> MazdaSpeed 3 - How-To's
Like Tree18Likes
 Old 03-11-2013, 07:34 AM   #1
DeadWayt's Avatar
Posts: 186   (View Stats)
DeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the world
Default How-To: Front Sway Bar Bushing replacement w/o dropping subframe
There are quite a few threads out there claiming this is possible, but none that are easily searchable that describe it very accurately/thoroughly, so I thought I'd steal a couple of Haltech's downpipe install pics for illustration purposes and describe what I found to be the least painful way to replace the front sway bar bushings without dropping the front subframe.
Required tools:
Ramps, jack + jack stands, or lift
Socket wrench w/ 14mm and 10mm sockets
Blue thread locker (not strictly required, but it might save you from having to tighten bolts again in three weeks)
Suggestions:
I kept both 3/8" and 1/2" wrenches handy for this. A 3/8" wrench fits in the accessible area better, but a 1/2" wrench will make it easier to reach the bolts on the front side of the bar (you'll be reaching over it to access them).
Use ramps or a four-post lift rather than jack stands. I've found it's easier to button up suspension components with everything loaded.
Steps:
1) Jack it up, ramp it up, lift it up, etc. Make sure you have the nose way up in the air. You'll need to be able to scoot past the rear (dogbone) mount area for ease of access. Chock the wheels if necessary.
2) Slide on back past the front subframe. The first thing you want to do is remove the chassis brace and skidplate that protects the fuel lines (all one piece). It's held on by four 14mm bolts and one 10mm bolt. Remove the 10mm bolt (red highlight) first so that the plate isn't hanging from it after you remove the 14s. No sense bending it up too badly.
This weighs a couple pounds and will fall and hit you in the face once it's free if you don't keep your hand on it. So, y'know, do that. Or don't. It's your face.
3) Now that you have some room to work, get on your back so that you can look toward the front of the car. You should be looking at the back of the engine. If you peek up over the subframe, you should be able to eyeball the steering rack and at least part of the sway bar, depending on how big your head is. It's okay if you can't see it. You just need to reach it.
I found the best way to do this was to reach up through the exhaust hangers and then hook my arm toward the outside of the car to reach the two bolts holding each bracket. Use the clearance of the exhaust tunnel to crank the wrench. This is a lot easier than trying to fit the wrench in at a straight north-south angle.
From here, it's as simple (or not) as undoing the four bolts, yanking the brackets, and fitting the new ones. The crossmember is raised where the brackets are anchored, and between those bumps and the shaft collars on the bar itself, you should be able to feel around in there to re-attach the brackets with minimal frustration. If you have small hands, you can also reach your fingers in under the loop in the sway bar from the wheel well to feel around for the front bolt holes. That's easier than trying to angle them in from the back.
That's it. Don't forget to reinstall the chassis brace/skidplate. Crack a beer. You're done.
'08.5 MS3 GT -- Metropolitan Grey
www.speedsportlife.com
DeadWayt is offline   Reply With Quote
The Following 14 Users Say Thank You to DeadWayt For This Useful Post:
allo80 (02-18-2015), Atticaz (11-15-2015), BackRoads (04-23-2015), DuBz (03-11-2013), friesx100 (07-02-2014), ge3kspd (04-13-2015), jack_hammer (03-11-2013), Jakeypoo (10-16-2016), jasper (08-22-2013), Leila (05-30-2014), mach69 (05-03-2013), mazdaspeeding (03-12-2013), RoadTripSaloonGT (12-23-2018), xtasy (03-11-2013)
 Old 03-11-2013, 07:39 AM   #2
jack_hammer's Avatar
Posts: 6,821   (View Stats)
Groans: 549
if you're just doing the bushings, you should be able to get to them from the wheel well.
1) take off wheels
2) disconnect end links
3) reach in and disconnect the bushings
caveat: the front bolt on the driver side bushing might require some extra work, extensions, u-joints, etc.
and when you put it back together, you have to just up the control arm put a load on the wheels. but, that's just another option.
rfinkle2 and madman55 like this.
it's fun to do bad things
The Following User Says Thank You to jack_hammer For This Useful Post:
 Old 03-11-2013, 07:46 AM   #3
DeadWayt's Avatar
I tried doing it from the wheel wells, but I couldn't get a wrench in at an angle to engage the bolts and have cranking room.
