> MazdaSpeed 3 - How-To's
Like Tree3Likes
  • 2 Post By Lewis7789
  • 1 Post By Lewis7789
 Old 08-02-2011, 06:16 PM   #1
Enginoob's Avatar
Posts: 151   (View Stats)
Enginoob has a reputation beyond reputeEnginoob has a reputation beyond reputeEnginoob has a reputation beyond reputeEnginoob has a reputation beyond reputeEnginoob has a reputation beyond reputeEnginoob has a reputation beyond reputeEnginoob has a reputation beyond reputeEnginoob has a reputation beyond reputeEnginoob has a reputation beyond reputeEnginoob has a reputation beyond reputeEnginoob has a reputation beyond repute
Groaned at 7 Times in 1 Post
Default DIY RPF1 Center Caps
So, if you are like me and either hate the look of the RPF1 center caps or don't really feel like dishing out $100 bucks for a set of CENTER CAPS for Christ's sake, this should be useful to you. This should work on all 16", 17", and 18" RPF1's. I believe that the 15s and 19s use a different center cap. This is my first ever how-to, so please be kind.
To begin, you will need these supplies:
Valspar Primer - $4
Valspar Gloss Paint of your choice (it's nice to have options, isn't it) - $4
Valspar Clear (gloss if you want a glossy finish, flat if you want a matte finish) - $4
3M sandpaper (300-400) grit - $3
Pliers
3M tape (I used painter's tape but really anything but Scotch should work) - $2
2" Knockout seal P/N 60720 (can be found at Home Depot) x5 (if you want a spare, just in case) - $6
A possible alternative to painting the knockout seals is to use plasti dip, which is the rubber coating they use for tools. It costs around $12, so the price won't be different.
Also, if you want a more permanent installation (just to make sure they don't come off), you may want to add superglue to the prongs when you go to press them in the last time. I chose not to in case I was required to remove them when I autocross
I have had them in for a few days and they are still in there snug. I have NOT exceeded 75mph since installation.
Total Cost - $30 max
This is what the knockout seal should look like:
Prepping for paint:
Take the knockout seals out of the packaging and tape up all of the prongs on the back with tape. This will keep you from scratching your wheel as you attach and remove the homemade center caps. Do this for all of the caps. It should look something like this:
Next, head to your wheel with the caps and pliers. Bend the prongs until there is a very snug fit. You don't want them coming off while you are driving but at the same time you want to be able to get them on. Rinse and repeat. NOTE: Make sure that you bend the prongs equally so that the cap stays as close as possible to center.
Once this is done, sand the face of all of the caps so that it appears rough on the entire surface. If you cannot get the groove perfectly, that is okay.
Painting:
Now that all of the center caps have been fitted to the wheel and sanded, it is time to begin painting. Begin with primer, adding 3-5 coats per instructions. The reason that I chose to add more coats than it calls for is to get rid of that 2" stamp more easily. It will may not be gone at this stage, but it will eventually disappear. Wait an hour or so to begin painting color.
Once all caps are primered, do the same steps as above, but apply more coats. Apply 3-5 coats, wait for the paint to dry to handle, sand lightly, and then paint another 2-3 coats. This helps to smooth the finish out. By now the 2" stamp should be gone. Wait an hour or so to begin applying the clear coat.
Finally, apply 4-6 coats of clear coat so that you have a nice strong finish. Let the caps dry fully before you try to press them into the wheels (I waited 24 hours). Otherwise, you may press smudge marks into the paint because it isn't dry all of the way through. If you have flat clear paint, it should look like this:
Installing on the wheels:
All you really have to do is press them in. Make sure they are still snug and the tape is still on so you don't scratch your wheels. Once finished, it should look like this:
Thanks for reading and I hoped it helped you save a few bucks!
Edit: 1/7/2012
After over 5 months with them on the car, I have had zero issues whatsoever. They remains snug as when I installed them the first day, and the paint shows minimal to no signs of chipping/scratches. Bear in mind I have taken several long trips and have exceeded 140 mph and they are still holding strong. Food for thought if you were concerned about the longevity of the caps.
Mods: Cobb STS|20% Tint|CP-e DP w/ cat|SU Street RMM|Gauges|JBR Mudflaps|Hella Supertones Horns|Denso 22's|Autotech HPFP internals|Red JBR RSB
Enginoob is offline   Reply With Quote
The Following 12 Users Say Thank You to Enginoob For This Useful Post:
apena85 (09-11-2011), BlueStreak (08-26-2011), CWP_MS3 (06-11-2014), dkapetansky (08-02-2011), Hectik1 (08-02-2011), K7addict (09-27-2011), Lewis7789 (09-25-2013), Mike@Stratified (06-23-2014), Raider (08-02-2011), socks (08-02-2011), taf0422 (07-13-2014), TWOptSL0W (05-26-2012)
 Old 08-02-2011, 06:20 PM   #2
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,774   (View Stats)
Meh
MAKE LOVE TO THE CANVAS
 Old 08-02-2011, 06:21 PM   #3
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Way to get resourceful man, DYI's ftw +1
They look really good for what they are..my ENKEI's have their Infinity symbol on the center cap and I love that, but that look works really well for your setup.
