> MazdaSpeed 3 - How-To's
 Old 12-31-2009, 08:07 AM   #1
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
Default How to install a Reverse Light HID Kit
Well for the life of me I cant get this to post right so maybe someone can help me out with it, but nonetheless heres the how to. This kit is amazing, only complaint I have is that it is a 6000K instead of a 5000k which imo would be better for those who have very dark tint. Regardless its a huge improvement over stock.
Update: There was alot of rattling noise coming from all of the wires installed in the hatch so Ive installed bubble wrap around everything to keep it quite.
Update II: I installed a distribution block for my amp and moved the fuse for the hids as close to the block as possible. Also changed fuse down to a 20amp since the new digital hids use <6amps for startup and 3.4amps for normal operation.
With 5% tint on all windows these still provide enough light to back up.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
The Following User Says Thank You to nyghtryder For This Useful Post:
riott (01-12-2011)
 Old 01-01-2010, 09:06 AM   #2
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Addikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the world
Groans: 157
Groaned at 29 Times in 16 Posts
nice, good write up man i might get me a set because stock ones suck
09 MGM MS3
BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s
Addikted To Boost is offline   Reply With Quote
The Following User Says Thank You to Addikted To Boost For This Useful Post:
nyghtryder (01-01-2010)
 Old 01-01-2010, 02:23 PM   #3
nyghtryder's Avatar
There sweet I cant wait for the next assclown to ride up my ass at a stop light, cuz Im gonna blind the shit out of them.
NATOR PA
The Following 2 Users Say Thank You to nyghtryder For This Useful Post:
J-villa (06-30-2010), superskaterxes (01-06-2010)
 Old 01-02-2010, 01:45 AM   #4
Abysal's Avatar
Posts: 26   (View Stats)
Abysal has a spectacular aura aboutAbysal has a spectacular aura about
ha, yep, and need to make a by-pass switch to light them up for those idiots riding their high beams behind you.
Abysal is offline   Reply With Quote
The Following User Says Thank You to Abysal For This Useful Post:
nyghtryder (01-02-2010)
 Old 01-02-2010, 05:23 AM   #5
nyghtryder's Avatar
5% tint takes care of that
NATOR PA
 Old 01-02-2010, 08:08 AM   #6
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
CosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the world
Nice write-up. One question tho, wouldn't it be better to have the hot wire from a switched source rather than right off the battery? Just a thought, not trying to start anything.
CosmicArkie is offline   Reply With Quote
The Following User Says Thank You to CosmicArkie For This Useful Post:
 Old 01-02-2010, 08:09 AM   #7
chisss's Avatar
Posts: 49   (View Stats)
chisss has a spectacular aura aboutchisss has a spectacular aura aboutchisss has a spectacular aura about
Very nice
chisss is offline   Reply With Quote
The Following User Says Thank You to chisss For This Useful Post:
 Old 01-02-2010, 07:50 PM   #8
nyghtryder's Avatar
Not really sure why I would need it from a switch. There is an inline fuse and the only way the lights can turn on is when the car is in reverse. The battery tap only supplies power once the signal wire from the oem reverse lights go on. The relay on the wire harness acts as a switch.
NATOR PA
 Old 01-06-2010, 02:44 PM   #9
car46999's Avatar
Posts: 46   (View Stats)
car46999 is a name known to allcar46999 is a name known to allcar46999 is a name known to allcar46999 is a name known to allcar46999 is a name known to allcar46999 is a name known to all
Nice write up.
I do highly recommend that you move the fuse closer to the battery. 12" is a common reference used in car audio.
The reason is that: if the power wire grounded out before the fuse, it would not stop the wire from getting super hot and melting or causing a fire. Which is why the fuse should be under the hood by the battery.
Basically the fuse only protects what is after it (to include wire, electronics, etc).
Also you might be close to the current limits of that 14awg wire. Not too sure how long your wire is. 12awg might be a better choice.
car46999 is offline   Reply With Quote
The Following User Says Thank You to car46999 For This Useful Post:
nyghtryder (01-09-2010)
 Old 01-06-2010, 02:52 PM   #10
nyghtryder's Avatar
I was thinking about using 12ga as well, however the harness itself is 16ga. I didnt want to setup too far and I thought that 12ga may have been too aggressive. The wire doesnt get hot and the kit really isnt on for a significant amount of time.
There really isnt any place that the wire can ground out. It doesnt go through any metal without grommets. But it couldnt hurt to mount it under the hood.
