> MazdaSpeed 3 - How-To's
Notices
Like Tree3Likes
  • 2 Post By mczimer
  • 1 Post By TiGraySpeed6
 Old 07-29-2012, 10:04 AM   #1
mczimer's Avatar
Posts: 1,120   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Default HOW TO: Clean your valves - easy & cheap
Here is the BEST method for cleaning your valves: before/after soaking/after a little blasting
Equipment needed: (noted below, with pics)
  • An air compressor setup
  • Media gun/abrasive gun (open/close valve-but not necessary)
  • Fine walnut media **Note: HF has a different categorization than other places for the grit on the media**
  • B12 -2 cans (1 could do, if you are tight on cash)
  • 1' section of clear hose from Home Depot - 1" ID, available by plumbing
  • A towel you can sacrifice
  • Two way fluid transfer pump
  • Masking tape
  • Safety glasses/gloves (IMPORTANT)
  • Camera- to brag once you are done
Brief Overview of procedure:
  1. Remove IM, followed jbarone instructions (here)
  2. Ensure which 2 valves are TDC- top dead center/closed
  3. Soak those valves in B12 for at least 1 hour & cover other valves with masking tape
  4. Suck out majority of B12 using two-way fluid pump
  5. Air blast valve to remove remining B12, while using a towel around gun tip to catch carbon/B12 coming out (goggles/gloves on) (90psi for all air use)
  6. Blast valves with media in 2sec pulses for 30sec, vacuum on, repeat until happy
  7. Suck out media with small hose, then air blast for 10sec to remove anything else
  8. Tape over cleaned valves
  9. Proceed on other valves in same order (TDC/soak/suck/blast/clean)
  10. Photoshoot
TOTAL COST, without air compressor = only ~60 bucks, and you have 24.8/25 pounds of media left to help many others and clean again!
In order to achieve these results, the process goes as follows:
STEP 1
Soak 2 TDC-top dead center valves in B12 (maybe-substitute denatured alcohol/seafoam/methanol)
Top dead center is achevied by removing the passenger front wheel, then a little plastic guard which is held on by 3 plastic screw-you can't miss it, then you will see this:
The (14mm) tensioner pulley is on the left-turn this clockwise to loosen the tension on the belt before/after messing with the PS pump. You will need someone to remove the belt from the PS pump as you relieve the tension
The (21mm) crank pulley is on the right, turn clockwise to turn the engine, it will be at TDC when it gets toughest to turn (check valves are TDC by looking, then pouring some B12 in and see if it stays put)
**Note: Only 2 valves will be entirely TDC at a time. On mine, one valve was 90% closed, so take note for next time (ie- valves 2/4 and 1/3 are TDC grouped for me)
**Note: I do recommend removing the belt from the power steering pump before turning the crank pulley (before tilting the PS pump to the side during the Intake Manifold removal is even better), but it is not needed
STEP 2
After soaking the TDC valves either overnight (prep night before), or for 1+ hours, use either your shop vac (if you wish to ruin the filter and spend time cleaning it-trust me on this) or a two way fluid transfer pump (Here: 5 bucks at HF) to suck out as much B12 as you can into a container
Now take your gun, wrap the towel around the tip. Now insert/jam it into the valve to AIR blast all the leftover B12 out (it will shoot out, so wrap the towel in layers to make it thicker, and apply pressure)
**Note: Always use safety goggles and some gloves
STEP 3
Now, apply the one foot section 1" clear ID tube from Home Depot ($2) into the valve runner, as in this picture:
**Note: I soaked one valve for only ~1hr and got the same results, but it took a whole 2-3 minutes longer to clean!
I drilled a hole just small enough for my gun tip to fit into, roughly 1" from the base of the tube, then I stuck the gun/hose into the valve runner and apply the vacuum cleaner/shop vac to the open end.
I blasted at 90psi-the gun max operating pressure (BMW instructions say 6 bar, which is 116 psi BMW Link)
Blasting was done in pulses of 2sec for about 30 seconds total, then the valves were nearly spotless! Of course, I kept going to make them shiny and pretty, but honestly, this can be done on all the valves in under 10min.
**Note: I turned the vacuum on periodically to suck up excess media, since the tube collects much of the media. Keeping a vacuum on a "low" setting throughout the blasting could also be done, but you will use more media, as noted below. I also held the gun sideways (hood-style) to avoid any jamming, which worked best.
Unlike the prior write ups, I used a gun from harbor freight which had an open/close valve for the media. This allowed me to only blast air, which cleans very well on its own. This also allowed me to use less than 1 hopper of media for ALL the valves (out of the 25 pounds I got from Harbor Freight). Blasting only air into the valve periodically in essence reuses the media which is laying down there; think of it as a balloon which you let loose in a box-it smacks into everything. Another great point of using this gun was the ability to air-clean the engine bay, since 100% of the media is never going to be contained.
