 Old 06-11-2009, 03:47 PM   #1
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
Default will these fit my car with no problems??
I want to get the Tenzo Cuzco rims for my car with tires 225/40/18. But what i want to know is will i have any clearance issues??
 Old 06-11-2009, 03:52 PM   #2
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
What are the specs of the rim?
ms3077 is offline   Reply With Quote
 Old 06-11-2009, 04:50 PM   #3
18psiWhiteMS3
Lurkers
Posts: n/a
Bolt Pattern Offset
4x100 - 4x4.5/114.3 42
5x100 - 5x4.5/114.3 42
 Old 06-11-2009, 05:02 PM   #4
ms3077's Avatar
Groans: 974
Originally Posted by 18psiWhiteMS3 View Post
Bolt Pattern Offset
The offset is a bit aggressive but should still work without issues. I use to have rims with a 43 offset on 225/40/18s and never any problems. Whats the width btw? 7.5?
 Old 06-11-2009, 05:05 PM   #5
18psiWhiteMS3
Lurkers
Posts: n/a
8 inch wide
 Old 06-11-2009, 05:09 PM   #6
ms3077's Avatar
Groans: 974
8 inch wide
You'll be fine if you don't plan on dropping it.
edit: I see you have cobb springs, they don't lower too much in the rear right? On second thought you might be pushing it... Might have to roll your rear fendors.
AC problems help! LiEast MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 05-24-2011 07:55 PM
Will i have problems? Grim MazdaSpeed 3/6 - Turbo Induction 5 04-04-2009 01:03 PM
DashHawk problems... Driverman5777 MazdaSpeed 3/6 - ECU Computer Tuning 6 01-21-2009 02:27 PM
site problems jmhinkle Site News 2 01-05-2009 12:04 PM
too many problems/TXS DP tbone Mazdaspeed3/6 General Discussion 9 11-13-2008 11:35 AM
Page generated in 0.27095 seconds with 20 queries