 Old 03-12-2013, 02:24 PM   #4
Darren08's Avatar
Posts: 103   (View Stats)
Darren08 has a reputation beyond reputeDarren08 has a reputation beyond reputeDarren08 has a reputation beyond reputeDarren08 has a reputation beyond reputeDarren08 has a reputation beyond reputeDarren08 has a reputation beyond reputeDarren08 has a reputation beyond reputeDarren08 has a reputation beyond reputeDarren08 has a reputation beyond reputeDarren08 has a reputation beyond reputeDarren08 has a reputation beyond repute
Groaned at 4 Times in 2 Posts
Gonna give this a shot tomorrow. Im tired of the clunking. Tried to go in through the wheel well when I replaced the end links but I couldn't find a way to crank the bolts, no room.
2008 MS3....Vrroooom, spool, pshhhht!
Darren08 is offline   Reply With Quote
 Old 04-26-2013, 10:41 PM   #5
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Groaned at 6 Times in 6 Posts
Did it today.......car has 70k miles and I drive it in the winter. I almost gave up with the bolts, took me 3 hours.
I think dropping the sub might be better with higher mileage cars.
TumTum2570 likes this.
The Following User Says Thank You to stockms3 For This Useful Post:
Tommy (11-28-2014)
 Old 04-26-2013, 11:49 PM   #6
himurax13's Avatar
Posts: 4,582   (View Stats)
Groans: 255
I did this on my Pu and it was easy as fuck. On the Gen one, it took 4 hours because we only disconnected the endlinks and everything was impossible to get to.
Sent via stockish Black Mica Pu
Pickles Tune in progress
rfinkle2 (04-13-2015)
 Old 05-03-2013, 02:23 PM   #7
mach69's Avatar
Posts: 79   (View Stats)
mach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond repute
Thanks. I plan on doing this tomorrow, 5/4. Hopefully it will be as easy as you describe. I do own a gen won, FML.
2008 Mazdaspeed 3 - True Red
Engine: CPE Nano, CPE TIP, CPE TMIC, CPE HPFP, CS BeCuse Injector Seals, SU Boost Tubes, Forge BPV V1, ITV-22, AQ Motorsports DP, Dashhawk, Spin-on Oil filter conversion, Saikou Michi OCC, Cobb AP Self-tuned, VTCS Delete, EGR Delete, TB Coolant Bypass, DFDD VVT, 3 bar map
Drivetrain: Southbend Clutch Stage 3 DD, JBR Short Shift Plate, SU Shifter Bushings, CPE Stage 2 RMM, CPE TMM
Suspension: Koni Yellows, Eibach Springs, Cobb RSB, MOOG Swaybar Endlinks, Energy Suspension FSB Bushings
mach69 is offline   Reply With Quote
 Old 05-03-2013, 03:47 PM   #8
himurax13's Avatar
Groans: 255
Originally Posted by mach69 View Post
Thanks. I plan on doing this tomorrow, 5/4. Hopefully it will be as easy as you describe. I do a gen won, FML.
Good luck bro, let us know how it turns out.
 Old 05-03-2013, 03:57 PM   #9
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Thief! lol
 Old 05-03-2013, 11:25 PM   #10
DeadWayt's Avatar
Thief! lol
 Old 05-04-2013, 03:05 PM   #11
mach69's Avatar
Well, its done. After two hours of pissing and moaning. I handicapped myself by working out my shoulders and biceps earlier in the day. The ramps i built helped.
 Old 05-04-2013, 09:50 PM   #12
DeadWayt's Avatar
Damn, I bet. My neck was actually a little sore the day after I did mine.
 Old 08-22-2013, 01:02 PM   #13
jasper's Avatar
Posts: 643   (View Stats)
jasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the world
Did mine today, took about an hour including lifting the car. Your directions were perfect. The hard part is getting leverage to loosen the bolts. In all, in various ways I used a tall 14 mm, a regular 14 mm and a short extension, in 3/8"s. I used a 14 mm in 1/2" for the brace bolts. I was surprised how loose the sway bar is once the bolts were off. Greased up the new ones and put them in place. That persistent knock is gone.
RoadTripSaloonGT likes this.