Gun used:
Gun has standard 1/4" air hose fitting and was sealed at the threads using tephlon tape (standard air tool procedure according tpo the neighbor)
This is what my setup looks like, note the vacuum attached on the end:
STEP 4
After blasting was to my liking, I stuck a small plastic hose attached to my vacuum into the valve to suck up any excess, then I blasted the valve with AIR for 10sec to clean anything remaining out (although it would just burn off, walnut is combustable).
**Note: cover the finished/remaining valves with masking tape to avoid any richochet media going in. I also taped the gun's hopper closed since I was holding it at all angles
That's it guys, let me know if you want clarification on anything. As a sidenote, you could probably acheive very clean valves simply by using the air and soaking (as noted in this thread, post #15) Props to timjs for inspiration on this project. I think B12 does an identical job to the Mazda Zoom Zoom Cleaner, possibly in a less concentrated form; but, nonetheless, it is just as effective for a fraction of the cost. Zoom Zoom Cleaner is originally designed for rotary engine cleaning, link to RX8 forum info
I used the liquid B12, since it is cheaper and the spray does nothing we need
TiGraySpeed6 and rfinkle2 like this.
mczimer is offline   Reply With Quote
The Following 21 Users Say Thank You to mczimer For This Useful Post:
08.5MS3 (07-31-2012), 3Gee Tee (07-29-2012), ak_spray (08-07-2012), BrianB6 (11-09-2012), Constantin (07-30-2012), djuosnteisn (08-03-2012), exentix (07-29-2012), IMASA (07-29-2012), jracer (07-29-2012), MS3-a(sore)ASS-rex (07-29-2012), MS6FL (07-29-2012), MSMS3 (07-30-2012), Pseud0logik (07-29-2012), Qwik6 (04-23-2013), rfinkle2 (08-07-2012), Sid3wayS (07-29-2012), speed23 (07-29-2012), superskaterxes (07-30-2012), tddvrrn (07-31-2012), TiGraySpeed6 (07-29-2012), trf5000 (07-29-2012)
 Old 07-29-2012, 10:19 AM   #2
Blackrider's Avatar
Posts: 314   (View Stats)
Blackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the world
Groaned at 19 Times in 13 Posts
Good writeup! Really the only thing I did differently was I used pneumatic pressure to turn the crank, but I have a setup for that!
2008 MazdaSpeed 3
Exhaust - Mazdaspeed & Ebay Downpipe
Induction - MazdaSpeed CAI, Unknown TIP, SU Boost Tubes & TMIC
Tuning - Auto Tech Internals, Cobb Accessport, Grimmspeed 3 port EBCS
Misc - J-Speed Shifter Plate, SU RMM
Blackrider is offline   Reply With Quote
 Old 07-29-2012, 10:53 AM   #3
3Gee Tee's Avatar
Posts: 1,440   (View Stats)
Groaned at 28 Times in 20 Posts
Tagged, thanks!
99 Miata________________________<3_______________________08 MS3
 Old 07-29-2012, 10:57 AM   #4
exentix's Avatar
Posts: 1,143   (View Stats)
exentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the world
Groans: 44
Groaned at 14 Times in 5 Posts
What was the mileage before doing it? Did you run an occ or egr delete?
exentix is offline   Reply With Quote
 Old 07-29-2012, 12:11 PM   #5
mczimer's Avatar
These valves were cleaned about 15k ago, EGR is deleted, and I have an OCC setup. Just comes to show this is a maintenance thing.
The Following User Says Thank You to mczimer For This Useful Post:
 Old 07-29-2012, 07:11 PM   #6
lowspeed
TiGraySpeed6's Avatar
Posts: 2,662   (View Stats)
Nice write up
I really like the method you ended up using- using that clear hose gracefully splits the difference between cheap, simple and effective. Very Well Done!
Raider - I'm thinking this is worth a bit o' $$, and an addition to the how-to database please
Mazdaspeed6 GT #3476 TiGray slicktop
Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete
M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, TB Coolant Bypass, SU Billet RMM
TWM Stage II STS & JBR SSB, Prosport Mech Boost
RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff
Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued
405/394 AWD - cf1.01 e38 BNRs3
315/372 AWD - cf1.01 e38 k04
TiGraySpeed6 is online now   Reply With Quote
rfinkle2 (08-07-2012), Worbit (07-29-2012)
 Old 07-29-2012, 07:41 PM   #7
BPASPEED's Avatar
Posts: 914   (View Stats)
BPASPEED is the leader of the worldBPASPEED is the leader of the worldBPASPEED is the leader of the worldBPASPEED is the leader of the worldBPASPEED is the leader of the worldBPASPEED is the leader of the worldBPASPEED is the leader of the worldBPASPEED is the leader of the worldBPASPEED is the leader of the worldBPASPEED is the leader of the worldBPASPEED is the leader of the world
Groans: 29
Good thread, thanks!
