> MazdaSpeed 3 - How-To's
 Old 05-18-2011, 02:25 PM   #1
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Neutral  +3 score
Default How-To NATOR A Boost Leak Tester for $15
Well, like the title says, I made a boost leak tester today. I haven't seen a How To on MSF, so I took pictures with my cell along the way... Here you go!
You will need:
3/8 inch drill bit/drill
2 inch PVC pipe cap ($1.25)
3 inch to 2 1/2 inch coupler with clamps ($6 at advanced auto parts)
Tire Valve Stem ($6 for a set of 2 at AAP)
This is how the pieces will be oriented...
First, drill a hole in the top of the 2 inch PVC cap with the 3/8 inch drill bit
Now, remove the nut for the valve stem so you can thread it into the new hole in your PVC cap. Leave the washer and the rubber washer (to create a seal)
Then, get some vice grips on the valve stem, and thread it through the hole
I actually tried to use pliers at first, but my hands weren't strong enough to hold the valve stem, and I got it a lil scratched up. Make sure you screw it in far enough so the rubber washer doesn't allow air through
Next screw that nut onto the top of the valve stem
To finish it off, Put the cap in the 3" end of the coupler, tighten it down, and you're ready to do a boost leak test!!!
To do this, remove your intake, and tighten the 2 1/2" side of the coupler on your TIP. Get an air compressor and pressurize the system.... Listen for leaks. Putting the tester on the TIP will pressurize all your boost/vacuum lines.
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
The Following 62 Users Say Thank You to Fatguy729 For This Useful Post:
3ONBOOST (02-23-2013), aggierandy (03-26-2013), Dahouse702 (11-26-2011), Dash08 (10-27-2012), david001wj (10-26-2012), daztdMS6 (01-01-2012), dereeek (02-06-2012), djuosnteisn (09-06-2011), Docnox (06-14-2011), Domino81 (07-26-2012), dot584 (05-13-2013), Drumheller (05-18-2011), Duke A Luke (07-12-2014), Familyguy427 (05-07-2013), Ferdball (05-18-2011), Flight_SkoolSpeed (05-03-2013), GLORIFIEDBOZO (02-02-2012), Grim_BL3FW (04-29-2012), iLLin (04-22-2013), jabeel00 (11-23-2015), JacksonMS30 (08-22-2011), K.Mah (10-17-2012), kabobulate (05-18-2011), kaprikorn (04-03-2013), kolosok17 (12-26-2013), kylec_2003 (04-30-2013), labikesrcool (05-19-2011), Mase (12-14-2012), mazda dude (03-26-2014), mczimer (04-06-2013), meelo88 (02-19-2014), Menace1 (02-12-2013), mike w (06-26-2013), Mistersix (03-26-2013), Monotonous ONE (08-21-2011), NewCar (04-16-2013), nichall10 (05-19-2011), omgvance (08-15-2012), phate (02-02-2012), Pointless (10-01-2012), Pseud0logik (02-18-2012), rfinkle2 (05-22-2011), robbspeed (09-05-2016), silvapain (07-04-2011), skeeter149 (05-18-2011), Sneak (05-18-2011), spals (03-22-2013), speed3Texas (02-15-2016), SpeedViktm (10-14-2012), Speed_j23 (02-02-2012), suparobg (01-25-2015), supraman (06-11-2011), Tacheny (02-06-2013), TexasSpeed3 (09-30-2011), theschrum (06-09-2011), tkephart (10-21-2012), Tokay444 (05-23-2011), tomek_46 (12-15-2011), Tommy (07-30-2012), vdgmcool (05-18-2011), wankular (05-18-2011), whos_MS3 (09-29-2011)
 Old 06-10-2011, 12:53 PM   #2
Fatguy729's Avatar
Groans: 82
Damn, why doesn't anyone sell something like this (besides the simplicity of making one)? Hell, maybe I will start... $20 plus shipping? They have flat rate boxes for $5-6... so $25 shipping included? Hmmm.... Fatguy = MSF vendor? LOL
The Following 2 Users Say Thank You to Fatguy729 For This Useful Post:
meelo88 (02-19-2014), xorphanx (11-23-2015)
 Old 06-10-2011, 01:02 PM   #3
wankular's Avatar
Posts: 4,343   (View Stats)
haha I made one but my coupler's blue. It's also a 2.75" - 2.5". I tried the 3" but it was too big for the cap and the coupler buckled due to how much I had to tighten it.