09 SPEED 3 CWP
installed: CP-e DP, CP-e FMIC, CP-e CAI, Cp-e TIP, Cp-e S2RMM, Cp-e PSMM, Cp-e DSMM, Cp-e Cat back,
HKS SSQV, Steed manifold, DO meth injection with HP Controls controller, Cobb ap, Saiko Michi OCC
TWM Short shifter and bushings, Rallysport mud flaps, 5%tint all around, 55 w 8000 k fogs, low and high beams.
Led 6000 k switchbacks, Led reverse and turn signals. 18 X 8 45 offset w/245/40's, Raceland Coil overs
jasper is offline   Reply With Quote
 Old 11-10-2013, 10:36 AM   #14
Ren
Ren's Avatar
Posts: 8   (View Stats)
Ren is just really niceRen is just really niceRen is just really niceRen is just really nice
Just did it. Took me about 2 hrs. Had a ratchet with a flex head, which really helped.
One of the bolts were stubborn. WD-40 fixed it.
07 MS3 with MS CAI.
Ren is offline   Reply With Quote
 Old 11-27-2013, 01:50 PM   #15
Lex2007's Avatar
Posts: 554   (View Stats)
Thanks for posting this DeadWayt. Much appreciated. You're a good and decent man.
 Old 12-10-2013, 07:00 AM   #16
a143gsxr's Avatar
Posts: 42   (View Stats)
a143gsxr is just really nicea143gsxr is just really nicea143gsxr is just really nicea143gsxr is just really nice
doing this thursday night on my Gen 1. Replaced PMM with a CP-e hoping that was the clunking. nope. lol
a143gsxr is offline   Reply With Quote
 Old 05-20-2014, 11:06 AM   #17
stewart stewart's Avatar
Posts: 7   (View Stats)
stewart stewart has a spectacular aura aboutstewart stewart has a spectacular aura about
Finished up doing this on my Gen1 this morning. Thanks for posting the details on this, DeadWayt. I used a 24" breaker bar (1/2") to back off three of the four front bolts, but the front driver bolt was a serious pain because my breaker wouldn't fit in there. Soaked it in WD-40 and left it overnight. Came right out with a big ratchet the next morning. I replaced the front and rear for good measure.....and my CLUNKING IS GONE! Thank you Jesus.
btw, I envy the guys who got this done in under an hour. My rears only took me about 30 min, but the fronts....
stewart stewart is offline   Reply With Quote
The Following User Says Thank You to stewart stewart For This Useful Post:
Leila (05-30-2014)
 Old 05-20-2014, 11:52 AM   #18
speed3 britz's Avatar
Posts: 1,155   (View Stats)
speed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the worldspeed3 britz is the leader of the world
I find it easier to drop the subframe, more room to work with on genjuan. I wasn't worried because I already needed an alighnment. Dropping subframe, swapping bushings and putting all back together only took about hour and half tops.
07 Mazdaspeed 3 Grand Touring Black Mica (The Summer Daily / Toy)
Fanboy Brand Mods: A'PEXi Turbo Timer, Autotech Internals, BNR S3 V1, Bosch 3 Bar MAP, CNT 3" CBE, COBB AP V3, STS, FMIC Piping, Corksport Adjustable Shocks/Struts, CP-E Dash Pod, Safe-Seals, Enkei Evo IX (17x8+38), Exide 51RX Battery, FoMoCo XT-M5-QS, Grimmspeed EBCS, Ground Control Bumpstops, Hankook RS-3 (235/45/17), H&R Springs, Hawk HPS Pads, HTP 51R Battery Tray, JBR 88d RMM, 80d PMM, Shifter Bushings, TIG's, Secondary EGR Delete, 3.5" Aluminum WP, Mudflaps, Kozmic Primary EGR Delete, maisonvi Knob Collection, Damond OCC, NGK LTR7IX-11, Progress RSB, Prosport Boost, Oil Temp, Oil Press, Redline Tuning Hood Struts, SPC Camber Arms, Speed Daddy (Ebay) Catless DP, SP63 MAP Harness, Stratified Guardian Angel, Treadstone TR8, TRZ TMM, TurboXS H-RFL VTA BOV, XS Power V1 Manifold
Maisonvi's Inherited Motor Build: ARP L19 Head Studs, Crank Bolt, Cam Bolts, Manley H-Beam Rods, SP63 Wiseco Armor Plated Pistons,
New Rice, AKA To be Installed: Autoexe Front Bumper Cover, GT Spec Strut Brace, Wedge Engineering Seat Base, Sparco Speed Bucket Seat,
08 Mazda 6i Hatchback (The Daily MPG Commuter)
93 Mazda B2600i 4wd (The Winter Beater / terMINATOR Parts Hauler)
speed3 britz is offline   Reply With Quote
 Old 05-30-2014, 12:17 PM   #19
Leila's Avatar
Posts: 327   (View Stats)
Leila is the leader of the worldLeila is the leader of the worldLeila is the leader of the worldLeila is the leader of the worldLeila is the leader of the worldLeila is the leader of the worldLeila is the leader of the worldLeila is the leader of the worldLeila is the leader of the worldLeila is the leader of the worldLeila is the leader of the world
I'm an asshole and didn't post here when I did mine a few months ago. This was a great help and my little girl hands were able to get in and out without a problem! Thanks!
