| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() | | #1 | ![]() |
| highest hp speed6 in cali ![]() Join Date: Nov 2010 Location: Nator San Diego, CA
Rep Power: 3199 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 192
Groaned at 326 Times in 194 Posts
(Thread Starter) | Not Ranked : 0 score edit: changed my filter media to SS scrubbing pads use this over SS wool ![]() instructions occ talk parts needed ebay occ or just a cylinder whatever works, and something you can stick a filter media in. fittings - pepboys, vatozone etc. SS teel scrubber pads - walmart etc breather filter - ebay (our valve covers are i think 15mm? their alot bigger than the standard breather filters they sell.) 5/8 hose (i think) - pepboys vato etc. assorted tools, taps etc. ![]() tap out the holes, rinse shavings out and shove the SS scrubbing pad in there. ![]() ![]() mount with a worm clamp or whatever, sure your smart you can figure it out. you could self tap a plate or screw a bracket into the fire wall, i mig'd a plate to the strut tower Last edited by Joe Isuzu; 02-27-2012 at 08:40 PM. |
| The Following 7 Users Say Thank You to Joe Isuzu For This Useful Post: | breakfstincluded (02-27-2012), ESB Jiu JItsu (08-06-2012), forcedinduktion (08-06-2012), GLORIFIEDBOZO (04-29-2012), rigor (02-27-2012), Sid3wayS (02-27-2012), SLOWHATCH (03-04-2012) |
| 500WHP INC ![]() Join Date: Feb 2009 Location: Tampa, Fl
Rep Power: 483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 389
Groans: 31
Groaned at 51 Times in 36 Posts
man you suck at diy instructions lol where does the second filter go that you got on the table ?
__________________ 2008.5 White Pearl MS3 474HP/453TQ http://imageshack.us/a/img4/1726/virtualdyno129124thgear.jpg(with CF 1.01 it was more like 425HP) Mods: 3.5 Bar MAP,Wisecos 9:5:1,Pauter Rods,BSD,balanced rotational assembly, ARP Studs,Devils Own Meth Kit DO7 100%, Garret 3076R T3 w/Titanium turbo blanket, CP-E Safe Seals,CP-E FMIC,CP-E CDFP,Cobb AP,DCR VVT,ITTV24,Grounding Kit,Custom 3.5" Intake and MAF, Custom T3 Manifold w/38MM Tial EWG black cermaic coated with Titanium heat wrap,Custom 3" V-Band DP Titanium heat wrapped,Borla Catback,Fidanza 11LB Flywheel,Spec 3+ Clutch,cometic head gasket,ceramic heat barrier on IM, Sure TIG,V.C.T.S. Welded, Kenne Bell BAS,CP-e Triple gauge pod, Prosport Boost Gauge,Glowshift Wideband AFR gauge, Glowshift EGT gauge,Streetunit Engine Mounts ALL 3,PTP BSD-Windage Tray, So Many Little things i cant remember. |
| The Following 2 Users Say Thank You to Nitr0EngiE For This Useful Post: | karl-hungus (02-29-2012), tddvrrn (09-04-2012) |
Groans: 192
didnt use it, normally im a bit better with instructions but this was something i felt is more custom than anything. just pointing in the right direction
![]() | | #4 | ![]() |
| Garage Queen ![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 2765 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,365
Groans: 54
So your basiclLy putting a breather on the cover with a cc in between ![]() What did you do with the inlet on the intake, just plugged it?
__________________ 2010 MS3 W/tech pkg Liquid Silver-Still Slower Then An Asthmatic Snail Cobb:Ap,Sri,Tip//JBR:Egr,Rsb,IM/TB Tigs,Rmm,Tmm//ATP:Catless long DP ETS:3.25" TMIC//M/D:OCC//Forge:v.2 BPV//AutoTech:FP Internals//PTP:Seals&studs Bosch:3-Bar//Grimmspeed:3-port EBCS//Stratified:G.A.//KW:Coilovers//RotaGrids:18x9.5 Meth/E85/Nitrous TUNING BY LEX |
![]() | | #5 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 1136 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,940
you realize the steal whole will rust fast, turn to shit and get sucked into the mtr lol unless it is stainless whole
__________________ BT T3 .5557 @26 psi Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, hallman mbc, 1 3/4 screamer p, odyssey batt, cs racepipe, dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth, ATC 6 puck sl fw 390 hp 440tq virtual dyno 1.01 cf perm |
![]() | | #6 | ![]() |
Groans: 192
sorry its stainless forgot to add i have a custom intake but on my old setup i just plugged it |
![]() | | #7 | ![]() |
Groans: 192
OP updated
![]() | | #8 | ![]() |
![]() Join Date: Feb 2012 Location: Sacramento, CA
Rep Power: 138 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 33 Times in 13 Posts
Lol... he said "steal whole"
![]() | | #9 | ![]() |
![]() Join Date: Jul 2011 Location: Clarksville, TN
Rep Power: 1550 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,278
Man you have such a great prison sex voice
__________________ "Intelligence isn't the ability to store information, but to find it" - Albert Einstein "When I read about the evils of drinking, I quit reading" - Henry Youngman |
![]() | | #10 | ![]() |
![]() Join Date: Sep 2011
Rep Power: 22 ![]() Thanks: 1
Groaned at 12 Times in 3 Posts
can you please tell us lil bit more about the installation? really interesting info im looking to get new ventilation kit from dealership but i already have some mods that i cant really go back to stock so i dont think dealer wont let me install that shit |
![]() | | #11 | ![]() |
Groans: 192
(Thread Starter) | Not Ranked : 0 score line from valve cover -> catch can (with hole or some type of breather)
![]() | | #12 | ![]() |
no line from intake like stock ? no vacuum line at all? sorry im so noob |
![]() | | #13 | ![]() |
Groans: 192
no, aslong as your engine is drawing enough vacuum through the pcv you can vent the valve cover.
