> MazdaSpeed 3 - How-To's
Like Tree2Likes
  • 2 Post By Constantin
 Old 11-16-2014, 07:44 PM   #1
Constantin's Avatar
Posts: 3,907   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Groaned at 18 Times in 16 Posts
Default How To: Change Hand Brake (EBrake) Line.
It is pretty straight forward, so I didn't make pictures myself. Maybe somebody will be doing this and will add pictures later. I'll gladly update the OP.
Here is what you do:
  • Unscrew the cable line from the hand brake handle. If you don't know, you don't have to disassemble the whole center counsel. Just pull the cup holder part up and you will get access the the bolt.
  • Under the car follow the lines to see which bolts to undo in order to move the heat shields. That part is easy.
  • Main pain in the ass is the heat shield that covers the place where hand brake "exits" the cabinet. After removing bolts that hod that (and removing the center brace) you can bend the heat shield a bit and just slide it forward on top of the exhaust. It will slide far enough, so you'll be able to reach the cables.
  • To remove the cable from the hinges, just pop out the "stoppers" - little metal ring with "teeth". They pop right out with help of a screw driver.
  • Then just remove the cable and from the car and install the new one.
NOTE: Don't forget which side goes were. Technically they are identical, but I guess you might run into problems when you route the new cable. The right side had a marking right up from the cable, you can't miss it.
Here is the part that I bought:
Dorman C660872 Brake CableDorman C660872 Brake Cable
. I paid $31.05 with shipping.
It worked out great!
Resources:
Mauro_Penguin and Quantum like this.
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arms | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
The Following 3 Users Say Thank You to Constantin For This Useful Post:
802MS3 (11-17-2014), Mauro_Penguin (11-17-2014), Tokay444 (11-16-2014)
 Old 06-13-2018, 08:34 PM   #2
Quantum's Avatar
Posts: 2   (View Stats)
Quantum is an unknown quantity at this point
I know this is a few years old but thanks for posting! Just ordered the line and planning to put it in this weekend.
Quantum is offline   Reply With Quote
Problems after brake pad change speedyspaghetti MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 05-05-2012 05:59 AM
Video: Watch an assembly line robot try its hand at street art Haltech Automotive News 0 04-19-2012 04:20 PM
Hand brake getting stuck... AtTheDriveIn MazdaSpeed 3/6 - Suspension & Brakes 4 01-04-2012 09:59 AM
Brake Fluid Change RichB MazdaSpeed 3/6 - Suspension & Brakes 44 10-28-2011 11:09 PM
VIDEO: Iacocca Mustang commercial debuts with Frank Sinatra, hand brake turns Haltech Automotive News 0 08-12-2009 02:20 PM
Page generated in 0.22643 seconds with 21 queries
