk, I think I did that with the rears. Last edited by paddypilot; 08-20-2014 at 10:58 AM. Reason: autism kicked in |
![]() | | #8 | ![]() |
Groans: 67
| Not Ranked : 0 score Is the side profile the same??
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
![]() | | #9 | ![]() |
![]() Join Date: May 2013 Location: Santa Cruz, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
Groaned at 28 Times in 13 Posts
| Not Ranked : 0 score (From a different site. The guy was trying to install ms6 brakes on a Mazda6) :
__________________ '93 RX-7: 100% CARB approved. Just some wheels and stuff. ![]() '03.5 Mazdaspeed Protege: Custom clunk and turkey call. '12 4Runner Limited: Hollister Hills pinstripes, dog hair, beach sand, melted surf wax, a few french fries under the seat... | |
![]() | | #10 | ![]() |
(Thread Starter) | Not Ranked : 0 score So apparently Advanced Auto has front rotors for the ms6, but they're 320mm? 12.2 inches is 309mm. edit: Another advanced has them too, but they're 314mm now. Wtf |
![]() | | #11 | ![]() |
| Not Ranked : 0 score Screw those guys. You'll get the correct parts the 1st time from someone who knows Mazdas. (They're a forum sponser, too!). Mazda 6 - CorkSport Mazda Performance - 360-260-CORK
![]() | | #12 | ![]() |
(Thread Starter) | Not Ranked : 0 score I kind of need my car on the road asap, otherwise I wouldn't have bothered with these asshats. edit: Also that site only sells pads and a caliper kit. |
| The Following User Says Thank You to paddypilot For This Useful Post: | SpencerC (08-20-2014) |
![]() | | #13 | ![]() |
Groans: 793
| Not Ranked : 0 score I never understood how people don't realize these cars aren't the same as the mz6 and mz3. There is very little carry over.
| The Following 4 Users Say Thank You to Tokay444 For This Useful Post: | ALPINEST4RS (08-20-2014), Easter Bunny (08-20-2014), Kyle Undefined (08-20-2014), Quigs (08-21-2014) |
![]() | | #14 | ![]() |
Groans: 67
To my knowledge, the MS6 uses the same rotor size (320 mm; 12.6") as the MS3. I edited the above post for clarity.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
| The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post: | Easter Bunny (08-20-2014), Kyle Undefined (08-20-2014), paddypilot (08-20-2014), SpencerC (08-20-2014) |
![]() | | #15 | ![]() |
![]() Join Date: Apr 2012 Location: Barrie, Ontario, Canada
| Not Ranked : 0 score Using regular 6 rotors on the speed wont work with your current configuration. When you tighten things the rotor is most likely binding against the pad. Centric and a few other suppliers make made for Speed rotors, may be best bet to find a place that sources those, and go in armed with part numbers cause parts counter guys know pretty much nothing, lol. Sent from my SM-N900W8 using Tapatalk
__________________ [SIGPIC][/SIGPIC] 2007 Mazdaspeed 6 - Bolted, Methed, Tuned |
| The Following User Says Thank You to DamagedGoods For This Useful Post: | paddypilot (08-20-2014) |
![]() | | #16 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah I was looking at Centric, but I don't think Advance Auto has them. What compatible brands would they carry? |
![]() | | #17 | ![]() |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
| Not Ranked : 0 score None. you won't find these at most parts stores. If you need them now see if a local dealer has them. If not then overnight an order
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." |
![]() | | #18 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
Groans: 52
| Not Ranked : 0 score Napa stocks rotors you need |
| The Following User Says Thank You to Nitr0EngiE For This Useful Post: | Neverlift (08-20-2014) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score Overnight from Japan, er... rockauto. Sent from my SM-N900W8 using Tapatalk
| The Following 2 Users Say Thank You to DamagedGoods For This Useful Post: | Easter Bunny (08-20-2014), Quigs (08-21-2014) |
![]() | | #20 | ![]() |
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
Groans: 52
| Not Ranked : 0 score I don't understand why people wait to the last minute to buy and change brakes.
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
![]() | | #21 | ![]() |
Groans: 793
| Not Ranked : 0 score @KNS Brakes; has all you need.
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Confirmed, I was given the wrong brakes. I just bought the car, so whoever owned it before me let the rotors get really bad. |
![]() | | #23 | ![]() |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score This. Why even fuck with another auto parts store? Advanced, Carquest, Vatozone, & Oreillys have all tried to give me the wrong parts for the MS6, only when Napa has told me it would take them "XX" amount of days to get the actual part I needed. No Napa, enjoy the Ford/Mazda stealership. Or, overnight them from Edge, KNS, etc. Napa Part #'s UP 880474 Front UP 880473 Rear They are about $250 for all 4. They carry Asstomouth rotors as well which are nice in appearance... but they are $120 each for the front. ATM 0941366
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score I got the right rotors this time, but I'm ordering quality parts online in the future when I have more time. Trying to get everything done before I get stationed in Mississippi. Now to figure out where that whining noise is coming from... I already did the girlfriend delete mod, so it can't be her... |
| The Following 6 Users Say Thank You to paddypilot For This Useful Post: | ALPINEST4RS (08-20-2014), btstarcher (08-20-2014), Dizzy Turbo (08-20-2014), kgb (08-25-2014), lilred (08-20-2014), Natey (08-21-2014) |
![]() | | #25 | ![]() |
![]() Join Date: Nov 2012 Location: Leominster Mass
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,003
| Not Ranked : 0 score I grabbed rotors and pads from autopart international for my ms3 last summer and got the right ones. I just made sure to tell the guy multiple times it was for a speed... Also have had a passenger side axle on my car from them for over a year. |