2009 MS3 sport MGM
 Old 06-10-2011, 01:12 PM   #4
Fatguy729's Avatar
Groans: 82
hmmm... I didn't have any issues with the 3", but that was the only size I could find at AAP (plus it's a quality coupler, 5 ply, nice and thick). Where did you get the 2.75"?
 Old 06-10-2011, 01:15 PM   #5
wankular's Avatar
The 2.75" was the TB one from my CX Racing fmic. I ended up buying a 4" long coupler to adjust my cold pipe a little better (and ended up having to cut a 1/2" off haha). It's a bitch trying to find a 4" long reducer coupler.
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
Fatguy729 (06-10-2011)
 Old 06-10-2011, 01:18 PM   #6
Fatguy729's Avatar
Groans: 82
Oh Ok, rock on LOL. I bet it was hard to find something like that!
 Old 06-10-2011, 02:17 PM   #7
shadesofgray19's Avatar
Posts: 794   (View Stats)
Not to rain on your parade, but here you go.
Boostpro.net : Products - Boost Leak Testers
shadesofgray19 is offline   Reply With Quote
The Following 3 Users Say Thank You to shadesofgray19 For This Useful Post:
Brennan (01-28-2012), jabeel00 (11-23-2015), Mistersix (03-26-2013)
 Old 06-10-2011, 02:33 PM   #8
Fatguy729's Avatar
Groans: 82
SHUT UP!!! LOL... Oh well...
 Old 06-10-2011, 03:53 PM   #9
bnoon's Avatar
Posts: 1,770   (View Stats)
It's OK fatguy, you still made yours instead of buying someone else's and saved some cash. And you still have one more valve stem in your pocket.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
bnoon is offline   Reply With Quote
The Following User Says Thank You to bnoon For This Useful Post:
 Old 06-10-2011, 04:25 PM   #10
jtspells's Avatar
Posts: 634   (View Stats)
jtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the world
Nice improvising, kinda funny our shop just spent around $1600 for a smoke machine and with one or 2 more modifications you would have a vacuum leak tester for a fraction of the price.
jtspells is offline   Reply With Quote
The Following User Says Thank You to jtspells For This Useful Post:
 Old 06-10-2011, 05:55 PM   #11
Fatguy729's Avatar
Groans: 82
yeah, I'm awesome LOL
 Old 06-10-2011, 06:09 PM   #12
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
also
Intake Leak Pressure Tester
I made my own as well lol.
The Following User Says Thank You to NJSPEED3 For This Useful Post:
 Old 08-13-2011, 06:33 PM   #13
mike000g's Avatar
Posts: 241   (View Stats)
mike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond repute
Groaned at 7 Times in 5 Posts
this came out on car mods,look it up on youtube.props to them.
mike000g is offline   Reply With Quote
 Old 08-13-2011, 06:46 PM   #14
Fatguy729's Avatar
Groans: 82
Was I supposed to understand or get something from that post?
 Old 11-14-2011, 01:07 PM   #15
MSpeedzilla's Avatar
Posts: 121   (View Stats)
MSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the world
FUCKING GENIUS
_____________________________________________
2008 Silver Gen 1, MS3 MSCAI, Cobb TIP, Full Catless Race/Downpipe, Cobb XLE Bpv, MAPerformance rmm, Cobb AP, HPFP, xt-m5-qs, Shift bushings(washers), denso ITV22, Torque Android app, .
MSpeedzilla is offline   Reply With Quote
The Following User Says Thank You to MSpeedzilla For This Useful Post:
Fatguy729 (11-14-2011)
 Old 11-14-2011, 01:22 PM   #16
Fatguy729's Avatar
Groans: 82
LOL glad to help!
