> MazdaSpeed 3 - How-To's
 Old 03-23-2011, 11:29 AM   #1
RussM's Avatar
Posts: 109   (View Stats)
RussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud of
Default Koni Yellow Sport Install Question
I have read several DIY on Koni FSD but couldn't find one on the Yellow Sport units. After 2 months of backorders mine finally showed up.
Question is do you need to cut down the front strut bumper stops or replace with shorter units from Ground Control or Fatcat Motorsports on the Yellows or if the stock bumper stops are still in good shape can you use them as is with no effect to the strut operation ?
Thanks for your input!
RussM is offline   Reply With Quote
 Old 03-23-2011, 12:56 PM   #2
R.MS3's Avatar
Posts: 987   (View Stats)
Most people just bought new bumper stops from Fatcat, which are shorter i believe. I think you need to cut the rears just a bit as well.
R.MS3 is offline   Reply With Quote
 Old 03-23-2011, 02:38 PM   #3
RussM's Avatar
Thanks for your Input!
 Old 03-23-2011, 06:01 PM   #4
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
depends on your car. mine (08.5) came with shorter oem bump stops but they were pretty fucked up. regardless, i'd buy aftermarket fronts and just cut the rears.
fronts...
rears...
 Old 03-24-2011, 09:17 AM   #5
R.MS3's Avatar
That's the setup the guy above your post has? The white bump stops shown are the fatcat ones. They will fit fine.
 Old 03-25-2011, 12:28 PM   #6
RussM's Avatar
fronts...
rears...
Thanks So Much, just took them apart and LF feel out in pieces and RF broken in half, ordered aftermarket units.
 Old 03-25-2011, 06:48 PM   #7
ms3_kidd's Avatar
Posts: 356   (View Stats)
ms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the world
konis were on back order for 2 months? lol IMPORTRP has had them them in stock this whole time lol.
2009 Mazdaspeed3 Grand Touring
Cobb SF Intake — Street Unit Silicone Boost Tubes — Street Unit Shifter Spacers — AWR Rear Engine Mount
HKS SSQV Blow Off Valve — 2nd Cat Delete — JBarone SSP — Yellow Fog Light Overlay — 20% Window Tint
Hella Supertones — H&R Lowering Springs — Koni Sports "Yellows" — GV Replica Front Lip — HKS Cat Back
ms3_kidd is offline   Reply With Quote
 Old 03-26-2011, 01:37 PM   #8
patrick failman
Groans: 74
the rear fat cats will need to be glued onto the tophats as they're not as girthy as the oem's...
 Old 10-08-2011, 12:27 PM   #9
mikeySP307's Avatar
Posts: 38   (View Stats)
mikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud of
I know the FSDs get messed up when they hit the bump stop, but shouldn't the yellows work just like OE struts/shocks? Why change the length of the bump stops?
mikeySP307 is offline   Reply With Quote
The Following User Says Thank You to mikeySP307 For This Useful Post:
Nliiitend1 (04-09-2012)
 Old 04-09-2012, 05:00 PM   #10
freeryder's Avatar
Posts: 5   (View Stats)
freeryder is an unknown quantity at this point
Default Ongoing bumpstop questions :)
I guess I am just running into this issue now... but I was kinda wondering the same? I am planning to replace the fronts as they are likely worn, but I have also read not to mess with the rear bumpstops as they interact with the spring during normal action. Is this true? The last thing I want to do is mess up the handling.
freeryder is offline   Reply With Quote
 Old 04-09-2012, 07:23 PM   #11
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
I would use OEM rear stops with Koni Yellows myself, especially if on the OEM springs.
They act as somewhat of a supplemental rear spring when engaged.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 04-10-2012, 01:27 PM   #12
freeryder's Avatar
Thanks for the reply Nliiitend1! I was going to PM you yesterday some questions but I haven't posted 15 times yet so that feature is locked .
Yea thats what I have been reading. I have cobb springs, but i imagine most manufacturers are taking this into account when they design their springs and decide on spring rates. My plan is to use stock bumpstops in the rear and likely fatcats for the front.
My only worry is what the state of the rear bumpstops are in. I would order OEM replacemens but I can't find anywhere that just sells the bumps and not the whole strut and mount. Any suggestions? I really hesitate with the "fingers crossed approach".
car has 55,000km on it and has been on the springs for approx. 20,000km.
 Old 04-10-2012, 02:24 PM   #13
ant_wailes's Avatar
Posts: 124   (View Stats)
ant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud ofant_wailes has much to be proud of
I'll be installing Koni Yellows with H&R springs soon. Are the FCM bumpstops similar if not the same as GC ones? Also, from what I've read I should only replace the front with these and just replace the rear with OEM?
ant_wailes is offline   Reply With Quote
 Old 04-10-2012, 02:35 PM   #14
R.MS3's Avatar
Yeah, buy new FCM fronts but you will most likely will have to cut the rears a bit... so if the old ones are still good, use those.
 Old 04-10-2012, 03:54 PM   #15
Nliiitend1's Avatar
Groans: 67
The rears are typically not in too bad a shape from what I've heard (until people start cutting them up, that is).
I haven't been able to find a place to get the OEM rear jounce bumpers by themselves...only the top mounts (which don't include the jounce bumpers).
Also, if it were my money I'd go with Ground Control front stops over the FC ones since they're a fraction of the price and from what anyone can tell they're functionally comparable.
2008 MS3 GT
2016 MX-5 Club
SLOWHATCH (04-10-2012)
Koni sport yellow struts sbh 2010 MS3 - Suspension & Brakes 10 12-30-2011 03:33 PM
Koni Sport install questions? onetechyguy MazdaSpeed 3/6 - Suspension & Brakes 1 03-04-2011 06:14 PM
Koni Yellow ----> Bilstein Sport impression daniyar79 MazdaSpeed 3/6 - Suspension & Brakes 12 07-27-2010 10:33 AM
H&R w/ Koni Yellow demonspeed MazdaSpeed 3/6 - Suspension & Brakes 12 07-22-2009 07:51 PM
Koni Yellow Install this weekend... thanotosq MazdaSpeed 3/6 - Suspension & Brakes 29 06-29-2009 08:24 PM
Page generated in 0.48908 seconds with 27 queries
