> MazdaSpeed 3 - How-To's
Notices
 Old 03-07-2010, 02:06 PM   #1
dizzin9's Avatar
Posts: 1,790   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
Groaned at 39 Times in 27 Posts
Default HOW TO: removing iwg
this is a simple how-to on removing the internal wastegate on your turbo. it's not the same for every turbo but i'm just giving u an idea especially for those folks who plan on going BT. i'll also update this thread when i get my flapper closed shut.
you need: 13mm wrench and a pen (or similar thin pointed object you can pry off a little hook with)
focus on these parts of the turbo:
grab your 13mm and remove these 3 bolts holding the bracket and the wg:
here's the little hook thingy that u need to remove on top of the arm. i used the filer from a nail clipper:
all done:
shots of the flapper opened/closed:
there's quite a few methods to keep that thing closed although i don't want to weld it. we'll see what i'll end up doing.
thanks for looking.
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT COUPE PREMIUM PERFORMANCE WHITE
6 SPD / 3.73s / HID W/ SECURITY PKG
dizzin9 is offline   Reply With Quote
The Following 5 Users Say Thank You to dizzin9 For This Useful Post:
802MS3 (03-07-2010), dkapetansky (08-11-2011), nighthawk358 (03-07-2010), Sacrilicious (03-07-2010), Snyeed (09-20-2011)
 Old 03-07-2010, 03:23 PM   #2
Miembro
nighthawk358's Avatar
Posts: 716   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
Groaned at 6 Times in 6 Posts
contact Ptp..they said they were going to do a bracket to hold the flapper shut
2008.5 MS3 Metro Gray
nighthawk358 is offline   Reply With Quote
 Old 08-11-2011, 05:06 PM   #3
manelscout4life's Avatar
Posts: 1,782   (View Stats)
manelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the world
Groans: 661
Groaned at 45 Times in 33 Posts
So dizzin9, how did you end up keeping it shut?
manelscout4life is offline   Reply With Quote
 Old 08-13-2011, 06:04 PM   #4
dizzin9's Avatar
Groans: 77
had somebody weld the flapper shut
 Old 08-15-2011, 07:29 PM   #5
irishking03's Avatar
Posts: 1,769   (View Stats)
irishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the world
Whats the point of closing this shut. Just wondering why.
HKS BOV Recirculated + HKS Suction Intake + HKS CBE + CNT Catted DP + JBR PMM 88 duro + JBR DogBone RMM 88 duro + GlowShift Wideband Gauge + GlowShift Boost Gauge + RPM Vent Pod + Block8Head Single Gauge Pod + Turbo XS FMIC + Cobb TIP + Cobb AP + 6000k HID + Matt Damond OCC + CorkSport Recirc Tube + Cp-e HPFP!
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
irishking03 is online now   Reply With Quote
 Old 08-15-2011, 08:24 PM   #6
pewpew
Sacrilicious's Avatar
IWG doesn't dump enough air, so you force it shut and slap on an EWG instead.
The Following User Says Thank You to Sacrilicious For This Useful Post:
manelscout4life (08-15-2011)
 Old 08-16-2011, 04:33 AM   #7
AHHHH I got it. Im not gonna waste money on doing this. Im doing a BT hopefully ready for install in 2012
 Old 08-16-2011, 05:35 AM   #8
socks's Avatar
Groans: 123
what'd you do to bolt the compressor housing back on?
I cut the meat off the wastegate actuator bracket and used just the half moon shape and bolted it back on.
1994 Mazda RX-7
 Old 11-27-2011, 10:09 AM   #9
Tabasco69's Avatar
Posts: 439   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
easiest way to isolate the iwg is to tac weld the acuator arm at the acuator and leave it installed, a small tack weld that can be ground off if you ever choose to revert back to the iwg or possibly sell it....welding the actual poppet inside the turbine housing essentially ruins it, or requires a lot more time and effort to reverse the delete, they way I suggest takes @1 minute either way.
Tabasco69 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tabasco69 For This Useful Post:
cabrone (01-23-2012), thehead (04-11-2012)
Removing Trim Primo Tiki Appearance - RED 9 12-20-2009 05:33 PM
removing mmv3 2010 MS3 - How-To's 6 12-08-2009 06:44 AM
Help With removing CPE DP spnkr21 Custom Performance Engineering (cp-e.com) 7 01-20-2009 05:58 PM
Removing COBB FSB... need help MS3 Ventura MazdaSpeed 3/6 - Suspension & Brakes 5 11-27-2008 04:46 PM
removing belts StewRat Drag Racing 5 09-03-2008 08:28 AM
Page generated in 0.31160 seconds with 26 queries