 Old 02-02-2012, 06:51 PM   #17
Speed_j23's Avatar
Posts: 611   (View Stats)
Speed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the world
You sure about the 3/8 drill cuz the valve stem doesn't seem to fit.
New: 06 WWP MS6
Old: 06 LPM MS6
Speed_j23 is offline   Reply With Quote
 Old 02-03-2012, 03:56 PM   #18
whos_MS3's Avatar
Posts: 230   (View Stats)
whos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the world
3/8 bit was perfect for me. a little snug, but that's how it should be
what size is the stem u have? .453 or something like that?
whos_MS3 is offline   Reply With Quote
 Old 02-05-2012, 08:09 PM   #19
Fatguy729's Avatar
Groans: 82
Its a tight fit but it was the perfect size when I did mine... I had to use vice grips (shown in the picture after trying to use pliers)
 Old 05-02-2012, 09:32 PM   #20
Fatguy729's Avatar
Groans: 82
Epic!
 Old 07-30-2012, 07:29 PM   #21
Tommy's Avatar
Posts: 2,308   (View Stats)
Groans: 155
Thanks for the write up.
Tommy is offline   Reply With Quote
The Following User Says Thank You to Tommy For This Useful Post:
Fatguy729 (10-14-2012)
 Old 09-15-2012, 05:39 PM   #22
trdsw's Avatar
Posts: 141   (View Stats)
trdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud of
Thanks to the OP. I dont have an advanced auto parts but the local oreillys had the same exact part so I was able to follow through with making the tester. I added a boost gauge that I had laying around to mine so I could see how quickly/slowly my leak was.
trdsw is offline   Reply With Quote
The Following 3 Users Say Thank You to trdsw For This Useful Post:
Fatguy729 (10-14-2012), Menace1 (02-12-2013), Pointless (10-01-2012)
 Old 10-01-2012, 06:39 PM   #23
Cudarich's Avatar
Posts: 41   (View Stats)
Cudarich is a name known to allCudarich is a name known to allCudarich is a name known to allCudarich is a name known to allCudarich is a name known to allCudarich is a name known to all
Groaned at 7 Times in 4 Posts
Another thanks to the OP, this helped me confirm my major boost leak suspicion, found approximately where its coming from, now gotta pull my intake out and figure out the exact location.
Cudarich is offline   Reply With Quote
The Following User Says Thank You to Cudarich For This Useful Post:
 Old 10-26-2012, 04:19 PM   #24
JDspeed6's Avatar
Posts: 2   (View Stats)
JDspeed6 is an unknown quantity at this point
I bought all the supplies tonight except the metal tire valve stems. Went to 3 different places and all I can find are the rubber ones. Do you think that would work too? Imagine I'd have to drill a much larger hole.
JDspeed6 is offline   Reply With Quote
 Old 10-26-2012, 05:32 PM   #25
Fatguy729's Avatar
Groans: 82
I honestly dunno. I went with the metal cuz I wanted it to be sturdy and it needs to screw in tightly for a tight seal. I'm not sure how many uses you would get from the rubber kind before it started leaking.plus, with te metal kind, you screw the washer and nut down till its tight, I think the rubber kind has a set width that might not work with the PVC cap.
NICE!!! If I had an unused guage laying around it would be cool, but I wasn't gonna spend extra money for such a simple piece.
I just plug my AP in and monitor boost on it while I test.
 Old 11-10-2012, 03:34 PM   #26
nothing to see here....
drknyte's Avatar
Posts: 496   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
So once it'sinstalledhow do you operate it? Smoke or air? Sorry I`m a nub!
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
 Old 11-10-2012, 04:08 PM   #27
Fatguy729's Avatar
Groans: 82
Ummm air. Like the original post says
 Old 11-18-2012, 06:25 PM   #28
razorscs's Avatar
Posts: 391   (View Stats)
razorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the world
For those having trouble finding a quality valve stem, places like Miner's Ace Hardware or Lowe's etc. will have valve stems, they aren't automotive but it doesn't matter, they are all metal and will hold the pressure.
