Will these fit. Will these fit without rubbing/throwing anything off and rim fit as well witout any problems. Kazera KZ-X Black w/Red Stripe BFGoodrich g-Force T/A KDW 2 |
Yeah, should fit no trouble |
required tire size for the wheels says 205/50 whys that? Also im not a fan nor do i like the g-force bfg's lots of road noise and quickly wear, not sure where you live but those got 10k here in Texas for me. Kumho and Michelin or falken seem to work best for me as far a noise and wear patterns. |
I've heard of wider rims with less offset working fine, so you won't have any problems there. The only possible issue I see is the brakes but I don't think you'd have problems with that either |
The tire size you selected is a little short. 225/50/17 is much closer to the stock tires size (a hair taller) The wheels are about perfect, good offset choice. |
| All times are GMT -7. The time now is 08:23 AM. |
