 Old 05-30-2009, 12:45 PM   #1
tburton101's Avatar
Posts: 201   (View Stats)
tburton101 is just really nicetburton101 is just really nicetburton101 is just really nicetburton101 is just really nice
Default Will these fit.
Will these fit without rubbing/throwing anything off and rim fit as well witout any problems.
Kazera KZ-X Black w/Red Stripe
BFGoodrich g-Force T/A KDW 2
car was sold.
tburton101 is offline   Reply With Quote
 Old 05-30-2009, 01:55 PM   #2
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Yeah, should fit no trouble
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 05-30-2009, 02:40 PM   #3
motocrosser614's Avatar
Posts: 687   (View Stats)
motocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the world
Groaned at 15 Times in 14 Posts
required tire size for the wheels says 205/50 whys that?
Also im not a fan nor do i like the g-force bfg's lots of road noise and quickly wear, not sure where you live but those got 10k here in Texas for me. Kumho and Michelin or falken seem to work best for me as far a noise and wear patterns.
motocrosser614 is offline   Reply With Quote
 Old 05-30-2009, 03:04 PM   #4
JMEngineer's Avatar
Posts: 2,122   (View Stats)
JMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the world
Groans: 32
Groaned at 19 Times in 15 Posts
I've heard of wider rims with less offset working fine, so you won't have any problems there. The only possible issue I see is the brakes but I don't think you'd have problems with that either
2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list...
2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch
-GTX2867R Coming Soon
JMEngineer is offline   Reply With Quote
 Old 05-31-2009, 05:45 PM   #5
Wide tire man
dbrier's Avatar
Posts: 957   (View Stats)
dbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the world
The tire size you selected is a little short.
225/50/17 is much closer to the stock tires size (a hair taller)
The wheels are about perfect, good offset choice.
2012 Crystal White Pearl Mazdaspeed3
Cobb AccessPort, Autotech HPFP internals, Corksport Stage II intake with TIP and airbox, Corksport rear camber arms, Corksport catted test pipe, Denso ITV22 plugs, JBR rear sway bar and HD mounts, CP-e stage II rear motor mount, Mazda5 rear brake upgrade, Bilstein struts, Eibach pro springs.
Too many wheels & tires to list.
dbrier is offline   Reply With Quote
Page generated in 0.25594 seconds with 23 queries