Stella: 2008 CBM MS3 GT
Done: AWR RMM, Cobb AP, Cobb SF Intake, Cobb TIH, Greddy ti-c Exhaust, JBR SSP & Bushings, Modified/Painted Badges, TWM Big Type R Shifter, Smoked Reflectors/Indicators, Yellow Fogs, Sharkfin Antenna, Enkei FLC-01 Bronze wheels, Corksport TMIC, Corksport BPV Hose and IC Hoses, JBR RCA, SURE SBB
Planned: Corksport Catted DP/racepipe, CP-e HPFP
Leila is offline   Reply With Quote
 Old 06-25-2014, 08:18 PM   #20
ohioan's Avatar
Posts: 14   (View Stats)
ohioan is on a distinguished road
Don't know if I did something wrong or what... I did drop the sub frame (Gen 1) and after about 6 hours, finally got the old off and the new on. Theclunk, STILL THERE! My buddy that did it with me, thought it had to be something else. I kinda hoped so too because doing this was an extra shitty job.
So I just took off the end links and zip tied the sway bar. No clunk. Oh and now I do for sure need an alignment.
Probably the wrong place to ask since this is a enthusiasts site, but
what's the repercussions of leaving the bar like that?
It'll cost $350 to have mazda replace the $30 bushings... had it quoted at a couple local shops and the price was the same.
ohioan is offline   Reply With Quote
 Old 06-26-2014, 04:20 PM   #21
Lex2007's Avatar
Did you get everything tight to spec after you swapped the in the new bushings? Sounds like you didn't otherwise you wouldn't have the clunk again afterwards. The bushings being worn and the bushings being loose would likely cause a similar effect. No?
$350....that's nuts.
Having no sway bar connected = lots of SWAY and fully independent suspension.
 Old 06-26-2014, 10:03 PM   #22
ohioan's Avatar
To spec, doubt it. I don't understand what I didn't unhook in order to get as much room as everyone is saying they have room under there. I was barely able to get a 3/8 rachet with a small cheater bar in there, let alone a clunky ass torque wrench...
 Old 06-26-2014, 10:43 PM   #23
azarashi's Avatar
Posts: 709   (View Stats)
azarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the world
I didnt bother using a torque wrench, best tool i use was http://i.imgur.com/vlk3H0B.jpg. Made it a fuck ton easier and I wouldnt have been able to do it any other way.
2008 Mazdaspeed 3 GT - Cobb SRI, HKS BOV, Cobb AP V2, Sure RMM, EBC Front Rotors, Hawk HPS, ROCA PMM, Yokohama YK580, SenSen Rear shocks
Planned: Cobb TIP, Autotech HPFP, MattD RMM, Koni Street Shocks/struts
azarashi is offline   Reply With Quote
 Old 06-27-2014, 06:22 AM   #24
MSMS3's Avatar
Posts: 2,511   (View Stats)
Groans: 140
Two additional observations. Those new bushings need to be liberally greased before installing. Second, if you use aftermarket bushings, the brackets are likely to be wider than stock. The slots will likely not line up with the bolt holes. You will have to either tap the "keeper" rings on the swaybar inward to make room, or widen the slot on the bracket to make it fit. I could not get those rings to move, even hammering on them, and had to modify the JBR bushing brackets.