NATOR PA
 Old 01-06-2010, 03:13 PM   #11
mariospeedwagon's Avatar
Posts: 78   (View Stats)
mariospeedwagon is a glorious beacon of lightmariospeedwagon is a glorious beacon of lightmariospeedwagon is a glorious beacon of lightmariospeedwagon is a glorious beacon of lightmariospeedwagon is a glorious beacon of light
nice work, where did u mount the ballasts
mariospeedwagon is offline   Reply With Quote
The Following User Says Thank You to mariospeedwagon For This Useful Post:
 Old 01-06-2010, 03:47 PM   #12
car46999's Avatar
It is a good idea to move the fuse. Fires are usually never planned...
The wire gauge should be ok. But bigger is always better
 Old 01-09-2010, 02:17 PM   #13
nyghtryder's Avatar
mounted inside of the hatch door.
left reverse lights on for 10min and no heat in the wire. theres absolutely no reason to move fuse closer.
NATOR PA
 Old 01-10-2010, 05:15 PM   #14
carfanatic101's Avatar
Posts: 25   (View Stats)
carfanatic101 has a spectacular aura aboutcarfanatic101 has a spectacular aura about
Groaned at 4 Times in 2 Posts
pointless but sweet
carfanatic101 is offline   Reply With Quote
The Following User Says Thank You to carfanatic101 For This Useful Post:
nyghtryder (01-11-2010)
 Old 01-11-2010, 04:00 PM   #15
nyghtryder's Avatar
Originally Posted by carfanatic101 View Post
pointless but sweet
whats pointless?
NATOR PA
 Old 01-11-2010, 04:05 PM   #16
sleeper329's Avatar
Posts: 511   (View Stats)
sleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the world
I did this using the kit from dabears2k over the weekend also.
In answer to someones question dabears said you when you do both sides you need a separate power feed from the battery and just use the original reverse power as a trigger. I'd assume the stock fuse isnt big enough or wire gauge high enough for the current these draw... not to sure if thats why though.
I agree with the OP its an awesome mod and makes it sooo much easier if you have tinted windows at night.
^^USE THIS LINK AND COUPON CODE SURIOT AT CHECKOUT FOR A DISCOUNT!^^
sleeper329 is offline   Reply With Quote
The Following User Says Thank You to sleeper329 For This Useful Post:
 Old 01-11-2010, 04:17 PM   #17
nyghtryder's Avatar
yours is a 6000K temp as well correct.
you are correct about the current draw. The oem fuse is probably 15amp and all hid kits need to have a 30amp. The oem wire is 18-22ga so it would definately be overloaded.
NATOR PA
 Old 01-11-2010, 05:15 PM   #18
sleeper329's Avatar
I believe it is 6000k, and for $95 the kit is perfect even if its not. Plus they warranty their bulbs.
I have to try to get some pics up.
Did your kits bulbs have a connector that locks into the tail light like the stock bulbs do?
Mine they actually have you glue the bulbs in place.....
 Old 01-11-2010, 05:29 PM   #19
nyghtryder's Avatar
Nope mine had to be glued in too. I used epoxy instead of super glue cuz I didnt feel that the glue would really hold them in well.
I talked to debears2k about a fitting that would work with the oem reverse lights and they told me that they couldnt get a manufacturer to make them which is why were glueing them in.
NATOR PA
 Old 01-13-2010, 07:56 AM   #20
car46999's Avatar
You might have missed the point, the fuse does not protect from heat.
The fuse protects the wire and ballasts in case of a short.
nyghtryder (01-13-2010)
 Old 01-13-2010, 12:33 PM   #21
nyghtryder's Avatar
I realize that but the chance of a short is non-existent. Im trying to keep as little under the hood as possilbe so my dealer trips are easier on my warr.
NATOR PA
 Old 02-05-2010, 10:04 PM   #22
man i gotta do this mod cause my back window is kind of too dark and i can hardly see when backin up
 Old 02-06-2010, 07:50 AM   #23
nyghtryder's Avatar
i love them as said before i just wish they were 5000k instead of 6000k.
NATOR PA
 Old 02-06-2010, 03:15 PM   #24
isnt 6k like blueish??? i like our stock white hid headlights output, what is it like 5k?
 Old 02-07-2010, 07:52 AM   #25
nyghtryder's Avatar
6k is blue and 5k is pure white, stock is 4300k which has yellow in it.
NATOR PA
 Old 02-07-2010, 10:06 AM   #26
sleeper329's Avatar
i think mine are 5k bc they are pure white.
 Old 02-07-2010, 04:59 PM   #27
nyghtryder's Avatar
whod you get yours from?
