> MazdaSpeed 3 - How-To's
Like Tree5Likes
  • 5 Post By silvapain
 Old 10-01-2012, 06:08 PM   #1
Default HOW TO: Drain Fuel Tank
I had to drain a full tank of old fuel after my engine build, so I thought I might as well make a How-To for it...
1. Open engine bay fuse panel, and remove the primary fuel pump relay (labeled 'Circuit' in the diagram on the cover)
2. Create a jumper cable by crimping on two spade terminals on a short piece of wire. I used 14ga wire.
3. Plug one terminal into the port on the the fuse panel closest to the windshield. This is the +12VDC terminal:
4. Disconnect the blue fuel line connector on the HPFP. This is the line from the fuel tank to the HPFP (low pressure line).
5. Using a funnel and hose, run a line from the disconnected fuel line to a gas can:
6. Connect the other spade terminal to the port on the fuse panel just next to the one used in step 3 above. This will start the ITFP. NOTE: fuel pump relay 2 controls the high/low speed for the pump. with the relay not energized, the pump will run at low speed (which we want):
7. Profit:
Disconnect either jumper lead to stop the pump.
The Following 25 Users Say Thank You to silvapain For This Useful Post:
802MS3 (01-14-2013), ABSpeed3 (10-04-2012), atvfreek (08-19-2013), Blk_pu (06-15-2015), dan7225 (06-16-2015), El_Diablo (08-24-2013), J'sSpeed3 (12-02-2012), jracer (10-01-2012), kabobulate (10-01-2012), KRheeder (02-14-2014), MattJackson86 (02-14-2014), mazdafreak (02-16-2014), mituc (01-12-2014), mxlplx71 (01-30-2013), Nliiitend1 (01-14-2013), Pointless (08-19-2013), Pseud0logik (10-01-2012), R4LLY3 (01-11-2014), rfinkle2 (03-15-2013), Rich990 (11-05-2013), Rokusek (01-14-2013), SLOWHATCH (04-14-2013), Strangel (06-11-2015), TWOptSL0W (10-01-2012), WetzMS3 (06-19-2014)
 Old 10-01-2012, 06:14 PM   #2
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
youre welcome
 Old 01-09-2013, 12:04 AM   #3
Mase33's Avatar
Posts: 19   (View Stats)
Mase33 is on a distinguished road
holy crap thanks for information !
Mase33 is offline   Reply With Quote
 Old 01-14-2013, 11:58 AM   #4
Rokusek's Avatar
Posts: 5,551   (View Stats)
7. Profit:
Thank you good sir! I will be using this method this weekend to also drain an entire tank of gas from my car before start up as well!!!
robry (04-21-2014), silvapain (01-15-2013)
 Old 04-08-2013, 12:40 PM   #5
865ms3's Avatar
Posts: 2,602   (View Stats)
865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world
@silvapain; can you confirm this is the same on the gen2?
edit: this works as well on the gen two. the relay is in a different spot. i just tried it. standing at the driver side fender you will jump the two horizontal plugs in the circuit. these will be the two closest to you.
Brent
Mazda Dragon Camp - Event Coordinator
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
865ms3 is offline   Reply With Quote
The Following User Says Thank You to 865ms3 For This Useful Post:
 Old 04-14-2013, 10:41 AM   #6
Carl's Avatar
Posts: 366   (View Stats)
Carl is the leader of the worldCarl is the leader of the worldCarl is the leader of the worldCarl is the leader of the worldCarl is the leader of the worldCarl is the leader of the worldCarl is the leader of the worldCarl is the leader of the worldCarl is the leader of the worldCarl is the leader of the worldCarl is the leader of the world
Sub
Carl is offline   Reply With Quote
 Old 08-19-2013, 07:34 AM   #7
Snotrocket's Avatar
Posts: 900   (View Stats)
Snotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the world
@865ms3 pics?
2010 MS3 Black
395whp/386wtq
| Molnar Rods | CP-e Stage 2 Pistons | Much Head Work | ATP GTX3076 | Tial 38mm EWG | HTP 4 Inch Intake | BSD | Passenger and Rear MM | Denso ITV22's | OCC | Ultimate Racing TBE | Tredstone TR8C FMIC | Tial BPV | Autotech Internals | Grimmspeed ECBS 3 port | Te37 Volks| 245/45/17 Dunlop zzi tires| Cobb AP Self Street Tuned | Sonic Tuning Coilovers | Stoptech breaks and slotted roters
Snotrocket is offline   Reply With Quote
 Old 08-19-2013, 09:09 AM   #8
865ms3's Avatar
Originally Posted by Snotrocket View Post
@865ms3 pics?