I chose JBR because they have re-greasable zerk futtings to keep things quiet.
2017 Audi Q5 3.0 T (supercharged) Stage 2, EPL tune, JHM overdrive crank pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 430 hp.
 Old 06-27-2014, 07:57 AM   #25
Lex2007's Avatar
First question: Did you use OEM bushings?
Youre 100% correct. I misspoke. At least one of those bolts on each side is only reachable with a super long ratchet or an air ratchet. I used an air ratchet and I did not torque to spec, just tightened as much as possible and used a lot of silicone grease.
 Old 06-28-2014, 07:44 AM   #26
ohioan's Avatar
I used these...
Sway Bar Bushings | SURE Motorsports
 Old 06-28-2014, 07:56 PM   #27
xshigeox's Avatar
Posts: 240   (View Stats)
xshigeox is the leader of the worldxshigeox is the leader of the worldxshigeox is the leader of the worldxshigeox is the leader of the worldxshigeox is the leader of the worldxshigeox is the leader of the worldxshigeox is the leader of the worldxshigeox is the leader of the worldxshigeox is the leader of the worldxshigeox is the leader of the worldxshigeox is the leader of the world
Try replacing the end links. I had to do both the bushings and the end links to fix all my clunks. Nice and quiet now.
//AT INTERNALS //COBB AP // COBB SRI // UR TEST PIPE // FORGE V1// JBR SSP // JBR RSB // KONI YELLOWS // CS SPRINGS //
xshigeox is offline   Reply With Quote
The Following 2 Users Say Thank You to xshigeox For This Useful Post:
license2ill (03-26-2015), ohioan (06-29-2014)
 Old 06-28-2014, 11:39 PM   #28
mituc's Avatar
Posts: 3,519   (View Stats)
Groans: 111
I just came across this thread... I or the mechanics who worked on my car never dropped, loosened or even touched the subframe. The only scenario they had to drop the subframe is for the gen2 1.6 diesels.
It;s indeed a pain both in the ass and balls to change the bushings, it's 30 minutes of frustration and cursing but the subframe stays there. Keep in mind that the second you loosened all the bolts on the sub-frame you may need to re-do the alignment just to be sure. It's not mandatory but recommended even if you draw any marks with the previous position.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 06-29-2014, 04:05 PM   #29
ohioan's Avatar
I will do this with the $26 endlinks from autozone and get back to you to let you know if it fixes the clunk. Otherwise, it's staying unhooked and zip-tied to the strut...
I'll fix it before I trade it in or sell it. With as many miles as I have on the car (116k), I don't think I'll be tracking it again. Plus Nelson's Ledges road course is closing from what I hear.
Thanks guys for the help again.
 Old 11-11-2014, 09:29 PM   #30
ihasmazda's Avatar
Posts: 1,011   (View Stats)
ihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the world
My turn tomorrow... crazy thing is it didn't start to clunk until very recently... I about died when I saw this gap considering most folks had clunk with no visible signs of wear.
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
ihasmazda is offline   Reply With Quote
 Old 11-11-2014, 09:36 PM   #31
azarashi's Avatar
Have fun, im gonna imagine its harder on the speed 6 to do but either way good luck. I finally replaced my rears (easiest thing in the world) cause they started to creak real bad now that its colder.
 Old 11-12-2014, 05:01 AM   #32
CaptainCode's Avatar
Posts: 81   (View Stats)
CaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond repute
Groaned at 6 Times in 2 Posts
Tried my front ones on the weekend. Rear bolts on the brackets are easy. Front ones are seized. Gave up after 4hrs and spraying with pb blaster in preparation for a second try this weekend.
JBR SRI+TIP, Autotech internals, Stratified stage 2 flash tune, Corksport BPV, UR test pipe, Damond Motorsports RMM
CaptainCode is offline   Reply With Quote
 Old 11-15-2014, 02:57 PM   #33
One bolt sheared off. Am I screwed? Probably have to drop the sub frame to get the other half of the bolt out? I got the bushings changed but still clunks on the side missing this bolt. Hoping it'll be ok through winter. Not clunking anywhere near as much as before.
