| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() | | #1 | ![]() |
![]() Join Date: Mar 2011 Location: Douglasville, GA
Rep Power: 101 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Parts: Three way switch, bought at radioshack for $3.00. It has a center off position, and two on positions; this is to allow me to either turn on the sprayer manually, or to turn the power over to my boost switch, so that when it reaches set boost, the intercooler sprayer fires. Bosst Switch, bought of ebay $14.00Turns accessory on when it reaches set boost pressure. Overflow tank, autozone for $7.00 190 Garden Myster, Lowes for $3.00 for a set, garden section Three way hose splicer Lowes for $3.00 for set, garden section Windshield Wiper Fluid Motor, Autozone $13.99 4mm Vacuum Hose I had some left over, so I'm not sure of price. There's no real good place to mount the tank, so I just placed it right next to my CAI; seem to be the most accessible and least obstructive place. I also mounted the Fluid pump on the side of the battery cover, and wired it through and underneath to hide the wires; which I ran in through the firewall on passenger side. I did it that way because I already had a few wires running through there and didn't feel like messing with the firewall opening on the driver side. ![]() I then ran the hose up trough my hood and down to the vent, since I have a vented hood, I place it on the side of the actual scoop. The sprayer is set to the middle of the TMIC, and it's sprays at 190 degree radius, which completely covers the top surface of the Intercooler. ![]() I placed my switch next to the access port on the driver side; it's a three way switch, which I wired to allow me to turn the pump on, off, or over to my boost switch. ![]() This is the boost switch, which I spliced into the line going to my boost gauge, and placed it right next to the toggle switch to lessen the amount of wire I had to run. ![]() ![]() ![]() I had the main power wire (fused) going to the center of the switch, one going to the pump directly and another going to the boost switch. The boost switch then in place splices into the acc wire going to the pump, in turn reducing the amount of wire ran and giving it control of the power (I hope that made sense) I originally had the boost switch set to two PSI, but this was way too much of a spray, I now run it at 10psi, and seems to be just the right amount. Thus far I seem to be getting on average 10 degrees lower on my BATs on equal runs with and without the spray. Also, my BATS are reduce much faster after a 5 second spray during normal use, or if the car has been sitting out in the sun, it helps a lot with heat soak. Total install time was about two hours, with routing the wires and hose being the most time consuming part.
__________________ ![]() Pablo P. 2009 MazdaSpeed 3
| The Following 16 Users Say Thank You to Peladao For This Useful Post: | Fatguy729 (08-20-2011), IshiKage (08-19-2011), Karmat (08-19-2011), kgb (08-20-2011), LatinKraze (08-30-2011), manelscout4life (08-19-2011), Paul (03-30-2012), predapio (08-20-2011), PunjabiPlaya (08-20-2011), Raider (08-20-2011), rfinkle2 (08-20-2011), ridenfish39 (08-20-2011), SLOWHATCH (08-20-2011), tddvrrn (08-19-2011), TexasSpeed3 (08-20-2011), Zdraveca (08-20-2011) |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 1611 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
wow, that's pretty cool. btw: mister. as in mist. unless you're at a renaissance faire. then it may be myst..
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows ![]() ![]() Last edited by tddvrrn; 08-19-2011 at 10:30 PM. |
![]() Join Date: Jan 2011 Location: Cranford, New Jersey
Rep Power: 496 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 180
Brilliant.
__________________ 2001 Mazda Millenia S (Brilliant Black) - SOLD. Will be missed 2007 Mazdaspeed 6 (Velocity Red) - Continuing the zoom-zoom tradition |
| The Following User Says Thank You to Karmat For This Useful Post: | Dolfius (10-16-2012) |
![]() | | #4 | ![]() |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 1941 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,524
Groans: 276
Groaned at 519 Times in 415 Posts
that hood looks...umm...weird. DG hood ftw
__________________ CP-E SRI :|: PTP HPFP :|: HTP Turbo Inlet Poo owner. FML |
![]() | | #5 | ![]() |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 709 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 679
Groans: 39
Not bad man. Good work. And I like your painted plastic covers, cleans up the bay a lot.
__________________ GT3071R / HTP 3.5” / PG FMIC / M2 Catless DP / JBR BPV Hose / GFB 50-50 BOV / NKG LTR7IX-11 / Cobb AP / Koni Yellows / Cobb Springs / 3-Bar MAP / KDM Internals / Sure Track RMM DIY Parts: 730g Shift Knob / Short Shift Plate / Rear Sway Bar / Adjustable End-links / 3-Port ECBS Daily: Stockers w/215-45-18 Hankook V12 Track: TRmotorsport C3 w/245-45-17 Kuhmo XS |
![]() | | #6 | ![]() |
| Scammer Hunter ![]() ![]() Join Date: Mar 2008 Location: Jacksonville, FL
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,858
Groans: 449
| Not Ranked : 0 score Fixed...
__________________ ![]() ![]() ![]() 1) Looking to Buy a used Mazdaspeed? Read this! 2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here. 3) Wanna buy and sell here? DONATE for VIP 4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting! 5) Help MSF grow with FAQ threads!? |
![]() | | #7 | ![]() |
![]() Join Date: May 2010 Location: Wilkes Barre/Holland PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 171
I like it. something I was thinking about doing myself one of these days. Then someone just told me to go with Devils Own alcohol injection and get the D07 nozzle so I've never tried doing this. Props to you though looks good!
