Like Tree5Likes
  • 4 Post By ChaunceyM
  • 1 Post By smurugby12
 Old 10-22-2016, 09:31 PM   #1
Kong's Avatar
Posts: 42   (View Stats)
Kong has a spectacular aura aboutKong has a spectacular aura aboutKong has a spectacular aura about
Default Winter vs All Season Tires
Looking at either getting Bridgestone Blizzak WS80 or Continental Extremecontact DWS 06.
225/40/18 for both.
I've read that most members swear by the DWS. Want to know opinions on how well they are compared to Blizzaks in winter. I need new tires in general and living in MN, it would be a nice addition for the winters.
Plan on getting the DWS once spring comes around, but seeing as we're headed into the winter season, would it be better to get the blizzaks and get the DWSs once it warms back up?
Any opinions, advice, etc? I'd appreciate it!
Kong is offline   Reply With Quote
 Old 10-22-2016, 10:06 PM   #2
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Groans: 29
225/40/18 for both.
Get the blizzaks then the Continental Dry Wet summer tires for when it warms up. What's the point of getting winter tires then all season?
 Old 10-23-2016, 09:52 AM   #3
Kong's Avatar
I could stick with my current tires for the next season and stick with the blizzaks for winter, that's why.
 Old 10-23-2016, 10:02 AM   #4
broda's Avatar
Posts: 375   (View Stats)
broda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the world
Since you're in Minnesota I'm going to say you'll want the Blizzaks
broda is offline   Reply With Quote
 Old 10-23-2016, 11:17 AM   #5
Cheapspeed's Avatar
Groans: 29
That's not what you asked.
You asked if you should get winter tires for winter and all seasons for summer.
 Old 10-23-2016, 12:21 PM   #6
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
Any winter tire will absolutely dominate an all-season tire in winter. Even if the roads are clear, the rubber compounds stay soft in freezing temps thus providing superior traction. Add in any snow and ice and it's not even close.
I've had great experience with Blizzaks on 3 cars, but all major manufacturers make a great winter tire.
Get winter rubber for winter and performance summer rubber for the other 3 seasons.
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
The Following 3 Users Say Thank You to ChaunceyM For This Useful Post:
Cheapspeed (10-23-2016), Kong (10-23-2016), Vansquish (10-23-2016)
 Old 10-23-2016, 01:46 PM   #7
MikeBavaro's Avatar
Posts: 269   (View Stats)
MikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant future
I wouldn't oversize on the DWS tires, the sidewalls are already soft enough, if you drive the car hard you might roll it over far enough and muff up the bead........ Ive gotten very close on 215's on the autocross course
2007 MS3
True Red
HKS BOV-K&N CAI-APV3-CS TMIC
CS Short Throw-Whiteline Bushings-CS Rear Bar
1968 Mustang
Built 289 w/ factory heads
Built C4
Bulit 8" posi
Runs low 14's at 100 flat
MikeBavaro is offline   Reply With Quote
The Following User Says Thank You to MikeBavaro For This Useful Post:
Kong (10-23-2016)
 Old 10-23-2016, 08:59 PM   #8
Kong's Avatar
Kinda just went off the stickied tire thread.
 Old 10-23-2016, 09:01 PM   #9
MikeBavaro's Avatar
Are the gen 2's 225s from the factory?
Im assuming you have a gen 2?
2007 MS3
True Red
1968 Mustang
Built C4
Bulit 8" posi
 Old 10-24-2016, 05:20 AM   #10
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
yeah that's stock size. But I also wouldn't recommend them for hard driving...I ran a set of 245/45/17 DW's on 17x9s and you could see the sidewall rubbing an inch down the tire at the dragon. DWS will not be any better, and straight line traction will be worse as well.
Blue Pu.
 Old 10-24-2016, 06:58 AM   #11
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Lol, either quit overdriving or bump up pressure.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 10-24-2016, 07:55 AM   #12
Yatta's Avatar
Posts: 1,862   (View Stats)
If it stays below 40 there, get snows, I ran some blizzaks and they are amazing; but... if it gets above 40 it is like using a roll of electrical tape... the tread rolls right off. (we have wild temperature changes in Colorado for winter). I’ve used general Altimax (a continental brand) and they worked very well, this will be my first winter on DWS but I can say the dry and wet performance is great; they do not have any overlap on the sidewall to protect the rims though...
 Old 10-24-2016, 09:09 AM   #13
anavrinIV's Avatar
Groans: 63
I don't have them anymore.
Blue Pu.
 Old 10-24-2016, 05:57 PM   #14
Eth Fiend
phate's Avatar
The same holds true for all tires.
-06 MS6
 Old 10-25-2016, 05:14 AM   #15
anavrinIV's Avatar
Groans: 63
Understood...but the NT05s I was on last trip didn't have this issue.
I'm obviously not an expert driver my only point was I wouldn't suggest DWs if you're going for a serious summer tire.
Blue Pu.
 Old 10-25-2016, 06:53 AM   #16
smurugby12's Avatar
Posts: 278   (View Stats)
smurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the world
225/40/18 for both.
Dude you'll want Blizzaks. I am from Minneapolis too. I have the exact setup above; DWS for spring/summer/fall and Blizzaks for winter. Even though the DWS is an all season tire, they are pretty lousy in the snow, especially below freezing temperatures. I don't feel safe driving around with those in the winter and I would highly recommend Blizzaks for better winter safety and performance.
Kong likes this.
smurugby12 is offline   Reply With Quote
All Season Tires carolejshaffer 2010 MS3 - Wheels & Tires 3 05-20-2014 02:39 PM
All Season Tires carolejshaffer MazdaSpeed 3/6 - Wheels & Tires 3 05-20-2014 11:53 AM
Tire Testing Showdown: Winter vs. All-Season Haltech Automotive News 0 12-21-2011 01:10 PM
All season wheels and tires Stingray69 Gen2 MS3 General Discussion 18 11-14-2011 06:52 PM
Winter Rims/Tires Package or just Tires? Amber3 MazdaSpeed 3/6 - Wheels & Tires 12 12-02-2009 12:20 AM
Page generated in 0.37364 seconds with 28 queries
