| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() | | #1 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
Groans: 261
| Not Ranked : 0 score subbed
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
(Thread Starter) | Not Ranked : 0 score And for the record, 2 aren't working and haven't been since around the time I bought the fucking car a year and a half ago.
![]() | | #4 | ![]() |
![]() Join Date: May 2011 Location: Lexington, KY / Troy, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score The exclamation point blinks several times each start up and is solid after that for permanent Tapatalked
__________________ 08.5 CWP MS3 GT AP Stage 2 S-OTS+ | Cobb Catted DP | Magnaflow CBE | JBR SRI | Cobb TIP | JBR 70 Duro RMM |NGK Iridiums | Autotech Internals | Lamin-X Yellow Fog Overlays |
| The Following 4 Users Say Thank You to cabrone For This Useful Post: | dastpe (03-14-2012), EdgeAutosport.com (03-14-2012), labikesrcool (03-14-2012), silvapain (03-14-2012) |
![]() | | #5 | ![]() |
(Thread Starter) | Not Ranked : 0 score Mine never blink in the AM though.
![]() | | #6 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
Groans: 112
| Not Ranked : 0 score I sold mine awhile ago, after I bought some new (cheap-ass) wheels/tires. My stock wheels were all bent to shit.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
![]() | | #7 | ![]() |
(Thread Starter) | Not Ranked : 0 score My front right and left rear are bent. Subsequently, the TPMS sensors in those wheels also do not work.
![]() | | #8 | ![]() |
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score I don't have them in my winter wheel setup. The little low pressure indicator blinks for about 10 seconds then goes solid every time you start your car. There is no sound, however. And inspection stations do not inspect tire pressure.
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
![]() | | #9 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's decided then. Unless someone has 2 sensors they want to sell me cheap, I have a box of 50 shorty valve stems to give my father-in-law tomorrow when we put my tires on.
![]() | | #10 | ![]() |
![]() Join Date: Jul 2010 Location: Arlington, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
Groaned at 10 Times in 7 Posts
| Not Ranked : 0 score I also drive all winter with no sensors...you get use to the little light. You should have no issues with inspection since the light is on it proves that the TPMS is functional...and if the inspector asks just tell him you run low pressure for a softer ride or some BS like that. |
![]() | | #11 | ![]() |
(Thread Starter) | Not Ranked : 0 score I don't worry about inspections.
![]() | | #12 | ![]() |
![]() Join Date: Nov 2010 Location: Annapolis, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,335
Groans: 45
| Not Ranked : 0 score My summer wheels don't have them. Between the DSC & TCS lights, whats another one |
| The Following 4 Users Say Thank You to Vader For This Useful Post: | EdgeAutosport.com (03-14-2012), karl-hungus (03-14-2012), kgb (04-14-2014), Pseud0logik (03-14-2012) |
![]() | | #13 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
| Not Ranked : 0 score QFT |
![]() | | #14 | ![]() |
Groans: 298
| Not Ranked : 0 score I thought you could disable that with the AP? Lemme search for the code. EDIT: Here is where I got the idea it can be done (and that is Chris@Xtreme who posted and he is no dummy) 2010 MAZDASPEED3 AccessPORT Available Now! Last edited by rfinkle2; 03-14-2012 at 11:54 AM. |
![]() | | #15 | ![]() |
![]() Join Date: Dec 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
Groaned at 249 Times in 46 Posts
| Not Ranked : 0 score I bought some on ebay for super cheap. I'm too OCD to have lights staring at me in the face all the time. Just get the cheapest ones (and a rebuild kit if they need) it and call it a day. |
![]() | | #16 | ![]() |
![]() Join Date: Feb 2010 Location: Daphne, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
| Not Ranked : 0 score I always put a black piece of electrical tape over the TMPS light. |
![]() | | #17 | ![]() |
Groans: 298
