 Old 04-20-2010, 02:43 AM   #1
rtabagaboy's Avatar
Posts: 363   (View Stats)
rtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the world
Groaned at 7 Times in 3 Posts
Default Wide Tires and Stock wheels
I am curious has anyone put wider tires on the stock wheels? i see some cheap 245/45/18 Potenza RE050 well 2 of them anyways. (anyone know the difference between RE050 and RE050A?)
Has anyone out there put wider than 225 tires on the stock rims? Would 245/45/18 be possible on the stock 7.5" rim? What about stock RX8 wheels?
How would staggered tire sizes affect performance? 2 large ones in front for all that powa!?
Phat tires Rule!
2008.5 BlackMica Mods:
- Cobb SRI, Turbosmart BPV, CPE RMM 60d, TRZ TMM, TopSpeed PMM, HTP Turbo Inlet... I'm workin' on it.
AZ Status!
rtabagaboy is offline   Reply With Quote
 Old 04-20-2010, 02:46 AM   #2
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
Groaned at 39 Times in 27 Posts
stock is 18x7 and potenzas suck balls
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline   Reply With Quote
 Old 04-20-2010, 03:59 AM   #3
soccerballz's Avatar
Posts: 596   (View Stats)
soccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the world
Im pretty sure our stock rims are 7.5". Im riding on 225's which already stick past the rim. I dont think you can go much bigger than that on our rims but I cant recall anyone trying and failing either. And as for 245's hellz no lol.
08' Black Mica MS3
Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight.
Sponsored by NATOR VA
soccerballz is offline   Reply With Quote
 Old 04-20-2010, 06:07 AM   #4
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
a) Stock rims are 7" not 7.5, for the Gen 1 anyway.
b) Go to the tire manufacturer website or tire rack and see what the rim width range is for the tire you are thinking of. Stick within that range. Outside if that, either handling, or safety, or both will suffer.
I believe the widest I have seen that is within that rim width is 225/45/18 unless you go to a much taller side wall which will cause clearance issues.
Suspension:
The Following 2 Users Say Thank You to FreeFlyFreak For This Useful Post:
ms3077 (04-20-2010), Sacrilicious (04-21-2010)
 Old 04-20-2010, 06:15 AM   #5
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
i have 245's on my rx8s. and those are 8" wide. They are the fattest tire that still falls within spec for that wheel size. anything bigger than 225 on the stock wheels is asking for trouble
The Following User Says Thank You to 8.5MS3 For This Useful Post:
ms3077 (04-20-2010)
 Old 04-20-2010, 09:48 AM   #6
jdmjerry's Avatar
Posts: 176   (View Stats)
jdmjerry is a splendid one to beholdjdmjerry is a splendid one to beholdjdmjerry is a splendid one to beholdjdmjerry is a splendid one to beholdjdmjerry is a splendid one to beholdjdmjerry is a splendid one to beholdjdmjerry is a splendid one to beholdjdmjerry is a splendid one to behold
lol i have 245's on a 9inch wheel... and the sidewall is stretched a hair, 245's on the stockers would look like crap+not work
2009 mazdaspeed 3
I eat your v8's for breakfast...
jdmjerry is offline   Reply With Quote
 Old 04-20-2010, 04:24 PM   #7
The Kamikaze King!
Groans: 754
OP if you do decide to squeeze them on there be sure to post here Rice of the Day to show us how it turned out.
Suspension:
ms3077 (04-20-2010)
 Old 04-20-2010, 04:37 PM   #8
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
Yep, stock rims = 7 inches NOT 7.5 inches
Anything wider than 225 = Massive fail.
Get some wider wheels if you want wider tires.
ms3077 is offline   Reply With Quote
 Old 04-20-2010, 04:41 PM   #9
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
yeah anything beyond 225's will not only be impractical, but they could become very unsafe as well. The tires will not wear correctly
 Old 04-20-2010, 06:12 PM   #10
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
Say Chi Sin Lo has disabled reputation
Groaned at 62 Times in 28 Posts
What everyone said.
2nd gen are 7.5 wide.
Say Chi Sin Lo is offline   Reply With Quote
 Old 04-20-2010, 11:52 PM   #11
rtabagaboy's Avatar
Guess I gotta get some new shoes then... 18x7 eww. 18x8 or 18x8.5 If I am not planning on fender rolling or lowering my car was is the widest to recommend? Thinking the Dunlop direzzas or ventus 12 evo in a few Kmiles. Rebate on the ventus right now 50$ thinkin about getting some early.
How does wheel offset affect what size tires you can put on? I don't really care if the wheel is flush or not I just want Wide wheels. Moar grip rite? Is there any ideal tire size for our car? can you have too much rubber from a performance standpoint
AZ Status!