NATOR PA
 Old 02-11-2010, 03:31 PM   #28
dscsk8er55's Avatar
Posts: 50   (View Stats)
dscsk8er55 is a jewel in the roughdscsk8er55 is a jewel in the roughdscsk8er55 is a jewel in the roughdscsk8er55 is a jewel in the rough
I want to do this. I like the idea of being able to turn them on with a switch. I might try to wire that up.
dscsk8er55 is offline   Reply With Quote
 Old 02-11-2010, 04:01 PM   #29
nyghtryder's Avatar
why would you need a switch?
NATOR PA
 Old 02-11-2010, 04:04 PM   #30
sleeper329's Avatar
dabears2k.com
dscsk8er55: isnt putting it in reverse kind of like a switch already?
 Old 02-11-2010, 04:09 PM   #31
nyghtryder's Avatar
did you specify a color?
NATOR PA
 Old 02-11-2010, 04:13 PM   #32
sleeper329's Avatar
nope. im sure if you contact them theyd do it for you though.
 Old 02-11-2010, 04:14 PM   #33
nyghtryder's Avatar
im not messing with these, i cant imagine trying to get all the epoxy off right now. Ill deal with the 6k.
NATOR PA
 Old 02-11-2010, 04:31 PM   #34
dscsk8er55's Avatar
I meant for while driving and being able to turn them on for a**holes that are riding my butt.
 Old 02-11-2010, 04:36 PM   #35
(toao)fallen's Avatar
Posts: 174   (View Stats)
(toao)fallen has a reputation beyond repute(toao)fallen has a reputation beyond repute(toao)fallen has a reputation beyond repute(toao)fallen has a reputation beyond repute(toao)fallen has a reputation beyond repute(toao)fallen has a reputation beyond repute(toao)fallen has a reputation beyond repute(toao)fallen has a reputation beyond repute(toao)fallen has a reputation beyond repute(toao)fallen has a reputation beyond repute(toao)fallen has a reputation beyond repute
mmm are there pic in the write up?
(toao)fallen is offline   Reply With Quote
 Old 02-11-2010, 04:40 PM   #36
sleeper329's Avatar
ohh.. press clutch, put in reverse with clutch fully dpressed... never tried but as long as u dont come off the clutch at all that should work right?
The Following 2 Users Say NO Thank You to sleeper329 For This Un-useful Post:
 Old 02-11-2010, 05:19 PM   #37
nyghtryder's Avatar
if ppl are riding you when your not stopped , your driving too slow
yep lots of them
NATOR PA
 Old 02-11-2010, 07:59 PM   #38
rrrrrr not getting pics good write up thou
 Old 02-11-2010, 08:11 PM   #39
J03808's Avatar
Posts: 93   (View Stats)
J03808 has a reputation beyond reputeJ03808 has a reputation beyond reputeJ03808 has a reputation beyond reputeJ03808 has a reputation beyond reputeJ03808 has a reputation beyond reputeJ03808 has a reputation beyond reputeJ03808 has a reputation beyond reputeJ03808 has a reputation beyond reputeJ03808 has a reputation beyond reputeJ03808 has a reputation beyond reputeJ03808 has a reputation beyond repute
Did the brightness of the reverse lights change between the 1st and 2nd generations? Because I have a 2010, and the reverse lights are already really bright. Like, almost as bright as many headlights...
2010 Mazdaspeed 3 - Velocity Red Mica w/ Tech Package: Stock
J03808 is offline   Reply With Quote
 Old 02-11-2010, 08:22 PM   #40
E4Performance's Avatar
Posts: 690   (View Stats)
E4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the world
Groaned at 69 Times in 65 Posts
They sure look 5k to me.
I know that all the 5k bulbs we've been getting from DDM lately have the blue bar next to the glass. The 6k is greyish. I see in your pics that the bar is blue.
E4Performance is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f33/how-install-reverse-light-hid-kit-45568/
HID Reverse Lights This thread Refback 06-21-2012 03:32 PM
TXS knock light install questions IKILLPEOPLE MazdaSpeed 3/6 - ECU Computer Tuning 25 08-19-2009 07:45 AM
Shift light install help Johan MazdaSpeed 3/6 - Car Audio & Electronics 2 07-25-2009 01:18 PM
Mazda3 MPS has a different color reverse light housing? Chinsel MazdaSpeed 3/6 - Appearance 4 06-17-2009 07:41 PM
Engine light after bov install... ATAZ MazdaSpeed 3 - Engine, Transmission & Driveline 8 02-24-2009 11:50 AM
Page generated in 0.56206 seconds with 33 queries
