Will These Wheels fit? BBS RGR 17x 8.5 Offset: 55mmBackspacing: 7.00"Bolt Pattern: 5-114 Weight: 18.0lbs. They are a little heavy but they look amazing. I am worried about the offset though. Also looking at SSR Type C-RS, Enkei RPF-01s, OZ Alleggerita HLT and Enkei RS-M all in 17x8. |
Ill add pics for you homos to look at. BBS wheels look the best but are so much money. Im leaning towards the OZ wheels. All wheels except the BBS are under 16 lbs for a 17x8. http://www.tirerack.com/images/wheel...r_db_ci3_l.jpg http://www.tirerack.com/images/wheel...anth_ci3_l.jpg http://www.tirerack.com/images/wheel...f1_b_ci3_l.jpg http://www.tirerack.com/images/wheel...anth_ci3_l.jpg http://www.tirerack.com/images/wheel...m_bs_ci3_l.jpg |
VOLK CE28NF FTW -> under 15lbs. for the 18x7.5 In reality you'll never notice the couple extra pounds of the BBS's. I'm pretty sure I've seen wider/less offset on an MS3 before. My 7.5" wide rims are only 43 offset so the extra width and higher offset just about cancel each other out, meaning they would fit a 6. |
yea i like those volks also but i can only find people with the white ones in stock |
and as far as finding the time attacks in stock, where is this? i want. |
tire rack has them right now but just the white with red lip. i think i might suck it up and get the BBS wheels. They look the best by far but they are special order... I dont want to wait. |
Like the oz 17x8 |
the OZ are my second choice. Today im calling tirerack to see if they can give me an estimate on how long the special orders take. I really want those BBS wheels. |
The RS-M is probably the best bang for the buck in your group. |
17x8 with 38mm off set should fit no problem I think. I would throw some nice 235/40/17 tires on them and rockem! |
You need a bolt pattern of 5X114 and center bore of at least 67.1 mm. The +38 offset will really limit the tires you can run and you might rub. |
The tires currently on them are bridgestone SO-3 pole position 215/45 17, will using wheel spacers affect the +38 offset? Not sure what that number refers to. I don't want to have to worry about rubbing... |
i bought the 17x8 OZ's. They are lighter and have a better offset than the BBS rims. I will most likely be putting Nitto NT-01 235/40/17s on them. |
Nice I am thinking about these as well. Make sure you take pics. BTW what color is your car? |
I might try and stuff 245/45/17s on there but I will definitely have to roll fenders for that. |
The shorter tires will have shorter sidewalls and handle a little better and they would also lower the car just bit. They also mess up your speedometer. |
i think 245/45/17 will be the best but i am not sure they will fit easily. |
That's a tall tire for these cars. It would be a good idea to run through the calculations to see how much the speedometer will be off. |
that can be re-calibrated cant it? |
There's probably a way to do it but I don't know how. On my bike I have a separate control that hooks up inline between the speed sensor and main wiring harness that I can adjust to +/- 99.9%. |
with the difference in size the speedo will be reading 5% fast which isnt too bad. |
| All times are GMT -7. The time now is 08:20 AM. |