 Old 11-15-2014, 03:10 PM   #34
azarashi's Avatar
Uh...how the fuck...Yah you will need to find a way to get the other piece out but likely will need to drop it now cause I dont know how the hell you would get a drill in there.
Unless you can do it from underneithe vs top.
 Old 11-15-2014, 03:21 PM   #35
Yeah I guess I'm too strong for these bolts lol. Fucker was seized. Used pb blaster but this one decided to break in half. I'm going to have to look into what to do to get the sub frame down without taking a whole bunch of shit apart. It can't be reached from below because there's no hole lined up with the bolt.
 Old 11-15-2014, 08:26 PM   #36
azarashi's Avatar
Fuck it, time to get a new car.
The Following User Says Thank You to azarashi For This Useful Post:
OverBoosted (11-15-2014)
 Old 11-17-2014, 04:44 AM   #37
davros's Avatar
Posts: 1,020   (View Stats)
davros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the world
So I have access to a lift. I'm going to guess removing the subframe would be the best plan to get to both the bushings and the end links. Or is that just a headache in its self?
2009 Metro Gray Mica Mazdaspeed 3
Cobb AP - HTP INTAKE - HKS BPV - GrimmSpeed EBCS - Autotech HPFP - ATP catless DP - JBR EGR full delete - Damon RMM PMM TMM- TR8/CX Piping - Damon Catch Can - FREEKTUNED
davros is offline   Reply With Quote
 Old 11-17-2014, 05:05 AM   #38
It would certainly make it easier to get the bolts and bushings out if you drop the sub frame. There's very limited space to get a socket in there and you can't use a long one either.
I found the only real way to fit the socket wrench in there was around the down pipe area and you have limited movement like 1/3 turn at the most.
 Old 11-28-2014, 12:00 PM   #39
Tommy's Avatar
Posts: 2,308   (View Stats)
Groans: 155
My '07 bolts are frozen on there. I gave up on this.
Tommy is offline   Reply With Quote
 Old 11-28-2014, 01:30 PM   #40
frothy's Avatar
Posts: 1,067   (View Stats)
I tackled this job last week.
I put the car up on jackstands and let the bolts soak in PB Blaster overnight.
Had the job done in under 30 minutes the next morning without dropping the subframe, torqued to spec and all.
Having the right tools definitely makes a difference...
Here's what I used:
I linked two wrenches together to crack the front passenger-side bolt loose from the front side.
The other three I dealt with from the rear with the long-handled 3/8" flex-head ratchet.
Once that's done, it's just a matter of backing the bolts off. A ratcheting flex-head gearwrench expedited this for me, somewhat.
The front driver's side is easily the most problematic. Unlike the front passenger-side bolt, you can't access it from the front. And although I was able to break the bolt loose with the long 3/8" flex-head ratchet w/ a deep socket, I couldn't back it off at all afterwards, due to a lack of overhead clearance.
I ended up using a stubby 3/8" ratchet (the flex-head aspect of it wasn't necessary or beneficial) with a standard-length socket and accessing it from the wheel well. No need to remove the tire. In fact, I used it as a head-rest.
If you happen to own 3/8" mid-length sockets, those might make short work of that front driver's-side bolt from the rear. Can't say for sure, as I didn't try this method...
Drive By Fire and PHB like this.
The Following 3 Users Say Thank You to frothy For This Useful Post:
Drive By Fire (04-14-2015), rfinkle2 (04-13-2015), roguemazda (12-30-2015)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f33/how-front-sway-bar-bushing-replacement-w-140109/
Considering upgrading to a 3 MPS (Speed) from a 2.0 sport. What are they like to live with? : mazda This thread Refback 01-31-2015 05:13 PM
How-To: MS6 Front Sway Bar Bushing TiGraySpeed6 MazdaSpeed 6 - How-To's 44 08-23-2017 08:16 AM
Front Lower Control Arm Bushing Motion TRex MazdaSpeed 3/6 - Suspension & Brakes 0 10-21-2012 06:43 PM
MS6 driver-side sway bar bushing removal wdautrem MazdaSpeed 3/6 - Suspension & Brakes 16 06-01-2012 09:44 PM
Front Strut Bushing Spirry MazdaSpeed 3/6 - Suspension & Brakes 0 04-18-2011 07:17 AM
Page generated in 0.59102 seconds with 44 queries