![]() | | #14 | ![]() |
how do i know if theres enough vacuum from pcv and I have installed ptp pill to prevent smoking do i have to take that off before installing occ? and can both pcv occ and valve vent occ can be installed at the same time? |
![]() | | #15 | ![]() |
![]() Join Date: May 2011 Location: Ft. Worth TEXAS
Rep Power: 74 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
I just added a second catch can just like you did. I was about to do a little filter like you did, but wouldnt that be pulling in unmetered air through it? Thats why i did a return line to the tip..
__________________ 07Speed3 TWM STS || Forge BPVv1 || Sure RMM || Cobb SRI || CNT DP || AP || Autotech || 2X MD/SM OCC || ITV22 || COBB/TR8L FMIC || JBR TB TIG || HTP TIP || JBR TMM || JBR EGR DELETE || SONIC COs Last edited by radbrad; 08-03-2012 at 05:41 PM. |
![]() | | #16 | ![]() |
Groans: 192
No vent valve is positive pressure, hooking it up to the tip aids in evacuation from vacuum from the turbo however you will be shoving ccrank case gases into the turbo which over time can damage the fins when the liquid condenses back into oil and gas hence why yu put a cc in between
![]() | | #17 | ![]() |
![]() Join Date: Nov 2010 Location: 93401
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 373
Groaned at 4 Times in 2 Posts
This sounds like a good idea Ill have to get to it one day. I am also interested in how to know if your pcv is working properly. Are there any signs to look for when logging?
__________________ Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP Stage 2 tune - Koni yellow struts - H&R springs _ (Looking for BT) |
![]() | | #18 | ![]() |
Groans: 192
Blowing dipstick/ smokey turbo
| The Following User Says Thank You to Joe Isuzu For This Useful Post: | dot584 (08-04-2012) |
![]() | | #19 | ![]() |
I made a custom occ and I actually stuffed it with the exact same thing you did last year. Like 3 packs of those scrubbies and it works great, no smoking ever and the return line is clean. The line coming into the occ gets gunked though still so I clean it every once in a while. Never blown a dipstick so I guess its working. Sent from my ADR6300 using Tapatalk 2
![]() | | #20 | ![]() |
![]() Join Date: Jul 2010 Location: Charlotte Nc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 352
I will be doing this one shortly thank you!!!!
__________________ 2006 Mazdaspeed6 GT Liquid Platinum Metallic "because racecar!" " I love this $%&*ing car" ![]() -Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps -2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete -TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender -Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod -Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge |
![]() | | #21 | ![]() |
![]() Join Date: Nov 2010 Location: Houston
Rep Power: 1138 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,587
Groaned at 32 Times in 13 Posts
| Not Ranked : 0 score Daddy Chinkus How full of wool should the CC be, like stuffed or just enough to fill up the empty space?
__________________ GTx3576, 93 + Direct Port Meth - Self Tune in progress... Custom 4" intake // TurboXS 3" catless DP -> CS 80mm Race pipe -> UR 3" catback // Custom eBay/Treadstone TR8L FMIC // Superskaters 75mm throttle body // CP-E EWG Manifold - Precision 46mm wastegate // CP-E HPFP // DW ITFP // Grimmspeed 3-port EBC // Custom Vented OCC // NGK Iridium IX // Turbo smart Dual-Port BOV // JBR Manifold - Throttle body TIG's - coolant bypass // TRZ Rmm // JBR Rear Sway Bar. Limitless Performance and Fabrication Built: K1 rods // Stock bore - compression Wiseco pistons // OEM Rod Bearings // Main Bearings // ARP Main - Head Studs // Spec stage 3+ full faced clutch // Ported intake manifold tapped for direct port meth. TEAM LBN BEERS, GET WELL SOON BUDDY -- FYCN Last edited by Voltwings; 08-06-2012 at 12:44 PM. |
![]() | | #22 | ![]() |
| Not Ranked : 0 score Quick question, you said second. As far as i know, most go between the PCV and valve cover. If you have your valve cover going to a vented can, what is the other half of the one connected to your PCV connected to, your intake?