2011 MS3. Cobb AP, GTX3071, SS EWG mani, Tial 38mm EWG, 3 bar MAP sensor and PnP harness, JBR WP intake, HTP battery tray with a 51 Optima Yellow battery, ITV22s, GFB BOV, Autotech internals, CPE injector seals and studs, VTCS delete, COBB FMIC, UR DP and TP, SURE Anchors SS plate and weight, JBR TIGs and Coolant bypass, JBR EGR delete, JBR RMM. 352/349
BPASPEED is offline   Reply With Quote
 Old 07-30-2012, 06:03 AM   #8
Constantin's Avatar
Posts: 2,371   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Excellent wright up man! I was going to do something similar. I thing now I'll resort to a comparison How To between manual method and walnut blasting.
Raider I think that deserves a sticky too.
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arm | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
 Old 07-30-2012, 07:33 AM   #9
mczimer's Avatar
I have done the manual job, which takes a good 3 hours. For 60 bucks, and a nearly endless supply of walnut, this actually would save you money in the longrun, not to mention a lot of time
CLEANED YOUR VALVES?
 Old 07-30-2012, 09:39 AM   #10
CaptainCrunch's Avatar
Posts: 83   (View Stats)
CaptainCrunch has disabled reputation
Internet high-five.
Thanks for this. I can't imagine what my now 80k valves look like.
CaptainCrunch is offline   Reply With Quote
 Old 07-30-2012, 09:47 AM   #11
Constantin's Avatar
I did manual too...didn't take 3 hours (we are talking only about cleaning - no disassembly). I have used drill though, which made it quite faster. The result was the same cleaned valves. Walnut blasting is better by all means. But for the guys w/o compressor manual method will work very good
Originally Posted by CaptainCrunch View Post
Internet high-five.
Here is a hit for you: http://www.mazdaspeedforums.org/foru...ml#post1531403
Last edited by Constantin; 07-30-2012 at 09:47 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-31-2012, 06:10 AM   #12
King Pimp/Scammer Hunter
Raider's Avatar
Posts: 14,818   (View Stats)
Groans: 448
Moved to proper section. Op, lease on me in a week to send NSF bucks. Busy with fam emergency now
1) Looking to Buy a used Mazdaspeed? Read this!
2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here.
3) Wanna buy and sell here? DONATE for VIP
4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
5) Help MSF grow with FAQ threads!?
Raider is online now   Reply With Quote
 Old 07-31-2012, 08:37 AM   #13
mczimer's Avatar
I think I got the jist of what you said, will do
 Old 08-07-2012, 06:22 AM   #14
Frequentflyer's Avatar
Posts: 1,875   (View Stats)
So here's the question; did you feel a difference after all this? Acceleration? Gas mileage? Drivability? I'd hate to do all this with no change, but I'm assuming you felt something.
08.5 CWP MS3 - Cobb AP *Stage 2* ATR tweaked - Cobb SRI w/AEM dry flow filter - RPMC Inlet - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - Rota 18x8.5 48+ SVN Black/w Red Lip - Bridgestone Potenza RE760 - Cobb RSB - Prosport Boost Gauge/Mearcat pod - Motorcraft XT-M5-QS in the tranny!
Frequentflyer is online now   Reply With Quote
 Old 08-07-2012, 07:16 AM   #15
Constantin's Avatar
Read this and you should have not more doubts:
How-to: Gain instant 20whp fo freeee
 Old 08-07-2012, 09:53 AM   #16
mczimer's Avatar
Yes, the powerband is much smoother after doing this. Also, there is power to be regained
 Old 08-07-2012, 09:57 AM   #17
rfinkle2's Avatar
Posts: 12,545   (View Stats)
Groans: 235
Thanks very much for this write-up. Really well done.
CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R)CPE HPFP CPE RMMCPE FMICCPE TOW PLATE CPE TRITON CBE HTP 3" TIP HTP BATTERY RELOCATECOBB APGRIMMSPEED 3 PORT BCSCOOLING MIST / DEVILS OWN METHANOL INJECTIONDEFI Boost gauge TWM FULL REPLACMENT TWM M1 ABRAMSJBR SSP JBR RSB JBR TIG H&R COILOVERSJUMPING JACKSON 3 BAR MAP HARNESSSTOPTECH STAINLESS LINESAKEBONO EURPO 915aTANABE STRUT BRACENEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KITGRAM LIGHTS 57 DRTOYO PROXES PLUS
rfinkle2 is online now   Reply With Quote
STOCK AIR BOX MOD (CHEAP AND EASY) akbrazil 2010 MS3 - How-To's 89 03-24-2013 05:37 PM
Cheap and easy exhaust TallKyle MazdaSpeed 6 - How-To's 77 02-25-2013 09:42 PM
how to: clean your valves vol 2 Joe Isuzu MazdaSpeed 6 - How-To's 34 01-24-2013 07:12 PM
how to clean your valves vol 2 Joe Isuzu MazdaSpeed 3 - How-To's 40 09-02-2012 07:01 AM
Page generated in 0.42504 seconds with 30 queries