i didnt take any. if you pull the "circuit" relay stand at the drive side fender. looking at the fuse box it will the the two horizontal plugs you jump (going off of my memory and my previous post)
Brent
Dragon Slayer Setup
FreekTuned
The Following 2 Users Say Thank You to 865ms3 For This Useful Post:
silvapain (08-19-2013), Snotrocket (08-19-2013)
 Old 08-19-2013, 10:20 AM   #9
2.3speed06's Avatar
Posts: 811   (View Stats)
2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world
MS6?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
2006 Black Cherry Mica Mazdaspeed 6 GT
Cobb AP 50/50 FREEKTune/Cobb 3port EBCS/C-PE Nano Intake/C-PE TIP/C-PE TMIC/HKS SQ3 BOV/Auto Tech HPFP/M2 DP/Custom CB/Denso ITV 22's/JBR RMM/Sure SSP/Sure Shifter Bushings/Custom EGR Kit/TB&IM TIG/MD Stage2 OCC/Koni Yellow S&S/H&R LS/Stoptech Blanks/EBC Red/Techna-Fit SS Brake Lines/
2.3speed06 is offline   Reply With Quote
 Old 08-19-2013, 10:54 AM   #10
theres a check connector on the MS6 in the underhood fuse box that you just ground one of the pins and it does the same thing.
 Old 08-24-2013, 09:04 PM   #11
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Just wanna say thanks again for this thread. Me and @sho used this method to drain about 9-10 gallons of bad fuel (Akron area stations have had issues lately) from his tank tonight before the Toledo autocross tomorrow. This method is the perfect one do use in situations such as this.
2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather
2004 Mazdaspeed Miata #3142- Stock, but not for long.
Equal rights for all, special privileges for none. ~ Thomas Jefferson
The Following 2 Users Say Thank You to El_Diablo For This Useful Post:
sho (08-24-2013), silvapain (08-24-2013)
 Old 08-24-2013, 10:11 PM   #12
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
this is great when you want to go to the track, but have a lot of fuel in the car, thanks for the advice on this last year.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 02-14-2014, 12:31 PM   #13
KRheeder's Avatar
Posts: 140   (View Stats)
KRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud of
Can this also be used to drain the tank of suspected water mixed with my fuel?
KRheeder is offline   Reply With Quote
 Old 02-14-2014, 12:36 PM   #14
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Well it drains the tank, so yes?
2006 Mazdaspeed6
The Following User Says Thank You to sidekick For This Useful Post:
Dizzy Turbo (06-19-2014)
 Old 02-14-2014, 12:40 PM   #15
KRheeder's Avatar
Yeah it does but im just thinking that seeing that water is more dense and the fact that it doesn't mix with fuel it will lay at the bottom of the tank.
its a stupid question I know, I don't have any experience with it hence the question.
 Old 02-14-2014, 12:41 PM   #16
cuethenoise's Avatar
Posts: 136   (View Stats)
cuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the world
Groaned at 6 Times in 2 Posts
Correct me if I'm wrong, but wouldn't this be hard on your low pressure fuel pump? I know most fuel pumps use the fuel for cooling and lubrication. Wouldn't running your tank dry like that put a lot of wear and tear on it? Not to mention it will suck all the gunk at the bottom of your tank into your fuel system and threw the pump. Seems like a good one time thing and not something to do all the time.
2012 Mazdaspeed3 w/ tech package
Stage 1 Stratified OTS
JBR Powerpath Stage 2
JBR 88a RMM
HPFP internals.
cuethenoise is offline   Reply With Quote
 Old 02-14-2014, 01:12 PM   #17
sidekick's Avatar
Groans: 47
You're running the pump at low speed, which means it will not need as much cooling/lubrication. You also shouldn't be doing this every week, so the wear/tear should be negligible. The pump always sucks from the bottom of the tank, so all of that "gunk" would be sucked up whether the tank is low or not. That's an old wives tale as far as I'm concerned. This is also why fuel pumps have filters.
But how do you know there is water in your tank? It shouldn't be an issue getting the water out this way, because the fuel pump will remove almost everything out of the tank doing it this way. There may still be a small amount of fuel left in the tank after doing this.
2006 Mazdaspeed6
Last edited by sidekick; 02-14-2014 at 01:12 PM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to sidekick For This Useful Post:
Agent_Orange (02-14-2014), El_Diablo (02-14-2014), KRheeder (02-14-2014), silvapain (02-15-2014)
 Old 02-14-2014, 01:13 PM   #18
Yeah I sort of agree, that is why I said maybe a one time thing, but some of the peeps above said they would use this method before going to the track. I would use the tried and true siphon method for this to be honest.
JBR 88a RMM
HPFP internals.
 Old 02-14-2014, 01:25 PM   #19
KRheeder's Avatar
Was driving home after work today, stopped to put in some fuel.
Left the gas station and 2-3 mins later the car started acting up. Would bog at times, had no power. I had to drive slowly. Initially I thought it might be a boost leak. When I got home I checked all the clamps etc. Installed everything again. car would start, idle roughly for like 5 seconds and die. The car was fine up to the point where I stopped at the gas station. Very bad batch of fuel or water in the fuel is my best guess. I cleaned all the sensors, checked all my connections etc
 Old 02-14-2014, 01:46 PM   #20
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Agent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the world
Groans: 665
Groaned at 76 Times in 40 Posts
What makes you think it's bad for the pump?
It's doing what it does any other time it's operating, but instead of going into the HPFP, it's going into a gas can.