 Old 04-21-2010, 05:06 AM   #12
8.5MS3's Avatar
Groans: 326
if you dont want to roll your fenders your pretty much stuck at 225, 235 if you get the right offset
offset - the distance the hub is from center with relation to wheel size ie. RX8 wheels are +50, which means the hub is 50 millimeters towards the front of the wheel with relation to the centerline. this is a "high" offset, which pushes the wheel further into the well. a lower offset will bring the wheel out further.
Too high an offset, you rub your shocks/hit the inside of the fender when turning the wheel, too low an offset and youll smack your fenders and they'll stick out of the wells
^^rx8's with 245/40 Starspecs. thats pretty much the limit. lots of rolling and grinding to get that to work
FenixTX717 (04-24-2010)
 Old 04-21-2010, 08:11 AM   #13
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
wait...grinding? where did you have to grind?
 Old 04-21-2010, 08:13 AM   #14
8.5MS3's Avatar
Groans: 326
where the rear bumper and fender meet. basically where you cant roll anymore. that was the only spot i was rubbing
 Old 04-21-2010, 09:14 AM   #15
pewpew
oh crap...that was a problem? do you have upgraded rear camber links or anything?
 Old 04-21-2010, 09:18 AM   #16
8.5MS3's Avatar
Groans: 326
no, suspension is stock except for swaybars
its only the first 1/2 inch, not the whole length of the joint
 Old 04-21-2010, 09:37 AM   #17
pewpew
that sux, man...i was planning to go for 245/40s on my next tire change...looks like i'm going to have to be extra careful...
 Old 04-21-2010, 09:43 AM   #18
8.5MS3's Avatar
Groans: 326
ur gonna hit there no matter what. it cant be rolled. just take a dremmel and be real careful, work slow. ill see if i can take pics of what i did tonite, if i remember lol
 Old 04-21-2010, 09:46 AM   #19
pewpew
blaaah...forget it...i'm just gonna get 235s again and call it a day. i have 48mm offset rims, so it's going to be even worse for me than it was for you...=/
 Old 04-21-2010, 10:01 AM   #20
Kdawg207's Avatar
Posts: 2,389   (View Stats)
i did and i absolutely love this set up on the stock rims....
Got Some New Rubber:
no issues whatsoever - way better result
Kdawg207 is offline   Reply With Quote
 Old 04-24-2010, 01:57 PM   #21
maritime ms6's Avatar
Posts: 19   (View Stats)
maritime ms6 is an unknown quantity at this point
I have 235/40 on stock ms6 rims.....no issues
maritime ms6 is offline   Reply With Quote
 Old 04-24-2010, 03:36 PM   #22
ms3077's Avatar
Groans: 974
You can fit a wider than recommend tire on a small rim but it doesn't mean it's right.
 Old 05-05-2010, 12:57 AM   #23
SnoXRacer183's Avatar
Posts: 238   (View Stats)
SnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond repute
I put 245-35-18 Hoosier R6s (which are more like 255s) on my 18x7.5 et46 stock size wheels and it works awesome. Don't listen to the stretch tire huggers. It works fine and looks good. And no these do not rub at all
2006 Subaru Impreza 2.5
SnoXRacer183 is offline   Reply With Quote
 Old 05-05-2010, 02:57 AM   #24
tigermack's Avatar
Posts: 650   (View Stats)
Groans: 78
I didn't know 245's would be stretched a hair on a 9".
 Old 05-11-2010, 10:39 AM   #25
bnoon's Avatar
Posts: 1,770   (View Stats)
Stock wheels are 7", NOT NOT NOT NOT 7.5". You can oversize an R compound tire due to the VERY stiff sidewalls, but true street tires will suffer when not on a proper sized wheel. That being said, you can still do it, just know it won't be optimal.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
bnoon is offline   Reply With Quote
 Old 05-11-2010, 10:53 AM   #26
The Kamikaze King!
Groans: 754
Just to clarify.
Gen 1 OEM wheels 7.0"
Gen 2 OEM wheels 7.5"
I know I never check which forum I am in.
Suspension:
soccerballz (05-11-2010)
 Old 05-11-2010, 12:56 PM   #27
bnoon's Avatar
Originally Posted by FreeFlyFreak View Post
Just to clarify.
Shit. Didn't even know that. Time to shut my mouth...
2002 BMW M3 - Sold!
 Old 05-11-2010, 01:04 PM   #28
The Kamikaze King!
Groans: 754
This is in the Gen 1 forum, but you never know.
It is always better, now a days in this forum, to clarify you are talking about MS6, MS3 G1, or MS3 G2, because of the differences, to make sure we are all talking about the same car in the same thread.
I have already been thoroughly confused a few times because of this issue.
One person talking apples, and someone reading thinking they are talking about oranges.
Suspension:
Page generated in 0.45611 seconds with 34 queries