![]() | | #8 | ![]() |
| I got all dem pipes ![]() Join Date: Feb 2010 Location: Dallas,TX
Rep Power: 547 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,093
Groans: 58
Groaned at 21 Times in 21 Posts
Thanks for the writeup I was thinking of doing this in a fiew weeks. Sent from my T-Mobile G2
__________________ 2011 MS3 Cobb AP,Cobb SF, Cobb TIP, KMD interals, ETS TMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR shifter bushings, Corksport CAB, Corksport Short Shifter Plate, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8, Nitto NT-555 245/45/17 E85 FREEKTUNE ![]() |
![]() | | #9 | ![]() |
![]() Join Date: Nov 2010 Location: Bensalem
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
Im doing a set up thats close to that but with a sneaky pete bottle and No2. Anyway my question is why would you want it to turn on when in boost? Seems kinda pointless because your usually moving at some sort of speed when in any sort of load/boost situation. |
![]() | | #10 | ![]() |
![]() Join Date: May 2011 Location: Fort Hood, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
Also, remember that your turbo makes 10+ psi no matter whether you're in 1st gear or 6th. In 1st and part of 2nd, your speed and the air hitting the TMIC won't have cooled off it off enough to eliminate heatsoak. Hope that helps.
__________________ 2008.5 Black Mica MS3 - Mazdaspeed CAI (converted to SRI) - RPMC TIP - PG FMIC - OBX TP - Hypertech because I don't give a fuck - CS RMM Inserts - Stock Plugged BPV - Solid shifter bushing mod - JBR Short Shifter Kit when I want to use it - sweet tintz yo | |
![]() | | #11 | ![]() |
| Banned ![]() ![]() Join Date: Apr 2011 Location: Lanoka Harbor, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 238
Groans: 68
Groaned at 62 Times in 28 Posts
i would've used shrink wrap instead of that mess of electrical tape
![]() | | #12 | ![]() |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 933
Groaned at 35 Times in 24 Posts
| Not Ranked : 0 score This cannot be a serious question
![]() | | #13 | ![]() |
(Thread Starter) | Not Ranked : 0 score I plan on cleaning it up, I was out of butane on my heat gun.
Last edited by Peladao; 08-20-2011 at 12:56 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #14 | ![]() |
Groans: 68
now go get some logs with sprayer ON and OFF for comparson of temps
| The Following User Says Thank You to Rich-PMS For This Useful Post: | Fatguy729 (08-20-2011) |
![]() | | #15 | ![]() |
I though I read something that stated the top mount received maximum airflow at 20 mph. But forgot that even at that speed heat soak is still present. | |
![]() | | #16 | ![]() |
| highest hp speed6 in cali ![]() Join Date: Nov 2010 Location: Nator San Diego, CA
Rep Power: 3195 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 192
Groaned at 326 Times in 194 Posts
moar meth
| The Following User Says Thank You to Joe Isuzu For This Useful Post: | Paul (03-30-2012) |
![]() | | #17 | ![]() |
![]() Join Date: Jun 2011 Location: El Paso, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 446
Groaned at 20 Times in 5 Posts
Meth... or this...
__________________ 2011 MS3 || Tech Pkg || Shark fin || || CS SRI || CS TIP || CS SRI Airbox || CS TMIC || CS CBE || || CS Boost & BpV Tubes || NGK Ir. Plugs || FORGE BPV v2 || || AT Internals || COBB AP || CNT DP || Koni Yellows || H&R Springs || || JBR Shift Knob || JBR Stage 2 SSP || JBR SSBushings || || JBR 88 RMM || JBR 80 TMM || JBR 80 PMM || JBR RSB || JBR RCAs || \\|// DizzyTunes 91 & E85/91 Mix Tunes by Bucker Phate \\|// || Window Tints, Lamine-x Headlights/Fogs, Black Out Tails || ![]() |
![]() | | #18 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() Thanks: 1
WHY NOT JUST USE THE WINDSHIELD WASHER ITSELF AND JUST MODIFY IT FACING TOWARDS THE INTERCOOLER??? OR BUY SEPARATE SPRINKLER FOR THE INTERCOOLER AND USE THE REAR WASHER RESERVOIR. ANYTHING IS POSSIBLE WITHOUT SPENDING THAT MUCH MONEY! And use 50/50 water and rubbing alcohol. Using the windshield washer controls is much easier than having another switch and another reservoir installed to your car. Last edited by m4rty08; 07-14-2012 at 02:20 AM. Reason: MSF Database - Automerged Doublepost |
| Intercooler mister a bust | triple_threat | MazdaSpeed 3/6 - Turbo Induction | 16 | 04-07-2012 01:34 PM |
| Intercooler mister. | Demi | MazdaSpeed 3 - How-To's | 74 | 03-30-2012 10:22 AM |
| FMIC Meth Mister | hnda etr | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 13 | 04-01-2010 05:48 PM |
| UDATED!!! Intercooler mister | Demi | MazdaSpeed 3/6 - Turbo Induction | 17 | 12-14-2008 01:35 PM |
| "DEMI" IC mister idea EASY!! | gsrtype1 | MazdaSpeed 3/6 - Turbo Induction | 59 | 08-04-2008 11:11 AM |