The Following User Says Thank You to helmetface For This Useful Post:
Enginoob (08-02-2011)
 Old 08-02-2011, 06:22 PM   #4
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
not bad, but i woulda matched the wheel color.
You could put a logo on it of some sort.
The Following 3 Users Say Thank You to socks For This Useful Post:
acmhd7 (08-02-2011), Enginoob (08-02-2011), whos_MS3 (09-27-2011)
 Old 08-02-2011, 06:26 PM   #5
Enginoob's Avatar
I thought it would have been too difficult to match Enkei's Matte Bronze, plus I already had all of the black paint on hand. All I had to pay for was the caps. I considered trying to nab a set of Mazda center caps and attaching the emblem to it in some fashion. I am not sure how they are attached to center caps, though. Small steps.
 Old 08-02-2011, 06:53 PM   #6
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
That is pretty cool! Beats an open wheel, IMO.
 Old 08-02-2011, 06:57 PM   #7
you can buy universal center caps on ebay for like 20 bux a set
 Old 08-02-2011, 07:31 PM   #8
acmhd7's Avatar
Posts: 460   (View Stats)
acmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the world
if you have the old centers just use those emblems. You will probably have to shave off the little nips that hold the caps in but you could give it a go....if you are feelin lucky.
acmhd7 is offline   Reply With Quote
 Old 08-02-2011, 07:34 PM   #9
Enginoob's Avatar
I considered that and I still may. The only thing is I want to keep the stockers complete in case I get in a pinch.
 Old 08-02-2011, 07:43 PM   #10
rabble rabble
802MS3's Avatar
Posts: 5,311   (View Stats)
Groans: 221
I painted the hubs. but each to his own I suppose.
'08 CWP MS3 w/ T3 3071r
 Old 08-24-2011, 02:54 PM   #11
vbt101's Avatar
Posts: 733   (View Stats)
vbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the world
those caps should be powdercoat-able...which might be useful for anyone who powdercoats their wheels.
vbt101 is offline   Reply With Quote
 Old 09-27-2011, 01:19 AM   #12
K7addict's Avatar
Posts: 909   (View Stats)
K7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the worldK7addict is the leader of the world
Groans: 32
I like it, cheap, easy to color match and it looks alright. I'm going to do this. Thanks.
2013 DODGE RAM 2500 LARAMIE
2012 MS3 Black Mica : Traded
2010 MS3 Velocity Red : Traded
2007 Suzuki GSX-R 750 : Crashed & Fixed
2004 Sentra SE-R Spec V : Traded
1995 Nissan Altima : Sold
1987 RX-7 : Sold
Originally Posted by helmetfail View Post
Cop: Sir, your car smells of marijuana, would you mind showing me your ashtray?
You: Um, there's no weed there sir...Just Meth...
Cop: %&#*#(#&$
K7addict is offline   Reply With Quote
 Old 06-11-2014, 11:29 AM   #13
Lewis7789's Avatar
Posts: 290   (View Stats)
Lewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the world
Forgive my bump but thanks for the Hot-to. I installed mine this past weekend and they look much better than seeing the rusty axle nuts and I never liked the $23/each Enkei center caps.
Enginoob and Mauro_Penguin like this.
2006 MS6 aka "Fatty". Only 278hp but I'll catch you in the corners.
Lewis7789 is offline   Reply With Quote
The Following 3 Users Say Thank You to Lewis7789 For This Useful Post:
CWP_MS3 (06-11-2014), Mauro_Penguin (06-15-2014), p057 (06-11-2014)
 Old 06-11-2014, 11:46 AM   #14
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
where did you get those enkei stickers? how much?
The Following User Says Thank You to p057 For This Useful Post:
 Old 06-11-2014, 11:48 AM   #15
Lewis7789's Avatar
eBay.
Enkei Black Acrylic Sticker Wheel Center Cap Emblem Logo 50 mm 4pcs | eBay
p057 likes this.
 Old 06-11-2014, 11:50 AM   #16
v8 convert
p057's Avatar
Groans: 220
I dont know why i always seem to forget that site exists. thanks!
The Following User Says NO Thank You to p057 For This Un-useful Post:
NavySailorMS3 (07-03-2014)
 Old 06-11-2014, 11:52 AM   #17
Lewis7789's Avatar
Haha, no problem.
 Old 06-23-2014, 06:51 PM   #18
william.fletcher2's Avatar
Posts: 248   (View Stats)
william.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the worldwilliam.fletcher2 is the leader of the world
Awesome write-up... will be doing this myself as mine do not have center-caps. Thanks!
william.fletcher2 is offline   Reply With Quote
The Following User Says Thank You to william.fletcher2 For This Useful Post:
Enginoob (06-26-2014)
 Old 07-12-2014, 08:54 PM   #19
My mom who is an artist decided she wanted to tackle mine. Got all the materials together today and she is painting them matte black with a glossy red evil M. Will post pictures as soon as she completes them.