2007 MS6- BNR S3, HTP 3" Intake, 3 Bar MAP, DO Meth, CP-E Catted DP, Autotech Internals, SRI, ETS TMIC, Sure Sidewinder, Sure Charge Tubes, Lex tuned, BC Coils, Sure RMM, JBR SSP, Dreadnaught, Whiteline RSB
2008 Mazdaspeed3- Totalled!
razorscs is offline   Reply With Quote
The Following 2 Users Say Thank You to razorscs For This Useful Post:
Fatguy729 (02-12-2013), Menace1 (02-12-2013)
 Old 03-26-2013, 07:41 PM   #29
Mistersix's Avatar
Posts: 2,585   (View Stats)
Approximately how much pressure should one pressurize with?
 Old 03-26-2013, 07:46 PM   #30
Fatguy729's Avatar
Groans: 82
I usually do about 25 psi... My tune only boosts 19, so I feel that's good enough.
Side note... Even if its clamped down as much as possible, the shit factory tip usually only holds about 10 lsu before leaking or popping off. My Cobb holds like a champ.
Don't freak out though, cuz nothing on the intake side is ever pressurized during normal operation
The Following User Says Thank You to Fatguy729 For This Useful Post:
Mistersix (03-27-2013)
 Old 03-26-2013, 07:53 PM   #31
ABolewski's Avatar
Posts: 1,279   (View Stats)
ABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the world
Groans: 52
Also, a good idea is too block off the recirc inlet on the TIP and let the BPV open to air while you pressurize. If you're running 20 PSI, and the BPV leaks at 20-24 PSI you're BPV is leaking. Just a tip.
2010 Alternative Lifestyle Blue Mazdaspeed3
(sold)
2008 Chevy Colorado. The only truck that comes with a lifetime guarantee...
ABolewski is offline   Reply With Quote
The Following User Says Thank You to ABolewski For This Useful Post:
 Old 04-05-2013, 07:48 PM   #32
Stealth01's Avatar
Posts: 6,910   (View Stats)
Stealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the world
Groans: 201
Groaned at 164 Times in 103 Posts
Here's the one I built tonight to test my intake system. Not the same as a boost leak, but I'm getting air into the system post-MAF/pre-turbo, so here's my tester:
Goes right onto the MAF Housing for my ID300.
Stealth01
2006 Mazdaspeed6 GT
Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose
SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG
Read my stories: https://www.smashwords.com/books/view/55318
Stealth01 is offline   Reply With Quote
The Following 2 Users Say Thank You to Stealth01 For This Useful Post:
Fatguy729 (04-05-2013), Mistersix (04-06-2013)
 Old 04-06-2013, 05:23 AM   #33
Mistersix's Avatar
Thats a good idea too. Looks like a HDP boost leak tester.
 Old 04-06-2013, 08:29 AM   #34
Fatguy729's Avatar
Groans: 82
Originally Posted by Stealth01 View Post
Here's the one I built tonight to test my intake system. Not the same as a boost leak, but I'm getting air into the system pre-MAF, so here's my tester
I assume you meant pre turbo LOL
 Old 04-06-2013, 08:51 AM   #35
Stealth01's Avatar
Groans: 201
Yes, but being retarded I sometimes mis-type.
Stealth01
2006 Mazdaspeed6 GT
 Old 05-06-2013, 09:03 PM   #36
Tattooboost's Avatar
Posts: 3   (View Stats)
Tattooboost will become famous soon enoughTattooboost will become famous soon enough
Just joined on here. Thanks for the info and pics built one of these today and was super simple.
Tattooboost is offline   Reply With Quote
The Following User Says Thank You to Tattooboost For This Useful Post:
Fatguy729 (05-06-2013)
 Old 05-13-2013, 07:05 PM   #37
yaeger101's Avatar
Posts: 124   (View Stats)
yaeger101 is a jewel in the roughyaeger101 is a jewel in the roughyaeger101 is a jewel in the rough
Groaned at 40 Times in 10 Posts
so do u block off the bpv off the tip or leave that hooked up
yaeger101 is offline   Reply With Quote
 Old 05-13-2013, 07:45 PM   #38
Ace Protege's Avatar
Posts: 753   (View Stats)
Ace Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the world
to those wondering, you can use a rubber valve stem. I've had mine, exactly the same as the OP's for a couple years with a rubber stem and its perfectly fine. If they can seal a tire/wheel at 35+ psi they can hold 25~ no problem. As far as drilling the hole, start with a 3/8 bit and see how it fits, I can't remember what size I used. it just pulls through and has a ridge that seals it.
