 Old 02-12-2011, 02:58 PM   #161
Scynfewl's Avatar
Posts: 208   (View Stats)
Scynfewl has a reputation beyond reputeScynfewl has a reputation beyond reputeScynfewl has a reputation beyond reputeScynfewl has a reputation beyond reputeScynfewl has a reputation beyond reputeScynfewl has a reputation beyond reputeScynfewl has a reputation beyond reputeScynfewl has a reputation beyond reputeScynfewl has a reputation beyond reputeScynfewl has a reputation beyond reputeScynfewl has a reputation beyond repute
I can't deal with the tires being so much smaller than the rims. I get it, I do. And if I don't focus on the actual sidewalls rhoadblocks ride looks dope as hell. But eww, i feel like your rubber is gonna peel off going around a fast food drive through.
Traded for 62mpg: Stage2+SF+FMIC - 93 Octane TurboXS FMIC - Custom Downpipe - HKS TBE - COBB SRI - Turbosmart BPV - Full Motor Mounts - NRG Engine Torque Damper - Cobb Stage 2 Suspension Kit Springs, Front/Rear Sway Bars - 6000k HID Conversion Low/Fog - COBB Short Shifter - Momo Corse Rev 18
Scynfewl is offline   Reply With Quote
The Following User Says Thank You to Scynfewl For This Useful Post:
KeysMS3 (02-15-2011)
 Old 02-12-2011, 07:53 PM   #162
RhoadBlock's Avatar
Posts: 793   (View Stats)
RhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the world
Groaned at 7 Times in 4 Posts
Haha, fair enough. Best response to anti-stretching I've read yet. I think my gas mileage and awareness of surroundings have actually increased dramatically since I went hellaflush lol
2007 MS6 - broked & gone
2006 MS6 - less broked
rhoadblock- the ms6 that will never run again
RhoadBlock is offline   Reply With Quote
 Old 03-20-2011, 10:01 AM   #163
jroc's Avatar
Posts: 1,482   (View Stats)
jroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the world
Groaned at 6 Times in 6 Posts
17x9 TRMotorsportc3. 255-40 tires. My god this setup is tits.
I was passing evos, porsche turbos, lotuses, gtos. Insane amounts of grip.
JDMFresh.com 1990 Mazda Miata
NASA Time Trials/Time Attack, Global Time Attack
A miata may be gay, but its probably faster than your car around a track. That's pretty gay.
jroc is offline   Reply With Quote
The Following User Says Thank You to jroc For This Useful Post:
:: Gusto :: (03-21-2011)
 Old 03-20-2011, 06:50 PM   #164
Speed_j23's Avatar
Posts: 611   (View Stats)
Speed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the world
What offset is that and what did you have to do to fit the wide of wheel/tire? (Roll,pull,camber, spacers???)
thinking of going with some 17x9 +45 offset wheels and i'm wondering what i would have to do to actually pull it off.
New: 06 WWP MS6
Old: 06 LPM MS6
Speed_j23 is offline   Reply With Quote
 Old 03-20-2011, 10:09 PM   #165
RhoadBlock's Avatar
New setup is awesome J. Looks about mid/high 30s offset from your pic but I can't really tell because of the angle. Seems like 17x9 +45 with 255/40s would put you awfully close to the strut/control arm.
 Old 03-20-2011, 11:07 PM   #166
jroc's Avatar
Rim/size:17x9 TRMotorsport c3
Offset:+48
weight: 19.6 lbs each.
Suspension: ksport coilovers, spc balljoints up front set to the farthest outside setting. Have never had an alignment done, so I'm not sure about camber/toe. Will be doing soon. No spacers, yet. Will be putting either a 3-5-8mm spacer up front. This setup clears the upper control arm, but not by much--5-10mm clearance at most.
Fender roll: stock front, moderate roll rear (done with a 2lb dead blow hammer, just enough to clear rear tires). No pull.
Ill take better pics later this week since ill be doing ducting work for the rotors. I had a thread up about offsets/widthsfor the ms6 but it got deleted in the crash.
Impression:
Holy spiderman grip. I was keeping up with cars I shouldn't have been, but I was. Turn in was crisp, but slightly laggy.
mroclimbr (03-01-2012)
 Old 12-14-2011, 06:19 PM   #167
Charcoal Ms6's Avatar
Posts: 4   (View Stats)
Charcoal Ms6 is a jewel in the roughCharcoal Ms6 is a jewel in the roughCharcoal Ms6 is a jewel in the rough
Groaned at 6 Times in 2 Posts
I have an Ms6 with 225/45/18 and im on stockies lowered on Eibach pro kit lowering springs. I will be getting 18x8.5 +38 offset wheels here on the 20th. are these going to need a fender roll or spacers? ive seen these on a ms6 with the same tires but on H&R lowering springs and with SPC ball joints. I will be rolling the same tires that are on my speed now.
Charcoal Ms6 is offline   Reply With Quote
The Following User Says NO Thank You to Charcoal Ms6 For This Un-useful Post:
Delphie (12-14-2011)
 Old 12-14-2011, 06:21 PM   #168
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
bad troll is bad
 Old 12-15-2011, 06:35 AM   #169
:: Gusto ::'s Avatar
Posts: 1,455   (View Stats)
Well I recently purchased some 19" asanti af116.... 19x8 & 19x10...
Sould look nice.
Sold my 18x9/x10.. to a guy from nh...
yea yea - i know i cant spell
 Old 12-20-2011, 04:56 AM   #170
RhoadBlock's Avatar
lol damn you are such a wheel whore dude
 Old 12-20-2011, 05:24 AM   #171
Yea man I am.. hah
I'm putting a shed up @ my house... just to hold more rims.
 Old 02-22-2012, 03:22 PM   #172
okay .. just bought some new.ish wheels
RH J5 19x9 +26, 19x10.5 +26
still have those Asanti wheels.. i think im going to re.lip to a 19x11
hah
 Old 02-23-2012, 06:01 AM   #173
RhoadBlock's Avatar
Damn that looks pretty dope. And not even close to aggressive for a Z lol
 Old 02-23-2012, 06:54 AM   #174
Hah.... nahh not to bad... might have to do some fender work.
But after seeing the 2013 mazda6.... I'm not sure how much longer ill keep this car.
 Old 02-23-2012, 01:37 PM   #175
RhoadBlock's Avatar
havent seen anything on it yet. look that good?
 Old 02-23-2012, 01:54 PM   #176
Yea they took what the new rx8/9 was supposed to look like.. & slapped to more doors on it.. making it a 4dr.... it looks like the maserati quadro.coupe..(how evr u spell it)... I hear from my friends @ my local dealer... all the reps are saing the car is going to be really really close to how the concept looks. :0)
 Old 02-28-2012, 07:19 AM   #177
boost2dms6's Avatar
Posts: 237   (View Stats)
boost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the world
Groaned at 6 Times in 4 Posts
That is hideous imo.
boost2dms6 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f319/widest-shoes-18226/
Mazda6 / Atenza > Looking to go 19x9.5 on my MS6... This thread Refback 06-23-2009 10:26 AM
Looking to go 19x9.5 on my MS6... - Mazda6 / Atenza This thread Refback 05-18-2009 03:26 PM
Page generated in 0.37623 seconds with 27 queries