__________________ GTx3576, 93 + Direct Port Meth - Self Tune in progress... Custom 4" intake // TurboXS 3" catless DP -> CS 80mm Race pipe -> UR 3" catback // Custom eBay/Treadstone TR8L FMIC // Superskaters 75mm throttle body // CP-E EWG Manifold - Precision 46mm wastegate // CP-E HPFP // DW ITFP // Grimmspeed 3-port EBC // Custom Vented OCC // NGK Iridium IX // Turbo smart Dual-Port BOV // JBR Manifold - Throttle body TIG's - coolant bypass // TRZ Rmm // JBR Rear Sway Bar. Limitless Performance and Fabrication Built: K1 rods // Stock bore - compression Wiseco pistons // OEM Rod Bearings // Main Bearings // ARP Main - Head Studs // Spec stage 3+ full faced clutch // Ported intake manifold tapped for direct port meth. TEAM LBN BEERS, GET WELL SOON BUDDY -- FYCN |
![]() | | #23 | ![]() |
| Banned ![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,102
Groans: 89
Groaned at 103 Times in 69 Posts
| Not Ranked : 0 score |
![]() | | #24 | ![]() |
Groans: 192
no no, pcv valve is located on your block, where it gets its vacuum from the engine via intake manifold. although the vent valve on the valve cover and pcv valve are both part of the pcv system, the occ on the valve cover does interact with the pcv valve at all. if you guys are interested i can build yall one | |
![]() | | #25 | ![]() |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 2901 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,214
Groaned at 9 Times in 7 Posts
tapafuck | |
![]() | | #26 | ![]() |
__________________ GTx3576, 93 + Direct Port Meth - Self Tune in progress... Custom 4" intake // TurboXS 3" catless DP -> CS 80mm Race pipe -> UR 3" catback // Custom eBay/Treadstone TR8L FMIC // Superskaters 75mm throttle body // CP-E EWG Manifold - Precision 46mm wastegate // CP-E HPFP // DW ITFP // Grimmspeed 3-port EBC // Custom Vented OCC // NGK Iridium IX // Turbo smart Dual-Port BOV // JBR Manifold - Throttle body TIG's - coolant bypass // TRZ Rmm // JBR Rear Sway Bar. Limitless Performance and Fabrication Built: K1 rods // Stock bore - compression Wiseco pistons // OEM Rod Bearings // Main Bearings // ARP Main - Head Studs // Spec stage 3+ full faced clutch // Ported intake manifold tapped for direct port meth. TEAM LBN BEERS, GET WELL SOON BUDDY -- FYCN | |
![]() | | #27 | ![]() |
Groans: 192
(Thread Starter) | Not Ranked : 0 score between the pcv valve and intake manifold
| The Following User Says Thank You to Joe Isuzu For This Useful Post: | Voltwings (08-06-2012) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Thank you, goodness, i don't know why this has been rocket science for me haha.
![]() | | #29 | ![]() |
i guess it doesn't have to go back to intake? just valve cover to occ? is it required to get a new tune then? |
![]() | | #30 | ![]() |
Groans: 192
![]() | | #31 | ![]() |
| The "ski man" himself ![]() Join Date: Jan 2012 Location: Phoenix, AZ
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 72
Do you think one could tie this into the " making your OCC a 3 port venturi" setup?
![]() | | #32 | ![]() |
Groans: 192
theres no vacuum in the vent valve, only positive pressure however at wot you may utilize the exhaust
| The Following User Says Thank You to Joe Isuzu For This Useful Post: | aaron_-01 (08-27-2012) |
![]() | | #33 | ![]() |
| Banned ![]() Join Date: Aug 2012
Rep Power: 0 ![]() ![]() Thanks: 0
Groaned at 42 Times in 8 Posts
no vacuum only boost from the VC port? That's not at all what my Mazda Master techs have told me when I asked them about an OCC setup in the past... care to explain? Maybe I'm thinking oranges to apples..
![]() | | #34 | ![]() |
Groans: 192
The stoc k setup utlizes the vacuum from the turbo to draw crankcase pressure, however there is no vacuum from the vc itself. Its also not "boost" just positive pressure, although if left clogged can create enough pressure to launch the dipstick
![]() | | #35 | ![]() |
thanks for the clarification, that makes sense.
| DIY vent valve OCC | Joe Isuzu | MazdaSpeed 6 - How-To's | 3 | 02-27-2012 08:41 PM |
| Mazda Valve Cover Vent Change | rfinkle2 | 2010 MS3 - Turbo Induction | 15 | 03-13-2011 06:29 PM |
| Defrost Vent Pod Install - AC Vent Removal | ZPrice | 2010 MS3 - How-To's | 11 | 06-10-2010 12:12 PM |