| Not Ranked : 0 score pming Chris @ xtreme to see if he knows the code. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | ak_spray (03-14-2012) |
![]() | | #18 | ![]() |
![]() Join Date: Feb 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
Groans: 46
__________________ Current Build: Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs Sold: 2008.5 Black Mica GenWon - Fully Bolted |
![]() | | #19 | ![]() |
Groans: 45
| Not Ranked : 0 score |
| The Following User Says Thank You to Vader For This Useful Post: | rfinkle2 (03-14-2012) |
![]() | | #20 | ![]() |
Groans: 298
I'll keep trying, and if Chris is around, I'm pretty sure he'll get back to me. | |
![]() | | #21 | ![]() |
![]() Join Date: Jul 2011 Location: graham, wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score Just take the air out of your then read codes with the ap lol
__________________ PTP windage tray/ BSD|PTP CDFP|Cobb SRI| JBR RMM|JBR SSP|CS TIP|Cobb AP+OTS tune |
![]() | | #22 | ![]() |
| COOL STORY BRO ![]() Join Date: Nov 2010 Location: Cape Girardeau Mo/San Diego CA
Rep Power: 2238 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,863
Groans: 179
Groaned at 179 Times in 30 Posts
| Not Ranked : 0 score I've been on my Rota's since July without TPMS and all it does is show up on the dash, if you really wanted to you could just take the sensors out of the factory wheels and make a TPMS bomb, I think there is a how to on here edit-found it Get rid of the TPMS
__________________ ![]() ![]() JBR 3.5" WHALE PENIS-su tmic- sure track urethane rmm- corksport catless 3" downpipe- ultimate racing tp-OBX 3" cat back -rally armor urethane flaps-Cobb Accessport FINKLE TUNED-sure shift anchors-autotech hpfp internals-HKS BOV VTA -jbr heavy shift knob- 245-40-r18 Falken 329's-paint matched uber smiley ZOOM ZOOM BOOM Last edited by Hamilton69; 03-14-2012 at 02:11 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #23 | ![]() |
Groans: 46
| Not Ranked : 0 score I would buy this if someone sold it due to my laziness...
![]() | | #24 | ![]() |
![]() Join Date: Jan 2010 Location: Annapolis, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 326
| Not Ranked : 0 score Hey, I think we bought the same wheels. Sonic Tuning ST100s? I'm not gonna worry about the TPMS. The light only beeps when it first comes on, every time you turn the car on there after the light just turns on, no beep. Back the the ST100's. I bought Conti DW 235/40/18's for them. I'm in the middle of moving so I haven't put them on yet so I'm very interested in seeing how yours look and fit. Post pics soon!
__________________ 2008.5 Mazdaspeed 3 GT True Red BNR S3. HTP Full 3.5" Intake. Self Ported Intake Mani. CorkSport Catless DP. UR Test Pipe. CXRacing Piping w/ TR8. GFB Respons BPV. Autotech HPFP. Stratified 3 Port EBCS. Stratified Guardian Angel. 3 Bar MAP Sensor w/ PnP Harness. |
![]() | | #25 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
Groans: 67
Take all your inflated wheels/tires off, put them in the hatch, and replace them with a setup with no sensors. Drive around for a while and your light comes on.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | Hamilton69 (03-14-2012) |
![]() | | #26 | ![]() |
![]() Join Date: Feb 2011 Location: Princeton, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,469
Groaned at 61 Times in 40 Posts
| Not Ranked : 0 score I had one break on mine and I took it to mazda and asked if they could cover it under warranty and they did. Its worth a shot if you have warranty. |
![]() | | #27 | ![]() |
![]() Join Date: Mar 2010 Location: Spanaway, Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 146
__________________ 2008 Silver MS3 GT - BNR S2, CP-E HPFP, CP-E Nano, Cobb FMIC, Cobb AP(E-85 Mix [FREEKTUNE]), GrimmSpeed EBCS, CNT Exhaust, Corksport DP, SU Test Pipe W/ Magnaflow HFC, Forge BPV v1, EGR Delete, AWR RMM, SU Shifter Bushing, CP-E Towplate, BC Coilovers, Cobb RSB, Motegi SP-10 HyperBlack(19lbs) |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have 62k on a 2008. Doubtful.
| TPMS valve stems snapping off | 2008speed3 | MazdaSpeed 3/6 - Wheels & Tires | 6 | 04-06-2011 08:07 PM |