 Old 07-12-2014, 09:56 PM   #20
helmetface's Avatar
Groans: 219
NCE about the caps.
Post pics of mom.
Mauro_Penguin (07-13-2014)
 Old 07-13-2014, 04:50 AM   #21
Enginoob's Avatar
I'm surprised that these are getting so much attention after this thread had been dead for nearly 3 years. Not complaining, though. Glad I could inspire.
The Following User Says Thank You to Enginoob For This Useful Post:
 Old 07-13-2014, 08:14 AM   #22
Originally Posted by helmetface View Post
NCE about the caps.
Post pics of mom.
I left those pictures on my home computer which is 6500 miles away... Remind me when I get home.
 Old 09-04-2014, 11:23 AM   #23
Well, about to go on the car today... here is a sneak peek.
2008.5 CWP Mazdaspeed3 GT w/Tech
Enkei RPF1 17x9 +35 | Cobb AP v3 | CBE | DP | TIH | BPV | Sport Springs | FSB | RSB | cp-e FMIC | RMM S2 | Tow Plate | Bilstein Struts
Cobb Tuning SoCal 91 Dyno Tune 289/315 | Freektune E85/93 tune in progress
The Following 2 Users Say Thank You to william.fletcher2 For This Useful Post:
Enginoob (09-04-2014), Mauro_Penguin (09-05-2014)
 Old 09-04-2014, 11:28 AM   #24
Lewis7789's Avatar
Eww.
 Old 09-05-2014, 01:08 PM   #25
Final Product, I somehow knicked the edge of this one slightly when putting it on. And have to get some better pictures with my real camera when I get more time, but here's a quick shot for now.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f33/diy-rpf1-center-caps-87750/
FS: (For Sale) Price Drop!!! - 5x100 - 17x8 +45 Gold Enkei RPF1 and Michelin Pilot Super Sports - NASIOC This thread Refback 01-11-2016 06:14 AM
Wheel Directory: Enkei RPF1 17x9.0 +45 - Page 15 - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 12-31-2015 10:27 PM
Post your best NC Pics! - Page 587 - MX-5 Miata Forum This thread Refback 12-14-2015 12:38 PM
Wheel Directory: Enkei RPF1 17x9.0 +45 - Page 12 - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-18-2015 08:40 AM
FS: (For Sale) (SD to LA, CA) - 5x100 - 17x8 +45 Gold Enkei RPF1 and Michelin Pilot Super Sports - NASIOC This thread Refback 08-01-2015 11:29 AM
SoCal Spotted - Page 410 - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 06-19-2015 03:53 PM
Custom Center Caps for RPF1 Wheels : ft86 This thread Refback 04-26-2015 08:55 PM
quattroworld.com Forums: 2" knockouts from HomeDepot ..>> This thread Refback 08-19-2014 08:30 PM
Chad's NC Street/Autocross Build - ClubRoadster.net This thread Pingback 06-15-2014 06:18 AM
Enkei RPF1s V2.0 - Page 151 - 8th Generation Honda Civic Forum This thread Pingback 03-07-2014 01:02 PM
Small centre caps for original 'daisy' wheels - Wheels, Tyres & Brakes - MX-5 Owners Club Forum - Forum This thread Refback 08-06-2013 02:00 AM
Saab 92 Forum : Saab92x.com / RPF1 center caps This thread Refback 05-03-2013 09:26 AM
HELP GUYS! regarding my enkei rpf1's - S2KI Honda S2000 Forums This thread Refback 04-17-2013 06:28 PM
acorn or cone for Rfp1's - NewCelica.org Forum This thread Refback 04-01-2013 09:00 PM
Enkei RPF1 Center Caps - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 02-07-2013 07:31 PM
RPF1 Center caps - S2KI Honda S2000 Forums This thread Refback 08-17-2012 08:36 PM
Small centre caps for original 'daisy' wheels - MX-5 OC Forum This thread Refback 10-31-2011 07:26 AM
WTB: Enkei RPF1 center caps - Toronto Subaru Club This thread Pingback 10-11-2011 09:42 AM
What About the Center Caps? Simoli MazdaSpeed 3/6 - Wheels & Tires 1 03-23-2011 10:50 AM
Oem Center Caps Help irishking03 Mazdaspeed3/6 General Discussion 2 12-03-2010 07:37 PM
Where to get Center caps? bioevolve MazdaSpeed 3/6 - Wheels & Tires 5 03-31-2009 01:03 PM
My Soon To Be New Center Caps... Radar_This MazdaSpeed 3/6 - Appearance 29 07-27-2008 12:43 PM
Page generated in 0.46698 seconds with 33 queries