As long as the pump is promptly stopped when fuel is no longer flowing, there should be no issue.
I would be more concerned with fuel flowing near live/exposed electrical circuits.
Agent_Orange is offline   Reply With Quote
The Following 2 Users Say Thank You to Agent_Orange For This Useful Post:
El_Diablo (02-14-2014), WetzMS3 (06-19-2014)
 Old 02-15-2014, 10:03 PM   #21
KRheeder's Avatar
This method works great. Turned out the petrol attendant and the shell garage put diesel instead of unleaded. What a mission to get it all out and the system clean. For the guys with mk2's, ive attached jumped circuit as its in a different location.
The Following User Says Thank You to KRheeder For This Useful Post:
Pointless (03-30-2014)
 Old 02-16-2014, 12:38 AM   #22
sidekick's Avatar
Groans: 47
You should do it again with gas run through it before starting the car.
2006 Mazdaspeed6
 Old 02-16-2014, 01:05 AM   #23
KRheeder's Avatar
I did yeah
Sent from my C6903 using Tapatalk
 Old 02-16-2014, 07:43 AM   #24
kbz0129's Avatar
Posts: 986   (View Stats)
kbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the world
@BZiggy10 Quick way to empty the tank.
2010 Ms3 PD Tuned
GTX3076 EWG Forged Engine Built By Yours Truly
2006 Ms6 GT-Stock
kbz0129 is offline   Reply With Quote
The Following User Says Thank You to kbz0129 For This Useful Post:
BZiggy10 (02-16-2014)
 Old 06-19-2014, 04:52 AM   #25
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
So I wonder what is the exact size of our fuel tank. I know it's listed to be 15,9 gallons, but is there a reserve?
mrQQ is offline   Reply With Quote
 Old 10-20-2014, 10:39 PM   #26
Big D's Avatar
Posts: 7   (View Stats)
Big D has a spectacular aura aboutBig D has a spectacular aura aboutBig D has a spectacular aura about
My MS6 sat in storage for 2yrs. Tne fuel stabilizer bottle was still on the counter that sent to my younger brother to put in when I left to Japan. I am Emptying it completely and maybe running gas through. I'm sure its bad.
Or should I siphon it all out?
Big D is offline   Reply With Quote
 Old 06-16-2015, 10:47 AM   #27
batmsp3's Avatar
Posts: 153   (View Stats)
batmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond repute
maybe I'm going full retard, but I was hoping to get clarification for the ms6. I would like to add pics after I am successful (or fuck something up) to help others.
@superskaterxes; where/what is the check connector you are referring to?
"Looks like Travis Stephens"
batmsp3 is offline   Reply With Quote
 Old 06-19-2015, 12:54 AM   #28
batmsp3's Avatar
Default Check connector
Think this might be it for the ms6
 Old 10-28-2015, 07:16 AM   #29
MSP611's Avatar
Posts: 2,291   (View Stats)
easy and smart
In progress:
 Old 04-07-2016, 05:28 AM   #30
sailnaked6842's Avatar
Posts: 100   (View Stats)
sailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond reputesailnaked6842 has a reputation beyond repute
I know I'm kicking the dust off this thread but just to confirm that for the MS6 you are only pulling the check connector and grounding the top right pin and will not need a jumper?
sailnaked6842 is offline   Reply With Quote
 Old 04-07-2016, 03:14 PM   #31
batmsp3's Avatar
yup ,just take a wire from the check connector and connect it to ground.
 Old 06-24-2016, 04:57 PM   #32
swosko's Avatar
Posts: 1   (View Stats)
swosko is an unknown quantity at this point
Thanks a ton for detailing this. Worked like a charm on my 08 MS3.
swosko is offline   Reply With Quote
 Old 04-20-2019, 07:27 AM   #33
Mitchell5's Avatar
Mitchell5 is an unknown quantity at this point
Thanks for all the info. I have a 2003
Protege5 and wonder if any of
You could confirm exactly which leads to jump? I am not sure if the relay is the same as on the 3. As responsibilities force me to drive a family truckster most days, it would be wonderful to get the 5
Back on the road. Thanks
Mitchell5 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f33/how-drain-fuel-tank-126258/
4 ?????? ? ??????? ??????? - ????????? ?? ??????????????? This thread Refback 07-17-2015 06:19 AM
4 ?????? ? ??????? ??????? - ????????? ?? ??????????????? This thread Refback 03-24-2013 12:05 PM
IN-TANK FUEL PUMP Adrenaline Mazdaspeed3/6 General Discussion 6 04-12-2013 09:22 AM
best way to drain the fuel tank mxlplx71 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 09-21-2012 11:46 AM
In tank fuel pump and fuel rail valve Seatime3 2010 MS3 - Fuel, Nitrous & Water Injection 1 04-30-2012 07:44 PM
Honda SUVs recalled for fuel-tank fix Haltech Automotive News 0 02-23-2012 09:50 AM
In-Tank Fuel Pressure Tester superskaterxes MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 17 11-02-2011 12:34 PM
Page generated in 0.53231 seconds with 43 queries