'02 Bmw 330ci
Kinda low and really slow.
'94 Mazda Protege -SOLD
1.8 BPT Vf10
263whp 258wtq
13.1 @ 107 mph
'05 ZX-6RR - Two Brothers slip on, GPR dampener V1, More to come
Ace Protege is offline   Reply With Quote
 Old 06-25-2013, 03:13 PM   #39
Mandinca's Avatar
Posts: 1,700   (View Stats)
Mandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the world
I'm also a noob at this kind of thing. I have the standard TIP, no mods to the car.
How do you suggest I block off the recirc inlet....which I am assuming is the smaller pipe on the TIP (is it?).
What do you mean "let the BPV open to air". Is that the valve on the cold pipe between the TMIC and TB ?
Thanks
Mandinca is offline   Reply With Quote
 Old 06-26-2013, 12:21 PM   #40
ABloodBrother's Avatar
Posts: 2,009   (View Stats)
ABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the worldABloodBrother is the leader of the world
Groaned at 17 Times in 13 Posts
Making one of these tomorrow. Thanks op
ABloodBrother is offline   Reply With Quote
The Following User Says Thank You to ABloodBrother For This Useful Post:
Slickasice (04-28-2017)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f33/how-nator-boost-leak-tester-15-a-81055/
Интересно, сколько скорость 6 владельцы повышение / вакуумные утечки и не знаю - Mazda 6 Форумы: Mazda 6 Форум / Mazda Atenza Форум This thread Refback 05-31-2015 02:08 AM
where to pickup a boost/vacumn leak tester? - Engine & Transmission - Top Tier Imports This thread Refback 01-05-2015 11:17 AM
overview for shnouz This thread Refback 11-28-2014 12:23 PM
Help for rough/harsh/"wheezy old man" start up on my Mazdaspeed6. Video included. : mazda This thread Refback 09-14-2014 07:47 AM
Wanted to buy: Boost Leak Tester This thread Pingback 02-14-2014 05:52 AM
Update/question - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-20-2013 05:45 PM
Whats New/General Speed 6 Discussion - Page 267 This thread Refback 09-27-2013 10:12 AM
where to pickup a boost/vacumn leak tester? This thread Refback 08-05-2013 09:33 PM
.. another maf calibration review - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 04-06-2013 08:06 AM
1 pinte d'huile pour 200km This thread Refback 01-18-2013 04:05 PM
Long term fuel trim after cpe SRI and CS TIP install - Page 2 - 2012 Mazda 3/Mazdaspeed 3 Forums This thread Refback 01-08-2013 07:02 AM
HOW TO FIND A BOOST LEAK - Page 12 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-26-2012 11:30 AM
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 03-01-2012 11:59 AM
Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-10-2012 10:28 PM
I wonder how many Speed 6 owners have boost/vacuum leaks & not know it - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-10-2012 06:07 PM
Long term fuel trim after cpe SRI and CS TIP install - Page 2 - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 11-14-2011 08:25 AM
Boost leak? mrQQ MazdaSpeed 3/6 - Turbo Induction 16 04-09-2011 01:09 AM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 12:06 PM
Possible MS6 Boost Leak Need Help TheNewGuy MazdaSpeed 6 - Engine, Transmission & Driveline 7 12-10-2009 07:18 PM
boost leak tester fdkss03 MazdaSpeed 3/6 - Turbo Induction 18 07-09-2008 07:36 AM
Copyright 2008 ; 2014 Cymru Internet Services LLC | FYHN Autosports HQ
Page generated in 0.59000 seconds with 44 queries
